  4. Grafana unter Docker installieren und Einrichten
    1.5k
grafana
125 Beiträge 16 Kommentatoren 41.8k Aufrufe 12 Beobachtet
  • NegaleinN Negalein
    @Glasfaser
    Ich bekomm Influxdb nicht verbunden.
    Hast du einen Rat für mich?
    influxdb.0	2020-03-07 02:30:41.031	error	(9947) Error: read ECONNRESET
    influxdb.0	2020-03-07 02:30:41.027	info	(9947) Connecting http://10.0.1.22:8086 ...
    influxdb.0	2020-03-07 02:30:34.824	debug	(9947) value not changed fronius.0.inverter.1.PAC, last-value=0, new-value=0, ts=1583544634815
    influxdb.0	2020-03-07 02:30:34.815	debug	(9947) value not changed fronius.0.inverter.1.DAY_ENERGY, last-value=0, new-value=0, ts=1583544634813
    influxdb.0	2020-03-07 02:30:31.026	error	(9947) Error: socket hang up
    influxdb.0	2020-03-07 02:30:31.020	info	(9947) Connecting http://10.0.1.22:8086 ...
    influxdb.0	2020-03-07 02:30:21.021	error	(9947) Error: socket hang up
    influxdb.0	2020-03-07 02:30:21.016	info	(9947) Connecting http://10.0.1.22:8086 ...
    influxdb.0	2020-03-07 02:30:16.869	debug	(9947) value not changed daswetter.0.NextHours.Location_1.Day_1.current.pressure_value, last-value=1009, new-value=1009, ts=1583544616865
    influxdb.0	2020-03-07 02:30:16.858	debug	(9947) value not changed daswetter.0.NextHours.Location_1.Day_1.current.humidity_value, last-value=90, new-value=90, ts=1583544616855
    influxdb.0	2020-03-07 02:30:16.819	debug	(9947) value not changed daswetter.0.NextHours.Location_1.Day_1.current.wind_value, last-value=17, new-value=17, ts=1583544616816
    influxdb.0	2020-03-07 02:30:16.727	debug	(9947) value not changed daswetter.0.NextHours.Location_1.Day_1.current.temp_value, last-value=3, new-value=3, ts=1583544616706
    influxdb.0	2020-03-07 02:30:16.616	debug	(9947) value not changed daswetter.0.NextHours.Location_1.Day_1.Hour_1.temp_value, last-value=3, new-value=3, ts=1583544616612
    influxdb.0	2020-03-07 02:30:11.017	error	(9947) Error: socket hang up
    influxdb.0	2020-03-07 02:30:11.000	info	(9947) Connecting http://10.0.1.22:8086 ...
    Synology_Nega_3 - Synology DiskStation (3).png samuelebistoletti docker-statsd-influxdb-grafana - Docker Hub.png
    Wo muss ich das eingeben, bzw. ist das überhaupt nötig?
    Muss mit diesem Chronograph auch vorher was gemacht werden?
    GlasfaserG
    GlasfaserG
    @Negalein sagte in Grafana unter Docker installieren und Einrichten:
    Schon sehr ..... lange her das ich es eingerichtet habe !
    Vielleicht das .
    Bei mir :
    • Amnesia1211A
      Amnesia1211A
      Amnesia1211
      schrieb am zuletzt editiert von Amnesia1211
      nano /etc/grafana/grafana.ini
      Also ich habe nano so installiert und das klappt auch:
      Quelle hinzufügen
      Quellen zulassen
      nano installieren
      Unter dem Terminal auf erstellen klicken
      Im Terminal eingeben: nano /etc/grafana/grafana.ini
      ini ändern
      Das alles klappt aber auch mit dem anderen Docker Container unter den Umgebungsvariablen.
      Umgebungsvariablen einfügen und einfach den Container starten
      Das einzige was ich nicht hin bekomme ist das Auslagern des Containers 😲
      Man muss nicht alles wissen, nur wissen wo es steht.
      Fragen schadet aber auch nicht :spock-hand:
      NegaleinN GlasfaserG 2 Antworten Letzte Antwort
      • Amnesia1211A Amnesia1211
        Quelle hinzufügen
        Quellen zulassen
        nano installieren
        ini ändern
        NegaleinN
        NegaleinN
        Negalein
        @Amnesia1211 sagte in Grafana unter Docker installieren und Einrichten:
        hab ich auch.
        Funktioniert bei mir nicht.
        ° Fixer ---> iob fix
          Quelle hinzufügen
          Quellen zulassen
          nano installieren
          ini ändern
          GlasfaserG
          GlasfaserG
          @Amnesia1211
          Ich bekomme die inbluxdb und die grafanadb ausgelagert das reicht mir.
