  4. Aqara Fensterkontakt mit Zigbee
99 Beiträge 17 Kommentatoren 20.0k Aufrufe 18 Beobachtet
  • K Kippe
    @asgothian log.txt
    So 😀
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @kippe 🤦
    Auf die Idee das in Code Tags (</>) einfach hinein zu posten bist du nicht gekommen ? So machen das die anderen auch.
    2021-11-19 19:04:04.708 - info: host.raspberrypi "system.adapter.weatherunderground.0" disabled
    2021-11-19 19:04:04.721 - info: host.raspberrypi stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
    2021-11-19 19:04:04.723 - info: host.raspberrypi stopInstance canceled schedule system.adapter.weatherunderground.0
    2021-11-19 19:04:19.062 - info: host.raspberrypi "system.adapter.zigbee.1" disabled
    2021-11-19 19:04:19.063 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 (force=false, process=true)
    2021-11-19 19:04:19.191 - info: zigbee.1 (7671) Got terminate signal TERMINATE_YOURSELF
    2021-11-19 19:04:19.194 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 send kill signal
    2021-11-19 19:04:19.193 - info: zigbee.1 (7671) cleaned everything up...
    2021-11-19 19:04:19.196 - info: zigbee.1 (7671) Zigbee: disabling joining new devices.
    2021-11-19 19:04:19.694 - info: zigbee.1 (7671) terminating
    2021-11-19 19:04:19.696 - info: zigbee.1 (7671) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-19 19:04:20.196 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 killing pid 7671
    2021-11-19 19:04:20.472 - info: host.raspberrypi instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-11-19 19:04:24.858 - info: host.raspberrypi "system.adapter.zigbee.1" enabled
    2021-11-19 19:04:24.985 - info: host.raspberrypi instance system.adapter.zigbee.1 started with pid 30171
    2021-11-19 19:04:27.979 - info: zigbee.1 (30171) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.18
    2021-11-19 19:04:28.107 - info: zigbee.1 (30171) Starting Zigbee npm ...
    2021-11-19 19:04:28.619 - info: zigbee.1 (30171) Installed Version: ioBroker/ioBroker.zigbee#f5f1f12098e7baa3da89789d496d62837324c9d8
    2021-11-19 19:04:28.995 - info: zigbee.1 (30171) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201127}}
    2021-11-19 19:04:29.000 - info: zigbee.1 (30171) Disable LED
    2021-11-19 19:04:29.002 - info: zigbee.1 (30171) Unable to disable LED, unsupported function.
    2021-11-19 19:04:29.012 - info: zigbee.1 (30171) --> transmitPower : normal
    2021-11-19 19:04:29.023 - info: zigbee.1 (30171) Currently 4 devices are joined:
    2021-11-19 19:04:29.056 - info: zigbee.1 (30171) 0x0017880108298e04 (addr 33183): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
    2021-11-19 19:04:29.061 - info: zigbee.1 (30171) 0x0017880108218318 (addr 14991): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
    2021-11-19 19:04:29.063 - info: zigbee.1 (30171) 0x00158d00062f883d (addr 60275): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
    2021-11-19 19:04:29.065 - info: zigbee.1 (30171) 0x54ef44100025c545 (addr 41079): MCCGQ14LM - Xiaomi Aqara E1 door & window contact sensor (EndDevice)
    2021-11-19 19:04:29.066 - info: zigbee.1 (30171) Zigbee started
    Es sieht zumindest so aus als ob du den aktuellen Adapter installiert hast und dieser auch läuft.
    Bitte trag die ieee von dem neuen Sensor in den State zigbee.0.info.debugmessages ein und lass den Adapter 2 Stunden laufen. Danach schau im Log nach Nachrichten mit dem Schlüsselwort "ELEVATED"
    A.
    • K Kippe
      @asgothian log.txt
      So 😀
      Korthy
      schrieb am zuletzt editiert von Korthy
      @kippe
      Kannst du das genauer erklären?
