  4. HTML Liste für Telegram und VIS
58 Beiträge 8 Kommentatoren 9.2k Aufrufe 15 Beobachtet
  • N Nordischerjung
    @liv-in-sky Moin,
    ich hatte iOBroker neu gestartet und nun funktioniert das Script nicht mehr. Hatte ich sonst nie. Hier die Fehlermeldung
    web.0	2021-09-01 11:26:03.794	warn	(15765) State "javascript.0.Tabellen@Liv.MeineToDoListe.toAdd" has no existing object, this might lead to an error in future versions
    javascript.1	2021-09-01 11:25:47.398	info	(13304) script.js.Einkaufsliste: javascript.1.Tabellen@Liv.MeineToDoListe.Spalte0,javascript.1.Tabellen@Liv.MeineToDoListe.Spalte1,javascript.1.Tabellen@Liv.MeineToDoListe.Spalte2,javascript.1.Tabelle
    javascript.1	2021-09-01 11:25:44.395	error	(13304) at processTimers (internal/timers.js:497:7)
    javascript.1	2021-09-01 11:25:44.395	error	(13304) at listOnTimeout (internal/timers.js:554:17)
    javascript.1	2021-09-01 11:25:44.394	error	(13304) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2105:34)
    javascript.1	2021-09-01 11:25:44.394	error	(13304) at Object.<anonymous> (script.js.Einkaufsliste:614:25)
    javascript.1	2021-09-01 11:25:44.394	error	(13304) at writeHTML (script.js.Einkaufsliste:378:21)
    javascript.1	2021-09-01 11:25:44.394	error	(13304) at JSON.parse (<anonymous>)
    javascript.1	2021-09-01 11:25:44.393	error	(13304) Error in callback: SyntaxError: Unexpected end of JSON input
    javascript.1	2021-09-01 11:25:43.846	error	(13304) at processTimers (internal/timers.js:497:7)
    javascript.1	2021-09-01 11:25:43.846	error	(13304) at listOnTimeout (internal/timers.js:554:17)
    javascript.1	2021-09-01 11:25:43.846	error	(13304) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2105:34)
    javascript.1	2021-09-01 11:25:43.846	error	(13304) at Object.<anonymous> (script.js.Einkaufsliste:1306:25)
    javascript.1	2021-09-01 11:25:43.845	error	(13304) at sendToTeleg (script.js.Einkaufsliste:1320:29)
    javascript.1	2021-09-01 11:25:43.845	error	(13304) at JSON.parse (<anonymous>)
    javascript.1	2021-09-01 11:25:43.845	error	(13304) Error in callback: SyntaxError: Unexpected end of JSON input
    Hast du da ne Idee? Das Eintragen, Löschen etc in der VIs funktioniert auch nicht mehr
    liv-in-skyL Offline
    liv-in-skyL Offline
    @nordischerjung
    ich teste gerade . irgendetwas läuft nicht rund
    bei deinem fehler: wie sehen den die datenpunkte aus - falls du keine wichtigendaten in der liste hast, würd ich mal den ganzen ordner (schwarzer pfeil) löschen und das script neu starten - die daten kannst du dir aus dem datenpunkt speichern (grüner pfeil) und später wieder eingeben (nicht in den datenpunkt kopieren)
    ich kann in der vis löschen und anlegen, habe aber ein problem mit dem bot - also in der telegram app ! aber hauptsächlichist telkegram extrem langsam
    lösch mal den ordner und starte das script neu - dann nochmal testen
    • N Nordischerjung
      @liv-in-sky Moin,
      liv-in-skyL Offline
      liv-in-skyL Offline
      @nordischerjung das löschen in der app - also einfach das item anklicken, dauert ewig bei mir
      was du noch machen kannst:
      lösche den markierten bereich im script
      ack: false,
      N 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        ack: false,
        N Offline
        N Offline
        Nordischerjung
        @liv-in-sky so sehen meine DP aus
        und so die Vis
        ich habe da nichts in dem DP stehen
        Gruß Nordischerjung
        sonnige Grüße von der Ostsee
        • N Nordischerjung
          und so die Vis
          liv-in-skyL Offline
          liv-in-skyL Offline
          @nordischerjung anydesk ?
            N Offline
            N Offline
            Nordischerjung
            @liv-in-sky hab ich nicht, auf Handy auch gerade schwer 😀
            Gruß Nordischerjung
            • N Nordischerjung
              liv-in-skyL Offline
              liv-in-skyL Offline
              @nordischerjung also bei mir läuft es jetzt - habe außer das ack-flag nix geändert
              in beide richtungen und so schnell, wie es sein soll
              anydesk kann man runterladen - wenn du zeit hast - melden - im chat ist ja auch meine Tnummer
              wird das script getriggert, wenn du in telegram etwas eingibst? ist der adapter gestartet ?
