  5. Blocky script
Blocky script
86 Beiträge 6 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • I ingenii
    @cinimod said in Blocky script:
    nem code tag </>
    ich hoffe du meinst das:
    <block type="comment" id="P*;A,KQ(tX3;?;KS_6UG" x="163" y="-562">
    <field name="COMMENT">Schalter_Wohnzimmer</field>
    <next>
    <block type="on_ext" id="Sz;+_7H0(F[ov}Ci4Cb">
    <value name="OID0">
    <shadow type="field_oid" id="M+,9mrkPy(Z-}QTxV#3"> <field name="oid">sonoff.0.T3_Wohn_Ess_Licht.POWER1</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="~$tqKw0v!N/dA)!Ho[?w"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_operation" id="dqm-1)9tfpy,n1k4R6Fh" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="on_source" id="[dk0f8)1NzVSrDL2E:t">
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="v^)!{Wp4W+}hJOYw_T0U">
    <field name="OP">EQ</field>
    <value name="A">
    <block type="get_value" id="dL@U7KuLNxkLxO]RWOyy">
    <field name="OID">sonoff.0.T3_Wohn_Ess_Licht.POWER1</field>
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="/7@jg.F8b~Z/:y?8M[9
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="toggle" id="bJ9bH}(2Wm~q9LzRD_Nj">
    <field name="OID">sonoff.0.T2_Licht_Esszimmer.POWER2</field>
    </block>
    </statement>
    <value name="IF1">
    <block type="logic_operation" id="iUk{10.nE;.2D5:I.ytr" inline="false">
    <value name="A">
    <block type="on_source" id="3:.Duo69DRgp:fYw}5)G">
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="6dO!TAA^qdbrgzJXhXg4">
    <value name="A">
    <block type="get_value" id="Vn,(UJBMsIil/w)6~rMk">
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="-K)tTaiBRH%0{6lKIiPx">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO1">
    <block type="toggle" id="r2m}E~{3^j(yQe?a7ldD">
    </block>
    </statement>
    </block>
    </statement>
    <next>
    <block type="comment" id=")W(XRelQPFAKVgN}~.Wk">
    <field name="COMMENT">Schalter_Esszimmer</field>
    <next>
    <block type="on_ext" id="(,jQ%[M{b3hvfYjfS``">
    <value name="OID0">
    <shadow type="field_oid" id="?QKwMzNq}Hxx-]]qF0Du">
    <field name="oid">sonoff.0.T2_Licht_Esszimmer.POWER2</field>
    </shadow>
    </value>
    <block type="controls_if" id="[[:VFdkVsFd_Oe1YVNM$">
    <value name="IF0">
    <block type="logic_operation" id="xiw9/tUrHsjD^,9#k/c)" inline="false">
    <value name="A">
    <block type="on_source" id="bFycJMH@bpq5[c;S|kE,">
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="unXz-MOp%8L?:F#WM.iq">
    <value name="A">
    <block type="get_value" id="WXRZH1l$+6gr^0mZ8Y93">
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="P^F~J205VrKo$N=Y9~">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <block type="toggle" id="Dp@{[/Dsd7c,)T-(v|)T">
    </block>
    </statement>
    <value name="IF1">
    <block type="logic_operation" id="u0r_cDJj];wyzz./j1!x" inline="false">
    <value name="A">
    <block type="on_source" id="QjL93SgJilwgs]-}
    X4"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_compare" id="^*0[l^Oe3[L;MIP|MU=3"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="aM;tl~-XR|n*x({oo#*j"> <field name="ATTR">val</field> <field name="OID">sonoff.0.T2_Licht_Esszimmer.POWER2</field> </block> </value> <value name="B"> <block type="logic_boolean" id="k([n(K:Pep;{t1]B|1-9"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO1"> <block type="toggle" id="5Cu+[iqdqikdq5`FJEM">
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </xml>
    CinimodC Offline
    CinimodC Offline
    Cinimod
    @ingenii
    wenn ich es mir recht überlege hätte mein script doch funktionieren müssen, du hast es nur nicht richtig nachgebaut ..
    das ist jetzt fix und fertig mit deinen Objekten bestückt ...