          Die garafa.ini ist für mich uninteressant, da sie ja nur einmal eingestellt wir und warum soll ich sie dann auslagern . (( Image von samuelebistoletti mit InfluxDB and Grafana ))
          Ich habe nur die zwei Odner auf der Synology angelegt noch mit den Rechten 0777 versehen , dann die Mout-Pfade im Container eingetragen und Grafana gestartet .
          Amnesia1211A 1 Antwort Letzte Antwort
          • GlasfaserG Glasfaser
            @Amnesia1211
            Amnesia1211A
            Amnesia1211A
            Amnesia1211
            @Glasfaser
            Glaube das mit den Rechten war der Entscheidende tipp, habe mich mit über FTP eingeloggt und die Rechte noch mal vergeben. Jetzt klappt es 👍
            Danke an alle für die super Hilfe !!!
            • S
              S
              stephan2k
              Kann ich mich hier kurz Anschließen mit einer Frage?
              Ich hab grafana auch in Dockers liegen. Durch Änderung der Umgebungsvariablen könnte ich auch Security Allow und Auto Anonymous setzen. Funktioniert.
              Nun wird beim inlineframe immer ein Background von Grafana mitgegeben (#161719), auch wenn ich dort "Transparent" sage.
              Im Netz habe ich gelesen in der HTML von Grafana bzw in der CSS kann man den Wert ändern.
              Pfad: usr\share\grafana\public\views\index.html
              Nun komm ich aber nicht auf das Filesystem von dem Docker Image. Hier benötige ich eure Hilfe.
              Im Terminal kann ich auch keine Eingaben machen
              • S stephan2k
                GlasfaserG
                GlasfaserG
                @stephan2k
                bash
                • D
                  D
                  Deathmeat
                  Für alle die, die immer noch Probleme haben mit der Freigabe bzw. mit dem Zugriff auf die grafana.ini.
                  Ich habe Grafana neu Installiert über den Zugriff per SSH auf die Nas.
                  Diese Befehle habe ich eingegeben:
                  docker run -d \
                    -p 3000:3000 \
                    --name=grafana \
                    -e "GF_INSTALL_PLUGINS=grafana-clock-panel,grafana-simple-json-datasource" \
                    -e "GF_USERS_ALLOW_SIGN_UP=false" \
                    -e "GF_AUTH_ANONYMOUS_ENABLED=true" \
                    -e "GF_AUTH_access enabled=true" \
                    -e "GF_AUTH_org_name=Deine_Firma.com" \
                    -e "GF_SECURITY_ALLOW_EMBEDDING=true" \
                    -e "GF_AUTH_oauth_auto_login=true" \
                    grafana/grafana
                  Damit habe ich es endlich geschafft meine Dashboards an die Iobroker Vis freizugeben.
                  stephan1827S M 2 Antworten Letzte Antwort
                  • D Deathmeat
                    docker run -d \
                      -p 3000:3000 \
                      --name=grafana \
                      grafana/grafana
                    stephan1827S
                    stephan1827S
                    stephan1827
                    Hat das mit den Verzeichnissen irgendjemand hin bekommen. Ich habe einige Container laufen und bei allen funktioniert das mit der Freigabe, nur bei Grafana und influxdb wird einfach nichts gespeichert.
                    • D Deathmeat
                      docker run -d \
                        -p 3000:3000 \
                        --name=grafana \
                        grafana/grafana
                      M
                      M
                      mguenther
                      schrieb am zuletzt editiert von mguenther
                      @deathmeat sagte in Grafana unter Docker installieren und Einrichten:
                      docker run -d \
                        -p 3000:3000 \
                        --name=grafana \
                        grafana/grafana
                      Anfänglich dachte ich, es klappt damit, aber ich muss mich jetzt jedes Mal quasi bei grafana anmelden. Das ist je nciht im Sinne des Erfinders - oder?
                      sudo docker run -d -p 3000:3000 --name="grafana" --net=host -v /volume1/docker/grafana:/var/lib/grafana -v /usr/syno/etc/certificate/system/default:/var/ssl  -e "GF_INSTALL_PLUGINS=grafana-clock-panel,grafana-simple-json-datasource"  -e "GF_USERS_ALLOW_SIGN_UP=false"  -e "GF_AUTH_ANONYMOUS_ENABLED=true"  -e "GF_AUTH_access enabled=true"  -e "GF_AUTH_org_name=Deine_Firma.com"  -e "GF_SECURITY_ALLOW_EMBEDDING=true"  -e "GF_AUTH_oauth_auto_login=true" grafana/grafana
                      Ich hatte vorher mir diese Video angeschaut:
                      https://youtu.be/Q5t7ld2be3k
                      OliverIOO KnallochseK 2 Antworten Letzte Antwort
                      • M mguenther
                        docker run -d \
                          -p 3000:3000 \
                          --name=grafana \
                          grafana/grafana
                        OliverIOO
                        OliverIOO
                        OliverIO
                        @mguenther said in Grafana unter Docker installieren und Einrichten:
                        docker run -d \
                          -p 3000:3000 \
                          --name=grafana \
                          grafana/grafana
                        woher hast du die ganzen environment variablen, die du da angegeben hast?