                N Offline
                N Offline
                Nordischerjung
                @liv-in-sky Moin
                noch mal kurzes feedback, ich habe gestern alle Ordner gelöscht, neu gestartet und siehe da läuft wieder. Sehr komisch aber es geht. Danke schön
                Gruß Nordischerjung
                • N Nordischerjung
                  @liv-in-sky Moin
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @nordischerjung
                  gut - hatte eh keine idee mehr
                    derrapf
                    schrieb am zuletzt editiert von derrapf
                    @liv-in-sky
                    Hallo alle
                    Ich wollte man das Scipt für die Einkaufsliste implementieren. Ich bekomme aber schon beim Abspeichern des Scripts einen Compile-error angezeigt:
                    Was stimmt denn hier nicht? Bei den anderen Usern scheint das Script ja zu laufen.
                    Ich habe mal rumexperimentiert. Es scheint die Variable "path" zu sein an der sich der Compiler stört. Wenn man die umbenennt kommt der Fehler bei const. Wenn man die umbenennt kommt der Fehler bei "let braucheEinFile=false; "..
                    Komisch...
                    Edit:
                    Habe im Log den Fehler gefunden " SyntaxError: Identifier 'path' has already been declared"
                    Und es stimmt. Ich verwende mehrere Script in denen const path = "irgendwas" steht.
                    Wie umgeht man jetz das Problem? Die Variable nicht als Konstanten sondern einfach als var definieren?
                    Gruss Ralf
                      derrapf
                      @derrapf sagte in HTML Liste für Telegram und VIS:
                      Komisch...
                      Ich glaube ich habe den Fehler. Es gab ein Script in common in dem path als Variable definiert war. Das hat dann wohl alles durcheinander gebracht. Jetzt scheint es zu tun.
                      Gruss Ralf
                      • D derrapf
                        Komisch...
                        Gruss Ralf
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @derrapf du solltest das script nicht mit firefox kopieren aus dem forum kopieren - nutze chrome, edge oder opera zum kopieren - der ff fügt beim kopieren massig leerzeilen ein - dann sollte es ohne änderungen laufen
                        ab irgendeiner version kamen da plötzlich diese meldungen - du kannst dir vorstellen, das ich einige scripte habe, die alle die selben settings haben - bisher habe ich - außer die roten "kringel" - keine probleme
                        • D derrapf
                          Komisch...
                          Gruss Ralf
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          Komisch...
                          Gruss Ralf
                          es gibt wahrscheinlich ein problem, wenn die variable in einem script ist, welches unter global liegt
                          probier das mit dem kopieren mit chrome nochmal - dann sollte es auch laufen
                            Komisch...
                            Gruss Ralf
                            derrapf
                            @liv-in-sky
                            OK. Danke für den Tip. Habe tatsächlich FF genutzt.
                            Gruss Ralf
                            B liv-in-skyL 2 Antworten Letzte Antwort
                            • D derrapf
                              @liv-in-sky
                              Gruss Ralf
                              bug77
                              Ich habe das Script auch mal eingefügt und aktiviert.
                              Zusätzlich noch in der VIS die Anzeige.
                              Wenn ich im VIS etwas eintrage , erscheint es in der VIS Liste nach 1-2sek.
                              In telegram verzögern nach 1 Minute.
                              Wenn ich in telegram etwas eintrage, wird es nicht der Liste hinzugefügt, obwohl in der telegram Instanz die Daten empfangen werden.
                              Kennt das jemand, was mache ich falsch?
                              • D derrapf
                                @liv-in-sky
                                Gruss Ralf
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @bug77
                                @derrapf hast du das Problem auch _ Post darüber
                                  @bug77
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @bug77
                                  @derrapf
                                  im ersten post ist ein geändertes script - das sollte besser funktionieren
                                  vergeßt nicht, eure settings zu übernehmen
                                  @bug77 sagte in HTML Liste für Telegram und VIS:
                                  das ist absicht - ich wollte nicht jede änderung einzeln übersenden an telegram - daher verzögert in telegram, wenn man in die vis etwas eingibt
                                    @bug77
                                    @derrapf
                                    saeft_2003
                                    @liv-in-sky
                                    Cooles Skript 👍 lässt sich das auch mit der alexa Einkaufsliste verknüpfen?
                                    • S saeft_2003
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @saeft_2003 für alexa nehme ich das:
                                      da sind alle listen, die man angelegt hat, drin
                                        saeft_2003
                                        @liv-in-sky
                                        Ok Danke das müsste dieses sein, oder?
                                        https://forum.iobroker.net/topic/28254/script-alexa-listen-pflegen-und-anzeigen
                                        • S saeft_2003
                                          @liv-in-sky
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @saeft_2003
                                          ja, dass ganz unten für alle listen