    teste gern mal dies :
      <block type="comment" id="P*;A,KQ(tX3;?;KS_6UG" x="-137" y="-562">
        <next>
            <value name="OID0">
              </shadow>
            </value>
                <value name="IF0">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="/7@jg.F8b~Z/:y?8M[9">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="toggle" id="N/=),G}Hun?n#|gnY3nk">
                  </block>
                </statement>
                <value name="IF1">
                    <value name="A">
                      <block type="logic_negate" id="21KS;K_v%@}C5@ayps|Q">
                        <value name="BOOL">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="toggle" id="kkW2~OE5Xf~2]+nM8miV">
                  </block>
                </statement>
              </block>
            </statement>
            <next>
                <next>
                    <value name="OID0">
                      </shadow>
                    </value>
                        <value name="IF0">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="toggle" id="lE2).nG};iUc[Qphg25f">
                          </block>
                        </statement>
                        <value name="IF1">
                            <value name="A">
                              <block type="logic_negate" id="B]z!|)u#9me:N`|@XSLm">
                                <value name="BOOL">
                                  <block type="on_source" id="QjL93SgJilwgs]-}X4">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="toggle" id="Gzm]x99(-Zw@foDqM^[?">
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    I 1 Antwort Letzte Antwort
    • CinimodC Cinimod
      @ingenii sagte in Blocky script:
      @cinimod
      Du bitte kein Stress.
      hab noch eine bitte wen du dann zeit hast.
      Hab wand Termostat Homematic, un ich will die ACTUAL_TEMPERATURE mit SET_POINT_TEMPERATURE abfragen und ein sonoff schalten.
      Meine Idee ist hier aber es funktioniert nicht:
      zu diesem brauch ich noch ein paar infos .... was soll passieren ? die Objekte oben sind alles tür/fenster kontakte ? die sollen bei jeder aktualisierung "Temperatur_Wohnzimmer" ausschalten ?
      I Offline
      I Offline
      ingenii
      schrieb am zuletzt editiert von ingenii
      @cinimod
      das obere teil sind Fenster Kontakten, das funktioniert bei anderem Script richtig.
      Ich will abfragen :setpointtemp.JPG
      mit:
      wen das unten aktual temp ist sollte dieser sonoff schalten mit wahr und bei höhere false
      • CinimodC Cinimod
        @ingenii
            <next>
                <value name="OID0">
                  </shadow>
                </value>
                    <value name="IF0">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      </block>
                    </statement>
                    <value name="IF1">
                        <value name="A">
                            <value name="BOOL">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      </block>
                    </statement>
                  </block>
                </statement>
                <next>
                    <next>
                        <value name="OID0">
                          </shadow>
                        </value>
                            <value name="IF0">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                              </block>
                            </statement>
                            <value name="IF1">
                                <value name="A">
                                    <value name="BOOL">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </xml>
        I Offline
        I Offline
        ingenii
        Super es funktioniert
        Vielen dank :)
        • I ingenii
          @cinimod
          mit:
          CinimodC Offline
          CinimodC Offline
          Cinimod
          @ingenii
          im Moment ist es aber so das sich bei jeder Änderung, bzw. sogar bei jeder Aktualisierung einer der Fensterkontakte das Gerät abschaltet. Das ist doch bestimmt nicht so gewollt. Ich vermute du willst wenn eines der Fenster offen ist soll das Gerät abschalten ja ? und wieder einschalten beim schließen ?
          willst mir den Code auch mal geben ? dieses mal in nem Code tag !?
          Müsste dann noch wissen ob der Wert true oder false ist wenn Fenster offen ?
          • CinimodC Cinimod
            @ingenii
            I Offline
            I Offline
            ingenii
            @cinimod
            ja mit Fenster Kontakten hab ich ein Fehler gehabt.
