    6.5k
  • M MCU
    @holzapfelauge
     <variables>
       <variable id="BW%9v~G}+|6BPI-mC^U~">X_completed</variable>
       <variable id="8SK,{_!3h?;v%0+=ZeUU">X_createdDateTime</variable>
       <variable id="rO9asU5s{Y2G@3IkL@g~">X_value</variable>
       <variable id="-gF.AQ8**.mG;]}U}aCI">NEW_JSON</variable>
       <variable id="MpCcK~ur_i5(;GNB}F?^">jsonitems</variable>
       <variable id="7huB30*E_mbam=Bi-D2z">select</variable>
       <variable id="W@MiB696qRDvf-aB*Cb1">i</variable>
       <variable id="dU=%0t3gDY!SaSObPx}I">ADD_select</variable>
     </variables>
     <block type="procedures_defcustomreturn" id="mxG_{B!Y/t/PJQkf4_^S" x="238" y="-663">
       <mutation statements="false">
         <arg name="X_completed" varid="BW%9v~G}+|6BPI-mC^U~"></arg>
         <arg name="X_createdDateTime" varid="8SK,{_!3h?;v%0+=ZeUU"></arg>
         <arg name="X_value" varid="rO9asU5s{Y2G@3IkL@g~"></arg>
       </mutation>
       <field name="NAME">JSON_ELEMENT</field>
       <field name="SCRIPT">dmFyIHggPXt9Ow0KLy9jb25zb2xlLmxvZyhYX2NvbXBsZXRlZCArICcgJytYX2NyZWF0ZWREYXRlVGltZSArJyAnKyBYX3ZhbHVlKTsNCg0KaWYgKFhfY29tcGxldGVkID09IGZhbHNlKSB7DQogICAgLy94LmNvbXBsZXRlZCA9ICJPZmZlbiI7IC8vU3RyaW5nKFhfY29tcGxldGVkKTsgICAgDQogICAgeC5TdGF0dXMgPSAiT2ZmZW4iOyAvL1N0cmluZyhYX2NvbXBsZXRlZCk7ICAgIA0KICAgIA0KfQ0KZWxzZSB7DQogICAgLy94LmNvbXBsZXRlZCA9ICJFcmxlZGlndCI7DQogICAgeC5TdGF0dXMgPSAiRXJsZWRpZ3QiOw0KfQ0KDQovL3guY3JlYXRlZERhdGVUaW1lPSBYX2NyZWF0ZWREYXRlVGltZTsNCi8veC52YWx1ZSA9IFhfdmFsdWU7DQp4LkRhdHVtPSBYX2NyZWF0ZWREYXRlVGltZTsNCnguQXVmZ2FiZSA9IFhfdmFsdWU7DQp4LnB1c2g7DQpyZXR1cm4geDs=</field>
     </block>
     <block type="create" id="G]R]no),5~HQ]rMcDMT(" x="237" y="-612">
       <field name="NAME">0_userdata.0.alexa.todo_json_jarvis</field>
       <next>
         <block type="create" id="=)6?8)IqYQnQuesdU7UA">
           <field name="NAME">0_userdata.0.alexa.todo_select</field>
           <value name="COMMON">
             <block type="text_join" id="t%HpOTmWwv0}]!N=QK~2">
               <mutation items="4"></mutation>
               <value name="ADD0">
                 <block type="text" id="CQZ?#lk_wSG1Juk.E}!*">
                   <field name="TEXT">{"read": true,"write": true, </field>
                 </block>
               </value>
               <value name="ADD1">
                 <block type="text" id="@SE1f2TGhb)XwfKW1jAM">
                   <field name="TEXT">"type": "string","name": "Auswahl", </field>
                 </block>
               </value>
               <value name="ADD2">
                 <block type="text" id="/#-h~q~zfI|N_oXBwK,`">
                   <field name="TEXT"></field>
                 </block>
               </value>
               <value name="ADD3">
                 <block type="text" id="?:x8KxIyksC4;q*pMkSl">
                   <field name="TEXT">"states": {"all":"Alle","false":"Offene","true":"Erledigte"}}</field>
                 </block>
               </value>
             </block>
           </value>
           <next>
             <block type="on_ext" id="ZM4rstIXoN#mZ-2b2%iG">
               <value name="OID0">
                 <shadow type="field_oid" id="!^G4~u8j[W6crS2yG6P`">
                   <field name="oid">alexa2.0.Lists.TO_DO.json</field>
                 </shadow>
               </value>
               <statement name="STATEMENT">
                 <block type="procedures_callnoreturn" id="*8x-8sM$V;V1!qlyv#1s">
                   <mutation name="JSON_FÜR_JARVIS"></mutation>
                 </block>
               </statement>
               <next>
                 <block type="on_ext" id="u:c:K(a.v=[lf5Y;.^gp">
                   <value name="OID0">
                     <shadow type="field_oid" id="EykUyR?a8C63eqTR@5%*">
                       <field name="oid">0_userdata.0.alexa.todo_select</field>
                     </shadow>
                   </value>
                     <block type="procedures_callnoreturn" id="LAP^y%R6t^IgBuhC$p#l">
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="procedures_defnoreturn" id="}z{CqW-9zw2xWC*XwEPb" x="237" y="62">
       <field name="NAME">JSON_FÜR_JARVIS</field>
       <statement name="STACK">
         <block type="variables_set" id="]g$swJ*{2zi#DDIxG_*9">
           <field name="VAR" id="-gF.AQ8**.mG;]}U}aCI">NEW_JSON</field>
           <value name="VALUE">
             <block type="lists_create_with" id="s=b/i.]d.{lIVezRf3G]">
               <mutation items="0"></mutation>
             </block>
           </value>
           <next>
             <block type="variables_set" id="B`W:^0^1rmhAz{G;3(=}">
               <field name="VAR" id="MpCcK~ur_i5(;GNB}F?^">jsonitems</field>
