  4. Test Adapter Gartenbewässerung v0.0.x
    6.7k
beregnungssteuerungbewässerunggartengartenbewässerungmagnetventilventilventile
567 Beiträge 66 Kommentatoren 186.0k Aufrufe 77 Beobachtet
  • JB_SullivanJ Offline
    JB_Sullivan
    #494
    @tombox
    Ich wollte gerade das Update auf die Version 0.0.8 machen, weil ich immer noch die folgenden Fehler angezeigt bekommen.
    gartenbewaesserung.0	2021-05-26 10:05:05.700	warn	(248) Read-only state "gartenbewaesserung.0.status.startAbend" has been written without ack-flag with value "Wed May 26 2021 20:39:43 GMT+0200"
    gartenbewaesserung.0	2021-05-26 10:05:05.699	warn	(248) Read-only state "gartenbewaesserung.0.status.startMorgen" has been written without ack-flag with value "Wed May 26 2021 05:40:21 GMT+0200"
    gartenbewaesserung.0	2021-05-26 10:05:05.698	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenuntergang" has been written without ack-flag with value "21:24:43 GMT+0200 (Mitteleuropäische Sommerzeit)"
    gartenbewaesserung.0	2021-05-26 10:05:05.697	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenaufgang" has been written without ack-flag with value "05:10:21 GMT+0200 (Mitteleuropäische Sommerzeit)"
    gartenbewaesserung.0	2021-05-26 10:05:05.541	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.539	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.538	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.522	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.521	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.520	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.517	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.514	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.513	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.512	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.511	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.510	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.509	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.508	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.507	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.506	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.504	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.503	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.502	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
    gartenbewaesserung.0	2021-05-26 10:05:05.501	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.500	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-26 10:05:05.498	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
    Seit der Admin Version 5.x.x funktioniert unter ioB / Windows aber das Adapter Update aus dem Admin heraus bei manchen Adapter nicht mehr. Es kommt dann ein sogenannter EBUSY Fehler. Leider gehört dein Adapter dazu.
    Der Workaround ist das Update aus der Konsole heraus durchzuführen. Aber auch das funktioniert im Fall der Version 0.0.8 nicht.
    Hast du eine Idee dazu?
    C:\iobroker\GLT>npm install iobroker.gartenbewaesserung@0.0.8
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.gartenbewaesserung - Not found
    npm ERR! 404
    npm ERR! 404  'iobroker.gartenbewaesserung@0.0.8' is not in the npm registry.
    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     C:\iobroker\GLT\env\npm-cache\_logs\2021-05-26T08_17_13_008Z-debug.log
    C:\iobroker\GLT>
    • JB_SullivanJ JB_Sullivan
      @tombox
      npm ERR! code E404
      npm ERR! 404
      npm ERR! 404
      C:\iobroker\GLT>
      tombox
      #495
      @jb_sullivan Installation geht nur über GitHub Katze wie im ersten Beitrag beschrieben
      • T tombox
        JB_Sullivan
        #496
        @tombox
        Wie gesagt, GITHUB Katze geht derzeit unter Admin 5.x.x wegen EBUSY Fehler nicht.
        Ich habe es aber doch noch hin bekommen und habe jetzt die 0.0.8 drauf. Trotzdem tauchen im LOG immer noch ein paar Fehlermeldungen auf.
        gartenbewaesserung.0	2021-05-26 10:44:59.822	warn	(5768) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
        gartenbewaesserung.0	2021-05-26 10:44:59.811	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
        gartenbewaesserung.0	2021-05-26 10:44:59.809	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
        gartenbewaesserung.0	2021-05-26 10:44:59.802	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
        gartenbewaesserung.0	2021-05-26 10:44:59.801	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
        gartenbewaesserung.0	2021-05-26 10:44:59.799	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
        gartenbewaesserung.0	2021-05-26 10:44:59.798	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
        gartenbewaesserung.0	2021-05-26 10:44:59.797	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
        gartenbewaesserung.0	2021-05-26 10:44:59.795	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
          @tombox
          tombox
          #497
          @jb_sullivan die objekte müssen vorher gelöscht werden damit sie korrekt neu erstellt werden
          • T tombox
            JB_Sullivan
            #498
            @tombox Habe ich gemacht, aber das ändert nichts.