                        bspw GF_AUTH_access enabled=true
                        ich kann die nirgends finden.
                        https://grafana.com/docs/grafana/latest/installation/docker/
                        ich denke du musst eine konsole in den docker container öffnen und dann in der ini-datei die Einstellung dort ändern
                        https://github.com/grafana/grafana/blob/10a942aad0498e9e9d4530d008751941bfec6511/conf/defaults.ini#L298
                        Meine Adapter und Widgets
                        Links im Profil
                        • M mguenther
                          docker run -d \
                            -p 3000:3000 \
                            --name=grafana \
                            grafana/grafana
                          KnallochseK
                          KnallochseK
                          Knallochse
                          @mguenther ich denke dir fehlt folgende Umgebungsvariable
                          GF_PANELS_DISABLE_SANITIZE_HTML=true
                          und
                          Kann ich ebenfalls nicht nachvollziehen.
                          • KnallochseK Knallochse
                            und
                            M
                            M
                            mguenther
                            @knallochse
                            habe ich von 2 Beiträgen über meinem von @Deathmeat übernommen
                            • OliverIOO OliverIO
                              docker run -d \
                                -p 3000:3000 \
                                --name=grafana \
                                grafana/grafana
                              M
                              M
                              mguenther
                              @oliverio
                              das klappt nur nicht so - lies mal diesen Thread von oben nach unten - da haben alle, die das grafana image nehmen keine Möglichkeit auf die Konsole zu kommen. Oder gibts da inzwischen nen workaround?
                              • M mguenther
                                @oliverio
                                OliverIOO
                                OliverIOO
                                OliverIO
                                @mguenther
                                ich mach das so:
                                zuerst die containerid des laufenden containers rausfinden
                                sudo docker container ls
                                dann folgenden Befehl mit eingesetzter container id ausführen
                                sudo docker exec -it 34f2dee181bf bash
                                am geänderten prompt merkst du, das du dann im container bist. raus kommst du mit exit
                                die änderungen an der ini-datei bleiben natürlich auch nur erhalten, wenn sie auf einer volume liegt.
                                https://grafana.com/docs/grafana/latest/administration/configure-docker/#save-your-grafana-data
                                mittlerweile nutze ich allerdings portainer, da ist es noch viel komfortabler und die konsole lässt sich mit klick direkt im browser öffnen
                                falls tools fehlen, diese temporär nachinstallieren. sind aber nach container neustart wieder weg (je nach volumes konfiguration) oder
                                mit docker commit aus dem container ein neues image mit den Änderungen erzeugen.
                                Links im Profil
                                  @mguenther
                                  ich mach das so:
                                  M
                                  M
                                  mguenther
                                  @oliverio
                                  portainer nutze ich auch - ich habe unter grafana folgendes Terminal und komme dann eben nicht in/an die ini-Datei:
                                  • M mguenther
                                    @oliverio
                                    OliverIOO
                                    OliverIOO
                                    OliverIO
                                    @mguenther sagte in Grafana unter Docker installieren und Einrichten:
                                    @oliverio
                                    ich liebe es wenn man jeder meiner bereits geschriebenen worte wertschätzt :)
                                    sudo apt-get install nano
                                    Links im Profil
                                      @oliverio
                                      M
                                      M
                                      mguenther
                                      @oliverio
                                      es fängt bei sudo an - ich habe gerade versucht es mit
                                      apt-get install sudo
                                      zu bekommen :)
                                      • M mguenther
                                        @oliverio
                                        zu bekommen :)
                                        OliverIOO
                                        OliverIOO
                                        OliverIO
                                        #66
                                        @mguenther
                                        dann ohne sudo probieren.
                                        wahrscheinlich bist du schon root
                                        Links im Profil
                                        M OliverIOO 2 Antworten Letzte Antwort
                                          @mguenther
                                          M
                                          M
                                          mguenther
                                          #67
                                          @oliverio
                                          ich starte den docker grafana mal komplett neu - habe eh noch nix drin und dann füge ich ein
                                          -v grafana-storage:/var/lib/grafana
                                          hinzu und gebe mir die entsprechenden Rechte für den Ordner. Dann kann ich auch die ini-Datei bearbeiten... :)
                                          83.8k