                 <block type="convert_json2object" id="|Na{Lsyc[M~de-(U@Lo*">
                     <block type="get_value" id="^Qf/]g}*V1]-.;T/%AIY">
                       <field name="OID">alexa2.0.Lists.TO_DO.json</field>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="+{vBa^+a7]q#9p]?hMH7">
                   <field name="VAR" id="7huB30*E_mbam=Bi-D2z">select</field>
                     <block type="get_value" id="$tt:77/o}Y:xtjuJ6vZR">
                       <field name="OID">0_userdata.0.alexa.todo_select</field>
                     </block>
                   </value>
                   <next>
                     <block type="debug" id=")#p1xctd[CKaOi}fUfW)" disabled="true">
                       <value name="TEXT">
                         <shadow type="text" id="t-2b_e#0STem%wB/vwMS">
                         </shadow>
                         <block type="variables_get" id="q%U/3q~`p=5uyPE-eaAk">
                         </block>
                       </value>
                       <next>
                         <block type="controls_forEach" id="Jr]rCwGV4+ZJW|.JDFoh">
                           <field name="VAR" id="W@MiB696qRDvf-aB*Cb1">i</field>
                           <value name="LIST">
                             <block type="variables_get" id=",~mWGy{FpQD5@ncHG9uq">
                             </block>
                           </value>
                           <statement name="DO">
                             <block type="debug" id="|}P0#g}U6HB({/,$])lw" disabled="true">
                               <value name="TEXT">
                                 <shadow type="text" id="+?}@}ZxJAsZN5TtPs{av">
                                 </shadow>
                                 <block type="convert_jsonata" id="*8%E3s_lo)vJX{xu(5MF">
                                   <value name="EXPRESSION">
                                     <shadow type="text" id="(m+8t{gx1Kk@3Hzq8,jB">
                                       <field name="TEXT">completed</field>
                                     </shadow>
                                   </value>
                                   <value name="TARGET">
                                     <block type="variables_get" id="IDyoQxR)dt9M*[n3ShUo">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="variables_set" id="MMmJ=$3Av~;=8?:CLJ/?">
                                   <field name="VAR" id="dU=%0t3gDY!SaSObPx}I">ADD_select</field>
                                     <block type="logic_boolean" id="=hyUVhSs!A%-9jI+{DUM">
                                     </block>
                                   </value>
                                   <next>
                                     <block type="controls_if" id="Kwi^{w?v/g=KmUzfK3o$">
                                       <mutation elseif="2"></mutation>
                                       <value name="IF0">
                                         <block type="logic_compare" id="paFV3UpfROlwbseECIW8">
                                           <field name="OP">EQ</field>
                                           <value name="A">
                                             <block type="variables_get" id="ms1-N4Hh4HwO3[vO,8qJ">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="text" id="dl=n:TaVE;zn,lo_dDU:">
                                               <field name="TEXT">all</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <statement name="DO0">
                                         <block type="variables_set" id="`#`6u*=P1Op#.AV?i?cD">
                                             <block type="logic_boolean" id="H_pQE1d|D~fo2]E3yfdx">
                                             </block>
                                           </value>
                                         </block>
                                       </statement>
                                       <value name="IF1">
                                         <block type="logic_compare" id="6iE*0Atm^B]yoUHj~e90">
                                           <value name="A">
                                             <block type="variables_get" id="fH~RkEanrpluVyhdQVd^">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="text" id="LYe@tI5;CI@eX?#Fb`tx">
                                               <field name="TEXT">false</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <statement name="DO1">
                                         <block type="controls_if" id="Skx)dhe*t;i%zFH9#HDe">
                                           <value name="IF0">
