6.1k Beiträge 316 Kommentatoren 6.0m Aufrufe 273 Beobachtet
  • M MCU
    @holzapfelauge
     <variables>
       <variable id="BW%9v~G}+|6BPI-mC^U~">X_completed</variable>
       <variable id="8SK,{_!3h?;v%0+=ZeUU">X_createdDateTime</variable>
       <variable id="rO9asU5s{Y2G@3IkL@g~">X_value</variable>
       <variable id="-gF.AQ8**.mG;]}U}aCI">NEW_JSON</variable>
       <variable id="MpCcK~ur_i5(;GNB}F?^">jsonitems</variable>
       <variable id="7huB30*E_mbam=Bi-D2z">select</variable>
       <variable id="W@MiB696qRDvf-aB*Cb1">i</variable>
       <variable id="dU=%0t3gDY!SaSObPx}I">ADD_select</variable>
     </variables>
     <block type="procedures_defcustomreturn" id="mxG_{B!Y/t/PJQkf4_^S" x="238" y="-663">
       <mutation statements="false">
         <arg name="X_completed" varid="BW%9v~G}+|6BPI-mC^U~"></arg>
         <arg name="X_createdDateTime" varid="8SK,{_!3h?;v%0+=ZeUU"></arg>
         <arg name="X_value" varid="rO9asU5s{Y2G@3IkL@g~"></arg>
       </mutation>
       <field name="NAME">JSON_ELEMENT</field>
       <field name="SCRIPT">dmFyIHggPXt9Ow0KLy9jb25zb2xlLmxvZyhYX2NvbXBsZXRlZCArICcgJytYX2NyZWF0ZWREYXRlVGltZSArJyAnKyBYX3ZhbHVlKTsNCg0KaWYgKFhfY29tcGxldGVkID09IGZhbHNlKSB7DQogICAgeC5jb21wbGV0ZWQgPSAiT2ZmZW4iOyAvL1N0cmluZyhYX2NvbXBsZXRlZCk7ICAgIA0KfQ0KZWxzZSB7DQogICAgeC5jb21wbGV0ZWQgPSAiRXJsZWRpZ3QiOw0KfQ0KDQp4LmNyZWF0ZWREYXRlVGltZT0gWF9jcmVhdGVkRGF0ZVRpbWU7DQp4LnZhbHVlID0gWF92YWx1ZTsNCngucHVzaDsNCnJldHVybiB4Ow==</field>
     </block>
     <block type="create" id="G]R]no),5~HQ]rMcDMT(" x="237" y="-612">
       <field name="NAME">0_userdata.0.alexa.todo_json_jarvis</field>
       <next>
         <block type="create" id="=)6?8)IqYQnQuesdU7UA">
           <field name="NAME">0_userdata.0.alexa.todo_select</field>
           <value name="COMMON">
             <block type="text_join" id="t%HpOTmWwv0}]!N=QK~2">
               <mutation items="4"></mutation>
               <value name="ADD0">
                 <block type="text" id="CQZ?#lk_wSG1Juk.E}!*">
                   <field name="TEXT">{"read": true,"write": true, </field>
                 </block>
               </value>
               <value name="ADD1">
                 <block type="text" id="@SE1f2TGhb)XwfKW1jAM">
                   <field name="TEXT">"type": "string","name": "Auswahl", </field>
                 </block>
               </value>
               <value name="ADD2">
                 <block type="text" id="/#-h~q~zfI|N_oXBwK,`">
                   <field name="TEXT"></field>
                 </block>
               </value>
               <value name="ADD3">
                 <block type="text" id="?:x8KxIyksC4;q*pMkSl">
                   <field name="TEXT">"states": {"all":"Alle","false":"Offene","true":"Erledigte"}}</field>
                 </block>
               </value>
             </block>
           </value>
           <next>
             <block type="on_ext" id="ZM4rstIXoN#mZ-2b2%iG">
               <value name="OID0">
                 <shadow type="field_oid" id="!^G4~u8j[W6crS2yG6P`">
                   <field name="oid">alexa2.0.Lists.TO_DO.json</field>
                 </shadow>
               </value>
               <statement name="STATEMENT">
                 <block type="procedures_callnoreturn" id="*8x-8sM$V;V1!qlyv#1s">
                   <mutation name="JSON_FÜR_JARVIS"></mutation>
                 </block>
               </statement>
               <next>
                 <block type="on_ext" id="u:c:K(a.v=[lf5Y;.^gp">
                   <value name="OID0">
                     <shadow type="field_oid" id="EykUyR?a8C63eqTR@5%*">
                       <field name="oid">0_userdata.0.alexa.todo_select</field>
                     </shadow>
                   </value>
                     <block type="procedures_callnoreturn" id="LAP^y%R6t^IgBuhC$p#l">
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="procedures_defnoreturn" id="}z{CqW-9zw2xWC*XwEPb" x="237" y="62">
       <field name="NAME">JSON_FÜR_JARVIS</field>
       <statement name="STACK">
         <block type="variables_set" id="]g$swJ*{2zi#DDIxG_*9">
           <field name="VAR" id="-gF.AQ8**.mG;]}U}aCI">NEW_JSON</field>
           <value name="VALUE">
             <block type="lists_create_with" id="s=b/i.]d.{lIVezRf3G]">
               <mutation items="0"></mutation>
             </block>
           </value>
           <next>
             <block type="variables_set" id="B`W:^0^1rmhAz{G;3(=}">
               <field name="VAR" id="MpCcK~ur_i5(;GNB}F?^">jsonitems</field>
                 <block type="convert_json2object" id="|Na{Lsyc[M~de-(U@Lo*">
                     <block type="get_value" id="^Qf/]g}*V1]-.;T/%AIY">
                       <field name="OID">alexa2.0.Lists.TO_DO.json</field>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="+{vBa^+a7]q#9p]?hMH7">
                   <field name="VAR" id="7huB30*E_mbam=Bi-D2z">select</field>
                     <block type="get_value" id="$tt:77/o}Y:xtjuJ6vZR">
                       <field name="OID">0_userdata.0.alexa.todo_select</field>
                     </block>
                   </value>
                   <next>
                     <block type="debug" id=")#p1xctd[CKaOi}fUfW)" disabled="true">
                       <value name="TEXT">
                         <shadow type="text" id="t-2b_e#0STem%wB/vwMS">
                         </shadow>
                         <block type="variables_get" id="q%U/3q~`p=5uyPE-eaAk">
                         </block>
                       </value>
                       <next>
                         <block type="controls_forEach" id="Jr]rCwGV4+ZJW|.JDFoh">
                           <field name="VAR" id="W@MiB696qRDvf-aB*Cb1">i</field>
                           <value name="LIST">
                             <block type="variables_get" id=",~mWGy{FpQD5@ncHG9uq">
                             </block>
                           </value>
                           <statement name="DO">
                             <block type="debug" id="|}P0#g}U6HB({/,$])lw" disabled="true">
