  4. Test Adapter Gartenbewässerung v0.0.x
    6.7k
beregnungssteuerungbewässerunggartengartenbewässerungmagnetventilventilventile
567 Beiträge 66 Kommentatoren 186.1k Aufrufe 77 Beobachtet
  • T tombox
    @jb_sullivan habe mal blind ein update in github gemacht da müssten die fehler weg sein und habe nochmal 4 ventile hinzugefügt bitte mal testen ob noch alles geht
    sigi234S Online
    sigi234S Online
    #488
    @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
    artenbewaesserung.0
    2021-05-13 23:38:54.772	warn	Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1620931019"
    2021-05-13 23:38:54.748	info	State value to set for "gartenbewaesserung.0.status.ventil6.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.713	info	State value to set for "gartenbewaesserung.0.status.ventil5.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.712	info	State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.711	info	State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.711	info	State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.710	info	State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.709	info	State value to set for "gartenbewaesserung.0.status.ventil6.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.704	info	State value to set for "gartenbewaesserung.0.status.ventil5.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.703	info	State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.699	info	State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.699	info	State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.698	info	State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
    2021-05-13 23:38:54.665	info	Stop ventil6
    2021-05-13 23:38:54.665	info	Stop ventil5
    2021-05-13 23:38:54.665	info	Stop ventil4
    2021-05-13 23:38:54.665	info	Stop ventil3
    2021-05-13 23:38:54.665	info	Stop ventil2
    2021-05-13 23:38:54.664	info	Stop ventil1
    2021-05-13 23:38:54.664	info	Bewässerung stop
    2021-05-13 23:38:54.664	info	Stop ventil6
    2021-05-13 23:38:54.664	info	Stop ventil5
    2021-05-13 23:38:54.664	info	Stop ventil4
    2021-05-13 23:38:54.663	info	Stop ventil3
    2021-05-13 23:38:54.663	info	Stop ventil2
    2021-05-13 23:38:54.662	info	Stop ventil1
    2021-05-13 23:38:54.587	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil10.dauer_in_state_mult"
    2021-05-13 23:38:54.587	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil9.dauer_in_state_mult"
    2021-05-13 23:38:54.586	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil8.dauer_in_state_mult"
    2021-05-13 23:38:54.586	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil7.dauer_in_state_mult"
    2021-05-13 23:38:54.569	warn	This object will not be created in future versions. Please report this to the developer.
    2021-05-13 23:38:54.569	warn	Object gartenbewaesserung.0.config.ventil10.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2021-05-13 23:38:54.568	warn	Object gartenbewaesserung.0.config.ventil9.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2021-05-13 23:38:54.568	warn	This object will not be created in future versions. Please report this to the developer.
    2021-05-13 23:38:54.568	warn	Object gartenbewaesserung.0.config.ventil8.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2021-05-13 23:38:54.568	warn	Object gartenbewaesserung.0.config.ventil7.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2021-05-13 23:38:54.567	info	State value to set for "gartenbewaesserung.0.config.updateinterval" has to be type "number" but received type "string"
    2021-05-13 23:38:54.565	info	State value to set for "gartenbewaesserung.0.config.pauseTime" has to be type "number" but received type "string"
    2021-05-13 23:38:54.510	info	State value to set for "gartenbewaesserung.0.config.raintresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.483	info	State value to set for "gartenbewaesserung.0.config.temptresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.476	info	State value to set for "gartenbewaesserung.0.config.ventil6.feuchtigkeit_tresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.475	info	State value to set for "gartenbewaesserung.0.config.ventil5.feuchtigkeit_tresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.475	info	State value to set for "gartenbewaesserung.0.config.ventil4.feuchtigkeit_tresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.475	info	State value to set for "gartenbewaesserung.0.config.ventil3.feuchtigkeit_tresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.474	info	State value to set for "gartenbewaesserung.0.config.ventil2.feuchtigkeit_tresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.474	info	State value to set for "gartenbewaesserung.0.config.ventil1.feuchtigkeit_tresh" has to be type "number" but received type "string"
