5.8k Beiträge 156 Kommentatoren 4.7m Aufrufe 137 Beobachtet
  • Rene55R Rene55
    @SBorg Ich habe gerade mal die Wetterstatistik bei mir angepasst und eingebaut.
    Hier bekomme ich dann folgende Meldungen:
    javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.Rekordwerte" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.Jahreswerte" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.Control" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.VorTag" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.608	info	State value to set for "0_userdata.0.Wetterstatistik.Data" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.608	info	State value to set for "0_userdata.0.Wetterstatistik.Vorjahres_Monat" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.608	info	State value to set for "0_userdata.0.Wetterstatistik.aktueller_Monat" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.533	info	State value to set for "0_userdata.0.Wetterstatistik" has to be type "folder" but received type "string"
    javascript.0	2021-10-03 17:08:58.433	warn	This object will not be created in future versions. Please report this to the developer.
    javascript.0	2021-10-03 17:08:58.433	warn	Object 0_userdata.0.Wetterstatistik.Rekordwerte is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    javascript.0	2021-10-03 17:08:58.433	warn	Object 0_userdata.0.Wetterstatistik.Jahreswerte is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    javascript.0	2021-10-03 17:08:58.431	warn	This object will not be created in future versions. Please report this to the developer.
    javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.Control is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.VorTag is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.Data is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.Vorjahres_Monat is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.aktueller_Monat is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    javascript.0	2021-10-03 17:08:58.430	warn	Object 0_userdata.0.Wetterstatistik is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
    Ist das so OK oder gibt es da Irritationen mit den Typen der DPs?
    LG Rainer
    SBorgS Offline
    SBorgS Offline
    SBorg
    #2967
    @rene55 Antwort auf beide Posts ;) :
    zum 1. Da stimmt so einiges an der Zuordnung der Datenpunkte nicht. Sieht aber dann beim 2. Post Ok aus :)
    Hattest du nicht auch schon öfters Probleme mit Influx/Grafana?
    btw @all: geht bitte nicht davon aus, dass ich mich immer an alles erinnere oder speziell auch zuordnen kann wer, was, wieso, warum....
    Meine "grauen Zellen" werden allmählich wirklich grau und bei der Menge an Posts, Chats, Emails, Issues ... verliere ich den Überblick. Bei einer Anfrage "...du erinnerst dich..." muss ich, ohne jemand zu Nahe treten zu wollen, öfters auch mal mit "Nein" antworten. Es ist einfach zu viel. Wenn ich also mal was verwechsele oder nicht mehr weiß, Sorry, keine Absicht :)
    LG SBorg ( SBorg auf GitHub)
    • NegaleinN Negalein
      @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      Falls nicht bitte melden, sind ggf. nur wenige Zeilen.
      bei mir steht es still :(
      beim Start dieses Scripts von @liv-in-sky kommt nun
      00:14:32.040	error	javascript.0 (31206) script.js.Wetter.Wettertabelle: SyntaxError: Unexpected token o in JSON at position 1
      00:14:32.040	error	javascript.0 (31206) at script.js.Wetter.Wettertabelle:53:17
      00:14:32.040	error	javascript.0 (31206) at dataStuff (script.js.Wetter.Wettertabelle:49:15)
      00:14:32.040	error	javascript.0 (31206) at main (script.js.Wetter.Wettertabelle:149:4)
      SBorgS Offline
      SBorgS Offline
      SBorg
      #2968
      + @all liv-in-sky Skript-Nutzer:
      Ändere mal so um Zeile ~#53 ab:
      let helper=JSON.parse(getState(id).val);
      in
      //let helper=JSON.parse(getState(id).val);
      let helper=getState(id).val[0];
      also Originalzeile auskommentieren und dafür die neue einfügen. Danach sollte es wieder laufen.
      • L Langer
        root@pi-slave:/home/iobroker# dir
        wetterstation.conf wetterstation.sh wetterstation.sub ws_updater.sh
        Ich hoffe das hast Du gemeint?
