  4. Backitup für kein Automatisches Backup aus
    6.5k
29 Beiträge 5 Kommentatoren 1.1k Aufrufe 5 Beobachtet
  • ChrisNettC ChrisNett
    @simatec
    ja das Backup läuft jetzt aber nur die beiden fehler, was müss ich da angeben?
    backitup.0	2021-06-02 07:51:15.521	info	(22053) [iobroker] backup was activated at 07:49 every 1 day(s)
    backitup.0	2021-06-02 07:51:15.420	info	(22053) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
    backitup.0	2021-06-02 07:51:07.730	info	(20698) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2021-06-02 07:51:07.728	info	(20698) terminating
    backitup.0	2021-06-02 07:51:07.727	info	(20698) cleaned everything up...
    backitup.0	2021-06-02 07:51:07.726	info	(20698) Got terminate signal TERMINATE_YOURSELF
    backitup.0	2021-06-02 07:45:44.462	info	(20698) [iobroker] backup was activated at 07:49 every 1 day(s)
    backitup.0	2021-06-02 07:45:44.351	info	(20698) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
    backitup.0	2021-06-02 07:45:36.733	info	(18982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2021-06-02 07:45:36.730	info	(18982) terminating
    backitup.0	2021-06-02 07:45:36.729	info	(18982) cleaned everything up...
    backitup.0	2021-06-02 07:45:36.727	info	(18982) Got terminate signal TERMINATE_YOURSELF
    simatecS Offline
    simatecS Offline
    simatec
    @christian-sandkaulen Der Log sagt leider nichts aus, außer dass du den Adapter neu gestartet hast
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    ChrisNettC 1 Antwort Letzte Antwort
    • simatecS simatec
      ChrisNettC Offline
      ChrisNettC Offline
      ChrisNett
      @simatec
      sorry dachte da seht das bei..
      Started iobroker ...
      [DEBUG] [iobroker] - host.PI4 6271 states saved
      [DEBUG] [iobroker] - host.PI4 7753 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [historyDB] - compress from historyDB started ...
      [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
      [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1
      [DEBUG] [zigbee] - done
      [DEBUG] [javascripts] - javascript directory "" not found
      [DEBUG] [javascripts] - done
      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_06_02-08_01_45_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-08_01_45_backupiobroker.tar.gz...
      [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-08_01_45_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/javascripts_2021_06_02-08_01_46_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [EXIT] 0
        @simatec
        GlasfaserG Offline
        GlasfaserG Offline
        @christian-sandkaulen sagte in Backitup für kein Automatisches Backup aus:
        Biste du im BETA Kanal unterwegs !?
        • GlasfaserG Glasfaser
          ChrisNettC Offline
          ChrisNettC Offline
          ChrisNett
          @glasfaser
          nicht das ich wüsste sol ich das ändern?
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            Zeige mal :
            iobroker version
            iobroker repo list
            which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              @simatec
              [EXIT] 0
              simatecS Offline
              simatecS Offline
              simatec
              @christian-sandkaulen Du hast weder bei dem History Backup einen Pfad angegeben noch beim Javascript.
              Wenn du die beiden Optionen mitsichern willst, dann musst dort die Pfadangabe rein. Wenn nicht die beiden Optionen in den Haupteinstellungen deaktivieren
                Zeige mal :
                iobroker version
                iobroker repo list
                ChrisNettC Offline
                ChrisNettC Offline
                ChrisNett
                @glasfaser
                pi@PI4:~ $ iobroker version
                3.3.9
                pi@PI4:~ $ iobroker repo list
                Stable (default): http://download.iobroker.net/sources-dist.json
                Beta (latest): http://download.iobroker.net/sources-dist-latest.json
                Active repo: Stable (default)
                pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.1
                v12.22.1
                6.14.12
                Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,7 kB]
                Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
                OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                Holen:6 http://packages.microsoft.com/repos/code stable/main armhf Packages [30,9 kB]
                Holen:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [30,9 kB]
                Holen:8 http://packages.microsoft.com/repos/code stable/main amd64 Packages [29,9 kB]
                Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [376 kB]
                Es wurden 13,5 MB in 13 s geholt (1.077 kB/s).