    2021-05-13 23:38:54.442	info	State value to set for "gartenbewaesserung.0.config.ventil6.dauer_in_state_mult" has to be type "undefined" but received type "string"
    2021-05-13 23:38:54.441	info	State value to set for "gartenbewaesserung.0.config.ventil5.dauer_in_state_mult" has to be type "undefined" but received type "string"
    2021-05-13 23:38:54.441	info	State value to set for "gartenbewaesserung.0.config.ventil4.dauer_in_state_mult" has to be type "undefined" but received type "string"
    2021-05-13 23:38:54.440	info	State value to set for "gartenbewaesserung.0.config.ventil3.dauer_in_state_mult" has to be type "undefined" but received type "string"
    2021-05-13 23:38:54.440	info	State value to set for "gartenbewaesserung.0.config.ventil2.dauer_in_state_mult" has to be type "undefined" but received type "string"
    2021-05-13 23:38:54.439	info	State value to set for "gartenbewaesserung.0.config.ventil1.dauer_in_state_mult" has to be type "undefined" but received type "string"
    2021-05-13 23:38:54.409	info	State value to set for "gartenbewaesserung.0.config.ventil6.dauerstate_mult" has to be type "number" but received type "string"
    2021-05-13 23:38:54.408	info	State value to set for "gartenbewaesserung.0.config.ventil5.dauerstate_mult" has to be type "number" but received type "string"
    2021-05-13 23:38:54.408	info	State value to set for "gartenbewaesserung.0.config.ventil4.dauerstate_mult" has to be type "number" but received type "string"
    2021-05-13 23:38:54.408	info	State value to set for "gartenbewaesserung.0.config.ventil3.dauerstate_mult" has to be type "number" but received type "string"
    2021-05-13 23:38:54.407	info	State value to set for "gartenbewaesserung.0.config.ventil2.dauerstate_mult" has to be type "number" but received type "string"
    2021-05-13 23:38:54.407	info	State value to set for "gartenbewaesserung.0.config.ventil1.dauerstate_mult" has to be type "number" but received type "string"
    2021-05-13 23:38:54.401	info	State value to set for "gartenbewaesserung.0.config.ventil6.dauer" has to be type "number" but received type "string"
    2021-05-13 23:38:54.400	info	State value to set for "gartenbewaesserung.0.config.ventil5.dauer" has to be type "number" but received type "string"
    2021-05-13 23:38:54.399	info	State value to set for "gartenbewaesserung.0.config.ventil4.dauer" has to be type "number" but received type "string"
    2021-05-13 23:38:54.399	info	State value to set for "gartenbewaesserung.0.config.ventil2.dauer" has to be type "number" but received type "string"
    2021-05-13 23:38:54.383	info	State value to set for "gartenbewaesserung.0.config.minSonnenuntergang" has to be type "number" but received type "string"
    2021-05-13 23:38:54.373	info	State value to set for "gartenbewaesserung.0.config.minSonnenaufgang" has to be type "number" but received type "string"
    2021-05-13 23:38:54.344	info	starting. Version 0.0.8 in C:/Program Files/iobroker/Home/node_modules/iobroker.gartenbewaesserung, node: v12.22.1, js-controller: 3.3.9
    Plattform: Windows
    RAM: 16 GB
    Node.js: 12.22.1
    NPM: 6.14.12
    JS Controller: 3.3.9
    Admin: 5.0.22
    Web: 3.4.1
    Socket.io: 3.1.4
    Script Engine: 5.1.3
    • sigi234S sigi234
      artenbewaesserung.0
      Plattform: Windows
      RAM: 16 GB
      Node.js: 12.22.1
      NPM: 6.14.12
      Admin: 5.0.22
      Web: 3.4.1
      Socket.io: 3.1.4
      tombox
      #489
      @sigi234 Jetzt müsste es passen, kann aber sein das man die werte in den optionen neu setzen muss damit sie den richtigen typ haben
      G 1 Antwort Letzte Antwort
      • T tombox
        gender
        #490
        @tombox
        Vielen Dank für das Update.
        Mir ist aufgefallen, dass nun das Objekt "Restlaufzeit" für die Anzeige der Minuten stets auf "null" bleibt. Die verbleibenden Sekunden werden korrekt angezeigt.
        Ansonsten scheint alles weiter wie gewohnt zu laufen.
