  4. Backitup für kein Automatisches Backup aus
    6.5k
29 Beiträge 5 Kommentatoren 1.1k Aufrufe 5 Beobachtet
  • ChrisNettC ChrisNett
    @simatec
    ja das Backup läuft jetzt aber nur die beiden fehler, was müss ich da angeben?
    backitup.0	2021-06-02 07:51:15.521	info	(22053) [iobroker] backup was activated at 07:49 every 1 day(s)
    backitup.0	2021-06-02 07:51:15.420	info	(22053) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
    backitup.0	2021-06-02 07:51:07.730	info	(20698) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2021-06-02 07:51:07.728	info	(20698) terminating
    backitup.0	2021-06-02 07:51:07.727	info	(20698) cleaned everything up...
    backitup.0	2021-06-02 07:51:07.726	info	(20698) Got terminate signal TERMINATE_YOURSELF
    backitup.0	2021-06-02 07:45:44.462	info	(20698) [iobroker] backup was activated at 07:49 every 1 day(s)
    backitup.0	2021-06-02 07:45:44.351	info	(20698) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
    backitup.0	2021-06-02 07:45:36.733	info	(18982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2021-06-02 07:45:36.730	info	(18982) terminating
    backitup.0	2021-06-02 07:45:36.729	info	(18982) cleaned everything up...
    backitup.0	2021-06-02 07:45:36.727	info	(18982) Got terminate signal TERMINATE_YOURSELF
    GlasfaserG Offline
    GlasfaserG Offline
    @christian-sandkaulen sagte in Backitup für kein Automatisches Backup aus:
    Biste du im BETA Kanal unterwegs !?
    ChrisNettC 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      ChrisNettC Offline
      ChrisNettC Offline
      ChrisNett
      @glasfaser
      nicht das ich wüsste sol ich das ändern?
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        Zeige mal :
        iobroker version
        iobroker repo list
        which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          @simatec
          sorry dachte da seht das bei..
          Started iobroker ...
          [DEBUG] [iobroker] - host.PI4 6271 states saved
          [DEBUG] [iobroker] - host.PI4 7753 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz
          [DEBUG] [iobroker] - done
          [DEBUG] [historyDB] - compress from historyDB started ...
          [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
          [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1
          [DEBUG] [zigbee] - done
          [DEBUG] [javascripts] - javascript directory "" not found
          [DEBUG] [javascripts] - done
          [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_06_02-08_01_45_backupiobroker.tar.gz" not found
          [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-08_01_45_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-08_01_45_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/javascripts_2021_06_02-08_01_46_backupiobroker.tar.gz" not found
          [DEBUG] [googledrive] - done
          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
          [DEBUG] [clean] - done
          [DEBUG] [telegram] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          [EXIT] 0
          simatecS Offline
          simatecS Offline
          simatec
          @christian-sandkaulen Du hast weder bei dem History Backup einen Pfad angegeben noch beim Javascript.
          Wenn du die beiden Optionen mitsichern willst, dann musst dort die Pfadangabe rein. Wenn nicht die beiden Optionen in den Haupteinstellungen deaktivieren
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
            Zeige mal :
            iobroker version
            iobroker repo list
            ChrisNettC Offline
            ChrisNettC Offline
            ChrisNett
            @glasfaser
            pi@PI4:~ $ iobroker version
            3.3.9
            pi@PI4:~ $ iobroker repo list
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest): http://download.iobroker.net/sources-dist-latest.json
            Active repo: Stable (default)
            pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.1
            v12.22.1
            6.14.12
            Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,7 kB]
            Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
            Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
            OK:4 https://deb.nodesource.com/node_12.x buster InRelease
            Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
            Holen:6 http://packages.microsoft.com/repos/code stable/main armhf Packages [30,9 kB]
            Holen:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [30,9 kB]
            Holen:8 http://packages.microsoft.com/repos/code stable/main amd64 Packages [29,9 kB]
            Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [376 kB]
            Es wurden 13,5 MB in 13 s geholt (1.077 kB/s).