        MfG
        Wastl
        #2969
        @langer
        Du springst da ja immer noch als root rum.
        Log dich aus und als Standarduser wieder an.
        ls -l /home/iobroker
        • da_WoodyD da_Woody
          Mir gings nur um das aussehen.
          schau in den spiegel, dann weist du, das ist nebensächlich...
          SBorgS Offline
          SBorgS Offline
          SBorg
          #2970
          @da_woody sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          Jeden Morgen...
          "Ich kenn dich zwar nicht, wasch dich aber trotzdem..." 😀
          • SBorgS SBorg
            in
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #2971
            Merci
            läuft wieder :)
            ° Fixer ---> iob fix
            • Rene55R Offline
              Rene55R Offline
              Rene55
              #2972
              @SBorg Danke für die Antwort. Probleme mit Influx/Grafana hatte ich eigentlich noch keine, oder sind mir nicht aufgefallen. Die Fehlermeldung aus dem ersten Post hatte ich ja auch nur einmal beim ersten Start des Scripts V1.0.0. Und da ja in dem Lgeintrag drin stand "Please report this to the developer." dachte ich mir, das sollte der Entwickler mal beäugen. Wenns nur bei mir auftrat ist es auch nicht weiter wichtig - es läuft ja alles.
              LG Rainer
                liv-in-skyL Offline
                liv-in-skyL Offline
                #2973
                @negalein
                da wurden wohl die states geändert - da kann das script nicht von allein drauf kommen, dass sich da was geändert hat
                @SBorg - ich denk, deine änderung müßte so passen - wenn du das array - 0 - element einliest, sollten die daten wieder wie vorher verarbeitet werden 👍
                NegaleinN SBorgS 2 Antworten Letzte Antwort
                • liv-in-skyL liv-in-sky
                  @negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #2974
                  @liv-in-sky sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                  Jepp, passt wieder :)
                    @negalein
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #2975
                    @liv-in-sky Mehr Zwangsweise, da der "neue" JSC mehr oder minder JSON nun als Array + Object vorschreibt. Von meiner Seite aus ändere ich nur sehr, sehr ungern etwas im laufenden Betrieb noch an States etc.
                    Da das hier im Thread wohl auch untergeht, magst du eine Änderung in deinem Skript hinzufügen, dass ab >=V1.0.0 Version xyz deines Skriptes zu nutzen ist :) 👍
                    • SBorgS SBorg
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #2976
                      @sborg
                      ich überlege gerade, ob man nicht einen teil einfügt, der überprüft, ob ein array oder pure json drinsteht - evtl umwandelt und dann weitermacht
                      muss das mal näher anschauen - dann bräuchten die user auch die alten dp nicht von hand konvertieren
                      • Rene55R Rene55
                        LG Rainer
                        SBorgS Offline
                        SBorgS Offline
                        SBorg
                        #2977
                        @rene55 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                        Siehste, verwechselt... ;)
                        ...wobei die Fehlermeldung nicht schlüssig ist. Wenn aber jetzt Ruhe ist und auch alles läuft --> dann "gut" so, nachvollziehen kann ich es eh nicht
                          @sborg
                          SBorgS Offline
                          SBorgS Offline
                          SBorg
                          #2978
                          Doch, da ich die auch am 01. des Monats wieder einlese (sonst muss ich immer etliche Datenbankabfragen und Auswertungen fahren die unnötig sind, denn zu dem entsprechenden Monat [wie bspw. aktuell Oktober 2020] liegen die Daten ja vor) und da es ein Array sein soll, schreibe ich das nun auch als Array. Ich kam zwar auch auf den Gedanken, um aber da spätere Inkompatibilitäten (zB. Nutzung in der VIS, Bindings...) zu vermeiden, bin ich dafür nur ein Format zu haben. Schlimmstenfalls 13 DPs zu ändern geht ja auch fix.
