  4. Test Adapter Gartenbewässerung v0.0.x
beregnungssteuerungbewässerunggartengartenbewässerungmagnetventilventilventile
567 Beiträge 66 Kommentatoren 230.5k Aufrufe 77 Beobachtet
  • JB_SullivanJ JB_Sullivan
    @tombox
    Ich wollte gerade das Update auf die Version 0.0.8 machen, weil ich immer noch die folgenden Fehler angezeigt bekommen.
    gartenbewaesserung.0	2021-05-26 10:05:05.700	warn	(248) Read-only state "gartenbewaesserung.0.status.startAbend" has been written without ack-flag with value "Wed May 26 2021 20:39:43 GMT+0200"
    gartenbewaesserung.0	2021-05-26 10:05:05.699	warn	(248) Read-only state "gartenbewaesserung.0.status.startMorgen" has been written without ack-flag with value "Wed May 26 2021 05:40:21 GMT+0200"
    gartenbewaesserung.0	2021-05-26 10:05:05.698	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenuntergang" has been written without ack-flag with value "21:24:43 GMT+0200 (Mitteleuropäische Sommerzeit)"
    gartenbewaesserung.0	2021-05-26 10:05:05.697	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenaufgang" has been written without ack-flag with value "05:10:21 GMT+0200 (Mitteleuropäische Sommerzeit)"
    gartenbewaesserung.0	2021-05-26 10:05:05.541	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.539	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.538	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.522	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.521	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.520	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.517	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.514	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.513	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.512	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.511	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.510	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.509	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.508	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.507	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.506	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.504	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.503	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.502	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.501	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.500	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.498	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
    Seit der Admin Version 5.x.x funktioniert unter ioB / Windows aber das Adapter Update aus dem Admin heraus bei manchen Adapter nicht mehr. Es kommt dann ein sogenannter EBUSY Fehler. Leider gehört dein Adapter dazu.
    Der Workaround ist das Update aus der Konsole heraus durchzuführen. Aber auch das funktioniert im Fall der Version 0.0.8 nicht.
    Hast du eine Idee dazu?
    C:\iobroker\GLT>npm install iobroker.gartenbewaesserung@0.0.8
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.gartenbewaesserung - Not found
    npm ERR! 404
    npm ERR! 404  'iobroker.gartenbewaesserung@0.0.8' is not in the npm registry.
    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     C:\iobroker\GLT\env\npm-cache\_logs\2021-05-26T08_17_13_008Z-debug.log
    C:\iobroker\GLT>
    T
    T
    tombox
    #495
    @jb_sullivan Installation geht nur über GitHub Katze wie im ersten Beitrag beschrieben
    • T tombox
      JB_SullivanJ
      JB_SullivanJ
      JB_Sullivan
      #496
      @tombox
      Wie gesagt, GITHUB Katze geht derzeit unter Admin 5.x.x wegen EBUSY Fehler nicht.
      Ich habe es aber doch noch hin bekommen und habe jetzt die 0.0.8 drauf. Trotzdem tauchen im LOG immer noch ein paar Fehlermeldungen auf.
      gartenbewaesserung.0	2021-05-26 10:44:59.822	warn	(5768) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
      gartenbewaesserung.0	2021-05-26 10:44:59.811	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
      gartenbewaesserung.0	2021-05-26 10:44:59.809	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
      gartenbewaesserung.0	2021-05-26 10:44:59.802	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
      gartenbewaesserung.0	2021-05-26 10:44:59.801	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
      gartenbewaesserung.0	2021-05-26 10:44:59.799	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
      gartenbewaesserung.0	2021-05-26 10:44:59.798	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
      gartenbewaesserung.0	2021-05-26 10:44:59.797	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
      gartenbewaesserung.0	2021-05-26 10:44:59.795	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
        @tombox
        T
        T
        tombox
        #497
        @jb_sullivan die objekte müssen vorher gelöscht werden damit sie korrekt neu erstellt werden
        • T tombox
          JB_SullivanJ
          JB_SullivanJ
          JB_Sullivan
          #498
          @tombox Habe ich gemacht, aber das ändert nichts.
