[Frage] Xiaomi Vacuum cleaner
Bei mir hat die Installation von Python-mirobo auf einem Raspi 3 NICHT geklappt. Hier der Fehlerbericht. `
Du brauchst python3 für das Skript, ich glaube das ist das Problem. Wenn aber nicht, das steht die Fehlermeldung irgendwo höher als was im Bild zu stehen ist. -
Leider auch Fehlermeldung bei Python 3:
Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 100% 389 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 389kB downloaded Downloading/unpacking cffi>=1.4.1 (from cryptography->python-mirobo) Downloading cffi-1.9.1.tar.gz (407kB): 407kB downloaded Running setup.py (path:/tmp/pip-build-vmqvaiw6/cffi/setup.py) egg_info for package cffi Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Downloading/unpacking appdirs>=1.4.0 (from setuptools>=11.3->cryptography->python-mirobo) Downloading appdirs-1.4.2-py2.py3-none-any.whl Downloading/unpacking packaging>=16.8 (from setuptools>=11.3->cryptography->python-mirobo) Downloading packaging-16.8-py2.py3-none-any.whl Downloading/unpacking pycparser (from cffi>=1.4.1->cryptography->python-mirobo) Downloading pycparser-2.17.tar.gz (231kB): 231kB downloaded Running setup.py (path:/tmp/pip-build-vmqvaiw6/pycparser/setup.py) egg_info for package pycparser warning: no previously-included files matching 'yacctab.*' found under directory 'tests' warning: no previously-included files matching 'lextab.*' found under directory 'tests' warning: no previously-included files matching 'yacctab.*' found under directory 'examples' warning: no previously-included files matching 'lextab.*' found under directory 'examples' Downloading/unpacking pyparsing (from packaging>=16.8->setuptools>=11.3->cryptography->python-mirobo) Downloading pyparsing-2.1.10-py2.py3-none-any.whl (56kB): 56kB downloaded Installing collected packages: python-mirobo, click, pretty-cron, construct, cryptography, idna, pyasn1, setuptools, cffi, appdirs, packaging, pycparser, pyparsing Running setup.py install for cryptography Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found c/_cffi_backend.c:15:17: fatal error: ffi.h: Datei oder Verzeichnis nicht gefunden #include <ffi.h>^ compilation terminated. Traceback (most recent call last): File "/usr/lib/python3.4/distutils/unixccompiler.py", line 116, in _compile extra_postargs) File "/usr/lib/python3.4/distutils/ccompiler.py", line 909, in spawn spawn(cmd, dry_run=self.dry_run) File "/usr/lib/python3.4/distutils/spawn.py", line 36, in spawn _spawn_posix(cmd, search_path, dry_run=dry_run) File "/usr/lib/python3.4/distutils/spawn.py", line 162, in _spawn_posix % (cmd, exit_status)) distutils.errors.DistutilsExecError: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3.4/distutils/core.py", line 148, in setup dist.run_commands() File "/usr/lib/python3.4/distutils/dist.py", line 955, in run_commands self.run_command(cmd) File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command cmd_obj.run() File "/usr/lib/python3/dist-packages/setuptools/command/bdist_egg.py", line 161, in run cmd = self.call_command('install_lib', warn_dir=0) File "/usr/lib/python3/dist-packages/setuptools/command/bdist_egg.py", line 147, in call_command self.run_command(cmdname) File "/usr/lib/python3.4/distutils/cmd.py", line 313, in run_command self.distribution.run_command(command) File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command cmd_obj.run() File "/usr/lib/python3/dist-packages/setuptools/command/install_lib.py", line 22, in run self.build() File "/usr/lib/python3.4/distutils/command/install_lib.py", line 109, in build self.run_command('build_ext') File "/usr/lib/python3.4/distutils/cmd.py", line 313, in run_command self.distribution.run_command(command) File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command cmd_obj.run() File "/usr/lib/python3/dist-packages/setuptools/command/build_ext.py", line 54, in run _build_ext.run(self) File "/usr/lib/python3.4/distutils/command/build_ext.py", line 339, in run self.build_extensions() File "/usr/lib/python3.4/distutils/command/build_ext.py", line 448, in build_extensions