Test Adapter Gartenbewässerung v0.0.x
@jb_sullivan Installation geht nur über GitHub Katze wie im ersten Beitrag beschrieben
Wie gesagt, GITHUB Katze geht derzeit unter Admin 5.x.x wegen EBUSY Fehler nicht.
Ich habe es aber doch noch hin bekommen und habe jetzt die 0.0.8 drauf. Trotzdem tauchen im LOG immer noch ein paar Fehlermeldungen auf.
gartenbewaesserung.0 2021-05-26 10:44:59.822 warn (5768) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383" gartenbewaesserung.0 2021-05-26 10:44:59.811 info (5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.809 info (5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.802 info (5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.801 info (5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.799 info (5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.798 info (5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.797 info (5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.795 info (5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean" -
gartenbewaesserung.0 2021-05-26 10:44:59.822 warn (5768) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383" gartenbewaesserung.0 2021-05-26 10:44:59.811 info (5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.809 info (5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.802 info (5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.801 info (5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.799 info (5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.798 info (5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.797 info (5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean" gartenbewaesserung.0 2021-05-26 10:44:59.795 info (5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"@jb_sullivan die objekte müssen vorher gelöscht werden damit sie korrekt neu erstellt werden
@tombox Habe ich gemacht, aber das ändert nichts.
gartenbewaesserung.0 2021-05-26 19:31:28.417 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.415 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.414 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.412 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.393 info (1988) Stop ventil4 gartenbewaesserung.0 2021-05-26 19:31:28.388 info (1988) Stop ventil3 gartenbewaesserung.0 2021-05-26 19:31:28.383 info (1988) Stop ventil2 gartenbewaesserung.0 2021-05-26 19:31:28.378 info (1988) Stop ventil1 gartenbewaesserung.0 2021-05-26 19:31:28.377 info (1988) Bewässerung stop gartenbewaesserung.0 2021-05-26 19:31:24.440 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:24.439 warn (1988) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052084" gartenbewaesserung.0 2021-05-26 19:31:24.438 warn (1988) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:01:24 GMT+0200" gartenbewaesserung.0 2021-05-26 19:31:24.437 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:24.426 info (1988) Start ventil1 gartenbewaesserung.0 2021-05-26 19:31:24.408 info (1988) Stop ventil4 in 5130sek gartenbewaesserung.0 2021-05-26 19:31:24.408 info (1988) Start ventil4 in 3630sek gartenbewaesserung.0 2021-05-26 19:31:24.408 info (1988) Stop ventil3 in 3620sek gartenbewaesserung.0 2021-05-26 19:31:24.407 info (1988) Stop ventil2 in 3610sek gartenbewaesserung.0 2021-05-26 19:31:24.407 info (1988) Start ventil2 in 1810sek gartenbewaesserung.0 2021-05-26 19:31:24.406 info (1988) Stop ventil1 in 1800sek gartenbewaesserung.0 2021-05-26 19:31:24.406 info (1988) Start ventil1 in 0sek gartenbewaesserung.0 2021-05-26 19:31:24.377 info (1988) Start pumpe gartenbewaesserung.0 2021-05-26 19:31:24.376 info (1988) Start Bewaesserung gartenbewaesserung.0 2021-05-26 19:31:24.194 info (1988) Stop ventil4 gartenbewaesserung.0 2021-05-26 19:31:24.194 info (1988) Stop ventil3 gartenbewaesserung.0 2021-05-26 19:31:24.193 info (1988) Stop ventil2 gartenbewaesserung.0 2021-05-26 19:31:24.192 info (1988) Stop ventil1 gartenbewaesserung.0 2021-05-26 19:31:24.191 info (1988) Bewässerung stop gartenbewaesserung.0 2021-05-26 19:30:51.762 warn (1988) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383" -