        P.S.: Ich weiß, der Adapter wird nicht mehr weiterentwickelt, aber ich wollte zumindest mal nachfragen, falls ich nur eine Einstellung falsch gemacht habe: Sobald ich eine andere Ventilöffnungszeit bei einem Ventil im Objekt "ventilx.dauer" einstelle, startet der gesamte Adapter immer neu. Das ist unsofern umständlich, als das es natürlich ärgerlich ist, wenn gerade schon ein Ventil offen ist und hier die Zeit abläuft. Stellt man dann ein anderes Ventil auf (mit einer andereren als der zuvor eingestellten Zeit, ist natürlich das vorher geöffnete Ventil auch wieder zu.
        Gibts da noch ne Möglichkeit der Veränderung?
        • G gender
          @tombox
          tombox
          #491
          @gender Den Fehler habe ich gefixt. Leider ist der Adapter nicht ausgelegt das man während des Betriebs die Zeiten ändert
            Snapergy
            #492
            @tombox
            Vielen Dank für das nochmalige Update. Du siehst, dass dein Adapter von den Usern ebenfalls als sehr gut eingeschätzt wird und auch wenn der andere Adapter aus deiner Sicht besser ist, die Nutzer sich in großer Zahl für deinen entscheiden. Da hast du wirklich klasse Arbeit geleistet! :)
            • S Snapergy
              @tombox
              Tschaeens
              #493
              @snapergy sehe ich genauso!
              Würde mir ebenfalls eine Weiterentwicklung wünschen!
              • JB_SullivanJ Offline
                JB_Sullivan
                #494
                @tombox
                Ich wollte gerade das Update auf die Version 0.0.8 machen, weil ich immer noch die folgenden Fehler angezeigt bekommen.
                gartenbewaesserung.0	2021-05-26 10:05:05.700	warn	(248) Read-only state "gartenbewaesserung.0.status.startAbend" has been written without ack-flag with value "Wed May 26 2021 20:39:43 GMT+0200"
                gartenbewaesserung.0	2021-05-26 10:05:05.699	warn	(248) Read-only state "gartenbewaesserung.0.status.startMorgen" has been written without ack-flag with value "Wed May 26 2021 05:40:21 GMT+0200"
                gartenbewaesserung.0	2021-05-26 10:05:05.698	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenuntergang" has been written without ack-flag with value "21:24:43 GMT+0200 (Mitteleuropäische Sommerzeit)"
                gartenbewaesserung.0	2021-05-26 10:05:05.697	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenaufgang" has been written without ack-flag with value "05:10:21 GMT+0200 (Mitteleuropäische Sommerzeit)"
                gartenbewaesserung.0	2021-05-26 10:05:05.541	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.539	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.538	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                gartenbewaesserung.0	2021-05-26 10:05:05.522	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.521	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.520	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.517	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                gartenbewaesserung.0	2021-05-26 10:05:05.514	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.513	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.512	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                gartenbewaesserung.0	2021-05-26 10:05:05.511	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.510	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.509	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                gartenbewaesserung.0	2021-05-26 10:05:05.508	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.507	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.506	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                gartenbewaesserung.0	2021-05-26 10:05:05.504	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.503	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.502	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                gartenbewaesserung.0	2021-05-26 10:05:05.501	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.500	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
                gartenbewaesserung.0	2021-05-26 10:05:05.498	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                Seit der Admin Version 5.x.x funktioniert unter ioB / Windows aber das Adapter Update aus dem Admin heraus bei manchen Adapter nicht mehr. Es kommt dann ein sogenannter EBUSY Fehler. Leider gehört dein Adapter dazu.
                Der Workaround ist das Update aus der Konsole heraus durchzuführen. Aber auch das funktioniert im Fall der Version 0.0.8 nicht.
                Hast du eine Idee dazu?
                C:\iobroker\GLT>npm install iobroker.gartenbewaesserung@0.0.8
                npm ERR! code E404
                npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.gartenbewaesserung - Not found
                npm ERR! 404
                npm ERR! 404  'iobroker.gartenbewaesserung@0.0.8' is not in the npm registry.
                npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                npm ERR! 404
                npm ERR! 404 Note that you can also install from a
                npm ERR! 404 tarball, folder, http url, or git url.
                npm ERR!     C:\iobroker\GLT\env\npm-cache\_logs\2021-05-26T08_17_13_008Z-debug.log
                C:\iobroker\GLT>
                • JB_SullivanJ JB_Sullivan
                  @tombox
                  npm ERR! code E404
                  npm ERR! 404
                  npm ERR! 404
                  C:\iobroker\GLT>
                  tombox
                  #495
                  @jb_sullivan Installation geht nur über GitHub Katze wie im ersten Beitrag beschrieben
                  • T tombox
                    JB_Sullivan
                    #496
                    @tombox
                    Wie gesagt, GITHUB Katze geht derzeit unter Admin 5.x.x wegen EBUSY Fehler nicht.