self.build_extension(ext) File "/usr/lib/python3/dist-packages/setuptools/command/build_ext.py", line 187, in build_extension _build_ext.build_extension(self, ext) File "/usr/lib/python3.4/distutils/command/build_ext.py", line 503, in build_extension depends=ext.depends) File "/usr/lib/python3.4/distutils/ccompiler.py", line 574, in compile self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts) File "/usr/lib/python3.4/distutils/unixccompiler.py", line 118, in _compile raise CompileError(msg) distutils.errors.CompileError: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1063, in run_setup run_setup(setup_script, args) File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 68, in run_setup DirectorySandbox(setup_dir).run(runner) File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 114, in run return func() File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 67, in runner _execfile(setup_script, ns) File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 43, in _execfile exec(code, globals, locals) File "/tmp/easy_install-xhimgt7q/cffi-1.9.1/setup.py", line 202, in <module>for i in range(1, len(argv))): File "/usr/lib/python3.4/distutils/core.py", line 163, in setup raise SystemExit("error: " + str(msg)) SystemExit: error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<string>", line 1, in <module>File "/tmp/pip-build-vmqvaiw6/cryptography/setup.py", line 334, in <module>**keywords_with_side_effects(sys.argv) File "/usr/lib/python3.4/distutils/core.py", line 108, in setup _setup_distribution = dist = klass(attrs) File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 262, in __init__ self.fetch_build_eggs(attrs['setup_requires']) File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 287, in fetch_build_eggs replace_conflicting=True, File "/usr/lib/python3/dist-packages/pkg_resources.py", line 631, in resolve dist = best[req.key] = env.best_match(req, ws, installer) File "/usr/lib/python3/dist-packages/pkg_resources.py", line 874, in best_match return self.obtain(req, installer) File "/usr/lib/python3/dist-packages/pkg_resources.py", line 886, in obtain return installer(requirement) File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 338, in fetch_build_egg return cmd.easy_install(req) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 636, in easy_install return self.install_item(spec, dist.location, tmpdir, deps) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 666, in install_item dists = self.install_eggs(spec, download, tmpdir) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 856, in install_eggs return self.build_and_install(setup_script, setup_base) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1078, in build_and_install self.run_setup(setup_script, setup_base, args) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1066, in run_setup raise DistutilsError("Setup script exited with %s" % (v.args[0],)) distutils.errors.DistutilsError: Setup script exited with error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 Complete output from command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-vmqvaiw6/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-d2rx3x4n-record/install-record.txt --single-version-externally-managed --compile: Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing `libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found c/_cffi_backend.c:15:17: fatal error: ffi.h: Datei oder Verzeichnis nicht gefunden #include <ffi.h>^ compilation terminated. Traceback (most recent call last): File "/usr/lib/python3.4/distutils/unixccompiler.py", line 116, in _compile extra_postargs) File "/usr/lib/python3.4/distutils/ccompiler.py", line 909, in spawn spawn(cmd, dry_run=self.dry_run) File "/usr/lib/python3.4/distutils/spawn.py", line 36, in spawn _spawn_posix(cmd, search_path, dry_run=dry_run) File "/usr/lib/python3.4/distutils/spawn.py", line 162, in _spawn_posix % (cmd, exit_status)) distutils.errors.DistutilsExecError: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3.4/distutils/core.py", line 148, in setup dist.run_commands() File "/usr/lib/python3.4/distutils/dist.py", line 955, in run_commands self.run_command(cmd) File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command cmd_obj.run() File "/usr/lib/python3/dist-packages/setuptools/command/bdist_egg.py", line 161, in run cmd = self.call_command('install_lib', warn_dir=0) File "/usr/lib/python3/dist-packages/setuptools/command/bdist_egg.py", line 147, in call_command self.run_command(cmdname) File "/usr/lib/python3.4/distutils/cmd.py", line 313, in run_command self.distribution.run_command(command) File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command cmd_obj.run() File "/usr/lib/python3/dist-packages/setuptools/command/install_lib.py", line 22, in run self.build() File "/usr/lib/python3.4/distutils/command/install_lib.py", line 109, in build self.run_command('build_ext') File "/usr/lib/python3.4/distutils/cmd.py", line 313, in run_command self.distribution.run_command(command) File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command cmd_obj.run() File "/usr/lib/python3/dist-packages/setuptools/command/build_ext.py", line 54, in run _build_ext.run(self) File "/usr/lib/python3.4/distutils/command/build_ext.py", line 339, in run self.build_extensions() File "/usr/lib/python3.4/distutils/command/build_ext.py", line 448, in build_extensions self.build_extension(ext) File "/usr/lib/python3/dist-packages/setuptools/command/build_ext.py", line 187, in build_extension _build_ext.build_extension(self, ext) File "/usr/lib/python3.4/distutils/command/build_ext.py", line 503, in build_extension depends=ext.depends) File "/usr/lib/python3.4/distutils/ccompiler.py", line 574, in compile self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts) File "/usr/lib/python3.4/distutils/unixccompiler.py", line 118, in _compile raise CompileError(msg) distutils.errors.CompileError: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1063, in run_setup run_setup(setup_script, args) File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 68, in run_setup DirectorySandbox(setup_dir).run(runner) File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 114, in run return func() File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 67, in runner _execfile(setup_script, ns) File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 43, in _execfile exec(code, globals, locals) File "/tmp/easy_install-xhimgt7q/cffi-1.9.1/setup.py", line 202, in <module>for i in range(1, len(argv))): File "/usr/lib/python3.4/distutils/core.py", line 163, in setup raise SystemExit("error: " + str(msg)) SystemExit: error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<string>", line 1, in <module>File "/tmp/pip-build-vmqvaiw6/cryptography/setup.py", line 334, in <module>**keywords_with_side_effects(sys.argv) File "/usr/lib/python3.4/distutils/core.py", line 108, in setup _setup_distribution = dist = klass(attrs) File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 262, in __init__ self.fetch_build_eggs(attrs['setup_requires']) File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 287, in fetch_build_eggs replace_conflicting=True, File "/usr/lib/python3/dist-packages/pkg_resources.py", line 631, in resolve dist = best[req.key] = env.best_match(req, ws, installer) File "/usr/lib/python3/dist-packages/pkg_resources.py", line 874, in best_match return self.obtain(req, installer) File "/usr/lib/python3/dist-packages/pkg_resources.py", line 886, in obtain return installer(requirement) File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 338, in fetch_build_egg return cmd.easy_install(req) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 636, in easy_install return self.install_item(spec, dist.location, tmpdir, deps) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 666, in install_item dists = self.install_eggs(spec, download, tmpdir) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 856, in install_eggs return self.build_and_install(setup_script, setup_base) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1078, in build_and_install