  4. Backitup für kein Automatisches Backup aus
    6.5k
29 Beiträge 5 Kommentatoren 1.1k Aufrufe 5 Beobachtet
  • simatecS simatec
    @christian-sandkaulen Der Log sagt leider nichts aus, außer dass du den Adapter neu gestartet hast
    ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    @simatec
    sorry dachte da seht das bei..
    Started iobroker ...
    [DEBUG] [iobroker] - host.PI4 6271 states saved
    [DEBUG] [iobroker] - host.PI4 7753 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
    [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - javascript directory "" not found
    [DEBUG] [javascripts] - done
    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz...
    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_06_02-08_01_45_backupiobroker.tar.gz" not found
    [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-08_01_45_backupiobroker.tar.gz...
    [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-08_01_45_backupiobroker.tar.gz...
    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/javascripts_2021_06_02-08_01_46_backupiobroker.tar.gz" not found
    [DEBUG] [googledrive] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 0
    • ChrisNettC ChrisNett
      @simatec
      ja das Backup läuft jetzt aber nur die beiden fehler, was müss ich da angeben?
      backitup.0	2021-06-02 07:51:15.521	info	(22053) [iobroker] backup was activated at 07:49 every 1 day(s)
      backitup.0	2021-06-02 07:51:15.420	info	(22053) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
      backitup.0	2021-06-02 07:51:07.730	info	(20698) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      backitup.0	2021-06-02 07:51:07.728	info	(20698) terminating
      backitup.0	2021-06-02 07:51:07.727	info	(20698) cleaned everything up...
      backitup.0	2021-06-02 07:51:07.726	info	(20698) Got terminate signal TERMINATE_YOURSELF
      backitup.0	2021-06-02 07:45:44.462	info	(20698) [iobroker] backup was activated at 07:49 every 1 day(s)
      backitup.0	2021-06-02 07:45:44.351	info	(20698) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
      backitup.0	2021-06-02 07:45:36.733	info	(18982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      backitup.0	2021-06-02 07:45:36.730	info	(18982) terminating
      backitup.0	2021-06-02 07:45:36.729	info	(18982) cleaned everything up...
      backitup.0	2021-06-02 07:45:36.727	info	(18982) Got terminate signal TERMINATE_YOURSELF
      GlasfaserG Offline
      GlasfaserG Offline
      @christian-sandkaulen sagte in Backitup für kein Automatisches Backup aus:
      Biste du im BETA Kanal unterwegs !?
      ChrisNettC 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        @glasfaser
        nicht das ich wüsste sol ich das ändern?
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          Zeige mal :
          iobroker version
          iobroker repo list
          which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            @simatec
            [EXIT] 0
            simatecS Offline
            simatecS Offline
            simatec
            @christian-sandkaulen Du hast weder bei dem History Backup einen Pfad angegeben noch beim Javascript.
            Wenn du die beiden Optionen mitsichern willst, dann musst dort die Pfadangabe rein. Wenn nicht die beiden Optionen in den Haupteinstellungen deaktivieren
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
              Zeige mal :
              iobroker version
              iobroker repo list
              ChrisNettC Offline
              ChrisNettC Offline
              ChrisNett
              @glasfaser
              pi@PI4:~ $ iobroker version
              3.3.9
              pi@PI4:~ $ iobroker repo list
              Stable (default): http://download.iobroker.net/sources-dist.json
              Beta (latest): http://download.iobroker.net/sources-dist-latest.json
              Active repo: Stable (default)
              pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.1
              v12.22.1
              6.14.12
              Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,7 kB]
              Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
              Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
              OK:4 https://deb.nodesource.com/node_12.x buster InRelease
              Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
              Holen:6 http://packages.microsoft.com/repos/code stable/main armhf Packages [30,9 kB]
              Holen:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [30,9 kB]
              Holen:8 http://packages.microsoft.com/repos/code stable/main amd64 Packages [29,9 kB]
              Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [376 kB]
              Es wurden 13,5 MB in 13 s geholt (1.077 kB/s).