            gartenbewaesserung.0	2021-05-26 19:31:28.417	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
            gartenbewaesserung.0	2021-05-26 19:31:28.415	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
            gartenbewaesserung.0	2021-05-26 19:31:28.414	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
            gartenbewaesserung.0	2021-05-26 19:31:28.412	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
            gartenbewaesserung.0	2021-05-26 19:31:28.393	info	(1988) Stop ventil4
            gartenbewaesserung.0	2021-05-26 19:31:28.388	info	(1988) Stop ventil3
            gartenbewaesserung.0	2021-05-26 19:31:28.383	info	(1988) Stop ventil2
            gartenbewaesserung.0	2021-05-26 19:31:28.378	info	(1988) Stop ventil1
            gartenbewaesserung.0	2021-05-26 19:31:28.377	info	(1988) Bewässerung stop
            gartenbewaesserung.0	2021-05-26 19:31:24.440	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
            gartenbewaesserung.0	2021-05-26 19:31:24.439	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052084"
            gartenbewaesserung.0	2021-05-26 19:31:24.438	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:01:24 GMT+0200"
            gartenbewaesserung.0	2021-05-26 19:31:24.437	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
            gartenbewaesserung.0	2021-05-26 19:31:24.426	info	(1988) Start ventil1
            gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil4 in 5130sek
            gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Start ventil4 in 3630sek
            gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil3 in 3620sek
            gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Stop ventil2 in 3610sek
            gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Start ventil2 in 1810sek
            gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Stop ventil1 in 1800sek
            gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Start ventil1 in 0sek
            gartenbewaesserung.0	2021-05-26 19:31:24.377	info	(1988) Start pumpe
            gartenbewaesserung.0	2021-05-26 19:31:24.376	info	(1988) Start Bewaesserung
            gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil4
            gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil3
            gartenbewaesserung.0	2021-05-26 19:31:24.193	info	(1988) Stop ventil2
            gartenbewaesserung.0	2021-05-26 19:31:24.192	info	(1988) Stop ventil1
            gartenbewaesserung.0	2021-05-26 19:31:24.191	info	(1988) Bewässerung stop
            gartenbewaesserung.0	2021-05-26 19:30:51.762	warn	(1988) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
              tombox
              #499
              @jb_sullivan Sollte so nicht passieren.. Alle objekte löschen. Per github installieren und instanz neustarten?
              • T tombox
                JB_Sullivan
                schrieb am zuletzt editiert von JB_Sullivan
                #500
                @tombox Genau so - habe ich alles genau so gemacht. Admin und js-controler ist latest letzter Stand.
                Habe es nochmal auf DEBUG gestellt - aber da kommt auch nicht viel bei raus.