self.run_setup(setup_script, setup_base, args) File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1066, in run_setup raise DistutilsError("Setup script exited with %s" % (v.args[0],)) distutils.errors.DistutilsError: Setup script exited with error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 ---------------------------------------- Cleaning up... Command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-vmqvaiw6/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-d2rx3x4n-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-vmqvaiw6/cryptography Storing debug log for failure in /root/.pip/pip.log root@raspberrypi:~#</module></module></string></module></ffi.h></module></module></string></module></ffi.h> -
No package 'libffi' found```` `
Die ffi headers installieren:
apt-get install libffi-dev -
Habe ich installiert. Danach erneut mirobo mit folgendem Fehlerprotokoll:
! Downloading/unpacking cffi>=1.4.1 (from cryptography->python-mirobo)
! Downloading cffi-1.9.1.tar.gz (407kB): 407kB downloaded
! Running setup.py (path:/tmp/pip-build-52nwxyku/cffi/setup.py) egg_info for package cffi
! Downloading/unpacking appdirs>=1.4.0 (from setuptools>=11.3->cryptography->python-mirobo)
! Downloading appdirs-1.4.2-py2.py3-none-any.whl
! Downloading/unpacking packaging>=16.8 (from setuptools>=11.3->cryptography->python-mirobo)
! Downloading packaging-16.8-py2.py3-none-any.whl
! Downloading/unpacking pycparser (from cffi>=1.4.1->cryptography->python-mirobo)
! Downloading pycparser-2.17.tar.gz (231kB): 231kB downloaded
! Running setup.py (path:/tmp/pip-build-52nwxyku/pycparser/setup.py) egg_info for package pycparser
! warning: no previously-included files matching 'yacctab.' found under directory 'tests'
! warning: no previously-included files matching 'lextab.' found under directory 'tests'
! warning: no previously-included files matching 'yacctab.' found under directory 'examples'
! warning: no previously-included files matching 'lextab.' found under directory 'examples'
! Downloading/unpacking pyparsing (from packaging>=16.8->setuptools>=11.3->cryptography->python-mirobo)
! Downloading pyparsing-2.1.10-py2.py3-none-any.whl (56kB): 56kB downloaded
! Installing collected packages: python-mirobo, cryptography, idna, pyasn1, setuptools, cffi, appdirs, packaging, pycparser, pyparsing
! Running setup.py install for cryptography
! Installed /tmp/pip-build-52nwxyku/cryptography/cffi-1.9.1-py3.4-linux-armv7l.egg
! Searching for pycparser
! Reading https://pypi.python.org/simple/pycparser/
! Best match: pycparser 2.17
! Downloading https://pypi.python.org/packages/be/64/ … f6af5a40c7
! Processing pycparser-2.17.tar.gz
! Writing /tmp/easy_install-uxbzzer1/pycparser-2.17/setup.cfg
! Running pycparser-2.17/setup.py -q bdist_egg --dist-dir /tmp/easy_install-uxbzzer1/pycparser-2.17/egg-dist-tmp-05lk5pnb
! zip_safe flag not set; analyzing archive contents...
! pycparser.ply.pycache.yacc.cpython-34: module references file
! pycparser.ply.pycache.yacc.cpython-34: module MAY be using inspect.getsourcefile
! pycparser.ply.pycache.yacc.cpython-34: module MAY be using inspect.stack
! pycparser.ply.pycache.lex.cpython-34: module references file
! pycparser.ply.pycache.lex.cpython-34: module MAY be using inspect.getsourcefile
! pycparser.ply.pycache.ygen.cpython-34: module references file
! Installed /tmp/pip-build-52nwxyku/cryptography/pycparser-2.17-py3.4.egg
! no previously-included directories found matching 'docs/_build'
! warning: no previously-included files matching '' found under directory 'vectors'
! generating cffi module 'build/temp.linux-armv7l-3.4/_padding.c'
! generating cffi module 'build/temp.linux-armv7l-3.4/_constant_time.c'
! generating cffi module 'build/temp.linux-armv7l-3.4/_openssl.c'
! building '_openssl' extension
! arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.4m -c build/temp.linux-armv7l-3.4/_openssl.c -o build/temp.linux-armv7l-3.4/build/temp.linux-armv7l-3.4/_openssl.o
! build/temp.linux-armv7l-3.4/_openssl.c:434:30: fatal error: openssl/opensslv.h: Datei oder Verzeichnis nicht gefunden
! #include <openssl opensslv.h="">^
! compilation terminated.