                                             <block type="logic_compare" id="N0mP%Y@nJII)FUkV(|ot">
                                               <value name="A">
                                                 <block type="convert_tostring" id="%lxfjvw/;}838}H#v-wA">
                                                     <block type="convert_jsonata" id="2=/{cS9wTG-j`^Z%!580">
                                                         <shadow type="text" id="}@K=JL!N,dddRT/*N0DF">
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id="`DcTGvtRHbcsq2i=ytZS">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="text" id="~L(vpPkIy;VPicYNW]yS">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                             <block type="variables_set" id="WMsqF_mnxx|zP$?YUArJ">
                                                 <block type="logic_boolean" id="#I[kEn`t=3Ft4CTu!WNV">
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                       <value name="IF2">
                                         <block type="logic_compare" id="U=F7PQoX8|APZ]Sz17K2">
                                           <value name="A">
                                             <block type="variables_get" id="o2Vh2IGtY-3]c8QQa!@B">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="text" id="e@cS%G1a[N-`qPV.A7EE">
                                               <field name="TEXT">true</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <statement name="DO2">
                                         <block type="controls_if" id=",,7q^;^ykjHZUFLC1s%{">
                                           <value name="IF0">
                                             <block type="logic_compare" id="zqC,-gE?urRyxEfdZAfu">
                                               <value name="A">
                                                 <block type="convert_tostring" id="LeRW,6c8xyUh;*wIL)MQ">
                                                     <block type="convert_jsonata" id="Q-MMm$fHe4io_vHjSY_.">
                                                         <shadow type="text" id="jJ+~bp;!d$*`m%Ctj6D$">
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id=";)I@*nH{bp=_]=}znxgN">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="text" id="zMJ,hoF}E)tES9{q$Z(h">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                             <block type="variables_set" id="8(T:~McP8TfZbWDftG*k">
                                                 <block type="logic_boolean" id="2ND5y7W@V^HEzfL~^uzk">
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                       <next>
                                         <block type="controls_if" id="49^HV302$#}aPx~PH5Tg">
                                           <value name="IF0">
                                             <block type="variables_get" id="IX|.A-#iMIj(T^]4DSEO">
                                             </block>
                                           </value>
                                             <block type="lists_setIndex" id="@:3ZNJZ:55#tL}E7vu^T">
                                               <mutation at="false"></mutation>
                                               <field name="MODE">INSERT</field>
                                               <field name="WHERE">LAST</field>
                                               <value name="LIST">
                                                 <block type="variables_get" id="af%%PgQ7fWx!_GIzW-u;">
                                                 </block>
                                               </value>
                                               <value name="TO">
                                                 <block type="procedures_callcustomreturn" id="DK/42*f_58--ovA;lXv)">
                                                   <mutation name="JSON_ELEMENT">
                                                     <arg name="X_completed"></arg>
                                                     <arg name="X_createdDateTime"></arg>
                                                     <arg name="X_value"></arg>
                                                   </mutation>
                                                   <value name="ARG0">
                                                     <block type="convert_jsonata" id="p~t%WLYkQmU]]h8l+Cs7">
                                                         <shadow type="text" id=";b2/pyI3v@1,eX5G?8PQ">
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id="!PMW.%,?n$]kNTW~!p8J">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="ARG1">
                                                     <block type="convert_from_date" id="zZ%~t]{DcMF2oM,p{Hup">