                gartenbewaesserung.0	2021-05-26 19:39:46.507	debug	(12300) system.adapter.admin.0: logging true
                gartenbewaesserung.0	2021-05-26 19:39:42.848	warn	(12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
                gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil4
                gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil3
                gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil2
                gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil1
                gartenbewaesserung.0	2021-05-26 19:39:42.736	info	(12300) Bewässerung stop
                gartenbewaesserung.0	2021-05-26 19:39:42.735	info	(12300) Stop ventil4
                gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil3
                gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil2
                gartenbewaesserung.0	2021-05-26 19:39:42.731	info	(12300) Stop ventil1
                gartenbewaesserung.0	2021-05-26 19:39:41.743	info	(12300) starting. Version 0.0.8 in C:/iobroker/GLT/node_modules/iobroker.gartenbewaesserung, node: v14.16.0, js-controller: 3.3.11
                gartenbewaesserung.0	2021-05-26 19:39:41.325	debug	(12300) statesDB connected
                gartenbewaesserung.0	2021-05-26 19:39:41.324	debug	(12300) States connected to redis: 127.0.0.1:9000
                gartenbewaesserung.0	2021-05-26 19:39:41.310	debug	(12300) States create User PubSub Client
                gartenbewaesserung.0	2021-05-26 19:39:41.309	debug	(12300) States create System PubSub Client
                gartenbewaesserung.0	2021-05-26 19:39:41.296	debug	(12300) Redis States: Use Redis connection: 127.0.0.1:9000
                gartenbewaesserung.0	2021-05-26 19:39:41.294	debug	(12300) objectDB connected
                gartenbewaesserung.0	2021-05-26 19:39:41.284	debug	(12300) Objects connected to redis: 127.0.0.1:9001
                gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects client initialize lua scripts
                gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects create User PubSub Client
                gartenbewaesserung.0	2021-05-26 19:39:41.262	debug	(12300) Objects create System PubSub Client
                gartenbewaesserung.0	2021-05-26 19:39:41.259	debug	(12300) Objects client ready ... initialize now
                gartenbewaesserung.0	2021-05-26 19:39:41.215	debug	(12300) Redis Objects: Use Redis connection: 127.0.0.1:9001
                gartenbewaesserung.0	2021-05-26 19:42:42.836	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:42:32.839	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:42:22.834	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:42:12.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:42:02.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:41:52.833	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:41:46.796	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:41:46.795	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052706"
                gartenbewaesserung.0	2021-05-26 19:41:46.794	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:11:46 GMT+0200"
                gartenbewaesserung.0	2021-05-26 19:41:46.793	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 19:41:46.779	info	(12300) Start ventil1
                gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Stop ventil4 in 5130sek
                gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Start ventil4 in 3630sek
                gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil3 in 3620sek
                gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil2 in 3610sek
                gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Start ventil2 in 1810sek
                gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Stop ventil1 in 1800sek
                gartenbewaesserung.0	2021-05-26 19:41:46.759	info	(12300) Start ventil1 in 0sek
                gartenbewaesserung.0	2021-05-26 19:41:46.739	info	(12300) Start pumpe
                gartenbewaesserung.0	2021-05-26 19:41:46.738	info	(12300) Start Bewaesserung
                gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil4
                gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil3
                gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil2
                gartenbewaesserung.0	2021-05-26 19:41:46.598	info	(12300) Stop ventil1
                gartenbewaesserung.0	2021-05-26 19:41:46.597	info	(12300) Bewässerung stop
                  JB_Sullivan
                  #501
                  Nur mal so eine Idee - hängt die folgende Fehlermeldung des Adapters ggf. damit zusammen, das die Astro Funktion, in den Sommermonaten ab Bielefeld und weiter nördlich diesen Fehler generiert?
                  gartenbewaesserung.0	2021-05-28 14:09:43.090	warn	(12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622227340"
                  Siehe - https://forum.iobroker.net/topic/45192/javajcript-und-astro-funktion-macht-propleme
                  javascript.0	2021-05-28 14:00:00.033	error	(11640) Cannot get astro date for "night"
                  javascript.0	2021-05-28 14:00:00.028	error	(11640) Cannot get astro date for "nightEnd"
                    MartyBr
                    #502
                    @jb_sullivan
                    Ich vermute das auch. Ich habe hier ein Script mit einer kleinen Variation. Das läuft auch im Sommer einwandfrei. Ich wohne auch nördlich von Bielefeld. Da gibt es im Sommer Probleme mit dem Datenpunkt "Nacht". Ich glaube, dass Script stammt von Paul.