! error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
! Complete output from command /usr/bin/python3 -c "import setuptools, tokenize;file='/tmp/pip-build-52nwxyku/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-extnf5u5-record/install-record.txt --single-version-externally-managed --compile:
! Downloading https://pypi.python.org/packages/be/64/ ... f6af5a40c7
! running install
! running build
! running build_py
! creating build
! creating build/lib.linux-armv7l-3.4
! creating build/lib.linux-armv7l-3.4/cryptography
! copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-3.4/cryptography
! copying src/cryptography/about.py -> build/lib.linux-armv7l-3.4/cryptography
! copying src/cryptography/fernet.py -> build/lib.linux-armv7l-3.4/cryptography
! copying src/cryptography/utils.py -> build/lib.linux-armv7l-3.4/cryptography
! copying src/cryptography/init.py -> build/lib.linux-armv7l-3.4/cryptography
! creating build/lib.linux-armv7l-3.4/cryptography/x509
! copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-3.4/cryptography/x509
! copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-3.4/cryptography/x509
! copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-3.4/cryptography/x509
! copying src/cryptography/x509/init.py -> build/lib.linux-armv7l-3.4/cryptography/x509
! copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-3.4/cryptography/x509
! copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-3.4/cryptography/x509
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat
! copying src/cryptography/hazmat/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/serialization.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings
! copying src/cryptography/hazmat/bindings/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/backends
! copying src/cryptography/hazmat/backends/multibackend.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends
! copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends
! copying src/cryptography/hazmat/backends/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/ciphers
! copying src/cryptography/hazmat/primitives/ciphers/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/ciphers
! copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/ciphers
! copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/ciphers
! copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/ciphers
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/interfaces
! copying src/cryptography/hazmat/primitives/interfaces/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/interfaces
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/twofactor
! copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/twofactor
! copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/twofactor
! copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/twofactor
! copying src/cryptography/hazmat/primitives/twofactor/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/twofactor
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! copying src/cryptography/hazmat/primitives/asymmetric/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/asymmetric
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! copying src/cryptography/hazmat/primitives/kdf/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/primitives/kdf
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/commoncrypto
! copying src/cryptography/hazmat/bindings/commoncrypto/binding.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/commoncrypto
! copying src/cryptography/hazmat/bindings/commoncrypto/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/commoncrypto
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/openssl
! copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/openssl
! copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/openssl
! copying src/cryptography/hazmat/bindings/openssl/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/openssl
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/commoncrypto
! copying src/cryptography/hazmat/backends/commoncrypto/ciphers.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/commoncrypto
! copying src/cryptography/hazmat/backends/commoncrypto/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/commoncrypto
! copying src/cryptography/hazmat/backends/commoncrypto/backend.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/commoncrypto
! copying src/cryptography/hazmat/backends/commoncrypto/hashes.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/commoncrypto
! copying src/cryptography/hazmat/backends/commoncrypto/hmac.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/commoncrypto
! creating build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/init.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-3.4/cryptography/hazmat/backends/openssl
! running egg_info
! writing dependency_links to src/cryptography.egg-info/dependency_links.txt
! writing top-level names to src/cryptography.egg-info/top_level.txt
! writing src/cryptography.egg-info/PKG-INFO
! writing entry points to src/cryptography.egg-info/entry_points.txt
! writing requirements to src/cryptography.egg-info/requires.txt
! warning: manifest_maker: standard file '-c' not found
! reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
! reading manifest template 'MANIFEST.in'
! writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
! running build_ext
! creating build/temp.linux-armv7l-3.4
! creating build/temp.linux-armv7l-3.4/build
! creating build/temp.linux-armv7l-3.4/build/temp.linux-armv7l-3.4
! Cleaning up...
! Command /usr/bin/python3 -c "import setuptools, tokenize;file='/tmp/pip-build-52nwxyku/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-extnf5u5-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-52nwxyku/cryptography
! Storing debug log for failure in /root/.pip/pip.log</openssl></openssl> -
Steht ja in github. Ich bin zu doof zum Lesen. Dennoch habe ich jetzt wieder eine Fehlermeldung:
! root@raspberrypi:~# apt-get install libssl-dev
! Paketlisten werden gelesen… Fertig
! Abhängigkeitsbaum wird aufgebaut.
! Statusinformationen werden eingelesen.... Fertig
! Die folgenden zusätzlichen Pakete werden installiert:
! libssl-doc
! Die folgenden NEUEN Pakete werden installiert:
! libssl-dev libssl-doc
! 0 aktualisiert, 2 neu installiert, 0 zu entfernen und 3 nicht aktualisiert.
! Es müssen 2.263 kB an Archiven heruntergeladen werden.