                          • SBorgS SBorg
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #2979
                            @sborg
                            hat sich erledigt
                            • SBorgS SBorg
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #2980
                              @sborg
                              script ist upgedated und läuft für jede dp-version
                              dem script ist es jetzt egal, was da drin steht - wenn es ein object ist, nimmt es das object - ist es ein string - wie früher - nimmt es einen string
                              https://forum.iobroker.net/topic/38286/vis-tabelle-für-wlan-wetterstation
                              • L Langer
                                MfG
                                Wastl
                                SBorgS Offline
                                SBorgS Offline
                                SBorg
                                #2981
                                @langer Ich nehme an durch den "bösen" root stimmen die Userrechte so nicht mehr.
                                Eigentlich sollte es so aussehen (bei mir läuft es unter User/Gruppe sborg )
                                wobei "wetterstation.js" uninteressant ist und bei der "sh" -rwxr--r-- völlig genügt, außer man arbeitet wirklich mit Gruppen.
                                Auch wenn es nerven mag, als User arbeiten und bei ev. nötigen Rechten halt ein "sudo" davor.
                                  @sborg
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #2982
                                  habs getestet, wirft aber Fehler aus.
                                  12:12:36.575	error	javascript.0 (31206) script.js.Wetter.Wettertabelle: SyntaxError: Unexpected token ] in JSON at position 0
                                  12:12:36.575	error	javascript.0 (31206) at script.js.Wetter.Wettertabelle:56:83
                                  12:12:36.576	error	javascript.0 (31206) at dataStuff (script.js.Wetter.Wettertabelle:50:15)
                                  12:12:36.576	error	javascript.0 (31206) at main (script.js.Wetter.Wettertabelle:153:4)
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #2983
                                    @negalein
                                    ich habe 3 werte umgewandelt mit [..] und als object type "object" statt "string" im raw geändert
                                    läuft bei mir
                                    hast du das in object umwandeln gemacht ?
                                      @negalein
                                      läuft bei mir
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #2984
                                      Ja, schon gestern
                                      So schaut das Script jetzt aus.
                                      Eventuell siehst du einen copy/paste Fehler.
                                      // @liv-in-sky 4.10.2021 11:45
                                      //forum: https://forum.iobroker.net/topic/38286/vis-tabelle-f%C3%BCr-wlan-wetterstation
                                      const dataInputPath="0_userdata.0.Statistik.Wetter.Data";  //SEHR WICHTIG !!!!!!!!!
                                      const inhaltFarbe="black"
                                      const inhaltHintergrund="lightgray"
                                      const monatFarbe="black"
                                      const hintergrund="gray"
                                      const htmlFarbTableBorderColor="black";
                                      const abstandZelle=6;
                                      const htmlRahmenLinien="all"
                                      const htmlSchriftgroessehtmlSchriftart=""  //nicht verwendbar!
                                      const htmlFarbFelderschrift="red";         //nicht verwendbar!