      "Bitte trag die ieee von dem neuen Sensor in den State zigbee.0.info.debugmessages ein"
      Wo findet man das? (State zigbee.0.info.debugmessages)
      Ich habe den gleichen Fenstersensor
      AsgothianA crunchipC 2 Antworten Letzte Antwort
      • K Korthy
        @kippe
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @korthy
        Im Objektbaum findest du die Objekte des Zigbee Adapters unter zigbee.0. Wenn du da weiter durchgehst findest du den Datenpunkt mit der "Adresse" zigbee.0.info.debugmessages
        A.
        • K Korthy
          @kippe
          crunchipC Offline
          crunchipC Offline
          @korthy sagte in Aqara Fensterkontakt mit Zigbee:
          ernsthaft? unter Objekte
          • AsgothianA Asgothian
            @korthy
            A.
            @asgothian
            Danke.
            Wo es schon um den Umgang damit geht.
            Muß man danach den Adapter Neustarten?
            Muß dafür in den Adapter Einstellungen Herdsman-Debug Messages aktiviert sein?
            Welcher Loglevel muß beim Adapter eingestellt sein?
            AsgothianA K 2 Antworten Letzte Antwort
              @asgothian
              Danke.
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @pete0815 sagte in Aqara Fensterkontakt mit Zigbee:
              @asgothian
              Danke.
              In Reihenfolge der Fragen:
              Nein.
              Nein.
              Egal.
              Einfach Eintragen, dann kommen die Meldungen.
              Austragen, und die Meldungen gehen wieder weg.
              A.
                @asgothian
                Danke.
                Korthy
                @pete0815
                da kommen keine Logs. ieee ohne 0x , oder ?
                • K Korthy
                  @pete0815
                  @korthy
                  ja. das dauert etwas (jedenfalls bei mir). einfach laufen lassen.
                    @korthy
                    Korthy
                    @pete0815
                    hier scheint sich auch nichts zu tun.
                    Staus ist immer NULL, kein Eintrag im Log, keine Reaktion einer Blockly Abfrage bei Änderung
                    • K Korthy
                      @pete0815
                      @korthy
                      vlt. hilft ein Adapter Neustart.
                      Diese Meldung im Log war für mich wie ein "Startsignal" das es ab jetzt funktioniert für das Gerät:
                      2021-11-22 17:09:36.521 - info: zigbee.0 (13524) debug devices set to ["84fd27fffece7c34"]
                        @korthy
                        Korthy
                        @pete0815
                        nö, bleibt dabei.
                        Ich denke, dass Aqara von der Version MCCGQ11LM zu MCCGQ14LM etwas wesentliches geändert hat. Die 11er laufen ja. Dort werden Batterie und Status angezeigt. Auch das korrekte Foto des Sensors
                        Evtl. muss das was in der Adapter Bibliothek aktualisiert werden.
                        • K Korthy
                          @pete0815
                          nö, bleibt dabei.
                          @korthy
                          da geht es meistens drum. Erst wird das Gerät identifiziert, dann die Datenpunkte die das Gerät liefert herausfinden (was und wo) und zu Letzt dies in der Bibliothek hinterlegen.
                          Wenn ich die Versuche bzgl. debug etc subjektiv deute, dann ist der Eintrag in der Bibliothek bereits passiert und nun läuft Ursachenforschung warum Deine Geräte sich nicht mit der Bibliothek korreckt verknüpfen.
                          Habe aber selbst nicht genau geforscht (Jugend forscht ...) und nur interessiert hier und da mitgelesen, da ich evtl. demnächst auch noch ein paar Sensoren brauche/kaufen wollte und die Aqaras findet man ja kaum noch :)
                            @korthy
                            Korthy
                            @pete0815
                            Die Aqaras gibt es beim Ali ;-)
                            • K Korthy
                              @pete0815
                              @korthy said in Aqara Fensterkontakt mit Zigbee:
                              @pete0815
                              Sorry meinte die Alten bzw. bin ich auch noch an die alten Preise ~7-8€ gewöhnt und schaue mich danach um ;)
                                sicadrip
                                Ich würde mich gerne ins Thema einklinken. Ich habe ebenfalls zwei Stück der neuen Türsensoren, die leider nicht erkannt werden.
                                Adapter: v1.6.7
                                Coordinator:
                                • ZigBee 3.0 USB Dongle plus
                                • type:z Stack3x0
                                • version: 2-1.2.7.1.