                               <value name="TEXT">
                                 <shadow type="text" id="+?}@}ZxJAsZN5TtPs{av">
                                 </shadow>
                                 <block type="convert_jsonata" id="*8%E3s_lo)vJX{xu(5MF">
                                   <value name="EXPRESSION">
                                     <shadow type="text" id="(m+8t{gx1Kk@3Hzq8,jB">
                                       <field name="TEXT">completed</field>
                                     </shadow>
                                   </value>
                                   <value name="TARGET">
                                     <block type="variables_get" id="IDyoQxR)dt9M*[n3ShUo">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="variables_set" id="MMmJ=$3Av~;=8?:CLJ/?">
                                   <field name="VAR" id="dU=%0t3gDY!SaSObPx}I">ADD_select</field>
                                     <block type="logic_boolean" id="=hyUVhSs!A%-9jI+{DUM">
                                     </block>
                                   </value>
                                   <next>
                                     <block type="controls_if" id="Kwi^{w?v/g=KmUzfK3o$">
                                       <mutation elseif="2"></mutation>
                                       <value name="IF0">
                                         <block type="logic_compare" id="paFV3UpfROlwbseECIW8">
                                           <field name="OP">EQ</field>
                                           <value name="A">
                                             <block type="variables_get" id="ms1-N4Hh4HwO3[vO,8qJ">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="text" id="dl=n:TaVE;zn,lo_dDU:">
                                               <field name="TEXT">all</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <statement name="DO0">
                                         <block type="variables_set" id="`#`6u*=P1Op#.AV?i?cD">
                                             <block type="logic_boolean" id="H_pQE1d|D~fo2]E3yfdx">
                                             </block>
                                           </value>
                                         </block>
                                       </statement>
                                       <value name="IF1">
                                         <block type="logic_compare" id="6iE*0Atm^B]yoUHj~e90">
                                           <value name="A">
                                             <block type="variables_get" id="fH~RkEanrpluVyhdQVd^">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="text" id="LYe@tI5;CI@eX?#Fb`tx">
                                               <field name="TEXT">false</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <statement name="DO1">
                                         <block type="controls_if" id="Skx)dhe*t;i%zFH9#HDe">
                                           <value name="IF0">
                                             <block type="logic_compare" id="N0mP%Y@nJII)FUkV(|ot">
                                               <value name="A">
                                                 <block type="convert_tostring" id="%lxfjvw/;}838}H#v-wA">
                                                     <block type="convert_jsonata" id="2=/{cS9wTG-j`^Z%!580">
                                                         <shadow type="text" id="}@K=JL!N,dddRT/*N0DF">
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id="`DcTGvtRHbcsq2i=ytZS">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="text" id="~L(vpPkIy;VPicYNW]yS">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                             <block type="variables_set" id="WMsqF_mnxx|zP$?YUArJ">
                                                 <block type="logic_boolean" id="#I[kEn`t=3Ft4CTu!WNV">
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                       <value name="IF2">
                                         <block type="logic_compare" id="U=F7PQoX8|APZ]Sz17K2">
                                           <value name="A">
                                             <block type="variables_get" id="o2Vh2IGtY-3]c8QQa!@B">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="text" id="e@cS%G1a[N-`qPV.A7EE">
                                               <field name="TEXT">true</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <statement name="DO2">
                                         <block type="controls_if" id=",,7q^;^ykjHZUFLC1s%{">
                                           <value name="IF0">
                                             <block type="logic_compare" id="zqC,-gE?urRyxEfdZAfu">
                                               <value name="A">
                                                 <block type="convert_tostring" id="LeRW,6c8xyUh;*wIL)MQ">
                                                     <block type="convert_jsonata" id="Q-MMm$fHe4io_vHjSY_.">
                                                         <shadow type="text" id="jJ+~bp;!d$*`m%Ctj6D$">
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id=";)I@*nH{bp=_]=}znxgN">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="text" id="zMJ,hoF}E)tES9{q$Z(h">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                             <block type="variables_set" id="8(T:~McP8TfZbWDftG*k">
                                                 <block type="logic_boolean" id="2ND5y7W@V^HEzfL~^uzk">
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                       <next>
                                         <block type="controls_if" id="49^HV302$#}aPx~PH5Tg">
                                           <value name="IF0">
                                             <block type="variables_get" id="IX|.A-#iMIj(T^]4DSEO">
                                             </block>
                                           </value>