                                      const htmlSchriftgroesse="14px";
                                      const htmlSchriftart="Ubuntu-Light"//"RobotoCondensed-Regular";       //oder z.b. "Helvetica"
                                      const weite="auto";                        //oder "500px"
                                      let myTable="table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                           "; font-family:"+htmlSchriftart+";\"";
                                      const varData={  Tiefstwert:       { einheit:"°C", name:"Minimum Temperatur"},
                                                     Hoechstwert:      { einheit:"°C", name:"Maximum Temperatur"},
                                                     Temp_Durchschnitt:{ einheit:"°C", name:"Durchschnittstemperatur"},
                                                     Max_Windboe:      { einheit:'km/h', name:"Max Windböe"},
                                                     Max_Regenmenge:   { einheit:'l/m2', name:"Max. Regen/Tag"},
                                                     Regenmenge_Monat: { einheit:'l/m2', name:"Regen"},
                                                     heisse_Tage:      { einheit:"", name:'Heiße Tage (über 30°C)'},
                                                     Sommertage:       { einheit:"", name:"Sommertage (über 25°C)"},
                                                     warme_Tage:       { einheit:"", name:"Warme Tage (über 20°C)"},
                                                     kalte_Tage:       { einheit:"", name:"Kalte Tage (Max. unter 10°C)"},
                                                     Frost_Tage:       { einheit:"", name:"Frosttage (Min. unter 0°C)"},
                                                     Eistage:          { einheit:"", name:"Eistage (Max. unter 0°C)"},
                                                     sehr_kalte_Tage:  { einheit:"", name:"Sehr kalte Tage (Min. unter -10°C)"}
                                      const monate =["JANUAR","FEBRUAR","MÄRZ","APRIL","MAI","JUNI","JULI","AUGUST","SEPTEMBER","OKTOBER","NOVEMBER","DEZEMBER"];
                                      //--------------------------nix mehr ändern ab hier--------------------------------------
                                      let myObj;
                                      let myArrAll=[]
                                      let myArrErstellt=[]
                                      let tableContent;
                                      let monWahlVIS;
                                      let lastThree;
                                      function dataStuff(){
                                      let myArrAll=[]
                                      let mySelector=dataInputPath+'.*.*'
                                      $(mySelector).each(function(id, i) {
                                      let ida=id.split("."); let lang=ida.length; let jahri=lang-2; let moni=lang-1;
                                      let obj2 = { jahr: ida[jahri]};
                                      let obj3 = { monat: ida[moni]};
                                      let formathelp= getState(id).val
                                      let helper;
                                      if (typeof(formathelp)=="object") {helper=getState(id).val[0];}  else{helper=JSON.parse(getState(id).val)}
                                      helper={ ...helper, ...obj2, ...obj3}
                                      myArrAll.push(JSON.stringify(helper))
                                      //log(myArrAll)
                                      tableContent = ""
                                      myObj=JSON.parse("["+myArrAll.toString()+"]")
                                      if (lastThree==0) {
                                      //KOPFZEILE
                                      let choseMonth=monate[monWahlVIS-1]
                                      let choseMonthArr=choseMonth.split('')
                                      let test=""
                                      for (let i=0;i<choseMonthArr.length;i++){
                                        // log(choseMonthArr[i])
                                         test=test+choseMonthArr[i]+`
                                      //log(test)
                                      //tableContent+='<td  class=\"test-klein\"  rowspan=\"14\"\">'+choseMonth+'</td><td>Wetterwerte</td>'
                                      tableContent+='<td class=\"myWetterStation\" width=\"25px\"  style=\"color:'+monatFarbe+';font-size:26px; background-color:'+hintergrund+' ; vertical-align:middle; text-align:center \"   rowspan=\"14\"\">'+test+'</td><td style=\"color:'+monatFarbe+'; background-color:'+hintergrund+'"\>Wetterwerte</td>'
                                      for (let i=0;i<myObj.length;i++) {
                                         if(parseInt(myObj[i].monat)==monWahlVIS){
                                      tableContent += '<td style=\"color:'+monatFarbe+'; background-color:'+hintergrund+'"\ align=center>'  + myObj[i].jahr+'</td>'}
                                      }; tableContent="<tr style=\"font-weight\:bold\">"+tableContent+"</tr>"
                                      //RESTZEILEN
                                      for(var index in varData){
                                         tableContent+='<td style=\"color:'+inhaltFarbe+'; background-color:'+inhaltHintergrund+'\">'+varData[index].name+'</td>'