                    Hier der Code:
                    const sec = false; // Sekunden darstellen oder nicht
                    const fC = true; // forceCreation ein/aus
                    const pfad = "Astro"; // Pfad zum Objekt - Objektbaum-Hauptverzeichnis
                    // TAGESZEITEN - T E I L
                    // Tageszeiten nach eigenem Gusto (Shifts siehe schedules weiter unten)
                    const tageszeiten = ["Nacht",
                                         "Morgendämmerung",
                                         "Sonnenaufgang",
                                         "Morgen",
                                         "Vormittag",
                                         "Mittag",
                                         "Nachmittag",
                                         "Abend",
                                         "Sonnenuntergang",
                                         "Abenddämmerung"
                    const idTageszeit = "javascript." + instance  + "." + pfad + ".Tageszeit.current" /*Tageszeit*/,
                          idTageszeitNext = "javascript." + instance  + "." + pfad + ".Tageszeit.next";
                    createState(idTageszeit, "nächsten Wechsel abwarten", fC, {
                        desc: "Name der Tageszeit",
                        type: "string"
                    createState(idTageszeitNext, "nächsten Wechsel abwarten", fC, {
                        name: "nächste Tageszeit",
                        desc: "Name der nächsten Tageszeit",
                        type: "string"
                    function neue_tageszeit(abschnitt) {
                        var akt = tageszeiten[parseInt(abschnitt, 10)],
                        // wenn aktuelles Element ist letztes, dann nächstes ist erstes :-D
                        nxt = (abschnitt + 1 === tageszeiten.length) ? tageszeiten[0] : tageszeiten[parseInt(abschnitt + 1, 10)];
                        setState(idTageszeit, akt);
                        setState(idTageszeitNext, nxt);
                        log("neue Tagezeit: " + akt);
                        log("nächte kommende Tagezeit: " + nxt);
                    // Nacht
                    schedule({
                        astro: "nauticalDusk",
                        shift: 45
                    }, function () {
                        neue_tageszeit(0);
                    // Morgengdämmerung
                    schedule({
                        astro: "nauticalDawn",
                        shift: -45
                    }, function () {
                        neue_tageszeit(1);
                    // Sonnenaufgang
                    schedule({
                        astro: "sunrise"
                    }, function() {
                        neue_tageszeit(2);
                    // Morgen
                    schedule({
                        astro: "sunriseEnd"
                    }, function () {
                        neue_tageszeit(3);
                    // Vormittag
                    schedule({
                        astro: "goldenHourEnd",
                        shift: 60
                    }, function () {
                        neue_tageszeit(4);
                    // Mittag
                    schedule({
                        astro: "solarNoon",
                        shift: -30
                    }, function () {
                        neue_tageszeit(5);
                    // Nachmittag
                    schedule({
                        astro: "solarNoon",
                        shift: 30
                    }, function () {
                        neue_tageszeit(6);
                    // Abend
                    schedule({
                        astro: "goldenHour",
                        shift: -60
                    }, function () {
                        neue_tageszeit(7);
                    // Sonnenuntergang
                    schedule({
                        astro: "sunsetStart",
                    }, function () {
                        neue_tageszeit(8);
                    // Abenddämmerung (nach Sonnenuntergang)
                    schedule({
                        astro: "sunset"
                    }, function () {
                        neue_tageszeit(9);
                    // A S T O - T E I L
                    /* Objekt Astrotag
                       Astrotag liegt zwischen Sonnauf- und untergang,
                       Astronacht liegt zwischen Sonnenunter- und aufgang */
                    const idAstrotag =  "javascript." + instance + "." + pfad + ".Astrotag";
                    // Objekt für Uhrzeiten der Astrozeiten
                    const astrotime = {
                        "elements" : [
                            // Astrotag beginnt
                                "fname" : "sunrise", // function name
                                "de" : {
                                    "name" : "Sonnenaufgang",
                                    "nxt" : "nächster",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Sunrise",
                                    "desc" : "top edge of the sun appears on the horizon"
                                "astroday" : true //during astroday
                                "fname" : "sunriseEnd", // function name