                                             <block type="lists_setIndex" id="@:3ZNJZ:55#tL}E7vu^T">
                                               <mutation at="false"></mutation>
                                               <field name="MODE">INSERT</field>
                                               <field name="WHERE">LAST</field>
                                               <value name="LIST">
                                                 <block type="variables_get" id="af%%PgQ7fWx!_GIzW-u;">
                                                 </block>
                                               </value>
                                               <value name="TO">
                                                 <block type="procedures_callcustomreturn" id="DK/42*f_58--ovA;lXv)">
                                                   <mutation name="JSON_ELEMENT">
                                                     <arg name="X_completed"></arg>
                                                     <arg name="X_createdDateTime"></arg>
                                                     <arg name="X_value"></arg>
                                                   </mutation>
                                                   <value name="ARG0">
                                                     <block type="convert_jsonata" id="p~t%WLYkQmU]]h8l+Cs7">
                                                         <shadow type="text" id=";b2/pyI3v@1,eX5G?8PQ">
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id="!PMW.%,?n$]kNTW~!p8J">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="ARG1">
                                                     <block type="convert_from_date" id="zZ%~t]{DcMF2oM,p{Hup">
                                                       <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                                       <field name="OPTION">custom</field>
                                                       <field name="FORMAT">JJJJ.MM.TT SS:mm:ss.sss</field>
                                                         <block type="convert_jsonata" id="C$2e~IAW]hx`*V~X[)D#">
                                                             <shadow type="text" id="[e:fFe+C8.d5_Q-Jzmwe">
                                                               <field name="TEXT">createdDateTime</field>
                                                             </shadow>
                                                           </value>
                                                             <block type="variables_get" id="`-z1(J9v}MJR?I=(_K[v">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="ARG2">
                                                     <block type="convert_jsonata" id="OnDoF_MTz~7s^|kTVg$B">
                                                         <shadow type="text" id="Be.Qa)$#T7.Qy[SAl+fw">
                                                           <field name="TEXT">value</field>
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id="ZdrDTX/aEU]9Q!=Cey5,">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                             <block type="controls_if" id="w9hDJs7nyR2z[DBTv!rF">
                               <value name="IF0">
                                 <block type="lists_isEmpty" id="W*NG``#wpfb[V(?1nNHL">
                                     <block type="variables_get" id="0%Yg#Juc=;)l@d3-#F7d">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="lists_setIndex" id="Qo=m1Wp$57Zy(l6yE,Z(">
                                   <value name="LIST">
                                     <block type="variables_get" id="5W5CKh5liv6FuatsK/?Z">
                                     </block>
                                   </value>
                                   <value name="TO">
                                     <block type="procedures_callcustomreturn" id="@HOvj(IHOLe56frxw!@l">
                                       </mutation>
                                       <value name="ARG0">
                                         <block type="logic_boolean" id="99FS2N/.0wC;4WBiN3KV">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         <block type="time_get" id="uT3s!cz2Cd4XE|j3#{9.">
                                         </block>
                                       </value>
                                       <value name="ARG2">
                                         <block type="text" id="W_Am_?MWaDu4^J,j!TWX">
                                           <field name="TEXT">KEINE DATEN</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                               <next>
                                 <block type="control" id="{W3|J:c#[2b{b:Xu]A{n">
                                   <field name="OID">0_userdata.0.alexa.todo_json_jarvis</field>
                                     <block type="convert_object2json" id="168#s}4?dNMkYXfgV!R:">
                                       <field name="PRETTIFY">FALSE</field>
                                         <block type="variables_get" id="pMM{?xO2~8WGxNgT$-UI">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="debug" id="N/EOUd~/!~AJc29vuAh7" disabled="true">
                                       <value name="TEXT">
                                         <shadow type="text" id="~j3T*-ZtFWuLI/`wpea=">
                                         </shadow>
                                         <block type="convert_object2json" id="vJ}n)j)ESFbL)v`qcOFU">
                                             <block type="variables_get" id="0lspr~*WijzCwXkZYN_!">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    Bitte mit dem anderen Blockly komplett tauschen bzw neu importieren.
    holzapfelaugeH
    holzapfelaugeH
    holzapfelauge
    #4691
    @mcu Da kommt bei mir das hier:
    Ich hätte auch gerne, dass anstatt value "Aufgabe" da steht und anstatt createdDateTime "Datum". Hab ich leider nicht hinbekommen. :man-shrugging:
    • holzapfelaugeH holzapfelauge
      M
      M
      MCU
