  5. Blocky script
Blocky script
86 Beiträge 6 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • I ingenii
    @cinimod said in Blocky script:
    nem code tag </>
    ich hoffe du meinst das:
    <block type="comment" id="P*;A,KQ(tX3;?;KS_6UG" x="163" y="-562">
    <field name="COMMENT">Schalter_Wohnzimmer</field>
    <next>
    <block type="on_ext" id="Sz;+_7H0(F[ov}Ci4Cb">
    <value name="OID0">
    <shadow type="field_oid" id="M+,9mrkPy(Z-}QTxV#3"> <field name="oid">sonoff.0.T3_Wohn_Ess_Licht.POWER1</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="~$tqKw0v!N/dA)!Ho[?w"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_operation" id="dqm-1)9tfpy,n1k4R6Fh" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="on_source" id="[dk0f8)1NzVSrDL2E:t">
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="v^)!{Wp4W+}hJOYw_T0U">
    <field name="OP">EQ</field>
    <value name="A">
    <block type="get_value" id="dL@U7KuLNxkLxO]RWOyy">
    <field name="OID">sonoff.0.T3_Wohn_Ess_Licht.POWER1</field>
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="/7@jg.F8b~Z/:y?8M[9
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="toggle" id="bJ9bH}(2Wm~q9LzRD_Nj">
    <field name="OID">sonoff.0.T2_Licht_Esszimmer.POWER2</field>
    </block>
    </statement>
    <value name="IF1">
    <block type="logic_operation" id="iUk{10.nE;.2D5:I.ytr" inline="false">
    <value name="A">
    <block type="on_source" id="3:.Duo69DRgp:fYw}5)G">
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="6dO!TAA^qdbrgzJXhXg4">
    <value name="A">
    <block type="get_value" id="Vn,(UJBMsIil/w)6~rMk">
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="-K)tTaiBRH%0{6lKIiPx">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO1">
    <block type="toggle" id="r2m}E~{3^j(yQe?a7ldD">
    </block>
    </statement>
    </block>
    </statement>
    <next>
    <block type="comment" id=")W(XRelQPFAKVgN}~.Wk">
    <field name="COMMENT">Schalter_Esszimmer</field>
    <next>
    <block type="on_ext" id="(,jQ%[M{b3hvfYjfS``">
    <value name="OID0">
    <shadow type="field_oid" id="?QKwMzNq}Hxx-]]qF0Du">
    <field name="oid">sonoff.0.T2_Licht_Esszimmer.POWER2</field>
    </shadow>
    </value>
    <block type="controls_if" id="[[:VFdkVsFd_Oe1YVNM$">
    <value name="IF0">
    <block type="logic_operation" id="xiw9/tUrHsjD^,9#k/c)" inline="false">
    <value name="A">
    <block type="on_source" id="bFycJMH@bpq5[c;S|kE,">
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="unXz-MOp%8L?:F#WM.iq">
    <value name="A">
    <block type="get_value" id="WXRZH1l$+6gr^0mZ8Y93">
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="P^F~J205VrKo$N=Y9~">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <block type="toggle" id="Dp@{[/Dsd7c,)T-(v|)T">
    </block>
    </statement>
    <value name="IF1">
    <block type="logic_operation" id="u0r_cDJj];wyzz./j1!x" inline="false">
    <value name="A">
    <block type="on_source" id="QjL93SgJilwgs]-}
    X4"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_compare" id="^*0[l^Oe3[L;MIP|MU=3"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="aM;tl~-XR|n*x({oo#*j"> <field name="ATTR">val</field> <field name="OID">sonoff.0.T2_Licht_Esszimmer.POWER2</field> </block> </value> <value name="B"> <block type="logic_boolean" id="k([n(K:Pep;{t1]B|1-9"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO1"> <block type="toggle" id="5Cu+[iqdqikdq5`FJEM">
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </xml>
    CinimodC Offline
    CinimodC Offline
    Cinimod
    @ingenii
    Hier jetzt der geänderte Code, habe dir Markiert welche Objekte du noch setzen musst. Einfach den ganzen Code importieren in dein Skript und alles andere löschen.