                    Ich habe es aber doch noch hin bekommen und habe jetzt die 0.0.8 drauf. Trotzdem tauchen im LOG immer noch ein paar Fehlermeldungen auf.
                    gartenbewaesserung.0	2021-05-26 10:44:59.822	warn	(5768) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
                    gartenbewaesserung.0	2021-05-26 10:44:59.811	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                    gartenbewaesserung.0	2021-05-26 10:44:59.809	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                    gartenbewaesserung.0	2021-05-26 10:44:59.802	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                    gartenbewaesserung.0	2021-05-26 10:44:59.801	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                    gartenbewaesserung.0	2021-05-26 10:44:59.799	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                    gartenbewaesserung.0	2021-05-26 10:44:59.798	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                    gartenbewaesserung.0	2021-05-26 10:44:59.797	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                    gartenbewaesserung.0	2021-05-26 10:44:59.795	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                      @tombox
                      tombox
                      #497
                      @jb_sullivan die objekte müssen vorher gelöscht werden damit sie korrekt neu erstellt werden
                      • T tombox
                        JB_Sullivan
                        #498
                        @tombox Habe ich gemacht, aber das ändert nichts.
                        gartenbewaesserung.0	2021-05-26 19:31:28.417	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                        gartenbewaesserung.0	2021-05-26 19:31:28.415	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                        gartenbewaesserung.0	2021-05-26 19:31:28.414	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                        gartenbewaesserung.0	2021-05-26 19:31:28.412	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                        gartenbewaesserung.0	2021-05-26 19:31:28.393	info	(1988) Stop ventil4
                        gartenbewaesserung.0	2021-05-26 19:31:28.388	info	(1988) Stop ventil3
                        gartenbewaesserung.0	2021-05-26 19:31:28.383	info	(1988) Stop ventil2
                        gartenbewaesserung.0	2021-05-26 19:31:28.378	info	(1988) Stop ventil1
                        gartenbewaesserung.0	2021-05-26 19:31:28.377	info	(1988) Bewässerung stop
                        gartenbewaesserung.0	2021-05-26 19:31:24.440	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                        gartenbewaesserung.0	2021-05-26 19:31:24.439	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052084"
                        gartenbewaesserung.0	2021-05-26 19:31:24.438	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:01:24 GMT+0200"
                        gartenbewaesserung.0	2021-05-26 19:31:24.437	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                        gartenbewaesserung.0	2021-05-26 19:31:24.426	info	(1988) Start ventil1
                        gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil4 in 5130sek
                        gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Start ventil4 in 3630sek
                        gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil3 in 3620sek
                        gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Stop ventil2 in 3610sek
                        gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Start ventil2 in 1810sek
                        gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Stop ventil1 in 1800sek
                        gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Start ventil1 in 0sek
                        gartenbewaesserung.0	2021-05-26 19:31:24.377	info	(1988) Start pumpe
                        gartenbewaesserung.0	2021-05-26 19:31:24.376	info	(1988) Start Bewaesserung
                        gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil4
                        gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil3
                        gartenbewaesserung.0	2021-05-26 19:31:24.193	info	(1988) Stop ventil2
                        gartenbewaesserung.0	2021-05-26 19:31:24.192	info	(1988) Stop ventil1
                        gartenbewaesserung.0	2021-05-26 19:31:24.191	info	(1988) Bewässerung stop
                        gartenbewaesserung.0	2021-05-26 19:30:51.762	warn	(1988) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
                          tombox
                          #499
                          @jb_sullivan Sollte so nicht passieren.. Alle objekte löschen. Per github installieren und instanz neustarten?
                          • T tombox
                            JB_Sullivan
                            schrieb am zuletzt editiert von JB_Sullivan
                            #500
                            @tombox Genau so - habe ich alles genau so gemacht. Admin und js-controler ist latest letzter Stand.