                                                       <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                                       <field name="OPTION">custom</field>
                                                       <field name="FORMAT">JJJJ.MM.TT SS:mm:ss.sss</field>
                                                         <block type="convert_jsonata" id="C$2e~IAW]hx`*V~X[)D#">
                                                             <shadow type="text" id="[e:fFe+C8.d5_Q-Jzmwe">
                                                               <field name="TEXT">createdDateTime</field>
                                                             </shadow>
                                                           </value>
                                                             <block type="variables_get" id="`-z1(J9v}MJR?I=(_K[v">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="ARG2">
                                                     <block type="convert_jsonata" id="OnDoF_MTz~7s^|kTVg$B">
                                                         <shadow type="text" id="Be.Qa)$#T7.Qy[SAl+fw">
                                                           <field name="TEXT">value</field>
                                                         </shadow>
                                                       </value>
                                                         <block type="variables_get" id="ZdrDTX/aEU]9Q!=Cey5,">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                             <block type="controls_if" id="w9hDJs7nyR2z[DBTv!rF">
                               <value name="IF0">
                                 <block type="lists_isEmpty" id="W*NG``#wpfb[V(?1nNHL">
                                     <block type="variables_get" id="0%Yg#Juc=;)l@d3-#F7d">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="lists_setIndex" id="Qo=m1Wp$57Zy(l6yE,Z(">
                                   <value name="LIST">
                                     <block type="variables_get" id="5W5CKh5liv6FuatsK/?Z">
                                     </block>
                                   </value>
                                   <value name="TO">
                                     <block type="procedures_callcustomreturn" id="@HOvj(IHOLe56frxw!@l">
                                       </mutation>
                                       <value name="ARG0">
                                         <block type="logic_boolean" id="99FS2N/.0wC;4WBiN3KV">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         <block type="time_get" id="uT3s!cz2Cd4XE|j3#{9.">
                                         </block>
                                       </value>
                                       <value name="ARG2">
                                         <block type="text" id="W_Am_?MWaDu4^J,j!TWX">
                                           <field name="TEXT">KEINE DATEN</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                               <next>
                                 <block type="control" id="{W3|J:c#[2b{b:Xu]A{n">
                                   <field name="OID">0_userdata.0.alexa.todo_json_jarvis</field>
                                     <block type="convert_object2json" id="168#s}4?dNMkYXfgV!R:">
                                       <field name="PRETTIFY">FALSE</field>
                                         <block type="variables_get" id="pMM{?xO2~8WGxNgT$-UI">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="debug" id="N/EOUd~/!~AJc29vuAh7" disabled="true">
                                       <value name="TEXT">
                                         <shadow type="text" id="~j3T*-ZtFWuLI/`wpea=">
                                         </shadow>
                                         <block type="convert_object2json" id="vJ}n)j)ESFbL)v`qcOFU">
                                             <block type="variables_get" id="0lspr~*WijzCwXkZYN_!">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    JSONTABLE dann umstellen auf:
    [{"label":"Aufgabe","align":"left"},{"label":"Datum","align":"left"}]
    holzapfelaugeH Offline
    holzapfelauge
    schrieb am zuletzt editiert von holzapfelauge
    #4694
    @mcu Vielen Dank! Jetzt wird zwar Aufgabe und Datum angezeigt, allerdings steht bei den offenen Aufgaben, wenn kein Eintrag vorhanden ist, immer noch "Keine Daten" in der Liste. 🤔
    EDIT: Habs hinbekommen. Einfach nur die Einträge, welche bei einem leeren Datenpunkt angezeigt werden sollen, deaktiviert.