gartenbewaesserung.0 2021-05-26 19:31:28.417 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.415 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.414 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.412 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:28.393 info (1988) Stop ventil4 gartenbewaesserung.0 2021-05-26 19:31:28.388 info (1988) Stop ventil3 gartenbewaesserung.0 2021-05-26 19:31:28.383 info (1988) Stop ventil2 gartenbewaesserung.0 2021-05-26 19:31:28.378 info (1988) Stop ventil1 gartenbewaesserung.0 2021-05-26 19:31:28.377 info (1988) Bewässerung stop gartenbewaesserung.0 2021-05-26 19:31:24.440 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:24.439 warn (1988) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052084" gartenbewaesserung.0 2021-05-26 19:31:24.438 warn (1988) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:01:24 GMT+0200" gartenbewaesserung.0 2021-05-26 19:31:24.437 info (1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:31:24.426 info (1988) Start ventil1 gartenbewaesserung.0 2021-05-26 19:31:24.408 info (1988) Stop ventil4 in 5130sek gartenbewaesserung.0 2021-05-26 19:31:24.408 info (1988) Start ventil4 in 3630sek gartenbewaesserung.0 2021-05-26 19:31:24.408 info (1988) Stop ventil3 in 3620sek gartenbewaesserung.0 2021-05-26 19:31:24.407 info (1988) Stop ventil2 in 3610sek gartenbewaesserung.0 2021-05-26 19:31:24.407 info (1988) Start ventil2 in 1810sek gartenbewaesserung.0 2021-05-26 19:31:24.406 info (1988) Stop ventil1 in 1800sek gartenbewaesserung.0 2021-05-26 19:31:24.406 info (1988) Start ventil1 in 0sek gartenbewaesserung.0 2021-05-26 19:31:24.377 info (1988) Start pumpe gartenbewaesserung.0 2021-05-26 19:31:24.376 info (1988) Start Bewaesserung gartenbewaesserung.0 2021-05-26 19:31:24.194 info (1988) Stop ventil4 gartenbewaesserung.0 2021-05-26 19:31:24.194 info (1988) Stop ventil3 gartenbewaesserung.0 2021-05-26 19:31:24.193 info (1988) Stop ventil2 gartenbewaesserung.0 2021-05-26 19:31:24.192 info (1988) Stop ventil1 gartenbewaesserung.0 2021-05-26 19:31:24.191 info (1988) Bewässerung stop gartenbewaesserung.0 2021-05-26 19:30:51.762 warn (1988) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"@jb_sullivan Sollte so nicht passieren.. Alle objekte löschen. Per github installieren und instanz neustarten?
@tombox Genau so - habe ich alles genau so gemacht. Admin und js-controler ist latest letzter Stand.
Habe es nochmal auf DEBUG gestellt - aber da kommt auch nicht viel bei raus.
gartenbewaesserung.0 2021-05-26 19:39:46.507 debug (12300) system.adapter.admin.0: logging true gartenbewaesserung.0 2021-05-26 19:39:42.848 warn (12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383" gartenbewaesserung.0 2021-05-26 19:39:42.738 info (12300) Stop ventil4 gartenbewaesserung.0 2021-05-26 19:39:42.738 info (12300) Stop ventil3 gartenbewaesserung.0 2021-05-26 19:39:42.737 info (12300) Stop ventil2 gartenbewaesserung.0 2021-05-26 19:39:42.737 info (12300) Stop ventil1 gartenbewaesserung.0 2021-05-26 19:39:42.736 info (12300) Bewässerung stop gartenbewaesserung.0 2021-05-26 19:39:42.735 info (12300) Stop ventil4 gartenbewaesserung.0 2021-05-26 19:39:42.734 info (12300) Stop ventil3 gartenbewaesserung.0 2021-05-26 19:39:42.734 info (12300) Stop ventil2 gartenbewaesserung.0 2021-05-26 19:39:42.731 info (12300) Stop ventil1 gartenbewaesserung.0 2021-05-26 19:39:41.743 info (12300) starting. Version 0.0.8 in C:/iobroker/GLT/node_modules/iobroker.gartenbewaesserung, node: v14.16.0, js-controller: 3.3.11 gartenbewaesserung.0 2021-05-26 19:39:41.325 debug (12300) statesDB connected gartenbewaesserung.0 2021-05-26 19:39:41.324 debug (12300) States connected to redis: 127.0.0.1:9000 gartenbewaesserung.0 2021-05-26 19:39:41.310 debug (12300) States create User PubSub Client gartenbewaesserung.0 2021-05-26 19:39:41.309 debug (12300) States create System PubSub Client gartenbewaesserung.0 2021-05-26 19:39:41.296 debug (12300) Redis States: Use Redis connection: 127.0.0.1:9000 gartenbewaesserung.0 2021-05-26 19:39:41.294 debug (12300) objectDB connected gartenbewaesserung.0 2021-05-26 19:39:41.284 debug (12300) Objects connected to redis: 127.0.0.1:9001 gartenbewaesserung.0 2021-05-26 19:39:41.263 debug (12300) Objects client initialize lua scripts gartenbewaesserung.0 2021-05-26 19:39:41.263 debug (12300) Objects create User PubSub Client gartenbewaesserung.0 2021-05-26 19:39:41.262 debug (12300) Objects create System PubSub Client gartenbewaesserung.0 2021-05-26 19:39:41.259 debug (12300) Objects client ready ... initialize now gartenbewaesserung.0 2021-05-26 19:39:41.215 debug (12300) Redis Objects: Use Redis connection: 127.0.0.1:9001gartenbewaesserung.0 2021-05-26 19:42:42.836 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:42:32.839 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:42:22.834 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:42:12.837 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:42:02.837 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:41:52.833 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:41:46.796 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:41:46.795 warn (12300) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052706" gartenbewaesserung.0 2021-05-26 19:41:46.794 warn (12300) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:11:46 GMT+0200" gartenbewaesserung.0 2021-05-26 19:41:46.793 info (12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string" gartenbewaesserung.0 2021-05-26 19:41:46.779 info (12300) Start ventil1 gartenbewaesserung.0 2021-05-26 19:41:46.762 info (12300) Stop ventil4 in 5130sek gartenbewaesserung.0 2021-05-26 19:41:46.762 info (12300) Start ventil4 in 3630sek gartenbewaesserung.0 2021-05-26 19:41:46.761 info (12300) Stop ventil3 in 3620sek gartenbewaesserung.0 2021-05-26 19:41:46.761 info (12300) Stop ventil2 in 3610sek gartenbewaesserung.0 2021-05-26 19:41:46.760 info (12300) Start ventil2 in 1810sek gartenbewaesserung.0 2021-05-26 19:41:46.760 info (12300) Stop ventil1 in 1800sek gartenbewaesserung.0 2021-05-26 19:41:46.759 info (12300) Start ventil1 in 0sek gartenbewaesserung.0 2021-05-26 19:41:46.739 info (12300) Start pumpe gartenbewaesserung.0 2021-05-26 19:41:46.738 info (12300) Start Bewaesserung gartenbewaesserung.0 2021-05-26 19:41:46.599 info (12300) Stop ventil4 gartenbewaesserung.0 2021-05-26 19:41:46.599 info (12300) Stop ventil3 gartenbewaesserung.0 2021-05-26 19:41:46.599 info (12300) Stop ventil2 gartenbewaesserung.0 2021-05-26 19:41:46.598 info (12300) Stop ventil1 gartenbewaesserung.0 2021-05-26 19:41:46.597 info (12300) Bewässerung stop -
Nur mal so eine Idee - hängt die folgende Fehlermeldung des Adapters ggf. damit zusammen, das die Astro Funktion, in den Sommermonaten ab Bielefeld und weiter nördlich diesen Fehler generiert?