                                "de" : {
                                    "name" : "Ende Sonnenaufgang",
                                    "nxt" : "nächstes",
                                    "desc" : ""
                                "en" : {
                                    "name" : "End of sunrise",
                                    "desc" : "bottom edge of the sun touches the horizon"
                                "fname" : "goldenHourEnd", // function name
                                "de" : {
                                    "name" : "Ende der goldenen Stunde am Morgen",
                                    "nxt" : "nächstes",
                                    "desc" : ""
                                "en" : {
                                    "name" : "End of golden hour",
                                    "desc" : "morning golden hour (soft light, best time for photography) ends"
                                "fname" : "solarNoon", // function name
                                "de" : {
                                    "name" : "Sonnenhöchststand",
                                    "nxt" : "nächster",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Solar noon",
                                    "desc" : "sun is in the highest position"
                                "fname" : "goldenHour", // function name
                                "de" : {
                                    "name" : "Goldene Stunde (am Abend)",
                                    "nxt" : "nächste",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Golden hour",
                                    "desc" : "evening golden hour starts"
                                "fname" : "sunsetStart", // function name
                                "de" : {
                                    "name" : "Beginn Sonnenuntergang",
                                    "nxt" : "nächster",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Sunset starts",
                            // Astronacht beginnt
                                "fname" : "sunset", // function name
                                "de" : {
                                    "name" : "Sonnenuntergang",
                                    "nxt" : "nächster",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Sunset",
                                    "desc" : "sun disappears below the horizon, evening civil twilight starts"
                                "astroday" : false //during astronight
                                "fname" : "dusk",
                                "de" : {
                                    "name" : "Abenddämmerung",
                                    "nxt" : "nächste",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Dusk",
                                    "desc" : "evening nautical twilight starts"
                                "fname" : "nauticalDusk",
                                "de" : {
                                    "name" : "nautische Abenddämmerung",
                                    "nxt" : "nächste",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Nautical dusk",
                                    "desc" : "evening astronomical twilight starts"
                                "fname" : "nadir",
                                "de" : {
                                    "name" : "Nadir",
                                    "nxt" : "nächster",
                                    "desc" : "Fußpunkt gegenüber dem Zenit"
                                "en" : {
                                    "name" : "Nadir",
                                    "desc" : "darkest moment of the night, sun is in the lowest position"
                                "fname" : "nauticalDawn",
                                "de" : {
                                    "name" : "nautische Morgendämmerung",
                                    "nxt" : "nächste",
                                    "desc" : ""
                                "en" : {
                                    "name" : "Nautical dawn",
                                    "desc" : "morning nautical twilight starts"
                                "fname" : "dawn",
                                "de" : {
                                    "name" : "Morgendämmerung",
                                    "nxt" : "nächste",
                                    "desc" : ""
                                "en" : {
                                    "name" : "dawn",
                                    "desc" : "morning nautical twilight ends, morning civil twilight starts"
                    function writeAstroTimes(i) {
                        // führende Nummer zur Sortierung in Admin/Objekte
                        var nr = (i+1 < 10) ? "0" + (i+1) : (i+1);
                        // Erstelle Objekt, falls nicht bereits vorhanden
                        var idAstroObject = "javascript." + instance + "." + pfad + ".Zeiten." + nr + " - " + astrotime.elements[i].fname;
                        createState(idAstroObject, " ", fC, {
                            name: astrotime.elements[i].de.nxt + " " + astrotime.elements[i].de.name + " Uhrzeit",
                            desc: astrotime.elements[i].en.desc,