    • ZefauZ Zefau
      jarvis - just another remarkable vis
      Was ist jarvis?
      jarvis ist eine Material Design Visualisierung, die auf Material UI basiert. jarvis gibt eine Struktur und Module vor, die zur Visualisierung genutzt werden, aber sehr flexibel konfiguriert werden können.
      jarvis ist responsive und passt sich der Größe des Screens an.
      Das Layout ist flexibel konfigurierbar. Es können optional (beliebig viele) Tabs verwendet werden. Jeder Tab kann entweder fullscreen sein oder beliebig viele columns haben, die die einzelnen modules in flexibler Reihenfolge beinhalten.
      Jedes Modul hat spezielle Konfigurationsmöglichkeiten (siehe Wiki je Modul).
      Warum jarvis?
      jarvis ist weitaus weniger flexibel als ioBroker.vis, aber bietet dafür ein standardisiertes Design, um schnell eine Visualisierung zusammenzustellen. Wer besonders spezifische Anforderungen hat, sollte (weiterhin) ioBroker.vis verwendet.
      Mehr Informationen
      Mehr Informationen - insbesondere zur Konfiguration - gibt es im Wiki.
      Gestalte mit und stimme ab
      Bitte stimmt für eure gewünschten Feature Requests ab: Nutzt dazu die Emoticon auf Github, um für eure favorisierten Feature Requests abzustimmen:
      https://forum.iobroker.net/assets/uploads/files/1606215967286-1c3e566f-8d54-4f19-8948-eb8833c5b15f-image.png
      Jeder Emoticon zählt gleich. Bitte stimmt nicht für alle / zu viele Feature Requests ab, sonst gibt es am Ende keine großen Unterschiede mehr.
      Die Reihenfolge nach abgegebenen Stimmen seht ihr hier: Übersicht der Feature Requests nach Stimmen
      Siehe https://forum.iobroker.net/post/526170
      Impressionen
      Die Konfiguration von Modulen kann frei angeordnet werden.
      Nachfolgend einige Impressionen / Beispiele:
      @braindead: https://forum.iobroker.net/post/490283
      @JackDaniel: https://forum.iobroker.net/post/490928
      @Mooo: https://forum.iobroker.net/post/493843
      Screencast / Video
      Screenshots
      Beispiel: Dashboard (3 columns)
      Beispiel: Karte (Vollbild)
      Beispiel: Statistiken (2 columns)
      Beispiel: Status (3 columns, davon 2 leer)
      Module
      Die folgenden Module sind aktuell (Februar 2020) verfügbar und können frei konfiguriert werden. Eine aktuelle Liste der Module ist im Wiki zu finden.
      AdapterStatus
      AdapterStatus
      Chart
      Chart
      DateTime
      DateTime1
      Map
      Map
      StateList
      StateListHorizontal
      Konfiguration / erste Schritte
      siehe Wiki auf Github
      Ausblick / Roadmap
      Ihr habt Wünsche? Bitte legt ein Issue auf Github an.
