  4. Test Coronavirus Statistics for ioBroker
    apollon77A
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 582.5k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    @jlssmt sagte in Test Coronavirus Statistics for ioBroker:
    Aber eigentlich sollten auch in der 0.8.3 die Krankenhausdaten da sein.
    nein, die waren erst ab der 0.8.4-0 dabei (wobei -0 bzw -X Nummer die alpha Versionen sind)
    Changelog
    0.8.4 (2021-10-26)
    (DutchmanNL) Bugfix: New DNS entry for COVID api
    (jlssmt) Hospital data for Germany added
    (jlssmt) fix umlauts in hospital service
    (jlssmt) extend api timer to fix 502 errors
    0.8.3 (2021-08-20)
    (jlssmt) Code refactoring
    (DutchmanNL) Bugfix: Unwanted deletion of data points for Germany solved
    ChrisNettC
    ChrisNettC
    ChrisNett
    #1043
    @dutchman sagte in Test Coronavirus Statistics for ioBroker:
    Changelog
    0.8.4 (2021-10-26)
    0.8.3 (2021-08-20)
    danke dann warte ich mal bis heute abend. über github geht es bei mir gerade irgtnwie nicht
    • ChrisNettC ChrisNett
      Changelog
      0.8.4 (2021-10-26)
      0.8.3 (2021-08-20)
      J
      J
      jlssmt
      #1044
      Ah sorry. Zu viele releases und zu lange her :-D
        Aktuelle Test Version 0.6.9
        Veröffentlichungsdatum 22-03-2021
        Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
        NPM npm i ioBroker.coronavirus-statistics@latest
        Adapter to show Global Corona Virus information and current reports
        Coronavirus Live Statistics adapter for ioBroker
        There is no configuration required, after installation it will :
        • Receive global information world-wide and write it to "global_totals"
        • Create a folder for each country with all relevant information regarding COVID-19
        • Update the information every 15 minutes
        The following information is available :
        Datapoint Details
        active Amount of current infected people
        cases Amount of totally known cases
        casesPerOneMillion Amount of totally known cases per million citizen
        critical Amount of critical situation (Hospitalized)
        deaths Amount of current registered deaths
        deathsPerOneMillion Amount of current registered deaths per million citizen
        recovered Amount of totally known recovered cases
        todayCases New Cases by Today
        todayDeaths Amount of totally known people died today
        test Total number of covid-19 tests taken globally
        tests per one million counties Total number of covid-19 tests taken globally per one million
        Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
        German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
        Generic Source : https://coronavirus-19-api.herokuapp.com
        Advanced settings
        Option Description
        All Countries Get data for all countries World-Wide (Default: false)
        Continents Group total amounts by continent in seperate state (Default: false)
        Delete unused States Delete data when countries are deselected (Default: false)
        German counties Get counties data for Germany (Selected only, Default false)
        German federal states Get federal state data for Germany (Selected only, Default false)
        Get all German federal states Get federal state data for Germany (Default false)
        Get all German counties Get all counties data for Germany (Default false)
        For Germany only
        It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
        You can choose to recieve all data or just select specific regions in advanced settings.
        Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
        Add missing countries
        It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
        coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
        Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
        List with country names
        With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
        The JSON string then looks like this, for example:
        	"Cabo_Verde": "Cape Verde",
        	"Timor-Leste": "East Timor"
        As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
        Changelog
        sigi234S
        sigi234S
        #1045
        @dutchman
        Hallo, die Warn kommt immer
        2021-11-17 10:14:42.439	warn	State attribute definition missing for daily_people_vaccinated_per_hundred
        2021-11-17 10:14:42.439	debug	Create_state called for : United_Kingdom.Vaccination.daily_people_vaccinated_per_hundred with value : 0.067
        2021-11-17 10:14:42.383	debug	Write value : false
        2021-11-17 10:14:42.383	warn	State attribute definition missing for daily_people_vaccinated
        2021-11-17 10:14:42.383	debug	Create_state called for : United_Kingdom.Vaccination.daily_people_vaccinated with value : 45681
        Version 0.8.6 in C:/Program Files/iobroker/Home/node_modules/iobroker.coronavirus-statistics, node: v12.22.7, js-controller: 3.3.18
        • sigi234S sigi234
          @dutchman
          DutchmanD
          DutchmanD
          Dutchman
          #1046
          @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
          @dutchman
          machste mir bitte n issue ? wohl was neues in der API
            @dutchman
            sigi234S
            sigi234S
            #1047
            @dutchman
            https://github.com/DrozmotiX/ioBroker.coronavirus-statistics/issues/331
            • sigi234S sigi234
              @dutchman
              DutchmanD
              DutchmanD
              Dutchman
              #1048
              @dutchman
              thank, habe neue version auf git geschoben please try :)
                @dutchman
                sigi234S
                sigi234S
                #1049
                Warnung ist weg. 👍
                • sigi234S sigi234
                  Warnung ist weg. 👍
                  DutchmanD
                  DutchmanD
                  Dutchman
                  #1050
                  Warnung ist weg. 👍
                  Danke fürs schnelle testen, fix geht Direkt heute nach stable
                  blue231181B 1 Antwort Letzte Antwort
                    Warnung ist weg. 👍
                    blue231181B
                    blue231181B
                    blue231181
                    #1051
                    @dutchman
                    Hallo zusammen, wird der Hospitalisierungs Index auch als DP ausgegeben? (Aus aktuellen Anlass….)