          gartenbewaesserung.0	2021-05-26 19:31:28.417	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
          gartenbewaesserung.0	2021-05-26 19:31:28.415	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
          gartenbewaesserung.0	2021-05-26 19:31:28.414	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
          gartenbewaesserung.0	2021-05-26 19:31:28.412	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
          gartenbewaesserung.0	2021-05-26 19:31:28.393	info	(1988) Stop ventil4
          gartenbewaesserung.0	2021-05-26 19:31:28.388	info	(1988) Stop ventil3
          gartenbewaesserung.0	2021-05-26 19:31:28.383	info	(1988) Stop ventil2
          gartenbewaesserung.0	2021-05-26 19:31:28.378	info	(1988) Stop ventil1
          gartenbewaesserung.0	2021-05-26 19:31:28.377	info	(1988) Bewässerung stop
          gartenbewaesserung.0	2021-05-26 19:31:24.440	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
          gartenbewaesserung.0	2021-05-26 19:31:24.439	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052084"
          gartenbewaesserung.0	2021-05-26 19:31:24.438	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:01:24 GMT+0200"
          gartenbewaesserung.0	2021-05-26 19:31:24.437	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
          gartenbewaesserung.0	2021-05-26 19:31:24.426	info	(1988) Start ventil1
          gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil4 in 5130sek
          gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Start ventil4 in 3630sek
          gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil3 in 3620sek
          gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Stop ventil2 in 3610sek
          gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Start ventil2 in 1810sek
          gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Stop ventil1 in 1800sek
          gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Start ventil1 in 0sek
          gartenbewaesserung.0	2021-05-26 19:31:24.377	info	(1988) Start pumpe
          gartenbewaesserung.0	2021-05-26 19:31:24.376	info	(1988) Start Bewaesserung
          gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil4
          gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil3
          gartenbewaesserung.0	2021-05-26 19:31:24.193	info	(1988) Stop ventil2
          gartenbewaesserung.0	2021-05-26 19:31:24.192	info	(1988) Stop ventil1
          gartenbewaesserung.0	2021-05-26 19:31:24.191	info	(1988) Bewässerung stop
          gartenbewaesserung.0	2021-05-26 19:30:51.762	warn	(1988) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
            T
            T
            tombox
            #499
            @jb_sullivan Sollte so nicht passieren.. Alle objekte löschen. Per github installieren und instanz neustarten?
            • T tombox
              JB_SullivanJ
              JB_SullivanJ
              JB_Sullivan
              schrieb am zuletzt editiert von JB_Sullivan
              #500
              @tombox Genau so - habe ich alles genau so gemacht. Admin und js-controler ist latest letzter Stand.
              Habe es nochmal auf DEBUG gestellt - aber da kommt auch nicht viel bei raus.
              gartenbewaesserung.0	2021-05-26 19:39:46.507	debug	(12300) system.adapter.admin.0: logging true
              gartenbewaesserung.0	2021-05-26 19:39:42.848	warn	(12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
              gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil4
              gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil3
              gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil2
              gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil1
              gartenbewaesserung.0	2021-05-26 19:39:42.736	info	(12300) Bewässerung stop
              gartenbewaesserung.0	2021-05-26 19:39:42.735	info	(12300) Stop ventil4
              gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil3
              gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil2
              gartenbewaesserung.0	2021-05-26 19:39:42.731	info	(12300) Stop ventil1
              gartenbewaesserung.0	2021-05-26 19:39:41.743	info	(12300) starting. Version 0.0.8 in C:/iobroker/GLT/node_modules/iobroker.gartenbewaesserung, node: v14.16.0, js-controller: 3.3.11
              gartenbewaesserung.0	2021-05-26 19:39:41.325	debug	(12300) statesDB connected