gartenbewaesserung.0 2021-05-28 14:09:43.090 warn (12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622227340"Siehe - https://forum.iobroker.net/topic/45192/javajcript-und-astro-funktion-macht-propleme
javascript.0 2021-05-28 14:00:00.033 error (11640) Cannot get astro date for "night" javascript.0 2021-05-28 14:00:00.028 error (11640) Cannot get astro date for "nightEnd" -
javascript.0 2021-05-28 14:00:00.033 error (11640) Cannot get astro date for "night" javascript.0 2021-05-28 14:00:00.028 error (11640) Cannot get astro date for "nightEnd"@jb_sullivan
Ich vermute das auch. Ich habe hier ein Script mit einer kleinen Variation. Das läuft auch im Sommer einwandfrei. Ich wohne auch nördlich von Bielefeld. Da gibt es im Sommer Probleme mit dem Datenpunkt "Nacht". Ich glaube, dass Script stammt von Paul.Hier der Code:
const sec = false; // Sekunden darstellen oder nicht const fC = true; // forceCreation ein/aus const pfad = "Astro"; // Pfad zum Objekt - Objektbaum-Hauptverzeichnis // ***************************************************************************** // TAGESZEITEN - T E I L // Tageszeiten nach eigenem Gusto (Shifts siehe schedules weiter unten) const tageszeiten = ["Nacht", "Morgendämmerung", "Sonnenaufgang", "Morgen", "Vormittag", "Mittag", "Nachmittag", "Abend", "Sonnenuntergang", "Abenddämmerung" ]; const idTageszeit = "javascript." + instance + "." + pfad + ".Tageszeit.current" /*Tageszeit*/, idTageszeitNext = "javascript." + instance + "." + pfad + ".Tageszeit.next"; createState(idTageszeit, "nächsten Wechsel abwarten", fC, { name: "Tageszeit", desc: "Name der Tageszeit", type: "string" }); createState(idTageszeitNext, "nächsten Wechsel abwarten", fC, { name: "nächste Tageszeit", desc: "Name der nächsten Tageszeit", type: "string" }); function neue_tageszeit(abschnitt) { var akt = tageszeiten[parseInt(abschnitt, 10)], // wenn aktuelles Element ist letztes, dann nächstes ist erstes :-D nxt = (abschnitt + 1 === tageszeiten.length) ? tageszeiten[0] : tageszeiten[parseInt(abschnitt + 1, 10)]; setState(idTageszeit, akt); setState(idTageszeitNext, nxt); log("neue Tagezeit: " + akt); log("nächte kommende Tagezeit: " + nxt); } // Nacht schedule({ astro: "nauticalDusk", shift: 45 }, function () { neue_tageszeit(0); }); // Morgengdämmerung schedule({ astro: "nauticalDawn", shift: -45 }, function () { neue_tageszeit(1); }); // Sonnenaufgang schedule({ astro: "sunrise" }, function() { neue_tageszeit(2); }); // Morgen schedule({ astro: "sunriseEnd" }, function () { neue_tageszeit(3); }); // Vormittag schedule({ astro: "goldenHourEnd", shift: 60 }, function () { neue_tageszeit(4); }); // Mittag schedule({ astro: "solarNoon", shift: -30 }, function () { neue_tageszeit(5); }); // Nachmittag schedule({ astro: "solarNoon", shift: 30 }, function () { neue_tageszeit(6); }); // Abend schedule({ astro: "goldenHour", shift: -60 }, function () { neue_tageszeit(7); }); // Sonnenuntergang schedule({ astro: "sunsetStart", }, function () { neue_tageszeit(8); }); // Abenddämmerung (nach Sonnenuntergang) schedule({ astro: "sunset" }, function () { neue_tageszeit(9); }); // ***************************************************************************** // A S T O - T E I L /* Objekt Astrotag Astrotag liegt zwischen Sonnauf- und untergang, Astronacht liegt zwischen Sonnenunter- und aufgang */ const idAstrotag = "javascript." + instance + "." + pfad + ".Astrotag"; // Objekt für Uhrzeiten der Astrozeiten const astrotime = { "elements" : [ // Astrotag beginnt { "fname" : "sunrise", // function name "de" : { "name" : "Sonnenaufgang", "nxt" : "nächster", "desc" : "" }, "en" : { "name" : "Sunrise", "desc" : "top edge of the sun appears on the horizon" }, "astroday" : true //during astroday }, { "fname" : "sunriseEnd", // function name "de" : { "name" : "Ende Sonnenaufgang", "nxt" : "nächstes", "desc" : "" }, "en" : { "name" : "End of sunrise", "desc" : "bottom edge of the sun touches the horizon" }, "astroday" : true //during astroday }, { "fname" : "goldenHourEnd", // function name "de" : { "name" : "Ende der goldenen Stunde am Morgen", "nxt" : "nächstes", "desc" : "" }, "en" : { "name" : "End of golden hour", "desc" : "morning golden hour (soft light, best time for photography) ends" }, "astroday" : true //during astroday }, { "fname" : "solarNoon", // function name "de" : { "name" : "Sonnenhöchststand", "nxt" : "nächster", "desc" : "" }, "en" : { "name" : "Solar noon", "desc" : "sun is in the highest position" }, "astroday" : true //during astroday }, { "fname" : "goldenHour", // function name "de" : { "name" : "Goldene Stunde (am Abend)", "nxt" : "nächste", "desc" : "" }, "en" : { "name" : "Golden hour", "desc" : "evening golden hour starts" }, "astroday" : true //during astroday }, { "fname" : "sunsetStart", // function name "de" : { "name" : "Beginn Sonnenuntergang", "nxt" : "nächster", "desc" : "" }, "en" : { "name" : "Sunset starts", "desc" : "bottom edge of the sun touches the horizon" }, "astroday" : true //during astroday }, // Astronacht beginnt { "fname" : "sunset", // function name "de" : { "name" : "Sonnenuntergang", "nxt" : "nächster", "desc" : "" }, "en" : { "name" : "Sunset", "desc" : "sun disappears below the horizon, evening civil twilight starts" }, "astroday" : false //during astronight }, { "fname" : "dusk", "de" : { "name" : "Abenddämmerung", "nxt" : "nächste", "desc" : "" }, "en" : { "name" : "Dusk", "desc" : "evening nautical twilight starts" }, "astroday" : false //during astronight }, { "fname" : "nauticalDusk", "de" : { "name" : "nautische Abenddämmerung", "nxt" : "nächste", "desc" : "" }, "en" : { "name" : "Nautical dusk", "desc" : "evening astronomical twilight starts" }, "astroday" : false //during astronight }, { "fname" : "nadir", "de" : { "name" : "Nadir", "nxt" : "nächster", "desc" : "Fußpunkt gegenüber dem Zenit" }, "en" : { "name" : "Nadir", "desc" : "darkest moment of the night, sun is in the lowest position" }, "astroday" : false //during astronight }, { "fname" : "nauticalDawn", "de" : { "name" : "nautische Morgendämmerung", "nxt" : "nächste", "desc" : "" }, "en" : { "name" : "Nautical dawn", "desc" : "morning nautical twilight starts" }, "astroday" : false //during astronight }, { "fname" : "dawn", "de" : { "name" : "Morgendämmerung", "nxt" : "nächste", "desc" : "" }, "en" : { "name" : "dawn", "desc" : "morning nautical twilight ends, morning civil twilight starts" }, "astroday" : false //during astronight } ] }; function writeAstroTimes(i) { // führende Nummer zur Sortierung in Admin/Objekte var nr = (i+1 < 10) ? "0" + (i+1) : (i+1); // Erstelle Objekt, falls nicht bereits vorhanden var idAstroObject = "javascript." + instance + "." + pfad + ".Zeiten." + nr + " - " + astrotime.elements[i].fname; createState(idAstroObject, " ", fC, { name: astrotime.elements[i].de.nxt + " " + astrotime.elements[i].de.name + " Uhrzeit", desc: astrotime.elements[i].en.desc, type: "string" }); setTimeout(function() { // kurz warten, damit Objekte ggf. erst angelgt werden können var astrotag = getState(idAstrotag).val, temp; var today = new Date(); var tomorrow = today.setDate(today.getDate()+1); var next_event; if (astrotag) { // Wenn Tag (Aufgang vorbei (erst wieder morgen, Untergang kommt noch heute) next_event = (astrotime.elements[i].astroday) ? tomorrow : today; // prüfen } else { // nach Nacht (Untergang vorbei (erst wieder morgen, Aufgang kommt heute oder morgen) next_event = (astrotime.elements[i].astroday) ? today : tomorrow; // prüfen } var fname = astrotime.elements[i].fname; temp = getAstroDate(fname, next_event); setState(idAstroObject, checkSec(temp.toLocaleTimeString()) ); }, 3 * 1000); } // Zeit mit oder ohne Sekunden anzeigen function checkSec (zeit) { if (!sec) { var newString_arr = zeit.split(":"); var newString = newString_arr[0] + ":" + newString_arr[1]; return (newString); } else return (zeit); } function getAstroday() { // Astrotag bestimmen (boolean) createState(idAstrotag, false, fC, { type: "boolean", name: "Astrologischer Tag", desc: "Liegt die aktuelle Zeit zwischen Sonnenauf- und untergang" }); setState(idAstrotag, isAstroDay()); } function iterateAstrotimes() { // Zeiten für jede Astrozeit schreiben for (var i = 0; i < astrotime.elements.length; i++) { writeAstroTimes(i); } } // Astrotag checken schedule("*/1 * * * *", function () { // jede Minute getAstroday(); iterateAstrotimes(); }); iterateAstrotimes(); getAstroday(); -
Gibt es denn nen Workaround dafür, dass bei jeder Änderung über die VIS der Adapter neustartet? Hat sich dort schon mal jemand was gebastelt? Ist ja schrecklich, wenn man viele Kreise besitzt :(
@tombox
Ich wollte gerade von meiner Testinstallation auf die produktive einsteigen und fand den Adapter weder in Beta noch im stable Repository.Dann wollte ich fragen, ob dieser Adapter noch weiter entwickelt wird und hatte auf github nachgesehen. Dort sind letzten Monat noch Änderungen durchgeführt worden.
Daher wndertze ich mich., als ich auf der Suche nach dem Github link im ersten Post las:
@tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
Die bessere alternative die auch weiterentwickelt wird ist:
https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
https://forum.iobroker.net/topic/44493/test-adapter-sprinkle-control-0-1-4-latestDas ist leider für mich keine Alternative, da dieser Adapter ausschließlich auf Vorhersagen und Verdunstungsberechnungen basiert.
Ich arbeite mit Feuchtesensoren (so ungenau sie auch sein mögen) und werde mir dann wohl doch eigene Scripte basteln müssen :-(
Oder ist diese Info inzwischen hoffentlich wieder überholt?
@tombox
@homoran Er wird nicht weiter entwickelt habe nur die sachen für js controller 3.3 gefixt. Ich denke aber das sprinkecontrol einbaut wenn du die anfrage stellst
@tombox Danke für die schnelle und ehrliche Antwort.
Aber ehrlich ist dein Adapter für mich besser, Sprinkle control hatte ich mir mal angesehen, da sind für mich zu viele Funktionen/Berechnungsgrundlagen, die ich nicht benötige, und solche Antworten wie:
Es tut mir leid, aber diese Änderung steht nicht im Einklang mit den Grundprinzipien des Adapters. Ich werde sie daher nicht umsetzen.
Erledige diese individuellen Aufgaben doch mit JS oder Blockly.motivieren nicht gerade.
@tombox hat bestimmt mit dem VW Wallbox Adapter genug zu tun, zumal der VAG Konzern die e-Autos z.Zt. raushaut wie geschnitten Brot und sich somit auch alle Nase lang etwas an den WB Einstellungen ändern dürfte.
Von daher habe ich dafür schon ein gewisses Verständnis. Aber mir geht es wie dir - der Gartenbewässerungsadapter von tombox ist einfach nur geil und leistet mir dieses, wie auch letztes Jahr hervorragende Dienste.
Hauptsache er bleibt noch lange lauffähig.
@jb_sullivan sagte in Test Adapter Gartenbewässerung v0.0.x:
das hab ich doch auch!
