  4. Test Adapter Weatherunderground v3.1.x
weatherundergroundweatherunderground adapter
43 Beiträge 9 Kommentatoren 5.0k Aufrufe 7 Beobachtet
  • M MartyBr
    @apollon77
    Bei mir wirft der Wunderrground Adapter seit einigen Tagen Fehler aus.
    Habe das Loggin auf debug gestellt:
    weatherunderground.0	2020-02-01 16:08:50.798	info	(8465) Terminated (NO_ERROR): Without reason
    weatherunderground.0	2020-02-01 16:08:48.296	debug	(8465) all forecast values set
    weatherunderground.0	2020-02-01 16:08:48.244	error	(8465) No current observation data found in response
    weatherunderground.0	2020-02-01 16:08:48.018	debug	(8465) get hourly forecast data: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&units=m&language=de&format=json
    weatherunderground.0	2020-02-01 16:08:47.836	debug	(8465) get daily forecast data: https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&language=de&units=m&format=json
    weatherunderground.0	2020-02-01 16:08:47.835	error	(8465) Wunderground reported an error: 204/null
    weatherunderground.0	2020-02-01 16:08:47.494	debug	(8465) get current observation data: https://api.weather.com/v2/pws/observations/current?numericPrecision=decimal&apiKey=6532d6454b8aa370768e63d6ba5a832e&units=m&stationId=IHOHENNE60&format=json
    weatherunderground.0	2020-02-01 16:08:47.494	debug	(8465) Use new API Key 6532d6454b8aa370768e63d6ba5a832e
    weatherunderground.0	2020-02-01 16:08:47.494	debug	(8465) Use New API
    weatherunderground.0	2020-02-01 16:08:47.493	debug	(8465) location has not changed, reuse extracted URLs
    weatherunderground.0	2020-02-01 16:08:47.492	debug	(8465) initialize Hourly Forecast Url: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&units=e&language=en-US&format=json
    weatherunderground.0	2020-02-01 16:08:47.491	debug	(8465) initialize Daily Forecast Url: https://api.weather.com/v3/wx/forecast/daily/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&language=en-US&units=e&format=json
    weatherunderground.0	2020-02-01 16:08:47.489	debug	(8465) initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IHOHENNE60&format=json
    weatherunderground.0	2020-02-01 16:08:47.487	debug	(8465) initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
    weatherunderground.0	2020-02-01 16:08:47.474	debug	(8465) initialize PWS Station Key: d8585d80376a429e
    weatherunderground.0	2020-02-01 16:08:47.431	debug	(8465) init forecast objects
    weatherunderground.0	2020-02-01 16:08:47.429	debug	(8465) init conditions objects
    weatherunderground.0	2020-02-01 16:08:47.427	debug	(8465) on ready: DL true true true true
    weatherunderground.0	2020-02-01 16:08:47.418	info	(8465) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.18.1
    host.iobroker	2020-02-01 16:08:46.472	info	instance system.adapter.weatherunderground.0 started with pid 8465
    Der Key ist okay. Hast du eine Idee?
    MartyBr
    Hier Infos zu meinem System:
    Martin
    Homematic und Homematic IP
    • P Offline
      PrinzEisenherz1
      Die haben was am Server gemacht. Da war nämlich eine Meldung das die API für 3 Tage nicht erreichbar ist.
      Gruß Johnny
      Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
      • P PrinzEisenherz1
        Gruß Johnny
        MartyBr
        @PrinzEisenherz1
        Hallo Johnny, vielen Dank für die Antwort.
        Gruß aus Berlin
        Martin
        Martin
        • integer63I Offline
          integer63I Offline
          integer63
          Nur zur Info (ist wahrscheinlich ein alter Hut): Nach den drei Tagen Maintenance musste ich bei meinem Skript (Hochladen von Daten zu WU) beim Aufruf von curl noch ein -k einfügen, da sich wohl etwas beim SSL Handling geändert hat (to allow curl to perform "insecure" SSL connections and transfers) - danach ging es wieder. Eventuell hat es ja etwas damit zu tun.
          • M MartyBr
            @apollon77
            @MartyBr 204 heißt üblicherweise das keine neuen Daten vorliegen. Und ja es gab die letzten Tagen wohl mehrere Probleme.
            Mal schauen ob danach wieder alles im Eimer ist ... wir werden sehen.
            • integer63I integer63
              @integer63 ja es gab Meldungen in einem anderen Forum das die wohl jetzt ein ungültiges ssl Zertifikat haben whyever.
              • apollon77A apollon77
                MartyBr
                @apollon77 Danke für die Info.
                Martin
                • NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  @apollon77
                  Ist das normal, dass in weatherunderground.0.currentObservationUrl eine andere Station und ApiKey aufscheint, als es im Adapter eingetragen ist? https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IGAMPE3&format=json
                  Meine Station heißt IWERNS10 und nicht IGAMPE3 wie in currentObservationUrl
                  Auch passt der Api-Key von currentObservationUrl nicht mit meinem Key.
                  In weatherunderground.0.forecast.current sind die Werte meiner Station. Das passt.
                  ° Fixer ---> iob fix
                  • NegaleinN Negalein
                    @apollon77
                    @Negalein Ja, die "currentObservation" wird aus der Location (Stadt und so) ermittelt und enthält den "web key". da sind noch weitere URLs und die sind dann teilweise mit dem was du erwartest
                    • crunchipC Offline
                      crunchipC Offline
                      @apollon77 hier stimmt doch irgendwie etwas mit den Zeiten nicht?
                      v3.3.1
                        v3.3.1
                        @crunchip Github issue mit Debug Log bitte
                          crunchipC Offline
                          crunchipC Offline
                          @apollon77 ok mach ich
                          steh da was wichtiges drin zum unkenntlichmachen z.b. key?
                          ,übrigens beim DWD hab ich mal wieder invalid Date drin stehen, siehe https://forum.iobroker.net/post/661744
                            @crunchip Na dann kennste ja das Spiel ;-)
                            PS: hjhjjkdrghp806749ß8uPI/&(