            Aktualisierung für 73 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:2 http://archive.raspberrypi.org/debian buster InRelease
            OK:3 http://packages.microsoft.com/repos/code stable InRelease
            nodejs:
              Installiert:           12.22.1-1nodesource1
              Installationskandidat: 12.22.1-1nodesource1
              Versionstabelle:
             *** 12.22.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u1 500
            • simatecS simatec
              ChrisNettC Offline
              ChrisNettC Offline
              ChrisNett
              @simatec
              wie bekomme ich die Pfade raus ?
                @simatec
                simatecS Offline
                simatecS Offline
                simatec
                @christian-sandkaulen Jeweils auf den Button ermitteln klicken.
                Wenn Javascript und der History Adapter richtig konfiguriert sind, holt sich Backitup die Daten
                https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#Javascript-Backup
                  @glasfaser
                  3.3.9
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.22.1
                  v12.22.1
                  6.14.12
                  nodejs:
                    Versionstabelle:
                  Eigentlich alles richtig eingestellt.
                  Du musst aber irgendwann mal die Beta-Version des js-controllers eingespielt haben, 3.3.9 war nie im Stable verfügbar.
                  Die 73 hängenden Upgrades würde ich reinholen:
                  sudo apt dist-upgrade
                  sudo reboot
                  ChrisNettC 2 Antworten Letzte Antwort
                    sudo reboot
                    ChrisNettC Offline
                    ChrisNettC Offline
                    ChrisNett
                    ja das kann sein als ich problem mit Zigbee hatte ist das gemacht worden, update mache ich gleich.
                    • simatecS simatec
                      ChrisNettC Offline
                      ChrisNettC Offline
                      ChrisNett
                      @simatec
                      danke JS habe ich ümgestellt aber was muss hier rein?
                        @simatec
                        Bei mir habe ich da (analog zu den JS-skripten) ein Spiegelverzeichnis in /home/iobroker/history angelegt. Also außerhalb von /opt/iobroker
                          sudo reboot
                          ChrisNettC Offline
                          ChrisNettC Offline
                          ChrisNett
                          73 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 149 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 4.907 kB Plattenplatz zusätzlich benutzt.
                          Möchten Sie fortfahren? [J/n] J
                          Abbruch.
                          pi@PI4:~ $
                          warum bricht der das mit "J" ab?
                            Abbruch.
                            pi@PI4:~ $
                            Keine Ahnung. Mit kleinem j mal probiert?
                            Oder y?
                              Oder y?
                              ChrisNettC Offline
                              ChrisNettC Offline
                              ChrisNett
                              ja auch und mit n bricht er auch ab...
                              aber backup geht jetzt
                              [DEBUG] [iobroker] - host.PI4 6316 states saved
                              [DEBUG] [iobroker] - host.PI4 7766 objects saved
                              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz
                              [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz
                              [DEBUG] [historyDB] - done
                              [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz
                              [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz...
                              [DEBUG] [googledrive] - Google Drive: Copy historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz...
                              [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-10_34_54_backupiobroker.tar.gz...
                              [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-10_34_54_backupiobroker.tar.gz...
                              [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz...
                              [EXIT] 0
                              :-) danke
                                [EXIT] 0
                                :-) danke
                                Komisch.
                                Versuch mal
                                sudo apt update && sudo apt dist-upgrade -y
                                  Oder y?
                                  ChrisNettC Offline
                                  ChrisNettC Offline
                                  ChrisNett
                                  habe mal zuerst
                                  sudo reboot
                                  gemacht und dann noch mal das update
                                  jetzt läuft es
                                    habe mal zuerst
                                    sudo reboot
                                    jetzt läuft es
                                    ChrisNettC Offline
                                    ChrisNettC Offline
                                    ChrisNett
                                    ich Frage noch kann ich auch nur zigbee wiederherstellen oder ist da immer alles drin?
                                      Für zigbee gibt es eine eigene Einstellung im Backitup-Adapter.
                                        ChrisNettC Offline
                                        ChrisNettC Offline
                                        ChrisNett
                                        Danke und der stellt auch nur zigbee wieder her ja?
                                          Ja, dafür gibt es den Punkt.