      MEILENSTEINE / ROADMAPs
      siehe https://github.com/Zefau/ioBroker.jarvis/milestones
      nächste Release
      • ROADMAP v2.1.0
      • ROADMAP v3.0.0
      handy80
      #4695
      @zefau Hallo, versuche gerade einen 0/1 Wert in jarvis darzustellen und per switchaction schaltbar zu machen. (nutze den Wolf-Adapter der Daten über das Wolf-Portal zieht) und möchte "Warmwasser 1x" schaltbar machen. Normale ON/OFF Button funktionieren aber mit den Werten 0/1 (Zahl) kommend aus ioBroker funktioniert es nicht. Der SwitchAction zeigt immer "eingeschaltet" an. Ich habe schon mit JSON auf Datenpunkt Eigenschaften
        "0": "Aus",
        "1": "Ein"
      versucht, hilft aber auch nichts. Habt ihr eine Idee für mich. bitte :-)
      • H handy80
          "0": "Aus",
          "1": "Ein"
        MCU
        #4696
        @handy80
        {"off":"0","on":"1"}
        H 1 Antwort Letzte Antwort
        • M MCU
          @handy80
          handy80
          #4697
          @mcu supervielen Dank! hat sofort funktioniert. Danke auch für die Screenshots, hatte dabei festgestellt, dass ich auch den Datenpunkt fürAnzeige noch pflegen musste. naja, immerhin, jetzt gibt's einen "blutigen" Anfänger weniger. Jarvis-Aufstieg zum Anfänger check! ;-)
            MarcoPescado
            #4698
            seitdem ich den Kalender benutze bekomme ich minütlich Warnungen.
            Was hat das zu bedeuten? Ich verwende 2.2.0
            Read-only state "jarvis.0.info.data" has been written without ack-flag with value "{"data":"BEGIN:VCALENDAR\r\nVERSION:2.0\r\nX-WR-CALNAME:XXXXXXXX\r\nX-APPLE-CALENDAR-COLOR:#CC73E1\r\nBEGIN:VEVENT\r\nCREATED:20210629T193019Z\r\nDTEND;TZID=Europe/Berlin:20210809T091500\r\nDTSTAMP:20210629T193020Z\r\nDTSTART;TZID=Europe/Berlin:20210809T083000\r\nLAST-
              karstent
              #4699
              nach dem ich den Adapter upgedatet habe erscheint nun die Meldung:
              File index.html not found: {}
              Die Backups aus dem Adapter haben das Problem leider nicht behoben.
              Was kann ich tun?
              • K karstent
                Was kann ich tun?
                ZefauZ Offline
                ZefauZ Offline
                Zefau
                #4700
                @karstent Adapter nochmal hochladen
                • ZefauZ Zefau
                  karstent
                  #4701
                  @zefau also noch mal deinstallieren und dann installieren?
                  • K karstent
                    ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    #4702
                    @karstent das geht auch. Gibt aber zum hochladen extra einen Button. Sonst per cli iobroker upload jarvis
                    K H 2 Antworten Letzte Antwort
                    -1
                    • ZefauZ Zefau
                      karstent
                      #4703
                      @zefau Danke, das hat geklappt. Habe es über die cli gemacht. 👍
                      • M MCU
                        @lustig29 Ich hab mal dem Entwickler vom Homepilot geschrieben, mal schauen was er sagt:
                        https://github.com/Pix---/ioBroker.homepilot/issues/26
                        lustig29
                        schrieb am zuletzt editiert von lustig29
                        #4704
                        @mcu Gab es denn schon eine Antwort? Oder wie kann man denn das mit einem Script lösen? Es geht um den Homepilot Adapter für den Rollotron Gurtwickler, da dort keine Datenpunkte für auf und zu vorhanden sind. Man kann das Rollo nur mit Prozentangabe steuern.
