  4. kein Zugriff über Port 8081 auf admin
    1.0k
    6.1k
39 Beiträge 3 Kommentatoren 3.0k Aufrufe 1 Beobachtet
  • L lustig29
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
    Adapter    "backitup"      : 2.1.17   , installed 2.1.17
    Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
    Adapter    "deconz"        : 1.3.19   , installed 1.3.19
    Adapter    "device-reminder": 1.2.9   , installed 1.2.9
    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
    Adapter    "fakeroku"      : 0.2.1    , installed 0.2.1
    Adapter    "fb-checkpresence": 1.1.8   , installed 1.1.8
    Adapter    "ham"           : 4.0.2    , installed 4.0.2
    Adapter    "harmony"       : 1.2.2    , installed 1.2.2
    Adapter    "heatingcontrol": 2.5.1    , installed 2.5.1
    Adapter    "hmip"          : 1.13.1   , installed 1.13.1
    Adapter    "homepilot"     : 1.0.3    , installed 1.1.6
    Adapter    "hs100"         : 2.0.6    , installed 2.0.6
    Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "iot"           : 1.8.22   , installed 1.8.22
    Adapter    "jarvis"        : 2.2.1    , installed 2.2.1
    Adapter    "javascript"    : 5.2.8    , installed 5.2.8
    Controller "js-controller" : 3.3.18   , installed 3.3.18
    Adapter    "lovelace"      : 2.0.4    , installed 2.0.4
    Adapter    "material"      : 1.0.4    , installed 1.0.4
    Adapter    "mihome-vacuum" : 3.2.2    , installed 3.2.2
    Adapter    "onvif"         : 0.4.4    , installed 0.4.4
    Adapter    "scenes"        : 2.3.6    , installed 2.3.6
    Adapter    "shuttercontrol": 1.2.1    , installed 1.2.1
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "sonos"         : 2.1.1    , installed 2.1.1
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
    Adapter    "tuya"          : 3.6.9    , installed 3.6.9
    Adapter    "tvprogram"     : 1.1.0    , installed 1.1.0
    Adapter    "vis"           : 1.4.3    , installed 1.4.3
    Adapter    "web"           : 3.4.7    , installed 3.4.7
    Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
    @lustig29 iobroker list instances
    L 1 Antwort Letzte Antwort
      lustig29
      @homoran said in WEB admin nicht erreichbar:
      + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 192.168.0.85 (SSL), r        un as: admin
      + instance is alive
      • L lustig29
        + instance is alive
        @lustig29 entweder deine Karte gibt gerade den Geist auf oder/und du hast dir die interne Datenbank zerschossen.
        such mal nach "mini howto" und gehe das durch.
        mit etwas Glück kannst du deine Installation fixen.
        Ansonsten neue Karte nehmen, Neuinstallation und Backup einspielen
          lustig29
          @homoran Mit dem Port 8089 komme ich drauf
          • L lustig29
            @lustig29 sagte in WEB admin nicht erreichbar:
            hast du das gesamte mini HowTo durchgearbeitet und die Datenbanken restauriert?
            Steht da was von 8089?
              lustig29
              @homoran Ja, habe ich. Aber ohne Erfolg. Habe dann eine Anleitung mit dem anderen Port gefunden. So bin ich wenigstens wieder drauf gekommen. Backup eingespielt und jetzt läuft es wieder.
              Also fast😐 Jetzt steht meine Node.js auf 14.18, wie kann ich sie auf 12.22.6 aktualisieren?
              • L lustig29
                @lustig29
                Für node schau in meine Signatur.
                  @lustig29
                  lustig29
                  schrieb am zuletzt editiert von lustig29
                  pi@raspberrypi:/opt/iobroker $ sudo apt update
                  OK:1 http://archive.raspberrypi.org/debian buster InRelease
                  OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:3 https://phoscon.de/apt/deconz buster InRelease
                  Ign:4 https://deb.nodesource.com/node_12.22.6 buster InRelease
                  Fehl:5 https://deb.nodesource.com/node_12.22.6 buster Release
                    404  Not Found [IP: 2a02:26f0:2c::216:f288 443]
                  • L lustig29
                    @lustig29
                    Das Repo ist falsch. Da gehören keine vollständigen Versionsnummern rein.
                    Nur der Zweig.
                    Eine 14.18. fängt man sich da aber trotzdem nicht ein, da muss noch was anderes gemacht worden sein, wenn wirklich node14 installiert ist.
                      @lustig29
                      Nur der Zweig.
                      lustig29
                       sudo apt update
                      OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                      Alle Pakete sind aktuell.
                      pi@raspberrypi:/opt/iobroker $ sudo apt upgrade
                      Paketaktualisierung (Upgrade) wird berechnet... Fertig
                      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                      • L lustig29
                         sudo apt update
                        @lustig29 Okay.
                        Und der Check auf korrekte Installation liefert?
                        which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                          @lustig29 Okay.
                          lustig29
                          /usr/bin/nodejs
                          /usr/local/bin/node
                          /usr/local/bin/npm
                          v12.22.6
                          v14.18.0
                          6.14.15
                          OK:2 https://phoscon.de/apt/deconz buster InRelease
                          OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                          OK:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:2 http://archive.raspberrypi.org/debian buster InRelease
                          nodejs:
                            Installiert:           12.22.6-deb-1nodesource1
                            Installationskandidat: 12.22.6-deb-1nodesource1
                            Versionstabelle:
                           *** 12.22.6-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                               10.24.0~dfsg-1~deb10u1 500
                          • L lustig29
                            /usr/bin/nodejs
                            /usr/local/bin/node
                            /usr/local/bin/npm
                            v12.22.6
                            v14.18.0
                            6.14.15
                            nodejs:
                              Versionstabelle:
                            @lustig29
                            Das ist in der Tat falsch.
                              @lustig29
                              lustig29
                              Was kann ich da machen?
                              • L lustig29
                                @lustig29
                                Steht im HowTo drin.
                                • L lustig29
                                  wie das denn?
                                  nur durch den reboot der Fritzbox?
                                  14.18 ist aktueller als 12.22
                                  warum willst du zurück?
                                    wie das denn?
                                    @homoran sagte in WEB admin nicht erreichbar:
                                    Zurück muss man nicht. Aber man sollte es sauber via apt im System haben. Ob jetzt 12 oder 14 ist egal.
                                      lustig29
                                      Wie bekomme ich es denn sauber via Apt ins System?
                                      • L lustig29
                                        @lustig29 HowTo lesen. Insbesondere den zweiten Teil, wo falsche Pfade behandelt werden.
                                          lustig29
                                          Ah, habe ich jetzt gefunden. Aber welchen genauen Pfad muss ich denn da eingeben?