! Nach dieser Operation werden 6.480 kB Plattenplatz zusätzlich benutzt.
! Möchten Sie fortfahren? [J/n] j
! Holen: 1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-dev armhf 1.0.1t-1+deb8u6 [1.095 kB]
! Holen: 2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-doc all 1.0.1t-1+deb8u6 [1.168 kB]
! Es wurden 2.263 kB in 2 s geholt (1.081 kB/s).
! Vormals nicht ausgewähltes Paket libssl-dev:armhf wird gewählt.
! (Lese Datenbank … 118246 Dateien und Verzeichnisse sind derzeit installiert.)
! Vorbereitung zum Entpacken von .../libssl-dev_1.0.1t-1+deb8u6_armhf.deb ...
! Entpacken von libssl-dev:armhf (1.0.1t-1+deb8u6) ...
! Vormals nicht ausgewähltes Paket libssl-doc wird gewählt.
! Vorbereitung zum Entpacken von .../libssl-doc_1.0.1t-1+deb8u6_all.deb ...
! Entpacken von libssl-doc (1.0.1t-1+deb8u6) ...
! Trigger für man-db (2.7.0.2-5) werden verarbeitet ...
! libssl-dev:armhf (1.0.1t-1+deb8u6) wird eingerichtet ...
! libssl-doc (1.0.1t-1+deb8u6) wird eingerichtet ...
! root@raspberrypi:~# pip3 install python-mirobo
! Downloading/unpacking python-mirobo
! Downloading python_mirobo-0.0.3-py3-none-any.whl
! Requirement already satisfied (use --upgrade to upgrade): construct in /usr/local/lib/python3.4/dist-packages (from python-mirobo)
! Downloading/unpacking cryptography (from python-mirobo)
! Downloading cryptography-1.7.2.tar.gz (420kB): 420kB downloaded
! Running setup.py (path:/tmp/pip-build-0ccwl8vj/cryptography/setup.py) egg_info for package cryptography
! Requirement already satisfied (use --upgrade to upgrade): pretty-cron in /usr/local/lib/python3.4/dist-packages (from python-mirobo)
! Requirement already satisfied (use --upgrade to upgrade): click in /usr/local/lib/python3.4/dist-packages (from python-mirobo)
! Downloading/unpacking idna>=2.0 (from cryptography->python-mirobo)
! Downloading idna-2.4-py2.py3-none-any.whl (55kB): 55kB downloaded
! Downloading/unpacking pyasn1>=0.1.8 (from cryptography->python-mirobo)
! Downloading pyasn1-0.2.3-py2.py3-none-any.whl (53kB): 53kB downloadedRequirement already satisfied (use --upgrade to upgrade): six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography->python-mirobo)
! Downloading/unpacking setuptools>=11.3 (from cryptography->python-mirobo)
! Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 1% 4.1 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 2% 8.2 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 3% 12k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 4% 16k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 5% 20k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 6% 24k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 7% 28k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 8% 32k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 9% 36k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 10% 40k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 11% 45k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 12% 49k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 13% 53k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 14% 57k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 15% 61k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 16% 65k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 17% 69k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 18% 73k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 19% 77k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 21% 81k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 22% 86k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 23% 90k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 24% 94k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 25% 98k Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 26% 102 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 27% 106 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 28% 110 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 29% 114 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 30% 118 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 31% 122 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 32% 126 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 33% 131 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 34% 135 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 35% 139 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 36% 143 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 37% 147 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 38% 151 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 39% 155 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 41% 159 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 42% 163 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 43% 167 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 44% 172 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 45% 176 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 46% 180 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 47% 184 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 48% 188 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 49% 192 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 50% 196 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 51% 200 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 52% 204 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 53% 208 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 54% 212 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 55% 217 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 56% 221 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 57% 225 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 58% 229 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 59% 233 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 61% 237 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 62% 241 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 63% 245 