              Aktualisierung für 73 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
              OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              OK:2 http://archive.raspberrypi.org/debian buster InRelease
              OK:3 http://packages.microsoft.com/repos/code stable InRelease
              nodejs:
                Installiert:           12.22.1-1nodesource1
                Installationskandidat: 12.22.1-1nodesource1
                Versionstabelle:
               *** 12.22.1-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                   10.24.0~dfsg-1~deb10u1 500
              • simatecS simatec
                ChrisNettC Offline
                ChrisNettC Offline
                ChrisNett
                @simatec
                wie bekomme ich die Pfade raus ?
                  @simatec
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @christian-sandkaulen Jeweils auf den Button ermitteln klicken.
                  Wenn Javascript und der History Adapter richtig konfiguriert sind, holt sich Backitup die Daten
                  https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#Javascript-Backup
                    @glasfaser
                    3.3.9
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.1
                    v12.22.1
                    6.14.12
                    nodejs:
                      Versionstabelle:
                    Eigentlich alles richtig eingestellt.
                    Du musst aber irgendwann mal die Beta-Version des js-controllers eingespielt haben, 3.3.9 war nie im Stable verfügbar.
                    Die 73 hängenden Upgrades würde ich reinholen:
                    sudo apt dist-upgrade
                    sudo reboot
                    ChrisNettC 2 Antworten Letzte Antwort
                      sudo reboot
                      ChrisNettC Offline
                      ChrisNettC Offline
                      ChrisNett
                      ja das kann sein als ich problem mit Zigbee hatte ist das gemacht worden, update mache ich gleich.
                      • simatecS simatec
                        ChrisNettC Offline
                        ChrisNettC Offline
                        ChrisNett
                        @simatec
                        danke JS habe ich ümgestellt aber was muss hier rein?
                          @simatec
                          Bei mir habe ich da (analog zu den JS-skripten) ein Spiegelverzeichnis in /home/iobroker/history angelegt. Also außerhalb von /opt/iobroker
                            sudo reboot
                            ChrisNettC Offline
                            ChrisNettC Offline
                            ChrisNett
                            73 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            Es müssen 149 MB an Archiven heruntergeladen werden.
                            Nach dieser Operation werden 4.907 kB Plattenplatz zusätzlich benutzt.
                            Möchten Sie fortfahren? [J/n] J
                            Abbruch.
                            pi@PI4:~ $
                            warum bricht der das mit "J" ab?
                              Abbruch.
                              pi@PI4:~ $
                              Keine Ahnung. Mit kleinem j mal probiert?
                              Oder y?
                                Oder y?
                                ChrisNettC Offline
                                ChrisNettC Offline
                                ChrisNett
                                ja auch und mit n bricht er auch ab...
                                aber backup geht jetzt
                                [DEBUG] [iobroker] - host.PI4 6316 states saved
                                [DEBUG] [iobroker] - host.PI4 7766 objects saved
                                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz
                                [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz
                                [DEBUG] [historyDB] - done
                                [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz
                                [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz...
                                [DEBUG] [googledrive] - Google Drive: Copy historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz...
                                [EXIT] 0
                                :-) danke
                                  [EXIT] 0
                                  :-) danke
                                  Komisch.
                                  Versuch mal
                                  sudo apt update && sudo apt dist-upgrade -y
                                    Oder y?
                                    ChrisNettC Offline
                                    ChrisNettC Offline
                                    ChrisNett
                                    habe mal zuerst
                                    sudo reboot
                                    gemacht und dann noch mal das update
                                    jetzt läuft es
                                      habe mal zuerst
                                      sudo reboot
                                      jetzt läuft es
                                      ChrisNettC Offline
                                      ChrisNettC Offline
                                      ChrisNett
                                      ich Frage noch kann ich auch nur zigbee wiederherstellen oder ist da immer alles drin?
                                        Für zigbee gibt es eine eigene Einstellung im Backitup-Adapter.
                                          ChrisNettC Offline
                                          ChrisNettC Offline
                                          ChrisNett
                                          Danke und der stellt auch nur zigbee wieder her ja?