                                            if(myObj[i].monat==monWahlVIS){
                                              tableContent += '<td style=\"color:'+inhaltFarbe+'; background-color:'+inhaltHintergrund+'\" align=right>' + myObj[i][index] + ' '+ varData[index].einheit+'</td>'}
        }; tableContent="<tr>"+tableContent+"</tr>"
                                      } //lastThree
                                      else {
                                      //log(myObj[0].monat)
                                          myObj.sort(function (alpha, beta) {
                                                   if (parseInt(alpha.monat) > parseInt(beta.monat))
                                                       return 1;
                                                    if (parseInt(beta.monat) > parseInt(alpha.monat))
                                                       return -1;
                                                    return 0;});
                                                //    log(myObj[0].monat)
                                      //KOPFZEILE LASTTHREE
                                      let choseJahr=lastThree.toString()//formatDate(getDateObject((new Date().getTime())), "JJJJ")//monate[monWahlVIS-1]
                                      let choseMonthArr=choseJahr.split('')
                                      let test=""
                                      //log(test)
                                         if( parseInt(myObj[i].jahr)==parseInt(choseJahr) && (parseInt(myObj[i].monat)==parseInt(monWahlVIS) || parseInt(myObj[i].monat)==parseInt(monWahlVIS)-1 || parseInt(myObj[i].monat)==parseInt(monWahlVIS)-2)){
                                      tableContent += '<td style=\"color:'+monatFarbe+'; background-color:'+hintergrund+'"\ align=center>'  + monate[parseInt(myObj[i].monat)-1]+'</td>';}
                                      //RESTZEILEN
                                      tableContent = '<'+myTable+' ><tbody>'+tableContent+'</tbody></table >'
                                      //log(tableContent)
                                      setState("javascript." + instance + ".Wetterstation.MonthlyDaten",tableContent)
                                      async function main() {
                                         if (!(await existsStateAsync("javascript." + instance + ".Wetterstation.MonthlyDaten"))) {
                                             await createStateAsync("Wetterstation.MonthlyDaten", "leer", {type: "string", name: "MonthlyDaten", role: "value", read: true, write: true, } ); }
                                         if (!(await existsStateAsync("javascript." + instance + ".Wetterstation.MonatAuswahl"))) {
                                             await createStateAsync("Wetterstation.MonatAuswahl", 10, {type: "number", name: "MonatAuswahl", role: "value", read: true, write: true, } ); }
                                         if (!(await existsStateAsync("javascript." + instance + ".Wetterstation.AuswahlJahr"))) {
                                             await createStateAsync("Wetterstation.AuswahlJahr", 0, {type: "number", name: "AuswahlJahr", role: "value", read: true, write: true, } ); }
                                         lastThree = (await getStateAsync("javascript." + instance + ".Wetterstation.AuswahlJahr")).val //? lastThree=true : lastThree=false;
                                         monWahlVIS=((await getStateAsync("javascript." + instance + ".Wetterstation.MonatAuswahl")).val )
                                         dataStuff();
                                      main()
                                      on({id: "javascript." + instance + ".Wetterstation.MonatAuswahl", change: "any"}, async function (obj) {
                                      main()
                                      on({id: "javascript." + instance + ".Wetterstation.AuswahlJahr", change: "any"}, async function (obj) {
                                      main()
                                      schedule('  */30 * * * *', function() {
                                         setState("javascript." + instance + ".Wetterstation.MonatAuswahl", parseInt(formatDate(getDateObject((new Date().getTime())), "MM"))) ;
                                         setStateDelayed("javascript." + instance + ".Wetterstation.AuswahlJahr", parseInt(formatDate(getDateObject((new Date().getTime())), "JJJJ")),10000) ;
                                        @negalein
                                        läuft bei mir
                                        SBorgS Offline
                                        SBorgS Offline
                                        SBorg
                                        #2985
                                        läuft bei mir
                                        Sorry @Negalein , lüppt bei mir auch.
                                        Hast du ev. aus Versehen bei einem der Datenpunkte ein [ oder ] zu wenig/viel?
                                        • SBorgS SBorg
                                          läuft bei mir
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #2986
                                          @liv-in-sky @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                          Haaaa, tatsächlich.
                                          Hatte 1x in der 1. Zeile [ mit ] vertauscht.
                                          Kleiner Fehler-----große Auswirkung
                                          PS: schon Bier gekauft ;)