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 64% 249 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 65% 253 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 66% 258 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 67% 262 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 68% 266 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 69% 270 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 70% 274 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 71% 278 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 72% 282 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 73% 286 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 74% 290 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 75% 294 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 76% 299 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 77% 303 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 78% 307 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 79% 311 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 80% 315 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 82% 319 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 83% 323 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 84% 327 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 85% 331 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 86% 335 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 87% 339 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 88% 344 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 89% 348 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 90% 352 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 91% 356 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 92% 360 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 93% 364 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 94% 368 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 95% 372 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 96% 376 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 97% 380 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 98% 385 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 99% 389 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 100% 389 Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): Downloading setuptools-34.3.1-py2.py3-none-any.whl (389kB): 389kB downloaded
! Running setup.py (path:/tmp/pip-build-0ccwl8vj/cffi/setup.py) egg_info for package cffi
! Running setup.py (path:/tmp/pip-build-0ccwl8vj/pycparser/setup.py) egg_info for package pycparser
! Installed /tmp/pip-build-0ccwl8vj/cryptography/cffi-1.9.1-py3.4-linux-armv7l.egg
! Writing /tmp/easy_install-p_x9avyu/pycparser-2.17/setup.cfg
! Running pycparser-2.17/setup.py -q bdist_egg --dist-dir /tmp/easy_install-p_x9avyu/pycparser-2.17/egg-dist-tmp-ketmxj32
! Installed /tmp/pip-build-0ccwl8vj/cryptography/pycparser-2.17-py3.4.egg
! arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.4/build/temp.linux-armv7l-3.4/_openssl.o -lssl -lcrypto -o build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/_openssl.cpython-34m.so
! building '_constant_time' extension
! arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.4m -c build/temp.linux-armv7l-3.4/_constant_time.c -o build/temp.linux-armv7l-3.4/build/temp.linux-armv7l-3.4/_constant_time.o
! arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.4/build/temp.linux-armv7l-3.4/_constant_time.o -o build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/_constant_time.cpython-34m.so
! building '_padding' extension
! arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.4m -c build/temp.linux-armv7l-3.4/_padding.c -o build/temp.linux-armv7l-3.4/build/temp.linux-armv7l-3.4/_padding.o
! arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.4/build/temp.linux-armv7l-3.4/_padding.o -o build/lib.linux-armv7l-3.4/cryptography/hazmat/bindings/_padding.cpython-34m.so
! Found existing installation: setuptools 5.5.1
! Not uninstalling setuptools at /usr/lib/python3/dist-packages, owned by OS
! Running setup.py install for cffi
! Traceback (most recent call last):
! File "<string>", line 1, in <module>File "/usr/local/lib/python3.4/dist-packages/setuptools/init.py", line 12, in <module>import setuptools.version
! File "/usr/local/lib/python3.4/dist-packages/setuptools/version.py", line 1, in <module>import pkg_resources
! File "/usr/local/lib/python3.4/dist-packages/pkg_resources/init.py", line 70, in <module>import packaging.version
! ImportError: No module named 'packaging'
! Complete output from command /usr/bin/python3 -c "import setuptools, tokenize;file='/tmp/pip-build-0ccwl8vj/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-uoxfec1w-record/install-record.txt --single-version-externally-managed --compile:
! Cleaning up...
! Command /usr/bin/python3 -c "import setuptools, tokenize;file='/tmp/pip-build-0ccwl8vj/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-uoxfec1w-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-0ccwl8vj/cffi
! Storing debug log for failure in /r</module></module></module></module></string></module></module></module></module></string> -
Steht ja in github. Ich bin zu doof zum Lesen. `
Bist du nicht, ich habe es nur schnell aktualisiert ;)> ImportError: No module named 'packaging'
Dies ist komplizierter, anscheinbar ist mein eigenes System irgendwie anders eingerichtet, sodass es funktioniert. Ich könnte dieses Problem auch jetzt bei mir wiedergeben, eine Lösung habe ich noch nicht gefunden. :( -
Das Problem habe ich gefunden, es geht um zu alten Versionen von pip & setuptools, ich habe die README.md aktualisiert.$ virtualenv -p python3 miroboenv .. $ source miroboenv/bin/activate .. $ pip3 install -U pip setuptools .. $ pip install python-mirobo .. $ mirobo State: Charging Battery: 100 Fanspeed: 30 Cleaning since: 0:00:00 Cleaned area: 1.6925 m²Danke für das Testen :)
Tpr,
So, weiter getestet wie versprochen. Ich bekomme noch immer Fehler.