      <block type="comment" id="P*;A,KQ(tX3;?;KS_6UG" x="-137" y="-562">
        <next>
            <value name="OID0">
              </shadow>
            </value>
                <value name="IF0">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="/7@jg.F8b~Z/:y?8M[9">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="comment" id="$z[0qyCGmyGurpdGPJSV">
                    <field name="COMMENT">objekt_Schalter_Esszimmer</field>
                    <next>
                      <block type="control" id="X3!T(--(aVU`39kJ?2Gs">
                        <value name="VALUE">
                          <block type="logic_boolean" id="DjK:xaj:hIbT$CvbNDfn">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF1">
                    <value name="A">
                      <block type="logic_negate" id="21KS;K_v%@}C5@ayps|Q">
                        <value name="BOOL">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="comment" id="iz|=lS`D.v^/:XJTJ])!">
                    <next>
                      <block type="control" id="2VYsMV}9l`Xm/AwKNv!|">
                          <block type="logic_boolean" id="GHDD6$ep4~((%AP-Uv6s">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
            <next>
                <next>
                    <value name="OID0">
                      </shadow>
                    </value>
                        <value name="IF0">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="comment" id="CUBEmL,@A*0qmYY`;M?S">
                            <field name="COMMENT">objekt_Schalter_Wohn_Esszimmer</field>
                            <next>
                              <block type="control" id="Uy/iuVj2((bFMLfXAwv}">
                                  <block type="logic_boolean" id="u2~EkyE1rb(]M^YLx(i-">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                        <value name="IF1">
                            <value name="A">
                              <block type="logic_negate" id="B]z!|)u#9me:N`|@XSLm">
                                <value name="BOOL">
                                  <block type="on_source" id="QjL93SgJilwgs]-}X4">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="comment" id="{L@Q.%tH1}pRZg15sOYb">
                            <next>
                              <block type="control" id="l8]#i{OGW(+lM.,*0wbm">
                                  <block type="logic_boolean" id="yVl?wf[T7pzc_|41xDk]">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    • I ingenii
      @cinimod
      Du bitte kein Stress.
      hab noch eine bitte wen du dann zeit hast.
      Hab wand Termostat Homematic, un ich will die ACTUAL_TEMPERATURE mit SET_POINT_TEMPERATURE abfragen und ein sonoff schalten.
      Meine Idee ist hier aber es funktioniert nicht:
      CinimodC Offline
      CinimodC Offline
      Cinimod
      @ingenii sagte in Blocky script:
      @cinimod
      zu diesem brauch ich noch ein paar infos .... was soll passieren ? die Objekte oben sind alles tür/fenster kontakte ? die sollen bei jeder aktualisierung "Temperatur_Wohnzimmer" ausschalten ?
      I 2 Antworten Letzte Antwort
      • I ingenii
        nem code tag </>
        <next>
        <value name="OID0">
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </xml>
        CinimodC Offline
        CinimodC Offline
        Cinimod
        @ingenii
        wenn ich es mir recht überlege hätte mein script doch funktionieren müssen, du hast es nur nicht richtig nachgebaut ..
        das ist jetzt fix und fertig mit deinen Objekten bestückt ...
        teste gern mal dies :
            <next>
                <value name="OID0">
                  </shadow>
                </value>
                    <value name="IF0">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="toggle" id="N/=),G}Hun?n#|gnY3nk">
                      </block>
                    </statement>
                    <value name="IF1">
                        <value name="A">
                            <value name="BOOL">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="toggle" id="kkW2~OE5Xf~2]+nM8miV">
                      </block>
                    </statement>
                  </block>
                </statement>
                <next>
                    <next>
                        <value name="OID0">
                          </shadow>
                        </value>
                            <value name="IF0">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="toggle" id="lE2).nG};iUc[Qphg25f">
                              </block>
                            </statement>
                            <value name="IF1">
                                <value name="A">
                                    <value name="BOOL">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="toggle" id="Gzm]x99(-Zw@foDqM^[?">
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </xml>
        I 1 Antwort Letzte Antwort
        • CinimodC Cinimod
          @cinimod
          I Offline
          I Offline
          ingenii
          schrieb am zuletzt editiert von ingenii
          @cinimod
          das obere teil sind Fenster Kontakten, das funktioniert bei anderem Script richtig.