                            type: "string"
                        setTimeout(function() { // kurz warten, damit Objekte ggf. erst angelgt werden können
                            var astrotag = getState(idAstrotag).val,
                                temp;
                            var today = new Date();
                            var tomorrow = today.setDate(today.getDate()+1);
                            var next_event;
                            if (astrotag) {
                                // Wenn Tag (Aufgang vorbei (erst wieder morgen, Untergang kommt noch heute)
                                next_event = (astrotime.elements[i].astroday) ? tomorrow : today; // prüfen
                            } else {
                                // nach Nacht (Untergang vorbei (erst wieder morgen, Aufgang kommt heute oder morgen)
                                next_event = (astrotime.elements[i].astroday) ? today : tomorrow; // prüfen
                            var fname = astrotime.elements[i].fname;
                            temp = getAstroDate(fname, next_event);
                            setState(idAstroObject, checkSec(temp.toLocaleTimeString()) );
                        }, 3 * 1000);
                    // Zeit mit oder ohne Sekunden anzeigen
                    function checkSec (zeit) {
                        if (!sec) {
                            var newString_arr = zeit.split(":");
                            var newString = newString_arr[0] + ":" + newString_arr[1];
                            return (newString);
                        } else return (zeit);
                    function getAstroday() {
                        // Astrotag bestimmen (boolean)
                        createState(idAstrotag, false, fC, {
                            type: "boolean",
                            desc: "Liegt die aktuelle Zeit zwischen Sonnenauf- und untergang"
                        setState(idAstrotag, isAstroDay());
                    function iterateAstrotimes() {
                        // Zeiten für jede Astrozeit schreiben
                        for (var i = 0; i < astrotime.elements.length; i++) {
                            writeAstroTimes(i);
                    // Astrotag checken
                    schedule("*/1 * * * *", function () { // jede Minute
                        getAstroday();
                        iterateAstrotimes();
                    getAstroday();
                    Martin
                    Homematic und Homematic IP
                      Snapergy
                      #503
                      Gibt es denn nen Workaround dafür, dass bei jeder Änderung über die VIS der Adapter neustartet? Hat sich dort schon mal jemand was gebastelt? Ist ja schrecklich, wenn man viele Kreise besitzt :(
                      • S Snapergy
                        tombox
                        #504
                        @snapergy Der Adapter ist leider nicht so aufgebaut dass das möglich ist.
                          #505
                          @tombox
                          Ich wollte gerade von meiner Testinstallation auf die produktive einsteigen und fand den Adapter weder in Beta noch im stable Repository.
                          Dann wollte ich fragen, ob dieser Adapter noch weiter entwickelt wird und hatte auf github nachgesehen. Dort sind letzten Monat noch Änderungen durchgeführt worden.
                          Daher wndertze ich mich., als ich auf der Suche nach dem Github link im ersten Post las:
                          @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
                          Die bessere alternative die auch weiterentwickelt wird ist:
                          https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
                          https://forum.iobroker.net/topic/44493/test-adapter-sprinkle-control-0-1-4-latest
                          Das ist leider für mich keine Alternative, da dieser Adapter ausschließlich auf Vorhersagen und Verdunstungsberechnungen basiert.
                          Ich arbeite mit Feuchtesensoren (so ungenau sie auch sein mögen) und werde mir dann wohl doch eigene Scripte basteln müssen :-(
                          Oder ist diese Info inzwischen hoffentlich wieder überholt?
                            @tombox
                            tombox
                            #506
                            @homoran Er wird nicht weiter entwickelt habe nur die sachen für js controller 3.3 gefixt. Ich denke aber das sprinkecontrol einbaut wenn du die anfrage stellst
                            • T tombox
                              #507
                              @tombox Danke für die schnelle und ehrliche Antwort.
                              Aber ehrlich ist dein Adapter für mich besser, Sprinkle control hatte ich mir mal angesehen, da sind für mich zu viele Funktionen/Berechnungsgrundlagen, die ich nicht benötige, und solche Antworten wie:
                              Es tut mir leid, aber diese Änderung steht nicht im Einklang mit den Grundprinzipien des Adapters. Ich werde sie daher nicht umsetzen.
                              Erledige diese individuellen Aufgaben doch mit JS oder Blockly.
                              motivieren nicht gerade.