1. starte ich````
pip3 install -U pip setuptools>! Traceback (most recent call last): >! File "/usr/bin/pip3", line 5, in <module>from pkg_resources import load_entry_point >! File "/usr/local/lib/python3.4/dist-packages/pkg_resources/__init__.py", line 70, in <module>import packaging.version >! ImportError: No module named 'packaging'</module></module> 2\. starte ich```` pip3 install python-mirobokommt
! ImportError: No module named 'packaging'</module></module>Irgendwo ist noch der Hund drin :) :D
Ohh, hmh. Nun, einzelne was ich nachdenken kann wäre das ganze pip manuell erneut installieren wie hier: https://raspberrypi.stackexchange.com/q … 2413#62413 (ohne paramiko zeile)
Die eigentliche Routine habe ich bereits nach Javascript umgeschrieben und scheint zu funktionieren. Jetzt muss ich das Ganze in einen Adapter umschreiben. Da ich hiermit noch keinerlei Erfahrungen habe, wird das etwas dauern. Mal sehen, was das nächste Wochenende bringt.
Kannst du die Umsetzung in Javascript schon mal hier bereit stellen?
:D `
Ja, das wäre toll.
Dann können wir ja schon einmal testen.
mfg
tpr,
Es will nicht! Nachdem ich
sudo pip install cryptographyeingegeben habe, erhalte ich folgende Fehlermeldung:
! File "/usr/local/lib/python2.7/dist-packages/pkg_resources/init.py", line 70, in <module>import packaging.version
! ImportError: No module named packaging.version
! Cleaning up...
! Command /usr/bin/python -c "import setuptools, tokenize;file='/tmp/pip-build-otSuJz/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-2vd4e4-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-otSuJz/cffi
! Storing debug log for failure in /root/.pip/pip.log</module>Was tun? Hast Du eine Idee? Alle anderen Befehle aus
liefen anstandslos durch. Und dann bei cryptography war Schluss
tpr.
Ergänzung: nachdem sich cryptography nicht installieren ließ habe ich einfach mal die beiden weiteren Befehle
ausgeführt. Danach lief die Installation von cryptography durch. Ich dachte schon, das sei es. Wenn ich dann aber mirobo ausführe, bekomme ich wieder die packaging Fehlermeldung
! ImportError: No module named 'packaging'</module></module>Habe alles so gemacht, wie Du es im Github beschreibst. Außer: "Using virtualenv is recommended." Das habe ich nicht durchgeführt. Auch, weil ich nicht kapiere, was das ist. Könnte da der Hund begraben sein?
tpr.
! ImportError: No module named 'packaging'</module></module> `Hallo skorpil,
leider ist der Grund für diese Fehlermeldung zu alte pip oder setuptools, deswegen weigert er da.
virtualenv (virtual environment) ist ein tool, womit man ohne root/sudo neue Entwicklungsumgebungen einrichten kann. D.h. damit könntest Du die Python-Pakete in ein Verzeichnis installieren lassen, und wenn etwas schief ginge, dieses Verzeichnis wieder löschen und neustarten.
Du könntest noch das ausprobieren, so geht die Einrichtung eines virtualenvs (alles von unten wird ohne root, d.h. mit deinem normalen Benutzer ausgeführt):
virtualenv -p python3 <name des/ordners="">source <name des/ordners="">/bin/activate</name></name>Dann wird alle Pakete in diesen eigenständigen Ordner wie üblich mit pip installiert (nach aktualisierung von pip & setuptools).
pip install -U pip pip install -U setuptools pip install python-miroboHoffentlich das hilft, wenn nicht, ich habe wirklich keine andere Ideen gerade.