                        • L lustig29
                          MCU
                          #4705
                          @lustig29 Nein, es gab leider noch keine Antwort. Vielleicht solltest du dann erstmal eine andere Variante zur Steuerung nutzen: DropdownAction. Damit kannst du die Werte dann vorgeben und das Rollo fährt dann ja an die entsprechende Position.
                          {"0":"ZU","25":"25","45":"45","65":"65","100":"OFFEN"}
                          Siehe oben im gif die Änderung vom Wert:
                          stephan1827S 1 Antwort Letzte Antwort
                          • M MCU
                            stephan1827S Offline
                            stephan1827
                            #4706
                            @Zefau gibt es eine Anleitung, um die V3 zu installieren? Ich habe den Adapter installiert und dort zeigt er auch die Version V3 an aber meine Instanz ist immer noch V2. Gibt es einen eigenen Thread für V3? Ich konnte keinen finden.
                            Stephan
                            W 1 Antwort Letzte Antwort
                            • stephan1827S stephan1827
                              Stephan
                              W Offline
                              W Offline
                              WW1983
                              #4707
                              @stephan1827
                              Probiere mal den Upload Button zu drücken:
                              Würde die V3 aber nur auf einer Testinstanz nutzen. Es handelt sich aktuell um eine Alpha die für den Altag noch nicht nutzbar ist.
                              • N neunteufels
                                @dercheffe @Jason
                                Bei mir fehlen nur die Icons im Wetter-Widget, sonst wird alles richtig angezeigt.
                                Ich denke der Hinweis von @dercheffe hilft hier nicht weiter.
                                Es gibt aber schon ein Issue auf git: https://github.com/Zefau/ioBroker.jarvis/issues/827
                                Leider noch ohne Reaktion von Zefau.
                                lg
                                derAndy
                                #4708
                                @neunteufels
                                hier gab es ja einige mit fehlenden Wetter Icons: Seit einigen Tagen ist die 2.2.2 verfügbar. Die funktioniert bei mir problemlos und zeigt die Wetter Icons wieder an.
                                holzapfelaugeH 1 Antwort Letzte Antwort
                                • D derAndy
                                  @neunteufels
                                  holzapfelauge
                                  #4709
                                  @derandy Wo wurde dir denn die 2.2.2 angeboten? Bei mir wird keine neue verfügbare Version angezeigt. Ist immer noch die 2.2.1!
                                  L 1 Antwort Letzte Antwort
                                  • holzapfelaugeH holzapfelauge
                                    luie
                                    schrieb am zuletzt editiert von luie
                                    #4710
                                    @holzapfelauge
                                    die gibt es im GitHub
                                    https://github.com/Zefau/ioBroker.jarvis/tree/v2.2.x
                                    debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
                                    • R Offline
                                      Robbi12
                                      #4711
                                      Hallo. Wollte auf 2.2.0 updaten. Nun hat er mir einfach die Version 3 installiert. Per Github link gehts auf 3.
                                      Wie bekomme ich die alte Version 2 drauf. Ich habe ein Backitup. Aber das funktioniert nicht so einfach
                                      • R Robbi12
                                        luie
                                        #4712
                                        @robbi12
                                        Du kannst versuchen den Adapter zu löschen, über die benutzerdefinierte URL neu installieren und dann dein backup wieder einspielen.
                                        • N Offline
                                          N Offline
                                          neunteufels
                                          #4713
                                          @derAndy
                                          Danke für den Hinweis.
                                          @Robbi12
                                          Ich habe über "beliebige Quelle" und folgenden Link installiert: https://github.com/Zefau/ioBroker.jarvis/tarball/v2.2.x
                                          Spannend ist, dass mir bei Jarvis noch immer 2.2.1 angezeigt wird, aber die Wetter-Icons sind wieder da.