              gartenbewaesserung.0	2021-05-26 19:39:41.324	debug	(12300) States connected to redis: 127.0.0.1:9000
              gartenbewaesserung.0	2021-05-26 19:39:41.310	debug	(12300) States create User PubSub Client
              gartenbewaesserung.0	2021-05-26 19:39:41.309	debug	(12300) States create System PubSub Client
              gartenbewaesserung.0	2021-05-26 19:39:41.296	debug	(12300) Redis States: Use Redis connection: 127.0.0.1:9000
              gartenbewaesserung.0	2021-05-26 19:39:41.294	debug	(12300) objectDB connected
              gartenbewaesserung.0	2021-05-26 19:39:41.284	debug	(12300) Objects connected to redis: 127.0.0.1:9001
              gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects client initialize lua scripts
              gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects create User PubSub Client
              gartenbewaesserung.0	2021-05-26 19:39:41.262	debug	(12300) Objects create System PubSub Client
              gartenbewaesserung.0	2021-05-26 19:39:41.259	debug	(12300) Objects client ready ... initialize now
              gartenbewaesserung.0	2021-05-26 19:39:41.215	debug	(12300) Redis Objects: Use Redis connection: 127.0.0.1:9001
              gartenbewaesserung.0	2021-05-26 19:42:42.836	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:42:32.839	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:42:22.834	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:42:12.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:42:02.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:41:52.833	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:41:46.796	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:41:46.795	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052706"
              gartenbewaesserung.0	2021-05-26 19:41:46.794	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:11:46 GMT+0200"
              gartenbewaesserung.0	2021-05-26 19:41:46.793	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
              gartenbewaesserung.0	2021-05-26 19:41:46.779	info	(12300) Start ventil1
              gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Stop ventil4 in 5130sek
              gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Start ventil4 in 3630sek
              gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil3 in 3620sek
              gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil2 in 3610sek
              gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Start ventil2 in 1810sek
              gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Stop ventil1 in 1800sek
              gartenbewaesserung.0	2021-05-26 19:41:46.759	info	(12300) Start ventil1 in 0sek
              gartenbewaesserung.0	2021-05-26 19:41:46.739	info	(12300) Start pumpe
              gartenbewaesserung.0	2021-05-26 19:41:46.738	info	(12300) Start Bewaesserung
              gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil4
              gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil3
              gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil2
              gartenbewaesserung.0	2021-05-26 19:41:46.598	info	(12300) Stop ventil1
              gartenbewaesserung.0	2021-05-26 19:41:46.597	info	(12300) Bewässerung stop
              • JB_SullivanJ
                JB_SullivanJ
                JB_Sullivan
                #501
                Nur mal so eine Idee - hängt die folgende Fehlermeldung des Adapters ggf. damit zusammen, das die Astro Funktion, in den Sommermonaten ab Bielefeld und weiter nördlich diesen Fehler generiert?
                gartenbewaesserung.0	2021-05-28 14:09:43.090	warn	(12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622227340"
                Siehe - https://forum.iobroker.net/topic/45192/javajcript-und-astro-funktion-macht-propleme
                javascript.0	2021-05-28 14:00:00.033	error	(11640) Cannot get astro date for "night"
                javascript.0	2021-05-28 14:00:00.028	error	(11640) Cannot get astro date for "nightEnd"
                  M
                  M
                  MartyBr
                  #502
                  @jb_sullivan
                  Ich vermute das auch. Ich habe hier ein Script mit einer kleinen Variation. Das läuft auch im Sommer einwandfrei. Ich wohne auch nördlich von Bielefeld. Da gibt es im Sommer Probleme mit dem Datenpunkt "Nacht". Ich glaube, dass Script stammt von Paul.