            fenster contakt ist 0 oder 1 deswegen ist das so in trigger
              <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn" x="-153" y="-781">
                <mutation xmlns="http://www.w3.org/1999/xhtml" items="5"></mutation>
                <field name="CONDITION">gt</field>
                <value name="OID0">
                  <shadow type="field_oid" id="g^#UD(O)#46O[YL/yhiu">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                  </shadow>
                </value>
                <value name="OID1">
                  <shadow type="field_oid" id="GR{OtJXvaxmJ/8frKVV5">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                  </shadow>
                </value>
                <value name="OID2">
                  <shadow type="field_oid" id="AaDu2IdLTc;_8Y^(=#1u">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                  </shadow>
                </value>
                <value name="OID3">
                  <shadow type="field_oid" id="gz?y}5:(-k]7M;_c)L@c">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                  </shadow>
                </value>
                <value name="OID4">
                  <shadow type="field_oid" id="f,#bPavRADQa!^9vgT;r">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                  </shadow>
                </value>
                  <block type="control" id="hS]=O?t$f/y`yv?xV.9v">
                    <field name="OID">sonoff.0.Temparature_wohnzimmer(TH10).POWER</field>
                    <value name="VALUE">
                      <block type="logic_boolean" id="@WvR96o@/GT_W,v[-k@;">
                      </block>
                    </value>
                  </block>
                </statement>
                <next>
                  <block type="on" id=".}/Q;u9LGC~UU*IR%fTl">
                    <field name="OID">hm-rpc.1.000E9D8993AF70.1.ACTUAL_TEMPERATURE</field>
                      <block type="controls_if" id="^IQpxvAC2OFS~7?Wb54p">
                        <value name="IF0">
                          <block type="logic_compare" id="4p}TwGI0SFOr*TCj$w{^">
                            <field name="OP">LTE</field>
                            <value name="A">
                              <block type="field_oid" id="(5(fmcDYXK=ZD(JjqoVC">
                                <field name="oid">hm-rpc.1.000E9D8993AF70.1.ACTUAL_TEMPERATURE</field>
                              </block>
                            </value>
                            <value name="B">
                              <block type="field_oid" id="}pxcBnko$#pIW37~ZyI+">
                                <field name="oid">hm-rpc.1.000E9D8993AF70.1.SET_POINT_TEMPERATURE</field>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="toggle" id="{/tEBaR7oRvyEvkE[^*1">
                          </block>
                        </statement>
                        <value name="IF1">
                          <block type="logic_compare" id="r*KEn=z,[kyIxuL5}P;p">
                            <value name="A">
                              <block type="field_oid" id="SJp4x+Q.G?cX]Oc6Ik,5">
                              </block>
                            </value>
                            <value name="B">
                              <block type="field_oid" id="1^:mkFciSEdEvK(u_vhn">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="toggle" id="LGOcO[jG=eA:0/(dG^^t">
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </xml>```
            • I ingenii
              @cinimod
                  <value name="OID0">
                    </shadow>
                  </value>
                  <value name="OID1">
                    </shadow>
                  </value>
                  <value name="OID2">
                    </shadow>
                  </value>
                  <value name="OID3">
                    </shadow>
                  </value>
                  <value name="OID4">
                    </shadow>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                  <next>
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                            </block>
                          </statement>
                          <value name="IF1">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                            </block>
                          </statement>
                        </block>
                      </statement>
                    </block>
                  </next>
                </block>
              </xml>```
              CinimodC Offline
              CinimodC Offline
              Cinimod
              @ingenii
              ist 0 dann zu oder auf ?
              Hab schon gesehen, hast den trigger geändert.
              Soll aber das geschlossene Fenster das Gerät wieder einschalten ? Falls "actual" kleiner als "set point".
              Die beiden trigger hebeln sich aktuell etwas aus.
              wenn du ein Fenster öffnest geht das gerät aus, aber sobald sich "ist Temperatur" wieder ändert macht er Gerät wieder an, das ist nicht sinnvoll.