                                Hier die Meldung beim pairen:
                                New device joined '0x54ef441000260443' model MCCGQ14LM
                                Device '0x54ef441000260443' announced itself
                                Hier die bisherigen Logs aus dem id-debug, habe dabei gelegentlich den Knopf gedrückt (zeigt dann linkquality an) - Kontakt schließen ruft keinen Logeintrag hervor. Ich lass es jetzt erst mal noch etwas weiterlaufen:
                                2021-11-23 18:04:28.018 - info: zigbee.0 (6408) Zigbee: allowing new devices to join.
                                2021-11-23 18:04:30.285 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"linkquality":66}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:30.285 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '66' from device 54ef441000260443 for 'Link quality'
                                2021-11-23 18:04:30.285 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":66,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":16,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:30.286 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":66,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":16,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 54ef441000260443 for 'Message from Zigbee'
                                2021-11-23 18:04:41.862 - warn: zigbee.0 (6408) Device '0x54ef441000260443' announced itself
                                2021-11-23 18:04:42.864 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"available":true}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:42.865 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated 'true' from device 54ef441000260443 for 'Available'
                                2021-11-23 18:04:42.865 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"linkquality":10}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:42.865 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '10' from device 54ef441000260443 for 'Link quality'
                                2021-11-23 18:04:44.642 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"linkquality":129}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:44.642 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '129' from device 54ef441000260443 for 'Link quality'
                                2021-11-23 18:04:44.643 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"attributeReport\",\"data\":{\"appVersion\":4,\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":139,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:44.643 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '"{\"type\":\"attributeReport\",\"data\":{\"appVersion\":4,\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":139,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 54ef441000260443 for 'Message from Zigbee'
                                2021-11-23 18:04:47.811 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"linkquality":129}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:47.811 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '129' from device 54ef441000260443 for 'Link quality'
                                2021-11-23 18:04:47.811 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":140,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:04:47.811 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":140,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 54ef441000260443 for 'Message from Zigbee'
                                2021-11-23 18:05:00.360 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"linkquality":129}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:05:00.360 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '129' from device 54ef441000260443 for 'Link quality'
                                2021-11-23 18:05:00.360 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":141,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:05:00.360 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":141,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 54ef441000260443 for 'Message from Zigbee'
                                2021-11-23 18:05:11.373 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"linkquality":129}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:05:11.374 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '129' from device 54ef441000260443 for 'Link quality'
                                2021-11-23 18:05:11.374 - warn: zigbee.0 (6408) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":142,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 54ef441000260443 type 'MCCGQ14LM'
                                2021-11-23 18:05:11.374 - warn: zigbee.0 (6408) ELEVATED publishToState: value generated '"{\"type\":\"attributeReport\",\"data\":{\"modelId\":\"lumi.magnet.acn001\"},\"linkquality\":129,\"groupID\":0,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":142,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 54ef441000260443 for 'Message from Zigbee'
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  installiertmal jetzt von GIT..geht es jetzt ?
                                  S K 2 Antworten Letzte Antwort
                                  • arteckA arteck
                                    sicadrip
                                    @arteck said in Aqara Fensterkontakt mit Zigbee:
                                    Ich hab gesehen, dass du in dem commit das device geadded hast. Bei mir wird jetzt lediglich das Bild vom Sensor auch angezeigt. Der state "Is open" oder "Contact event" wird bei mir aber noch nicht übermittelt (Sensor klackt aber hörbar) bei Näherung.
                                    • arteckA arteck
                                      Korthy
                                      @arteck
                                      Bei mir das Gleiche.
                                      Nach Update via Git ist zwar jetzt das Bild vorhanden, aber weiter ohne Funktion.
                                      arteckA K 2 Antworten Letzte Antwort
                                      • K Korthy
                                        @arteck
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @korthy auch unter Ausschliessen Tab nicht ? welchen Kanal hast du eingestellt ?
                                        • K Korthy
                                          @arteck
                                          Korthy
                                          @korthy
                                          Ich funke auf Kanal 11.
                                          "Ausschliessen Tab" verstehe ich nicht, bitte um Input.
                                          arteckA S 2 Antworten Letzte Antwort