                  Hier der Code:
                  const sec = false; // Sekunden darstellen oder nicht
                  const fC = true; // forceCreation ein/aus
                  const pfad = "Astro"; // Pfad zum Objekt - Objektbaum-Hauptverzeichnis
                  // TAGESZEITEN - T E I L
                  // Tageszeiten nach eigenem Gusto (Shifts siehe schedules weiter unten)
                  const tageszeiten = ["Nacht",
                                       "Morgendämmerung",
                                       "Sonnenaufgang",
                                       "Morgen",
                                       "Vormittag",
                                       "Mittag",
                                       "Nachmittag",
                                       "Abend",
                                       "Sonnenuntergang",
                                       "Abenddämmerung"
                  const idTageszeit = "javascript." + instance  + "." + pfad + ".Tageszeit.current" /*Tageszeit*/,
                        idTageszeitNext = "javascript." + instance  + "." + pfad + ".Tageszeit.next";
                  createState(idTageszeit, "nächsten Wechsel abwarten", fC, {
                      desc: "Name der Tageszeit",
                      type: "string"
                  createState(idTageszeitNext, "nächsten Wechsel abwarten", fC, {
                      name: "nächste Tageszeit",
                      desc: "Name der nächsten Tageszeit",
                      type: "string"
                  function neue_tageszeit(abschnitt) {
                      var akt = tageszeiten[parseInt(abschnitt, 10)],
                      // wenn aktuelles Element ist letztes, dann nächstes ist erstes :-D
                      nxt = (abschnitt + 1 === tageszeiten.length) ? tageszeiten[0] : tageszeiten[parseInt(abschnitt + 1, 10)];
                      setState(idTageszeit, akt);
                      setState(idTageszeitNext, nxt);
                      log("neue Tagezeit: " + akt);
                      log("nächte kommende Tagezeit: " + nxt);
                  // Nacht
                  schedule({
                      astro: "nauticalDusk",
                      shift: 45
                  }, function () {
                      neue_tageszeit(0);
                  // Morgengdämmerung
                  schedule({
                      astro: "nauticalDawn",
                      shift: -45
                  }, function () {
                      neue_tageszeit(1);
                  // Sonnenaufgang
                  schedule({
                      astro: "sunrise"
                  }, function() {
                      neue_tageszeit(2);
                  // Morgen
                  schedule({
                      astro: "sunriseEnd"
                  }, function () {
                      neue_tageszeit(3);
                  // Vormittag
                  schedule({
                      astro: "goldenHourEnd",
                      shift: 60
                  }, function () {
                      neue_tageszeit(4);
                  // Mittag
                  schedule({
                      astro: "solarNoon",
                      shift: -30
                  }, function () {
                      neue_tageszeit(5);
                  // Nachmittag
                  schedule({
                      astro: "solarNoon",
                      shift: 30
                  }, function () {
                      neue_tageszeit(6);
                  // Abend
                  schedule({
                      astro: "goldenHour",
                      shift: -60
                  }, function () {
                      neue_tageszeit(7);
                  // Sonnenuntergang
                  schedule({
                      astro: "sunsetStart",
                  }, function () {
                      neue_tageszeit(8);
                  // Abenddämmerung (nach Sonnenuntergang)
                  schedule({
                      astro: "sunset"
                  }, function () {
                      neue_tageszeit(9);
                  // A S T O - T E I L
                  /* Objekt Astrotag
                     Astrotag liegt zwischen Sonnauf- und untergang,
                     Astronacht liegt zwischen Sonnenunter- und aufgang */
                  const idAstrotag =  "javascript." + instance + "." + pfad + ".Astrotag";
                  // Objekt für Uhrzeiten der Astrozeiten
                  const astrotime = {
                      "elements" : [
                          // Astrotag beginnt
                              "fname" : "sunrise", // function name
                              "de" : {
                                  "name" : "Sonnenaufgang",
                                  "nxt" : "nächster",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Sunrise",
                                  "desc" : "top edge of the sun appears on the horizon"
                              "astroday" : true //during astroday
                              "fname" : "sunriseEnd", // function name
                              "de" : {
                                  "name" : "Ende Sonnenaufgang",
                                  "nxt" : "nächstes",
                                  "desc" : ""
                              "en" : {
                                  "name" : "End of sunrise",