          Ich will abfragen :setpointtemp.JPG
          mit:
          wen das unten aktual temp ist sollte dieser sonoff schalten mit wahr und bei höhere false
          • CinimodC Cinimod
            @ingenii
                <next>
                    <value name="OID0">
                      </shadow>
                    </value>
                        <value name="IF0">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                          </block>
                        </statement>
                        <value name="IF1">
                            <value name="A">
                                <value name="BOOL">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                          </block>
                        </statement>
                      </block>
                    </statement>
                    <next>
                        <next>
                            <value name="OID0">
                              </shadow>
                            </value>
                                <value name="IF0">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  </block>
                                </statement>
                                <value name="IF1">
                                    <value name="A">
                                        <value name="BOOL">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </xml>
            I Offline
            I Offline
            ingenii
            Super es funktioniert
            Vielen dank :)
            • I ingenii
              @cinimod
              mit:
              CinimodC Offline
              CinimodC Offline
              Cinimod
              @ingenii
              im Moment ist es aber so das sich bei jeder Änderung, bzw. sogar bei jeder Aktualisierung einer der Fensterkontakte das Gerät abschaltet. Das ist doch bestimmt nicht so gewollt. Ich vermute du willst wenn eines der Fenster offen ist soll das Gerät abschalten ja ? und wieder einschalten beim schließen ?
              willst mir den Code auch mal geben ? dieses mal in nem Code tag !?
              Müsste dann noch wissen ob der Wert true oder false ist wenn Fenster offen ?
              • CinimodC Cinimod
                @ingenii
                I Offline
                I Offline
                ingenii
                @cinimod
                ja mit Fenster Kontakten hab ich ein Fehler gehabt.
                fenster contakt ist 0 oder 1 deswegen ist das so in trigger
                  <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn" x="-153" y="-781">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" items="5"></mutation>
                    <field name="CONDITION">gt</field>
                    <value name="OID0">
                      <shadow type="field_oid" id="g^#UD(O)#46O[YL/yhiu">
                        <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                      </shadow>
                    </value>
                    <value name="OID1">
                      <shadow type="field_oid" id="GR{OtJXvaxmJ/8frKVV5">
                        <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                      </shadow>
                    </value>
                    <value name="OID2">
                      <shadow type="field_oid" id="AaDu2IdLTc;_8Y^(=#1u">
                        <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                      </shadow>
                    </value>
                    <value name="OID3">
                      <shadow type="field_oid" id="gz?y}5:(-k]7M;_c)L@c">
                        <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                      </shadow>
                    </value>
                    <value name="OID4">
                      <shadow type="field_oid" id="f,#bPavRADQa!^9vgT;r">
                        <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                      </shadow>
                    </value>
                      <block type="control" id="hS]=O?t$f/y`yv?xV.9v">
                        <field name="OID">sonoff.0.Temparature_wohnzimmer(TH10).POWER</field>
                          <block type="logic_boolean" id="@WvR96o@/GT_W,v[-k@;">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <next>
                      <block type="on" id=".}/Q;u9LGC~UU*IR%fTl">
                        <field name="OID">hm-rpc.1.000E9D8993AF70.1.ACTUAL_TEMPERATURE</field>
                          <block type="controls_if" id="^IQpxvAC2OFS~7?Wb54p">
                            <value name="IF0">
                              <block type="logic_compare" id="4p}TwGI0SFOr*TCj$w{^">
                                <field name="OP">LTE</field>
                                <value name="A">
                                  <block type="field_oid" id="(5(fmcDYXK=ZD(JjqoVC">
                                    <field name="oid">hm-rpc.1.000E9D8993AF70.1.ACTUAL_TEMPERATURE</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="field_oid" id="}pxcBnko$#pIW37~ZyI+">
                                    <field name="oid">hm-rpc.1.000E9D8993AF70.1.SET_POINT_TEMPERATURE</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="toggle" id="{/tEBaR7oRvyEvkE[^*1">
                              </block>
                            </statement>
                            <value name="IF1">
                              <block type="logic_compare" id="r*KEn=z,[kyIxuL5}P;p">
                                <value name="A">
                                  <block type="field_oid" id="SJp4x+Q.G?cX]Oc6Ik,5">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="field_oid" id="1^:mkFciSEdEvK(u_vhn">
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="toggle" id="LGOcO[jG=eA:0/(dG^^t">
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </xml>```
                • I ingenii
                  @cinimod
                      <value name="OID0">
                        </shadow>
                      </value>
                      <value name="OID1">
                        </shadow>
                      </value>
                      <value name="OID2">
                        </shadow>
                      </value>
                      <value name="OID3">
                        </shadow>
                      </value>
                      <value name="OID4">
                        </shadow>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <next>
                              <value name="IF0">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                </block>
                              </statement>
                              <value name="IF1">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                </block>
                              </statement>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </xml>```
                  CinimodC Offline
                  CinimodC Offline
                  Cinimod
                  @ingenii
                  ist 0 dann zu oder auf ?
                  Hab schon gesehen, hast den trigger geändert.