              • CinimodC Offline
                CinimodC Offline
                Cinimod
                jetzt aber :
                Hier der Code:
                 <variables>
                   <variable id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</variable>
                 </variables>
                 <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn" x="-87" y="-1038">
                   <value name="OID0">
                     </shadow>
                   </value>
                   <value name="OID1">
                     </shadow>
                   </value>
                   <value name="OID2">
                     </shadow>
                   </value>
                   <value name="OID3">
                     </shadow>
                   </value>
                   <value name="OID4">
                     </shadow>
                   </value>
                     <block type="controls_if" id="zr))xYp5q6uk7gWR:FLp">
                       <value name="IF0">
                         <block type="logic_compare" id="(%ip:yl;!KUbNeYJO=Q.">
                           <value name="A">
                             <block type="on_source" id="IQvqF`Ea*52V%WOo$(BG">
                             </block>
                           </value>
                           <value name="B">
                             <block type="math_number" id="YaM59`_}h-7w]wlp%rz]">
                               <field name="NUM">1</field>
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                           <next>
                             <block type="variables_set" id="]qW3c_5Vo7}]mwMJaX]u">
                               <field name="VAR" id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</field>
                                 <block type="logic_boolean" id="%|=KaL92,D:1}t?+_kh@">
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                       <value name="IF1">
                         <block type="logic_operation" id="NI74tl{Cv%y2nnZ2mq(_" inline="false">
                           <value name="A">
                             <block type="logic_operation" id="nBhW:|6IjFd#]:==r9MT" inline="false">
                               <value name="A">
                                 <block type="logic_operation" id="TzDrBAgL)l{6h%e)Nbix" inline="false">
                                   <value name="A">
                                     <block type="logic_compare" id="H-by~#=i7qLd];I!ss,u">
                                       <value name="A">
                                         <block type="get_value" id="G{e*#Ck_W4)[t!9NfppK">
                                           <field name="OID">ID auswählen</field>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="tV{:u[3b2[XI5;6o#uwv">
                                           <field name="NUM">0</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_compare" id="(Bj)7ZJ(0pgXXEA`sjl4">
                                       <value name="A">
                                         <block type="get_value" id="CN}w9(9wU2-hnR|}zN~M">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="qxF?+P?(5WT4+Zh~VDzH">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_operation" id="iAW5jBZ|80_MVv0zs#04" inline="false">
                                   <value name="A">
                                     <block type="logic_compare" id="=FJ$#)NF)p%K+ci}.G+{">
                                       <value name="A">
                                         <block type="get_value" id="b0E:[G*)^Jkwfko9)-UG">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="y@6zGn;xb0N/DCub4E+j">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_compare" id="7uPMqgWG]Q790FDLTidp">
                                       <value name="A">
                                         <block type="get_value" id="5o;cwewhu(gE!B3`kDDT">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="]T=$eX#l;JqAc9b,Y}+*">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_compare" id="(OQ76rw~]R]9Q_P/kA`V">
                               <value name="A">
                                 <block type="get_value" id="R-*;=g!1Qh_#Zl_G0VM4">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id="aeH:*7-Gn3!c~HF5au^!">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                         <block type="variables_set" id="ceR.;izW_r3Ty20RG_EX">
                             <block type="logic_boolean" id="D=!E,]q}FEHKUapa+q=2">
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </statement>
                   <next>
                           <value name="IF0">
                             <block type="logic_operation" id="=,{!f,Bw@+IW)fgy6X!," inline="false">
                               <value name="A">
                                 <block type="logic_compare" id="wv?fv3Sv#4)xrUA!h,;d">
                                   <field name="OP">LT</field>
                                   <value name="A">
                                     <block type="field_oid" id="Lq8qjAp2+9`o!gUlT+bp">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="field_oid" id="tF5CWW~t~IicQF.9T@Yb">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_negate" id="g0]-Go:bzYX?[3gMBj,7">
                                   <value name="BOOL">
                                     <block type="variables_get" id=":vB%}8-l)m2uIW$kGmf^">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="control" id="BCFn=IlgKqu+C@xy)z`p">
                                 <block type="logic_boolean" id="CjsW,Fb567aTJf@*m@?U">
                                 </block>
                               </value>
                             </block>
                           </statement>
                           <value name="IF1">
                               <field name="OP">GTE</field>
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="control" id="@*N1BGqFp,k14kZ$emx]">
                                 <block type="logic_boolean" id="knxl8#k^UDaS0z/qJVoA">
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
                 <block type="comment" id="%(@z6|4~ph%BgD-,,|to" x="613" y="-688">
                   <field name="COMMENT">hier alle Fensterkontakte eintragan</field>
                 </block>
                </xml>
                • I Offline
                  I Offline
                  ingenii
                  @cinimod
                  Script macht nichts.
                  • CinimodC Offline
                    CinimodC Offline
                    Cinimod
                    @ingenii
                    Hast du es direkt von mir kopiert, oder hast du es nachgebaut? Die Fenster Objekte hast du eingetragen? Sind die Fenster geschlossen 0 oder 1 ?
                    Habe es jetzt so gebaut das das Gerät nur eingeschaltet wird wenn alle Fenster zu sind. Du hast nicht wirklich darauf geantwortet ob das so in deinem Sinn war !?