      #4692
      @holzapfelauge Nein. Das geht nicht. evtl mit v3 irgendwann.
      Man müsste dann die HTML unabhängig vom DP (Alexa) machen.
      • M MCU
        M
        M
        MCU
        #4693
        @holzapfelauge
         <variables>
         </variables>
           </mutation>
           <field name="SCRIPT">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</field>
         </block>
           <next>
                   <value name="ADD0">
                     </block>
                   </value>
                   <value name="ADD1">
                     </block>
                   </value>
                   <value name="ADD2">
                     </block>
                   </value>
                   <value name="ADD3">
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                   <value name="OID0">
                     </shadow>
                   </value>
                     </block>
                   </statement>
                   <next>
                       <value name="OID0">
                         </shadow>
                       </value>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
                 </block>
               </value>
               <next>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                         </block>
                       </value>
                       <next>
                           <value name="TEXT">
                             </shadow>
                             </block>
                           </value>
                           <next>
                               <value name="LIST">
                                 </block>
                               </value>
                                   <value name="TEXT">
                                     </shadow>
                                         </shadow>
                                       </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                         </block>
                                       </value>
                                       <next>
                                           <value name="IF0">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                           <value name="IF1">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                               <value name="IF0">
                                                   <value name="A">
                                                             </shadow>
                                                           </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                           <value name="IF2">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                               <value name="IF0">
                                                   <value name="A">
                                                             </shadow>
                                                           </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                           <next>
                                               <value name="IF0">
                                                 </block>
                                               </value>
                                                   <value name="LIST">
                                                     </block>
                                                   </value>
                                                   <value name="TO">
                                                       </mutation>
                                                       <value name="ARG0">
                                                             </shadow>
                                                           </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="ARG1">
        </shadow>
                                                               </value>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="ARG2">
                                                             </shadow>
                                                           </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                               <next>
                                   <value name="IF0">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                       <value name="LIST">
                                         </block>
                                       </value>
                                       <value name="TO">
                                           </mutation>
                                           <value name="ARG0">
                                             </block>
                                           </value>
                                           <value name="ARG1">
                                             </block>
                                           </value>
                                           <value name="ARG2">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <next>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                           <value name="TEXT">
                                             </shadow>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
        </xml>
        JSONTABLE dann umstellen auf:
        [{"label":"Aufgabe","align":"left"},{"label":"Datum","align":"left"}]
        holzapfelaugeH 1 Antwort Letzte Antwort
        • M MCU
          @holzapfelauge
           <variables>
           </variables>
             </mutation>
           </block>
             <next>
                     <value name="ADD0">
                       </block>
                     </value>
                     <value name="ADD1">
                       </block>
                     </value>
                     <value name="ADD2">
                       </block>
                     </value>
                     <value name="ADD3">
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                     <value name="OID0">
                       </shadow>
                     </value>