                            Habe es nochmal auf DEBUG gestellt - aber da kommt auch nicht viel bei raus.
                            gartenbewaesserung.0	2021-05-26 19:39:46.507	debug	(12300) system.adapter.admin.0: logging true
                            gartenbewaesserung.0	2021-05-26 19:39:42.848	warn	(12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
                            gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil4
                            gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil3
                            gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil2
                            gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil1
                            gartenbewaesserung.0	2021-05-26 19:39:42.736	info	(12300) Bewässerung stop
                            gartenbewaesserung.0	2021-05-26 19:39:42.735	info	(12300) Stop ventil4
                            gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil3
                            gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil2
                            gartenbewaesserung.0	2021-05-26 19:39:42.731	info	(12300) Stop ventil1
                            gartenbewaesserung.0	2021-05-26 19:39:41.743	info	(12300) starting. Version 0.0.8 in C:/iobroker/GLT/node_modules/iobroker.gartenbewaesserung, node: v14.16.0, js-controller: 3.3.11
                            gartenbewaesserung.0	2021-05-26 19:39:41.325	debug	(12300) statesDB connected
                            gartenbewaesserung.0	2021-05-26 19:39:41.324	debug	(12300) States connected to redis: 127.0.0.1:9000
                            gartenbewaesserung.0	2021-05-26 19:39:41.310	debug	(12300) States create User PubSub Client
                            gartenbewaesserung.0	2021-05-26 19:39:41.309	debug	(12300) States create System PubSub Client
                            gartenbewaesserung.0	2021-05-26 19:39:41.296	debug	(12300) Redis States: Use Redis connection: 127.0.0.1:9000
                            gartenbewaesserung.0	2021-05-26 19:39:41.294	debug	(12300) objectDB connected
                            gartenbewaesserung.0	2021-05-26 19:39:41.284	debug	(12300) Objects connected to redis: 127.0.0.1:9001
                            gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects client initialize lua scripts
                            gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects create User PubSub Client
                            gartenbewaesserung.0	2021-05-26 19:39:41.262	debug	(12300) Objects create System PubSub Client
                            gartenbewaesserung.0	2021-05-26 19:39:41.259	debug	(12300) Objects client ready ... initialize now
                            gartenbewaesserung.0	2021-05-26 19:39:41.215	debug	(12300) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            gartenbewaesserung.0	2021-05-26 19:42:42.836	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:42:32.839	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:42:22.834	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:42:12.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:42:02.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:41:52.833	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:41:46.796	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:41:46.795	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052706"
                            gartenbewaesserung.0	2021-05-26 19:41:46.794	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:11:46 GMT+0200"
                            gartenbewaesserung.0	2021-05-26 19:41:46.793	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                            gartenbewaesserung.0	2021-05-26 19:41:46.779	info	(12300) Start ventil1
                            gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Stop ventil4 in 5130sek
                            gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Start ventil4 in 3630sek
                            gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil3 in 3620sek
                            gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil2 in 3610sek
                            gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Start ventil2 in 1810sek
                            gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Stop ventil1 in 1800sek
                            gartenbewaesserung.0	2021-05-26 19:41:46.759	info	(12300) Start ventil1 in 0sek
                            gartenbewaesserung.0	2021-05-26 19:41:46.739	info	(12300) Start pumpe
                            gartenbewaesserung.0	2021-05-26 19:41:46.738	info	(12300) Start Bewaesserung
                            gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil4
                            gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil3
                            gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil2
                            gartenbewaesserung.0	2021-05-26 19:41:46.598	info	(12300) Stop ventil1
                            gartenbewaesserung.0	2021-05-26 19:41:46.597	info	(12300) Bewässerung stop
                              JB_Sullivan
                              #501
                              Nur mal so eine Idee - hängt die folgende Fehlermeldung des Adapters ggf. damit zusammen, das die Astro Funktion, in den Sommermonaten ab Bielefeld und weiter nördlich diesen Fehler generiert?