                    • CinimodC Cinimod
                      @ingenii
                      I Offline
                      I Offline
                      ingenii
                      @cinimod
                      ich hab das am nachmmitag kopiert sensoren reinkopiert gestartet a er hat nichst gemacht .Fenster hab ich probiert aufmachen und zumachem, kein unterschied(Sensoren sind jetzt ale auf 0) Ich komme dan jetzt zu PC und script hat in zwischen zeit mein test sonoff auf wahr geschaltet. aber wen ich jetzt umstelle gewunschte temperatur pasiert nicht mehrt.
                        <variables>
                        </variables>
                          <value name="OID0">
                            </shadow>
                          </value>
                          <value name="OID1">
                            </shadow>
                          </value>
                          <value name="OID2">
                            </shadow>
                          </value>
                          <value name="OID3">
                            </shadow>
                          </value>
                          <value name="OID4">
                            </shadow>
                          </value>
                              <value name="IF0">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                    </block>
                                  </value>
                                  <next>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                              <value name="IF1">
                                  <value name="A">
                                      <value name="A">
                                          <value name="A">
                                              <value name="A">
                                                  <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                              <value name="A">
                                                  <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                          <value name="A">
                                              <value name="A">
                                                  <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                              <value name="A">
                                                  <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="B">
                                      <value name="A">
                                          <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </statement>
                          <next>
                                  <value name="IF0">
                                      <value name="A">
                                          <value name="A">
                                            </block>
                                          </value>
                                          <value name="B">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                          <value name="BOOL">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <value name="IF1">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </xml>
                      • I ingenii
                        @cinimod
                          <variables>
                          </variables>
                            <value name="OID0">
                              </shadow>
                            </value>
                            <value name="OID1">
                              </shadow>
                            </value>
                            <value name="OID2">
                              </shadow>
                            </value>
                            <value name="OID3">
                              </shadow>
                            </value>
                            <value name="OID4">
                              </shadow>
                            </value>
                                <value name="IF0">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                      </block>
                                    </value>
                                    <next>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                                <value name="IF1">
                                    <value name="A">
                                        <value name="A">
                                            <value name="A">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                            <value name="A">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                            <next>
                                    <value name="IF0">
                                        <value name="A">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                            <value name="BOOL">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                    <value name="IF1">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </xml>
                        I Offline
                        I Offline
                        ingenii
                        @ingenii
                        Wen ich setzte temp auf 5 grad ich sehe ein befehl in sonoff :
                        ich glaub es ist sicher nur was umgekehrt
                        • I ingenii
                          @ingenii
                          I Offline
                          I Offline
                          ingenii
                          @ingenii
                          wen ich von wurde geändert auf wurde aktualisiert stelle um das es ist egal was ich bei Termostat umstelle Script sende nur ON
                          • I ingenii
                            @ingenii
                            CinimodC Offline
                            CinimodC Offline
                            Cinimod
                            @ingenii
                            Mir ist gerade aufgefallen, du hast immer ObjektID unten benutzt ... da muss überall "wert von objektID" rein.
                            es ist ja aktuell so das das der trigger immer nur auslöst wenn der ISTWERT sich ändert, dann pack den sollwert auch in den trigger, und stell diesen wieder auf geändert !! dann sollte er auch prüfen wenn der sollwert sich ändert 😉
                            I 2 Antworten Letzte Antwort
                            • CinimodC Cinimod
                              @ingenii
                              I Offline
                              I Offline
                              ingenii
                              @cinimod
                              dein hinwies ist richtig, Danke
                              aber dieser trigger wen ich was am termostat endere mach nur bis Steuere TH10 auf Wahr, er kommt nicht weiter.Eine frage: gibt das ein sin wen für jeder wahr oder falsh ist extra trigger?