                       </block>
                     </statement>
                     <next>
                         <value name="OID0">
                           </shadow>
                         </value>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
                   </block>
                 </value>
                 <next>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                           </block>
                         </value>
                         <next>
                             <value name="TEXT">
                               </shadow>
                               </block>
                             </value>
                             <next>
                                 <value name="LIST">
                                   </block>
                                 </value>
                                     <value name="TEXT">
                                       </shadow>
                                           </shadow>
                                         </value>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                           </block>
                                         </value>
                                         <next>
                                             <value name="IF0">
                                                 <value name="A">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </statement>
                                             <value name="IF1">
                                                 <value name="A">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                                 <value name="IF0">
                                                     <value name="A">
                                                               </shadow>
                                                             </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                             <value name="IF2">
                                                 <value name="A">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                                 <value name="IF0">
                                                     <value name="A">
                                                               </shadow>
                                                             </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                             <next>
                                                 <value name="IF0">
                                                   </block>
                                                 </value>
                                                     <value name="LIST">
                                                       </block>
                                                     </value>
                                                     <value name="TO">
                                                         </mutation>
                                                         <value name="ARG0">
                                                               </shadow>
                                                             </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="ARG1">
        </shadow>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="ARG2">
                                                               </shadow>
                                                             </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                                 <next>
                                     <value name="IF0">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                         <value name="LIST">
                                           </block>
                                         </value>
                                         <value name="TO">
                                             </mutation>
                                             <value name="ARG0">
                                               </block>
                                             </value>
                                             <value name="ARG1">
                                               </block>
                                             </value>
                                             <value name="ARG2">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                             <value name="TEXT">
                                               </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
          </xml>
          holzapfelaugeH
          holzapfelaugeH
          holzapfelauge
          schrieb am zuletzt editiert von holzapfelauge
          #4694
          @mcu Vielen Dank! Jetzt wird zwar Aufgabe und Datum angezeigt, allerdings steht bei den offenen Aufgaben, wenn kein Eintrag vorhanden ist, immer noch "Keine Daten" in der Liste. 🤔
          EDIT: Habs hinbekommen. Einfach nur die Einträge, welche bei einem leeren Datenpunkt angezeigt werden sollen, deaktiviert.
          • ZefauZ Zefau
            jarvis - just another remarkable vis
            Was ist jarvis?
            jarvis ist eine Material Design Visualisierung, die auf Material UI basiert. jarvis gibt eine Struktur und Module vor, die zur Visualisierung genutzt werden, aber sehr flexibel konfiguriert werden können.
            jarvis ist responsive und passt sich der Größe des Screens an.
            Das Layout ist flexibel konfigurierbar. Es können optional (beliebig viele) Tabs verwendet werden. Jeder Tab kann entweder fullscreen sein oder beliebig viele columns haben, die die einzelnen modules in flexibler Reihenfolge beinhalten.
            Jedes Modul hat spezielle Konfigurationsmöglichkeiten (siehe Wiki je Modul).
            Warum jarvis?
            jarvis ist weitaus weniger flexibel als ioBroker.vis, aber bietet dafür ein standardisiertes Design, um schnell eine Visualisierung zusammenzustellen. Wer besonders spezifische Anforderungen hat, sollte (weiterhin) ioBroker.vis verwendet.