                                  "desc" : "bottom edge of the sun touches the horizon"
                              "fname" : "goldenHourEnd", // function name
                              "de" : {
                                  "name" : "Ende der goldenen Stunde am Morgen",
                                  "nxt" : "nächstes",
                                  "desc" : ""
                              "en" : {
                                  "name" : "End of golden hour",
                                  "desc" : "morning golden hour (soft light, best time for photography) ends"
                              "fname" : "solarNoon", // function name
                              "de" : {
                                  "name" : "Sonnenhöchststand",
                                  "nxt" : "nächster",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Solar noon",
                                  "desc" : "sun is in the highest position"
                              "fname" : "goldenHour", // function name
                              "de" : {
                                  "name" : "Goldene Stunde (am Abend)",
                                  "nxt" : "nächste",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Golden hour",
                                  "desc" : "evening golden hour starts"
                              "fname" : "sunsetStart", // function name
                              "de" : {
                                  "name" : "Beginn Sonnenuntergang",
                                  "nxt" : "nächster",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Sunset starts",
                          // Astronacht beginnt
                              "fname" : "sunset", // function name
                              "de" : {
                                  "name" : "Sonnenuntergang",
                                  "nxt" : "nächster",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Sunset",
                                  "desc" : "sun disappears below the horizon, evening civil twilight starts"
                              "astroday" : false //during astronight
                              "fname" : "dusk",
                              "de" : {
                                  "name" : "Abenddämmerung",
                                  "nxt" : "nächste",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Dusk",
                                  "desc" : "evening nautical twilight starts"
                              "fname" : "nauticalDusk",
                              "de" : {
                                  "name" : "nautische Abenddämmerung",
                                  "nxt" : "nächste",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Nautical dusk",
                                  "desc" : "evening astronomical twilight starts"
                              "fname" : "nadir",
                              "de" : {
                                  "name" : "Nadir",
                                  "nxt" : "nächster",
                                  "desc" : "Fußpunkt gegenüber dem Zenit"
                              "en" : {
                                  "name" : "Nadir",
                                  "desc" : "darkest moment of the night, sun is in the lowest position"
                              "fname" : "nauticalDawn",
                              "de" : {
                                  "name" : "nautische Morgendämmerung",
                                  "nxt" : "nächste",
                                  "desc" : ""
                              "en" : {
                                  "name" : "Nautical dawn",
                                  "desc" : "morning nautical twilight starts"
                              "fname" : "dawn",
                              "de" : {
                                  "name" : "Morgendämmerung",
                                  "nxt" : "nächste",
                                  "desc" : ""
                              "en" : {
                                  "name" : "dawn",
                                  "desc" : "morning nautical twilight ends, morning civil twilight starts"
                  function writeAstroTimes(i) {
                      // führende Nummer zur Sortierung in Admin/Objekte
                      var nr = (i+1 < 10) ? "0" + (i+1) : (i+1);
                      // Erstelle Objekt, falls nicht bereits vorhanden
                      var idAstroObject = "javascript." + instance + "." + pfad + ".Zeiten." + nr + " - " + astrotime.elements[i].fname;
                      createState(idAstroObject, " ", fC, {
                          name: astrotime.elements[i].de.nxt + " " + astrotime.elements[i].de.name + " Uhrzeit",
                          desc: astrotime.elements[i].en.desc,
                          type: "string"
                      setTimeout(function() { // kurz warten, damit Objekte ggf. erst angelgt werden können
                          var astrotag = getState(idAstrotag).val,
                              temp;
                          var today = new Date();
                          var tomorrow = today.setDate(today.getDate()+1);
                          var next_event;
                          if (astrotag) {
                              // Wenn Tag (Aufgang vorbei (erst wieder morgen, Untergang kommt noch heute)