                                <variables>
                                </variables>
                                  <value name="OID0">
                                    </shadow>
                                  </value>
                                  <value name="OID1">
                                    </shadow>
                                  </value>
                                  <value name="OID2">
                                    </shadow>
                                  </value>
                                  <value name="OID3">
                                    </shadow>
                                  </value>
                                  <value name="OID4">
                                    </shadow>
                                  </value>
                                      <value name="IF0">
                                          <value name="A">
                                            </block>
                                          </value>
                                          <value name="B">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                      <value name="IF1">
                                          <value name="A">
                                              <value name="A">
                                                  <value name="A">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="A">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
                                      <value name="OID0">
                                        <shadow type="field_oid" id="S5Ja?RFgi-amy%b3nasc">
                                        </shadow>
                                      </value>
                                      <value name="OID1">
                                        <shadow type="field_oid" id=",x^o!!V53@cT%;x8@hr]">
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="BOOL">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <field name="OP">GT</field>
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </xml>
                              CinimodC 2 Antworten Letzte Antwort
                              • CinimodC Cinimod
                                @ingenii
                                I Offline
                                I Offline
                                ingenii
                                @cinimod
                                Ich bin bl....
                                jetzt ist das ok.
                                • I ingenii
                                  @cinimod
                                    <variables>
                                    </variables>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                      <value name="OID1">
                                        </shadow>
                                      </value>
                                      <value name="OID2">
                                        </shadow>
                                      </value>
                                      <value name="OID3">
                                        </shadow>
                                      </value>
                                      <value name="OID4">
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <value name="A">
                                                  <value name="A">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                      <next>
                                          <value name="OID0">
                                            </shadow>
                                          </value>
                                          <value name="OID1">
                                            </shadow>
                                          </value>
                                              <value name="IF0">
                                                  <value name="A">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="BOOL">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <value name="IF1">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </xml>
                                  CinimodC Offline
                                  CinimodC Offline
                                  Cinimod
                                  @ingenii
                                  wenn er TH10 wahr steuert ist er doch durch gelaufen.
                                  Du hast den Sollwert verändert und er prüft dann ob der Istwert kleiner als der sollwert ist ... wenn das so ist macht er TH10 wahr. Ist doch genau was er tun soll ! oder hattest du was anderes im sinn ?
                                  dann musst du etwas genauer erklären was du willst, und vielleicht auch fürs bessere Verständnis was er da einschaltet, dann kann man sich ggf. besser ein Bild machen.
                                  • I ingenii
                                    @cinimod
                                      <variables>
                                      </variables>
                                        <value name="OID0">
                                          </shadow>
                                        </value>
                                        <value name="OID1">
                                          </shadow>
                                        </value>
                                        <value name="OID2">
                                          </shadow>
                                        </value>
                                        <value name="OID3">
                                          </shadow>
                                        </value>
                                        <value name="OID4">
                                          </shadow>
                                        </value>
                                            <value name="IF0">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                  </block>
                                                </value>
                                                <next>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                            <value name="IF1">
                                                <value name="A">
                                                    <value name="A">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                        <next>
                                            <value name="OID0">
                                              </shadow>
                                            </value>
                                            <value name="OID1">
                                              </shadow>
                                            </value>
                                                <value name="IF0">
                                                    <value name="A">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="BOOL">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </xml>
                                    CinimodC Offline
                                    CinimodC Offline
                                    Cinimod
                                    @cinimod
                                    Nein
                                    • CinimodC Cinimod
                                      @cinimod
                                      Nein
                                      I Offline
                                      I Offline
                                      ingenii
                                      @cinimod
                                      Wie ich schon geschrieben hab jetzt ist das Gut.
                                      Jetzt muss ich noch was anderes ausprobieren.
                                      ich hab 3 räume und ich muss leider nur ein Realei schalten das heitzung startet.
                                      ich hab 3 Termostaten und 3 verschiedene Temperatur.
                                      Wen 1 Raum (Termostat sagt du musst heizen schalte das Relais an das mir die andere räume das gleiche Relais auf Flash setzten und das geht in so ein loop.
                                      • I ingenii
                                        @cinimod
                                        CinimodC Offline
                                        CinimodC Offline
                                        Cinimod
                                        @ingenii
                                        Erstell dir für jeden Raum einen Datenpunkt, statt dem TH10 Schaltetst du diesen Datanpunkt true/false (ein script für jeden Raum).
                                        Dann noch ein weiters Skript welche die drei Datenpunkte überwacht, und das Relais schaltet wenn mindestens einer der drei Datenpunkte wahr ist, sonst false
                                        • CinimodC Cinimod
                                          @ingenii
                                          I Offline
                                          I Offline
                                          ingenii
                                          @cinimod
                                          Dantenpunkte hab ich, das hab ich schon gelernt, für Script brauche ich bisschen zeit .Danke für dein zeit.