            Mehr Informationen
            Mehr Informationen - insbesondere zur Konfiguration - gibt es im Wiki.
            Gestalte mit und stimme ab
            Bitte stimmt für eure gewünschten Feature Requests ab: Nutzt dazu die Emoticon auf Github, um für eure favorisierten Feature Requests abzustimmen:
            https://forum.iobroker.net/assets/uploads/files/1606215967286-1c3e566f-8d54-4f19-8948-eb8833c5b15f-image.png
            Jeder Emoticon zählt gleich. Bitte stimmt nicht für alle / zu viele Feature Requests ab, sonst gibt es am Ende keine großen Unterschiede mehr.
            Die Reihenfolge nach abgegebenen Stimmen seht ihr hier: Übersicht der Feature Requests nach Stimmen
            Siehe https://forum.iobroker.net/post/526170
            Impressionen
            Die Konfiguration von Modulen kann frei angeordnet werden.
            Nachfolgend einige Impressionen / Beispiele:
            @braindead: https://forum.iobroker.net/post/490283
            @JackDaniel: https://forum.iobroker.net/post/490928
            @Mooo: https://forum.iobroker.net/post/493843
            Screencast / Video
            Screenshots
            Beispiel: Dashboard (3 columns)
            Beispiel: Karte (Vollbild)
            Beispiel: Statistiken (2 columns)
            Beispiel: Status (3 columns, davon 2 leer)
            Module
            Die folgenden Module sind aktuell (Februar 2020) verfügbar und können frei konfiguriert werden. Eine aktuelle Liste der Module ist im Wiki zu finden.
            AdapterStatus
            AdapterStatus
            Chart
            Chart
            DateTime
            DateTime1
            Map
            Map
            StateList
            StateListHorizontal
            Konfiguration / erste Schritte
            siehe Wiki auf Github
            Ausblick / Roadmap
            Ihr habt Wünsche? Bitte legt ein Issue auf Github an.
            MEILENSTEINE / ROADMAPs
            siehe https://github.com/Zefau/ioBroker.jarvis/milestones
            nächste Release
            • ROADMAP v2.1.0
            • ROADMAP v3.0.0
            H
            H
            handy80
            #4695
            @zefau Hallo, versuche gerade einen 0/1 Wert in jarvis darzustellen und per switchaction schaltbar zu machen. (nutze den Wolf-Adapter der Daten über das Wolf-Portal zieht) und möchte "Warmwasser 1x" schaltbar machen. Normale ON/OFF Button funktionieren aber mit den Werten 0/1 (Zahl) kommend aus ioBroker funktioniert es nicht. Der SwitchAction zeigt immer "eingeschaltet" an. Ich habe schon mit JSON auf Datenpunkt Eigenschaften
              "0": "Aus",
              "1": "Ein"
            versucht, hilft aber auch nichts. Habt ihr eine Idee für mich. bitte :-)
            • H handy80
                "0": "Aus",
                "1": "Ein"
              M
              M
              MCU
              #4696
              @handy80
              {"off":"0","on":"1"}
              • M MCU
                @handy80
                H
                H
                handy80
                #4697
                @mcu supervielen Dank! hat sofort funktioniert. Danke auch für die Screenshots, hatte dabei festgestellt, dass ich auch den Datenpunkt fürAnzeige noch pflegen musste. naja, immerhin, jetzt gibt's einen "blutigen" Anfänger weniger. Jarvis-Aufstieg zum Anfänger check! ;-)
                • M
                  M
                  MarcoPescado
                  #4698
                  seitdem ich den Kalender benutze bekomme ich minütlich Warnungen.
                  Was hat das zu bedeuten? Ich verwende 2.2.0
                  Read-only state "jarvis.0.info.data" has been written without ack-flag with value "{"data":"BEGIN:VCALENDAR\r\nVERSION:2.0\r\nX-WR-CALNAME:XXXXXXXX\r\nX-APPLE-CALENDAR-COLOR:#CC73E1\r\nBEGIN:VEVENT\r\nCREATED:20210629T193019Z\r\nDTEND;TZID=Europe/Berlin:20210809T091500\r\nDTSTAMP:20210629T193020Z\r\nDTSTART;TZID=Europe/Berlin:20210809T083000\r\nLAST-
                  • K
                    K
                    karstent
                    #4699
                    nach dem ich den Adapter upgedatet habe erscheint nun die Meldung:
                    File index.html not found: {}
                    Die Backups aus dem Adapter haben das Problem leider nicht behoben.