                              gartenbewaesserung.0	2021-05-28 14:09:43.090	warn	(12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622227340"
                              Siehe - https://forum.iobroker.net/topic/45192/javajcript-und-astro-funktion-macht-propleme
                              javascript.0	2021-05-28 14:00:00.033	error	(11640) Cannot get astro date for "night"
                              javascript.0	2021-05-28 14:00:00.028	error	(11640) Cannot get astro date for "nightEnd"
                                MartyBr
                                #502
                                @jb_sullivan
                                Ich vermute das auch. Ich habe hier ein Script mit einer kleinen Variation. Das läuft auch im Sommer einwandfrei. Ich wohne auch nördlich von Bielefeld. Da gibt es im Sommer Probleme mit dem Datenpunkt "Nacht". Ich glaube, dass Script stammt von Paul.
                                Hier der Code:
                                const sec = false; // Sekunden darstellen oder nicht
                                const fC = true; // forceCreation ein/aus
                                const pfad = "Astro"; // Pfad zum Objekt - Objektbaum-Hauptverzeichnis
                                // TAGESZEITEN - T E I L
                                // Tageszeiten nach eigenem Gusto (Shifts siehe schedules weiter unten)
                                const tageszeiten = ["Nacht",
                                                     "Morgendämmerung",
                                                     "Sonnenaufgang",
                                                     "Morgen",
                                                     "Vormittag",
                                                     "Mittag",
                                                     "Nachmittag",
                                                     "Abend",
                                                     "Sonnenuntergang",
                                                     "Abenddämmerung"
                                const idTageszeit = "javascript." + instance  + "." + pfad + ".Tageszeit.current" /*Tageszeit*/,
                                      idTageszeitNext = "javascript." + instance  + "." + pfad + ".Tageszeit.next";
                                createState(idTageszeit, "nächsten Wechsel abwarten", fC, {
                                    desc: "Name der Tageszeit",
                                    type: "string"
                                createState(idTageszeitNext, "nächsten Wechsel abwarten", fC, {
                                    name: "nächste Tageszeit",
                                    desc: "Name der nächsten Tageszeit",
                                    type: "string"
                                function neue_tageszeit(abschnitt) {
                                    var akt = tageszeiten[parseInt(abschnitt, 10)],
                                    // wenn aktuelles Element ist letztes, dann nächstes ist erstes :-D
                                    nxt = (abschnitt + 1 === tageszeiten.length) ? tageszeiten[0] : tageszeiten[parseInt(abschnitt + 1, 10)];
                                    setState(idTageszeit, akt);
                                    setState(idTageszeitNext, nxt);
                                    log("neue Tagezeit: " + akt);
                                    log("nächte kommende Tagezeit: " + nxt);
                                // Nacht
                                schedule({
                                    astro: "nauticalDusk",
                                    shift: 45
                                }, function () {
                                    neue_tageszeit(0);
                                // Morgengdämmerung
                                schedule({
                                    astro: "nauticalDawn",
                                    shift: -45
                                }, function () {
                                    neue_tageszeit(1);
                                // Sonnenaufgang
                                schedule({
                                    astro: "sunrise"
                                }, function() {
                                    neue_tageszeit(2);
                                // Morgen
                                schedule({
                                    astro: "sunriseEnd"
                                }, function () {
                                    neue_tageszeit(3);
                                // Vormittag
                                schedule({
                                    astro: "goldenHourEnd",
                                    shift: 60
                                }, function () {
                                    neue_tageszeit(4);
                                // Mittag
                                schedule({
                                    astro: "solarNoon",
                                    shift: -30
                                }, function () {
                                    neue_tageszeit(5);
                                // Nachmittag
                                schedule({
                                    astro: "solarNoon",
                                    shift: 30
                                }, function () {
                                    neue_tageszeit(6);
                                // Abend
                                schedule({
                                    astro: "goldenHour",
                                    shift: -60
                                }, function () {
                                    neue_tageszeit(7);
                                // Sonnenuntergang
                                schedule({
                                    astro: "sunsetStart",
                                }, function () {
                                    neue_tageszeit(8);
                                // Abenddämmerung (nach Sonnenuntergang)
                                schedule({
                                    astro: "sunset"
                                }, function () {
                                    neue_tageszeit(9);
                                // A S T O - T E I L
                                /* Objekt Astrotag
                                   Astrotag liegt zwischen Sonnauf- und untergang,
                                   Astronacht liegt zwischen Sonnenunter- und aufgang */