                  Soll aber das geschlossene Fenster das Gerät wieder einschalten ? Falls "actual" kleiner als "set point".
                  Die beiden trigger hebeln sich aktuell etwas aus.
                  wenn du ein Fenster öffnest geht das gerät aus, aber sobald sich "ist Temperatur" wieder ändert macht er Gerät wieder an, das ist nicht sinnvoll.
                  • CinimodC Offline
                    CinimodC Offline
                    Cinimod
                    jetzt aber :
                    Hier der Code:
                     <variables>
                       <variable id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</variable>
                     </variables>
                     <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn" x="-87" y="-1038">
                       <value name="OID0">
                         </shadow>
                       </value>
                       <value name="OID1">
                         </shadow>
                       </value>
                       <value name="OID2">
                         </shadow>
                       </value>
                       <value name="OID3">
                         </shadow>
                       </value>
                       <value name="OID4">
                         </shadow>
                       </value>
                         <block type="controls_if" id="zr))xYp5q6uk7gWR:FLp">
                           <value name="IF0">
                             <block type="logic_compare" id="(%ip:yl;!KUbNeYJO=Q.">
                               <value name="A">
                                 <block type="on_source" id="IQvqF`Ea*52V%WOo$(BG">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id="YaM59`_}h-7w]wlp%rz]">
                                   <field name="NUM">1</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="variables_set" id="]qW3c_5Vo7}]mwMJaX]u">
                                   <field name="VAR" id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</field>
                                     <block type="logic_boolean" id="%|=KaL92,D:1}t?+_kh@">
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <value name="IF1">
                             <block type="logic_operation" id="NI74tl{Cv%y2nnZ2mq(_" inline="false">
                               <value name="A">
                                 <block type="logic_operation" id="nBhW:|6IjFd#]:==r9MT" inline="false">
                                   <value name="A">
                                     <block type="logic_operation" id="TzDrBAgL)l{6h%e)Nbix" inline="false">
                                       <value name="A">
                                         <block type="logic_compare" id="H-by~#=i7qLd];I!ss,u">
                                           <value name="A">
                                             <block type="get_value" id="G{e*#Ck_W4)[t!9NfppK">
                                               <field name="OID">ID auswählen</field>
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="tV{:u[3b2[XI5;6o#uwv">
                                               <field name="NUM">0</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_compare" id="(Bj)7ZJ(0pgXXEA`sjl4">
                                           <value name="A">
                                             <block type="get_value" id="CN}w9(9wU2-hnR|}zN~M">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="qxF?+P?(5WT4+Zh~VDzH">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_operation" id="iAW5jBZ|80_MVv0zs#04" inline="false">
                                       <value name="A">
                                         <block type="logic_compare" id="=FJ$#)NF)p%K+ci}.G+{">
                                           <value name="A">
                                             <block type="get_value" id="b0E:[G*)^Jkwfko9)-UG">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="y@6zGn;xb0N/DCub4E+j">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_compare" id="7uPMqgWG]Q790FDLTidp">
                                           <value name="A">
                                             <block type="get_value" id="5o;cwewhu(gE!B3`kDDT">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="]T=$eX#l;JqAc9b,Y}+*">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id="(OQ76rw~]R]9Q_P/kA`V">
                                   <value name="A">
                                     <block type="get_value" id="R-*;=g!1Qh_#Zl_G0VM4">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="aeH:*7-Gn3!c~HF5au^!">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="variables_set" id="ceR.;izW_r3Ty20RG_EX">
                                 <block type="logic_boolean" id="D=!E,]q}FEHKUapa+q=2">
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </statement>
                       <next>
                               <value name="IF0">
                                 <block type="logic_operation" id="=,{!f,Bw@+IW)fgy6X!," inline="false">
                                   <value name="A">
                                     <block type="logic_compare" id="wv?fv3Sv#4)xrUA!h,;d">
                                       <field name="OP">LT</field>
                                       <value name="A">
                                         <block type="field_oid" id="Lq8qjAp2+9`o!gUlT+bp">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="field_oid" id="tF5CWW~t~IicQF.9T@Yb">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_negate" id="g0]-Go:bzYX?[3gMBj,7">
                                       <value name="BOOL">
                                         <block type="variables_get" id=":vB%}8-l)m2uIW$kGmf^">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="control" id="BCFn=IlgKqu+C@xy)z`p">
                                     <block type="logic_boolean" id="CjsW,Fb567aTJf@*m@?U">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                               <value name="IF1">
                                   <field name="OP">GTE</field>
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="control" id="@*N1BGqFp,k14kZ$emx]">
                                     <block type="logic_boolean" id="knxl8#k^UDaS0z/qJVoA">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                     <block type="comment" id="%(@z6|4~ph%BgD-,,|to" x="613" y="-688">
                       <field name="COMMENT">hier alle Fensterkontakte eintragan</field>
                     </block>
                    </xml>
                    • I Offline
                      I Offline
                      ingenii
                      @cinimod
                      Script macht nichts.