Aber ich brauche den Schnickschnack von sprinkle nicht
Sitze mit meinem bescheidenen Wissen gerade am Blockly -
Sitze mit meinem bescheidenen Wissen gerade am Blockly@homoran sagte in Test Adapter Gartenbewässerung v0.0.x:
Sitze mit meinem bescheidenen Wissen gerade am BlocklySo sehe ich das auch....Sprinkler C. ist zu verworren.
Der hier hat alles was man braucht und ist stabil.
Mit einem Blockly lässt sich das zwar lösen aber ich bin da kein Freund davon.Finde es mega schade das der Adapter atirbt
@bob-der-1 sagte in Test Adapter Gartenbewässerung v0.0.x:
naja, sagen wir mal der ist akademisch.
Wenn man alleine auf Regenmenge, Luftfeuchte, Windstärke und Helligkeit (als Sonneneinstrahlung!!) die theoretische Bodenfeuchte berechnet, werden alleine z.B. verschiedene Bödendurchlässigkeiten, und Pflanzgegebenheiten nicht berücksichtigt.
So habe ich zwei Pflanzmauern (1x 25cm breit, 1x 60cm breit) sowie eine Rasenfläche und unterschiedlich wind- und sonnengeschützte Areale in meinem Garten (mit unterschiedlicher Bodenqualität)
in jedem spezifischen Areal steht ein Bodenfeuchtesensor und jedes dieser Areale soll je nach Bedarf getrennt bewässert werden (im Moment noch Mischbewässerung).
Dieses kann IMHO der Sprinkle-Adapter nicht abbilden.Ich hatte ihn gerade trotzdem noch mal installiert, finde aber keine einfache Möglichkeit eine Herangehensweise wie mit dem Gartenbewässerungs-Adapter dort abzubilden.
Dazu sind die beiden Ansätze zu unterschiedlich -
Könnte man den Adaper nicht in die Community aufnehmen, damit er uns erhalten bleibt und Erweiterungen möglich sind?
Wenn @tombox nichts dagegen hat? -
Wenn @tombox nichts dagegen hat?@sigi234
Dafür müsste er wahrscheinlich erstmal die "bürokratischen" Hürden der ioBroker Oberen überwinden, denn bis heute ist er weder im latest noch im stable zu finden.Entweder hat sich tombox gar nicht um eine Aufnahme bemüht, oder er müsste den Adapter in großen Teilen umschreiben, damit er überhaupt aufgenommen werden kann. Vielleicht liegt da die Kruxx mit der Weiterentwicklung - wer weiß das schon.
Ich kenne noch einen anderen Adapter der Super ist (BYDHVS) und der seit Wochen darauf wartet überhaupt aufgenommen zu werden. Der Entwickler hat seinen Teil wohl erledigt und nun wartet und wartet er.
Offensichtlich sind die "Master of Adapter Freigaben" im Moment mehr mit Admin 5.x und js-controller 3.3.x beschäftigt ;) - nicht böse gemeint
@sigi234
ich denke. das hat er ja gerade gemacht.
bei einer Versionsnummer von 0.0.7 wäre das auch gar nicht verwunderlich.
Aber sie läuft ja im Prinzip problemlos.
Da könnte IMHO die Version deutlich hochgesetzt werden, da (mir) der Funktionsumfang so vollkommen in Ordnung erscheint@jb_sullivan sagte in Test Adapter Gartenbewässerung v0.0.x:
Das ist ein anderes Thema
Das hat nichts miteinander zu tun, da müsste erst einmal der "Antrag gestellt werden".
@sigi234
@jb_sullivan Ich habe ihn nie in latest hinzugefügt weil er minimum dynamisch anzahl von ventile unterstützen müsste dafür. Dann kam der sprinkecontroler der ein guten Funktionsumfang hat und deswegen war für mich kein notwendigkeit ihn weiterzuentwickeln damit er beta/latest wird. Aber ich habe kein Problem damit ihn zu warten damit er funktionsfähig bleibt.