                                const idAstrotag =  "javascript." + instance + "." + pfad + ".Astrotag";
                                // Objekt für Uhrzeiten der Astrozeiten
                                const astrotime = {
                                    "elements" : [
                                        // Astrotag beginnt
                                            "fname" : "sunrise", // function name
                                            "de" : {
                                                "name" : "Sonnenaufgang",
                                                "nxt" : "nächster",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Sunrise",
                                                "desc" : "top edge of the sun appears on the horizon"
                                            "astroday" : true //during astroday
                                            "fname" : "sunriseEnd", // function name
                                            "de" : {
                                                "name" : "Ende Sonnenaufgang",
                                                "nxt" : "nächstes",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "End of sunrise",
                                                "desc" : "bottom edge of the sun touches the horizon"
                                            "fname" : "goldenHourEnd", // function name
                                            "de" : {
                                                "name" : "Ende der goldenen Stunde am Morgen",
                                                "nxt" : "nächstes",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "End of golden hour",
                                                "desc" : "morning golden hour (soft light, best time for photography) ends"
                                            "fname" : "solarNoon", // function name
                                            "de" : {
                                                "name" : "Sonnenhöchststand",
                                                "nxt" : "nächster",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Solar noon",
                                                "desc" : "sun is in the highest position"
                                            "fname" : "goldenHour", // function name
                                            "de" : {
                                                "name" : "Goldene Stunde (am Abend)",
                                                "nxt" : "nächste",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Golden hour",
                                                "desc" : "evening golden hour starts"
                                            "fname" : "sunsetStart", // function name
                                            "de" : {
                                                "name" : "Beginn Sonnenuntergang",
                                                "nxt" : "nächster",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Sunset starts",
                                        // Astronacht beginnt
                                            "fname" : "sunset", // function name
                                            "de" : {
                                                "name" : "Sonnenuntergang",
                                                "nxt" : "nächster",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Sunset",
                                                "desc" : "sun disappears below the horizon, evening civil twilight starts"
                                            "astroday" : false //during astronight
                                            "fname" : "dusk",
                                            "de" : {
                                                "name" : "Abenddämmerung",
                                                "nxt" : "nächste",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Dusk",
                                                "desc" : "evening nautical twilight starts"
                                            "fname" : "nauticalDusk",
                                            "de" : {
                                                "name" : "nautische Abenddämmerung",
                                                "nxt" : "nächste",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Nautical dusk",
                                                "desc" : "evening astronomical twilight starts"
                                            "fname" : "nadir",
                                            "de" : {
                                                "name" : "Nadir",
                                                "nxt" : "nächster",
                                                "desc" : "Fußpunkt gegenüber dem Zenit"
                                            "en" : {
                                                "name" : "Nadir",
                                                "desc" : "darkest moment of the night, sun is in the lowest position"
                                            "fname" : "nauticalDawn",
                                            "de" : {
                                                "name" : "nautische Morgendämmerung",
                                                "nxt" : "nächste",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "Nautical dawn",
                                                "desc" : "morning nautical twilight starts"
                                            "fname" : "dawn",
                                            "de" : {
                                                "name" : "Morgendämmerung",
                                                "nxt" : "nächste",
                                                "desc" : ""
                                            "en" : {
                                                "name" : "dawn",
                                                "desc" : "morning nautical twilight ends, morning civil twilight starts"
                                function writeAstroTimes(i) {
                                    // führende Nummer zur Sortierung in Admin/Objekte
                                    var nr = (i+1 < 10) ? "0" + (i+1) : (i+1);
                                    // Erstelle Objekt, falls nicht bereits vorhanden
                                    var idAstroObject = "javascript." + instance + "." + pfad + ".Zeiten." + nr + " - " + astrotime.elements[i].fname;