                    Beste Grüße
                    • blue231181B blue231181
                      @dutchman
                      Beste Grüße
                      J
                      J
                      jlssmt
                      #1052
                      @blue231181
                      Haben sich die Bundesländer mittlerweile auf eine deutschlandweite Regelung geeinigt? (Ich weiß es wirklich nicht)
                      Bis das nicht passiert ist, nein.
                      • J jlssmt
                        @blue231181
                        blue231181B
                        blue231181B
                        blue231181
                        #1053
                        @jlssmt
                        Ja soweit ich die Medien verfolgt habe ist der Hospitalisierungs Index unsere neue Richtlinie (korrigiert mich bitte falls ich falsch liege)
                          @jlssmt
                          J
                          J
                          jlssmt
                          #1054
                          @blue231181
                          Ist das die 7-Tage-Inzidenz für Krankenhauseinlieferungen?
                          Wie berechnet der sich denn?
                          Gilt der dann pro Bundesland?
                          • J jlssmt
                            @blue231181
                            blue231181B
                            blue231181B
                            blue231181
                            #1055
                            @jlssmt
                            Ja der gilt pro Bundesland
                            Die Hospitalisierungsrate oder auch Hospitalisierungsinzidenz gibt an, wie viele der mit COVID-19 Erkrankten pro 100.000 Einwohnern ins Krankenhaus eingewiesen wurden. Als Grundlage dienen die Krankenhauseinweisungen der letzten sieben Tage.
                            Eventuell gibt es ja diesen DP?
                              @jlssmt
                              J
                              J
                              jlssmt
                              #1056
                              @blue231181
                              Ne. Den gibts nicht. Und um den zu berechnen müssten wir eine Historie für die letzten sieben Tage mit den Einlieferungen aufbauen.
                              Für die Einlieferungen habe ich jedoch keine Datenquelle...
                              Wenn du mir eine API zeigst, können wir das gerne einpflegen. Ich denke aber nicht, dass das so schnell geht. Die Mühlen mahlen sehr langsam...
                              blue231181B HomoranH 2 Antworten Letzte Antwort
                              • J jlssmt
                                @blue231181
                                blue231181B
                                blue231181B
                                blue231181
                                #1057
                                @jlssmt
                                Ach du bist mit an der Entwicklung beteiligt?
                                Dann mal ein Riesen großes Kompliment an die Zeit und Mühe die Ihr Investiert.
                                Ich nutz den Adapter seit 1,5 Jahren täglich und finde es einen sinnvollsten überhaupt
                                Also vielen Dank und allen Respekt 😃
                                J ChaotC 2 Antworten Letzte Antwort
                                  @jlssmt
                                  J
                                  J
                                  jlssmt
                                  #1058
                                  @blue231181
                                  Kein Thema ;-)
                                  Ich hab mich in den letzten Monaten ein bisschen reingeschmuggelt, ja.
                                  Für Bayern finde ich den Indexwert hier: https://www.lgl.bayern.de/gesundheit/infektionsschutz/infektionskrankheiten_a_z/coronavirus/karte_coronavirus/index.htm#kennzahlen
                                  Aber woher dort die Daten kommen, weiß keiner. Vmtl. aus einer Excel Tabelle, die per Fax vom Krankenhaus an das Ministerium geschickt wurde, welches dann wiederum alle Excel abtippen und zu einem Wert konsolidieren.
                                  Die Tabelle könnte ich verwenden, wollen wir aber nicht, weil wir das dann 16x machen müssten und bei jeder Änderung der Adapter nicht mehr funktioniert...
                                    @jlssmt
                                    ChaotC
                                    ChaotC
                                    Chaot
                                    #1059
                                    @blue231181 Ich orientiere mich an dem Prozentsatz der freien Betten. Das ist jetzt zwar nicht die offizielle Variante, aber aus früheren Zeiten weiß ich das ab 10% Restkapazität verschiedene Notfallpläne anlaufen. Ich denke mal das die hier vielleicht noch etwas verschoben haben, aber spätestens ab 5% brennt alles.
                                    Auch wenn auf Regierungsebene da vielleicht andere Zahlen konstruiert werden ist letztlich doch die verfügbare Kapazität das Maß der Dinge. Wenn 0% erreicht sind gibt es eben Tote auf der Straße (mal krass gesagt).
                                    • J jlssmt
                                      @blue231181
                                      Kein Thema ;-)
                                      blue231181B
                                      blue231181B
                                      blue231181
                                      #1060
                                      @jlssmt kann ich verstehen
                                      Dann einen schönen Gruß ans ganze Team und nochmal vielen Dank
                                      • ChaotC Chaot
                                        blue231181B
                                        blue231181B
                                        blue231181
                                        #1061
                                        @chaot danke, das wäre ne gute Alternative
                                        Ich teste das mal aus
                                        • J
                                          J
                                          jlssmt
                                          schrieb am zuletzt editiert von jlssmt
                                          #1062
                                          @chaot
                                          Ich denke dem Kollegen hier geht es eher darum zu wissen, wann 2G ist und wann nicht.
                                          Das bekommt man durch die Prozentzahlen nicht raus.
                                          Bayern hat bspw. noch 11% frei, aber die Ampel ist rot und der Hospitalisierungsindex steht bei 8,7
                                          Man weiß ja auch, dass nicht Corona OPs verschoben werden um die Kapazität frei zu halten. Das fließt alles nicht in den Prozentsatz rein
                                          blue231181B ChaotC 2 Antworten Letzte Antwort
                                          84.0k