                    Was kann ich tun?
                    • K karstent
                      Was kann ich tun?
                      ZefauZ
                      ZefauZ
                      Zefau
                      #4700
                      @karstent Adapter nochmal hochladen
                      • ZefauZ Zefau
                        K
                        K
                        karstent
                        #4701
                        @zefau also noch mal deinstallieren und dann installieren?
                        • K karstent
                          ZefauZ
                          ZefauZ
                          Zefau
                          #4702
                          @karstent das geht auch. Gibt aber zum hochladen extra einen Button. Sonst per cli iobroker upload jarvis
                          K H 2 Antworten Letzte Antwort
                          -1
                          • ZefauZ Zefau
                            K
                            K
                            karstent
                            #4703
                            @zefau Danke, das hat geklappt. Habe es über die cli gemacht. 👍
                            • M MCU
                              @lustig29 Ich hab mal dem Entwickler vom Homepilot geschrieben, mal schauen was er sagt:
                              https://github.com/Pix---/ioBroker.homepilot/issues/26
                              L
                              L
                              lustig29
                              schrieb am zuletzt editiert von lustig29
                              #4704
                              @mcu Gab es denn schon eine Antwort? Oder wie kann man denn das mit einem Script lösen? Es geht um den Homepilot Adapter für den Rollotron Gurtwickler, da dort keine Datenpunkte für auf und zu vorhanden sind. Man kann das Rollo nur mit Prozentangabe steuern.
                              • L lustig29
                                M
                                M
                                MCU
                                #4705
                                @lustig29 Nein, es gab leider noch keine Antwort. Vielleicht solltest du dann erstmal eine andere Variante zur Steuerung nutzen: DropdownAction. Damit kannst du die Werte dann vorgeben und das Rollo fährt dann ja an die entsprechende Position.
                                {"0":"ZU","25":"25","45":"45","65":"65","100":"OFFEN"}
                                Siehe oben im gif die Änderung vom Wert:
                                stephan1827S 1 Antwort Letzte Antwort
                                • M MCU
                                  stephan1827S
                                  stephan1827S
                                  stephan1827
                                  #4706
                                  @Zefau gibt es eine Anleitung, um die V3 zu installieren? Ich habe den Adapter installiert und dort zeigt er auch die Version V3 an aber meine Instanz ist immer noch V2. Gibt es einen eigenen Thread für V3? Ich konnte keinen finden.
                                  Stephan
                                  W 1 Antwort Letzte Antwort
                                  • stephan1827S stephan1827
                                    Stephan
                                    W
                                    W
                                    WW1983
                                    #4707
                                    @stephan1827
                                    Probiere mal den Upload Button zu drücken:
                                    Würde die V3 aber nur auf einer Testinstanz nutzen. Es handelt sich aktuell um eine Alpha die für den Altag noch nicht nutzbar ist.
                                    • N neunteufels
                                      @dercheffe @Jason
                                      Bei mir fehlen nur die Icons im Wetter-Widget, sonst wird alles richtig angezeigt.
                                      Ich denke der Hinweis von @dercheffe hilft hier nicht weiter.
                                      Es gibt aber schon ein Issue auf git: https://github.com/Zefau/ioBroker.jarvis/issues/827
                                      Leider noch ohne Reaktion von Zefau.
                                      lg
                                      D
                                      D
                                      derAndy
                                      #4708
                                      @neunteufels
                                      hier gab es ja einige mit fehlenden Wetter Icons: Seit einigen Tagen ist die 2.2.2 verfügbar. Die funktioniert bei mir problemlos und zeigt die Wetter Icons wieder an.
                                      • D derAndy
                                        @neunteufels
                                        holzapfelaugeH
                                        holzapfelaugeH
                                        holzapfelauge
                                        #4709
                                        @derandy Wo wurde dir denn die 2.2.2 angeboten? Bei mir wird keine neue verfügbare Version angezeigt. Ist immer noch die 2.2.1!
                                        L 1 Antwort Letzte Antwort
                                          L
                                          L
                                          luie
                                          schrieb am zuletzt editiert von luie
                                          #4710
                                          @holzapfelauge
                                          die gibt es im GitHub
                                          https://github.com/Zefau/ioBroker.jarvis/tree/v2.2.x
                                          debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
                                          33.2k
                                          84.4k