                                JB_Sullivan
                                #508
                                @tombox hat bestimmt mit dem VW Wallbox Adapter genug zu tun, zumal der VAG Konzern die e-Autos z.Zt. raushaut wie geschnitten Brot und sich somit auch alle Nase lang etwas an den WB Einstellungen ändern dürfte.
                                Von daher habe ich dafür schon ein gewisses Verständnis. Aber mir geht es wie dir - der Gartenbewässerungsadapter von tombox ist einfach nur geil und leistet mir dieses, wie auch letztes Jahr hervorragende Dienste.
                                Hauptsache er bleibt noch lange lauffähig.
                                  #509
                                  @jb_sullivan sagte in Test Adapter Gartenbewässerung v0.0.x:
                                  das hab ich doch auch!
                                  Aber ich brauche den Schnickschnack von sprinkle nicht
                                  Sitze mit meinem bescheidenen Wissen gerade am Blockly
                                    bob der 1.
                                    #510
                                    @homoran sagte in Test Adapter Gartenbewässerung v0.0.x:
                                    So sehe ich das auch....Sprinkler C. ist zu verworren.
                                    Der hier hat alles was man braucht und ist stabil.
                                    Mit einem Blockly lässt sich das zwar lösen aber ich bin da kein Freund davon.
                                    Finde es mega schade das der Adapter atirbt
                                    • B bob der 1.
                                      #511
                                      @bob-der-1 sagte in Test Adapter Gartenbewässerung v0.0.x:
                                      naja, sagen wir mal der ist akademisch.
                                      Wenn man alleine auf Regenmenge, Luftfeuchte, Windstärke und Helligkeit (als Sonneneinstrahlung!!) die theoretische Bodenfeuchte berechnet, werden alleine z.B. verschiedene Bödendurchlässigkeiten, und Pflanzgegebenheiten nicht berücksichtigt.
                                      So habe ich zwei Pflanzmauern (1x 25cm breit, 1x 60cm breit) sowie eine Rasenfläche und unterschiedlich wind- und sonnengeschützte Areale in meinem Garten (mit unterschiedlicher Bodenqualität)
                                      in jedem spezifischen Areal steht ein Bodenfeuchtesensor und jedes dieser Areale soll je nach Bedarf getrennt bewässert werden (im Moment noch Mischbewässerung).
                                      Dieses kann IMHO der Sprinkle-Adapter nicht abbilden.
                                      Ich hatte ihn gerade trotzdem noch mal installiert, finde aber keine einfache Möglichkeit eine Herangehensweise wie mit dem Gartenbewässerungs-Adapter dort abzubilden.
                                      Dazu sind die beiden Ansätze zu unterschiedlich
                                      • sigi234S Online
                                        sigi234S Online
                                        #512
                                        Könnte man den Adaper nicht in die Community aufnehmen, damit er uns erhalten bleibt und Erweiterungen möglich sind?
                                        Wenn @tombox nichts dagegen hat?
                                        • sigi234S sigi234
                                          JB_Sullivan
                                          #513
                                          @sigi234
                                          Dafür müsste er wahrscheinlich erstmal die "bürokratischen" Hürden der ioBroker Oberen überwinden, denn bis heute ist er weder im latest noch im stable zu finden.
                                          Entweder hat sich tombox gar nicht um eine Aufnahme bemüht, oder er müsste den Adapter in großen Teilen umschreiben, damit er überhaupt aufgenommen werden kann. Vielleicht liegt da die Kruxx mit der Weiterentwicklung - wer weiß das schon.
                                          Ich kenne noch einen anderen Adapter der Super ist (BYDHVS) und der seit Wochen darauf wartet überhaupt aufgenommen zu werden. Der Entwickler hat seinen Teil wohl erledigt und nun wartet und wartet er.
                                          Offensichtlich sind die "Master of Adapter Freigaben" im Moment mehr mit Admin 5.x und js-controller 3.3.x beschäftigt ;) - nicht böse gemeint
                                          HomoranH T 2 Antworten Letzte Antwort