                      • CinimodC Offline
                        CinimodC Offline
                        Cinimod
                        @ingenii
                        Hast du es direkt von mir kopiert, oder hast du es nachgebaut? Die Fenster Objekte hast du eingetragen? Sind die Fenster geschlossen 0 oder 1 ?
                        Habe es jetzt so gebaut das das Gerät nur eingeschaltet wird wenn alle Fenster zu sind. Du hast nicht wirklich darauf geantwortet ob das so in deinem Sinn war !?
                        • CinimodC Cinimod
                          @ingenii
                          I Offline
                          I Offline
                          ingenii
                          @cinimod
                          ich hab das am nachmmitag kopiert sensoren reinkopiert gestartet a er hat nichst gemacht .Fenster hab ich probiert aufmachen und zumachem, kein unterschied(Sensoren sind jetzt ale auf 0) Ich komme dan jetzt zu PC und script hat in zwischen zeit mein test sonoff auf wahr geschaltet. aber wen ich jetzt umstelle gewunschte temperatur pasiert nicht mehrt.
                            <variables>
                            </variables>
                              <value name="OID0">
                                </shadow>
                              </value>
                              <value name="OID1">
                                </shadow>
                              </value>
                              <value name="OID2">
                                </shadow>
                              </value>
                              <value name="OID3">
                                </shadow>
                              </value>
                              <value name="OID4">
                                </shadow>
                              </value>
                                  <value name="IF0">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                      <next>
                                            </block>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                  <value name="IF1">
                                      <value name="A">
                                          <value name="A">
                                              <value name="A">
                                                  <value name="A">
                                                      <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="A">
                                                      <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                              <value name="A">
                                                  <value name="A">
                                                      <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="A">
                                                      <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                          <value name="A">
                                              <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                                            </block>
                                          </value>
                                          <value name="B">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                              <next>
                                      <value name="IF0">
                                          <value name="A">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                              <value name="BOOL">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                      <value name="IF1">
                                          <value name="A">
                                            </block>
                                          </value>
                                          <value name="B">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                </block>
                              </next>
                            </block>
                          </xml>
                          • I ingenii
                            @cinimod
                              <variables>
                              </variables>
                                <value name="OID0">
                                  </shadow>
                                </value>
                                <value name="OID1">
                                  </shadow>
                                </value>
                                <value name="OID2">
                                  </shadow>
                                </value>
                                <value name="OID3">
                                  </shadow>
                                </value>
                                <value name="OID4">
                                  </shadow>
                                </value>
                                    <value name="IF0">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                        <next>
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                    <value name="IF1">
                                        <value name="A">
                                            <value name="A">
                                                <value name="A">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                                <value name="A">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                  </block>
                                </statement>
                                <next>
                                        <value name="IF0">
                                            <value name="A">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                                <value name="BOOL">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <value name="IF1">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                      </block>
                                    </statement>
                                  </block>
                                </next>
                              </block>
                            </xml>
                            I Offline
                            I Offline
                            ingenii
                            @ingenii
                            Wen ich setzte temp auf 5 grad ich sehe ein befehl in sonoff :
                            ich glaub es ist sicher nur was umgekehrt
                            • I ingenii
                              @ingenii
                              I Offline
                              I Offline
                              ingenii
                              @ingenii
                              wen ich von wurde geändert auf wurde aktualisiert stelle um das es ist egal was ich bei Termostat umstelle Script sende nur ON
                              • I ingenii
                                @ingenii
                                CinimodC Offline
                                CinimodC Offline
                                Cinimod
                                @ingenii
                                Mir ist gerade aufgefallen, du hast immer ObjektID unten benutzt ... da muss überall "wert von objektID" rein.