                              next_event = (astrotime.elements[i].astroday) ? tomorrow : today; // prüfen
                          } else {
                              // nach Nacht (Untergang vorbei (erst wieder morgen, Aufgang kommt heute oder morgen)
                              next_event = (astrotime.elements[i].astroday) ? today : tomorrow; // prüfen
                          var fname = astrotime.elements[i].fname;
                          temp = getAstroDate(fname, next_event);
                          setState(idAstroObject, checkSec(temp.toLocaleTimeString()) );
                      }, 3 * 1000);
                  // Zeit mit oder ohne Sekunden anzeigen
                  function checkSec (zeit) {
                      if (!sec) {
                          var newString_arr = zeit.split(":");
                          var newString = newString_arr[0] + ":" + newString_arr[1];
                          return (newString);
                      } else return (zeit);
                  function getAstroday() {
                      // Astrotag bestimmen (boolean)
                      createState(idAstrotag, false, fC, {
                          type: "boolean",
                          desc: "Liegt die aktuelle Zeit zwischen Sonnenauf- und untergang"
                      setState(idAstrotag, isAstroDay());
                  function iterateAstrotimes() {
                      // Zeiten für jede Astrozeit schreiben
                      for (var i = 0; i < astrotime.elements.length; i++) {
                          writeAstroTimes(i);
                  // Astrotag checken
                  schedule("*/1 * * * *", function () { // jede Minute
                      getAstroday();
                      iterateAstrotimes();
                  getAstroday();
                  Martin
                  Homematic und Homematic IP
                  • S
                    S
                    Snapergy
                    #503
                    Gibt es denn nen Workaround dafür, dass bei jeder Änderung über die VIS der Adapter neustartet? Hat sich dort schon mal jemand was gebastelt? Ist ja schrecklich, wenn man viele Kreise besitzt :(
                    • S Snapergy
                      T
                      T
                      tombox
                      #504
                      @snapergy Der Adapter ist leider nicht so aufgebaut dass das möglich ist.
                      • HomoranH
                        #505
                        @tombox
                        Ich wollte gerade von meiner Testinstallation auf die produktive einsteigen und fand den Adapter weder in Beta noch im stable Repository.
                        Dann wollte ich fragen, ob dieser Adapter noch weiter entwickelt wird und hatte auf github nachgesehen. Dort sind letzten Monat noch Änderungen durchgeführt worden.
                        Daher wndertze ich mich., als ich auf der Suche nach dem Github link im ersten Post las:
                        @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
                        Die bessere alternative die auch weiterentwickelt wird ist:
                        https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
                        https://forum.iobroker.net/topic/44493/test-adapter-sprinkle-control-0-1-4-latest
                        Das ist leider für mich keine Alternative, da dieser Adapter ausschließlich auf Vorhersagen und Verdunstungsberechnungen basiert.
                        Ich arbeite mit Feuchtesensoren (so ungenau sie auch sein mögen) und werde mir dann wohl doch eigene Scripte basteln müssen :-(
                        Oder ist diese Info inzwischen hoffentlich wieder überholt?
                          @tombox
                          T
                          T
                          tombox
                          #506
                          @homoran Er wird nicht weiter entwickelt habe nur die sachen für js controller 3.3 gefixt. Ich denke aber das sprinkecontrol einbaut wenn du die anfrage stellst
                          • T tombox
                            #507
                            @tombox Danke für die schnelle und ehrliche Antwort.
                            Aber ehrlich ist dein Adapter für mich besser, Sprinkle control hatte ich mir mal angesehen, da sind für mich zu viele Funktionen/Berechnungsgrundlagen, die ich nicht benötige, und solche Antworten wie:
                            Es tut mir leid, aber diese Änderung steht nicht im Einklang mit den Grundprinzipien des Adapters. Ich werde sie daher nicht umsetzen.
                            Erledige diese individuellen Aufgaben doch mit JS oder Blockly.
                            motivieren nicht gerade.
                              JB_SullivanJ
                              JB_SullivanJ
                              JB_Sullivan
                              #508
                              @tombox hat bestimmt mit dem VW Wallbox Adapter genug zu tun, zumal der VAG Konzern die e-Autos z.Zt. raushaut wie geschnitten Brot und sich somit auch alle Nase lang etwas an den WB Einstellungen ändern dürfte.
                              Von daher habe ich dafür schon ein gewisses Verständnis. Aber mir geht es wie dir - der Gartenbewässerungsadapter von tombox ist einfach nur geil und leistet mir dieses, wie auch letztes Jahr hervorragende Dienste.
                              Hauptsache er bleibt noch lange lauffähig.