                Aktualisierung für 73 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                OK:3 http://packages.microsoft.com/repos/code stable InRelease
                nodejs:
                  Installiert:           12.22.1-1nodesource1
                  Installationskandidat: 12.22.1-1nodesource1
                  Versionstabelle:
                 *** 12.22.1-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     10.24.0~dfsg-1~deb10u1 500
                • simatecS simatec
                  ChrisNettC Offline
                  ChrisNettC Offline
                  ChrisNett
                  @simatec
                  wie bekomme ich die Pfade raus ?
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @christian-sandkaulen Jeweils auf den Button ermitteln klicken.
                    Wenn Javascript und der History Adapter richtig konfiguriert sind, holt sich Backitup die Daten
                    https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#Javascript-Backup
                      @glasfaser
                      3.3.9
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.1
                      v12.22.1
                      6.14.12
                      nodejs:
                        Versionstabelle:
                      Eigentlich alles richtig eingestellt.
                      Du musst aber irgendwann mal die Beta-Version des js-controllers eingespielt haben, 3.3.9 war nie im Stable verfügbar.
                      Die 73 hängenden Upgrades würde ich reinholen:
                      sudo apt dist-upgrade
                      sudo reboot
                      ChrisNettC 2 Antworten Letzte Antwort
                        sudo reboot
                        ChrisNettC Offline
                        ChrisNettC Offline
                        ChrisNett
                        ja das kann sein als ich problem mit Zigbee hatte ist das gemacht worden, update mache ich gleich.
                        • simatecS simatec
                          ChrisNettC Offline
                          ChrisNettC Offline
                          ChrisNett
                          @simatec
                          danke JS habe ich ümgestellt aber was muss hier rein?
                            @simatec
                            Bei mir habe ich da (analog zu den JS-skripten) ein Spiegelverzeichnis in /home/iobroker/history angelegt. Also außerhalb von /opt/iobroker
                              sudo reboot
                              ChrisNettC Offline
                              ChrisNettC Offline
                              ChrisNett
                              73 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 149 MB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 4.907 kB Plattenplatz zusätzlich benutzt.
                              Möchten Sie fortfahren? [J/n] J
                              Abbruch.
                              pi@PI4:~ $
                              warum bricht der das mit "J" ab?
                                Abbruch.
                                pi@PI4:~ $
                                Keine Ahnung. Mit kleinem j mal probiert?
                                Oder y?
                                  Oder y?
                                  ChrisNettC Offline
                                  ChrisNettC Offline
                                  ChrisNett
                                  ja auch und mit n bricht er auch ab...
                                  aber backup geht jetzt
                                  [DEBUG] [iobroker] - host.PI4 6316 states saved
                                  [DEBUG] [iobroker] - host.PI4 7766 objects saved
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz
                                  [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz
                                  [DEBUG] [historyDB] - done
                                  [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz
                                  [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz...
                                  [EXIT] 0
                                  :-) danke
                                    [EXIT] 0
                                    :-) danke
                                    Komisch.
                                    Versuch mal
                                    sudo apt update && sudo apt dist-upgrade -y
                                      Oder y?
                                      ChrisNettC Offline
                                      ChrisNettC Offline
                                      ChrisNett
                                      habe mal zuerst
                                      sudo reboot
                                      gemacht und dann noch mal das update
                                      jetzt läuft es
                                        habe mal zuerst
                                        sudo reboot
                                        jetzt läuft es
                                        ChrisNettC Offline
                                        ChrisNettC Offline
                                        ChrisNett
                                        ich Frage noch kann ich auch nur zigbee wiederherstellen oder ist da immer alles drin?
                                          Für zigbee gibt es eine eigene Einstellung im Backitup-Adapter.