                                es ist ja aktuell so das das der trigger immer nur auslöst wenn der ISTWERT sich ändert, dann pack den sollwert auch in den trigger, und stell diesen wieder auf geändert !! dann sollte er auch prüfen wenn der sollwert sich ändert 😉
                                • CinimodC Cinimod
                                  @ingenii
                                  I Offline
                                  I Offline
                                  ingenii
                                  @cinimod
                                  dein hinwies ist richtig, Danke
                                  aber dieser trigger wen ich was am termostat endere mach nur bis Steuere TH10 auf Wahr, er kommt nicht weiter.Eine frage: gibt das ein sin wen für jeder wahr oder falsh ist extra trigger?
                                    <variables>
                                    </variables>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                      <value name="OID1">
                                        </shadow>
                                      </value>
                                      <value name="OID2">
                                        </shadow>
                                      </value>
                                      <value name="OID3">
                                        </shadow>
                                      </value>
                                      <value name="OID4">
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <value name="A">
                                                  <value name="A">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                      <next>
                                        <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;">
                                          <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
                                          <value name="OID0">
                                            <shadow type="field_oid" id="S5Ja?RFgi-amy%b3nasc">
                                            </shadow>
                                          </value>
                                          <value name="OID1">
                                            <shadow type="field_oid" id=",x^o!!V53@cT%;x8@hr]">
                                            </shadow>
                                          </value>
                                              <value name="IF0">
                                                  <value name="A">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="BOOL">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <value name="IF1">
                                                  <field name="OP">GT</field>
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </xml>
                                  CinimodC 2 Antworten Letzte Antwort
                                  • CinimodC Cinimod
                                    @ingenii
                                    I Offline
                                    I Offline
                                    ingenii
                                    @cinimod
                                    Ich bin bl....
                                    jetzt ist das ok.
                                    • I ingenii
                                      @cinimod
                                        <variables>
                                        </variables>
                                          <value name="OID0">
                                            </shadow>
                                          </value>
                                          <value name="OID1">
                                            </shadow>
                                          </value>
                                          <value name="OID2">
                                            </shadow>
                                          </value>
                                          <value name="OID3">
                                            </shadow>
                                          </value>
                                          <value name="OID4">
                                            </shadow>
                                          </value>
                                              <value name="IF0">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                              <value name="IF1">
                                                  <value name="A">
                                                      <value name="A">
                                                          <value name="A">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                          <next>
                                              <value name="OID0">
                                                </shadow>
                                              </value>
                                              <value name="OID1">
                                                </shadow>
                                              </value>
                                                  <value name="IF0">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="BOOL">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <value name="IF1">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </xml>
                                      CinimodC Offline
                                      CinimodC Offline
                                      Cinimod
                                      @ingenii
                                      wenn er TH10 wahr steuert ist er doch durch gelaufen.
                                      Du hast den Sollwert verändert und er prüft dann ob der Istwert kleiner als der sollwert ist ... wenn das so ist macht er TH10 wahr. Ist doch genau was er tun soll ! oder hattest du was anderes im sinn ?
                                      dann musst du etwas genauer erklären was du willst, und vielleicht auch fürs bessere Verständnis was er da einschaltet, dann kann man sich ggf. besser ein Bild machen.
                                      • I ingenii
                                        @cinimod
                                          <variables>
                                          </variables>
                                            <value name="OID0">
                                              </shadow>
                                            </value>
                                            <value name="OID1">
                                              </shadow>
                                            </value>
                                            <value name="OID2">
                                              </shadow>
                                            </value>
                                            <value name="OID3">
                                              </shadow>
                                            </value>
                                            <value name="OID4">
                                              </shadow>
                                            </value>
                                                <value name="IF0">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                    <value name="A">
                                                        <value name="A">
                                                            <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </statement>
                                            <next>
                                                <value name="OID0">
                                                  </shadow>
                                                </value>
                                                <value name="OID1">
                                                  </shadow>
                                                </value>
                                                    <value name="IF0">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="BOOL">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                    <value name="IF1">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </xml>
                                        CinimodC Offline
                                        CinimodC Offline
                                        Cinimod
                                        @cinimod
                                        Nein
                                        • CinimodC Cinimod
                                          @cinimod
                                          Nein
                                          I Offline
                                          I Offline
                                          ingenii
                                          @cinimod
                                          Wie ich schon geschrieben hab jetzt ist das Gut.
                                          Jetzt muss ich noch was anderes ausprobieren.
                                          ich hab 3 räume und ich muss leider nur ein Realei schalten das heitzung startet.
                                          ich hab 3 Termostaten und 3 verschiedene Temperatur.
                                          Wen 1 Raum (Termostat sagt du musst heizen schalte das Relais an das mir die andere räume das gleiche Relais auf Flash setzten und das geht in so ein loop.