                                #509
                                @jb_sullivan sagte in Test Adapter Gartenbewässerung v0.0.x:
                                das hab ich doch auch!
                                Aber ich brauche den Schnickschnack von sprinkle nicht
                                Sitze mit meinem bescheidenen Wissen gerade am Blockly
                                  B
                                  B
                                  bob der 1.
                                  #510
                                  @homoran sagte in Test Adapter Gartenbewässerung v0.0.x:
                                  So sehe ich das auch....Sprinkler C. ist zu verworren.
                                  Der hier hat alles was man braucht und ist stabil.
                                  Mit einem Blockly lässt sich das zwar lösen aber ich bin da kein Freund davon.
                                  Finde es mega schade das der Adapter atirbt
                                  • B bob der 1.
                                    #511
                                    @bob-der-1 sagte in Test Adapter Gartenbewässerung v0.0.x:
                                    naja, sagen wir mal der ist akademisch.
                                    Wenn man alleine auf Regenmenge, Luftfeuchte, Windstärke und Helligkeit (als Sonneneinstrahlung!!) die theoretische Bodenfeuchte berechnet, werden alleine z.B. verschiedene Bödendurchlässigkeiten, und Pflanzgegebenheiten nicht berücksichtigt.
                                    So habe ich zwei Pflanzmauern (1x 25cm breit, 1x 60cm breit) sowie eine Rasenfläche und unterschiedlich wind- und sonnengeschützte Areale in meinem Garten (mit unterschiedlicher Bodenqualität)
                                    in jedem spezifischen Areal steht ein Bodenfeuchtesensor und jedes dieser Areale soll je nach Bedarf getrennt bewässert werden (im Moment noch Mischbewässerung).
                                    Dieses kann IMHO der Sprinkle-Adapter nicht abbilden.
                                    Ich hatte ihn gerade trotzdem noch mal installiert, finde aber keine einfache Möglichkeit eine Herangehensweise wie mit dem Gartenbewässerungs-Adapter dort abzubilden.
                                    Dazu sind die beiden Ansätze zu unterschiedlich
                                    • sigi234S
                                      sigi234S
                                      #512
                                      Könnte man den Adaper nicht in die Community aufnehmen, damit er uns erhalten bleibt und Erweiterungen möglich sind?
                                      Wenn @tombox nichts dagegen hat?
                                      • sigi234S sigi234
                                        JB_SullivanJ
                                        JB_SullivanJ
                                        JB_Sullivan
                                        #513
                                        @sigi234
                                        Dafür müsste er wahrscheinlich erstmal die "bürokratischen" Hürden der ioBroker Oberen überwinden, denn bis heute ist er weder im latest noch im stable zu finden.
                                        Entweder hat sich tombox gar nicht um eine Aufnahme bemüht, oder er müsste den Adapter in großen Teilen umschreiben, damit er überhaupt aufgenommen werden kann. Vielleicht liegt da die Kruxx mit der Weiterentwicklung - wer weiß das schon.
                                        Ich kenne noch einen anderen Adapter der Super ist (BYDHVS) und der seit Wochen darauf wartet überhaupt aufgenommen zu werden. Der Entwickler hat seinen Teil wohl erledigt und nun wartet und wartet er.
                                        Offensichtlich sind die "Master of Adapter Freigaben" im Moment mehr mit Admin 5.x und js-controller 3.3.x beschäftigt ;) - nicht böse gemeint
                                        HomoranH T 2 Antworten Letzte Antwort
                                          @sigi234
                                          #514
                                          ich denke. das hat er ja gerade gemacht.
                                          bei einer Versionsnummer von 0.0.7 wäre das auch gar nicht verwunderlich.
                                          Aber sie läuft ja im Prinzip problemlos.
                                          Da könnte IMHO die Version deutlich hochgesetzt werden, da (mir) der Funktionsumfang so vollkommen in Ordnung erscheint
                                          Das ist ein anderes Thema
                                          Das hat nichts miteinander zu tun, da müsste erst einmal der "Antrag gestellt werden".
                                          84.2k