                                    createState(idAstroObject, " ", fC, {
                                        name: astrotime.elements[i].de.nxt + " " + astrotime.elements[i].de.name + " Uhrzeit",
                                        desc: astrotime.elements[i].en.desc,
                                        type: "string"
                                    setTimeout(function() { // kurz warten, damit Objekte ggf. erst angelgt werden können
                                        var astrotag = getState(idAstrotag).val,
                                            temp;
                                        var today = new Date();
                                        var tomorrow = today.setDate(today.getDate()+1);
                                        var next_event;
                                        if (astrotag) {
                                            // Wenn Tag (Aufgang vorbei (erst wieder morgen, Untergang kommt noch heute)
                                            next_event = (astrotime.elements[i].astroday) ? tomorrow : today; // prüfen
                                        } else {
                                            // nach Nacht (Untergang vorbei (erst wieder morgen, Aufgang kommt heute oder morgen)
                                            next_event = (astrotime.elements[i].astroday) ? today : tomorrow; // prüfen
                                        var fname = astrotime.elements[i].fname;
                                        temp = getAstroDate(fname, next_event);
                                        setState(idAstroObject, checkSec(temp.toLocaleTimeString()) );
                                    }, 3 * 1000);
                                // Zeit mit oder ohne Sekunden anzeigen
                                function checkSec (zeit) {
                                    if (!sec) {
                                        var newString_arr = zeit.split(":");
                                        var newString = newString_arr[0] + ":" + newString_arr[1];
                                        return (newString);
                                    } else return (zeit);
                                function getAstroday() {
                                    // Astrotag bestimmen (boolean)
                                    createState(idAstrotag, false, fC, {
                                        type: "boolean",
                                        desc: "Liegt die aktuelle Zeit zwischen Sonnenauf- und untergang"
                                    setState(idAstrotag, isAstroDay());
                                function iterateAstrotimes() {
                                    // Zeiten für jede Astrozeit schreiben
                                    for (var i = 0; i < astrotime.elements.length; i++) {
                                        writeAstroTimes(i);
                                // Astrotag checken
                                schedule("*/1 * * * *", function () { // jede Minute
                                    getAstroday();
                                    iterateAstrotimes();
                                getAstroday();
                                Martin
                                Homematic und Homematic IP
                                  Snapergy
                                  #503
                                  Gibt es denn nen Workaround dafür, dass bei jeder Änderung über die VIS der Adapter neustartet? Hat sich dort schon mal jemand was gebastelt? Ist ja schrecklich, wenn man viele Kreise besitzt :(
                                  • S Snapergy
                                    tombox
                                    #504
                                    @snapergy Der Adapter ist leider nicht so aufgebaut dass das möglich ist.
                                    • HomoranH Offline
                                      HomoranH Offline
                                      #505
                                      @tombox
                                      Ich wollte gerade von meiner Testinstallation auf die produktive einsteigen und fand den Adapter weder in Beta noch im stable Repository.
                                      Dann wollte ich fragen, ob dieser Adapter noch weiter entwickelt wird und hatte auf github nachgesehen. Dort sind letzten Monat noch Änderungen durchgeführt worden.
                                      Daher wndertze ich mich., als ich auf der Suche nach dem Github link im ersten Post las:
                                      Die bessere alternative die auch weiterentwickelt wird ist:
                                      https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
                                      https://forum.iobroker.net/topic/44493/test-adapter-sprinkle-control-0-1-4-latest
                                      Das ist leider für mich keine Alternative, da dieser Adapter ausschließlich auf Vorhersagen und Verdunstungsberechnungen basiert.
                                      Ich arbeite mit Feuchtesensoren (so ungenau sie auch sein mögen) und werde mir dann wohl doch eigene Scripte basteln müssen :-(
                                      Oder ist diese Info inzwischen hoffentlich wieder überholt?
                                        @tombox
                                        tombox
                                        #506
                                        @homoran Er wird nicht weiter entwickelt habe nur die sachen für js controller 3.3 gefixt. Ich denke aber das sprinkecontrol einbaut wenn du die anfrage stellst
                                        • T tombox
                                          HomoranH Offline
                                          HomoranH Offline
                                          #507
                                          @tombox Danke für die schnelle und ehrliche Antwort.
                                          Aber ehrlich ist dein Adapter für mich besser, Sprinkle control hatte ich mir mal angesehen, da sind für mich zu viele Funktionen/Berechnungsgrundlagen, die ich nicht benötige, und solche Antworten wie:
                                          Es tut mir leid, aber diese Änderung steht nicht im Einklang mit den Grundprinzipien des Adapters. Ich werde sie daher nicht umsetzen.
                                          Erledige diese individuellen Aufgaben doch mit JS oder Blockly.
                                          motivieren nicht gerade.
