  4. Backitup für kein Automatisches Backup aus
    6.5k
29 Beiträge 5 Kommentatoren 1.1k Aufrufe 5 Beobachtet
    @christian-sandkaulen
    Stell Mal eine 'krumme' Uhrzeit ein. Zu vollen Stunden ist auf Google Drive schon mal zu viel los.
    3:37 z.B.
    ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    Danke habe gerade mal 7:37 eingestellt müsste dann ja gleich laufen..
    • ChrisNettC ChrisNett
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version: 10.x.x
      Nodejs-Version: v12.22.1
      NPM-Version: 6.14.12
      Installationsart:
      Image genutzt: Ja
      Ort/Name der Imagedatei: PI4
      Hallo zusammen leider führt der Adapter kein automatisches Backup aus.
      hier der log eines Manuel Backup
      Started iobroker ...
      [DEBUG] [iobroker] - host.PI4 6304 states saved
      [DEBUG] [iobroker] - host.PI4 7824 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-06_41_47_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [historyDB] - compress from historyDB started ...
      [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
      [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1
      [DEBUG] [zigbee] - done
      [DEBUG] [javascripts] - javascript directory "/media/usb/scripts" not found
      [DEBUG] [javascripts] - done
      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-06_41_47_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_06_02-06_41_58_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-06_41_59_backupiobroker.tar.gz...
      [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-06_41_59_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/javascripts_2021_06_02-06_41_59_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [EXIT] 0
      was mache ich falsch? es hat eine ganze zeit lang funktioniert aber jetzt irgendwie nicht mehr.
      Meister MopperM Online
      Meister Mopper
      schrieb am zuletzt editiert von Meister Mopper
      @christian-sandkaulen sagte in Backitup für kein Automatisches Backup aus:
      Node-Version:
      10.x.x
      Nodejs-Version:
      v12.22.1
      Da stimmt was nicht. Die Versionen sollen identisch sein:
      Proxmox und HA ...
      ChrisNettC 1 Antwort Letzte Antwort
        simatecS Offline
        simatecS Offline
        simatec
        @christian-sandkaulen Dein History und Javascript Backup sind nicht korrekt konfiguriert.
        Hier müssen die richtigen Pfade noch konfiguriert werden
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
          Node-Version:
          10.x.x
          Nodejs-Version:
          v12.22.1
          ChrisNettC Offline
          ChrisNettC Offline
          ChrisNett
          @meister-mopper
          habe ich fasch eingetragen die sind gleich
          • simatecS simatec
            ChrisNettC Offline
            ChrisNettC Offline
            ChrisNett
            schrieb am zuletzt editiert von ChrisNett
            @simatec
            ja das Backup läuft jetzt aber nur die beiden fehler, was müss ich da angeben?
            backitup.0	2021-06-02 07:51:15.521	info	(22053) [iobroker] backup was activated at 07:49 every 1 day(s)
            backitup.0	2021-06-02 07:51:15.420	info	(22053) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
            backitup.0	2021-06-02 07:51:07.730	info	(20698) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            backitup.0	2021-06-02 07:51:07.728	info	(20698) terminating
            backitup.0	2021-06-02 07:51:07.727	info	(20698) cleaned everything up...
            backitup.0	2021-06-02 07:51:07.726	info	(20698) Got terminate signal TERMINATE_YOURSELF
            backitup.0	2021-06-02 07:45:44.462	info	(20698) [iobroker] backup was activated at 07:49 every 1 day(s)
            backitup.0	2021-06-02 07:45:44.351	info	(20698) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
            backitup.0	2021-06-02 07:45:36.733	info	(18982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            backitup.0	2021-06-02 07:45:36.730	info	(18982) terminating
            backitup.0	2021-06-02 07:45:36.729	info	(18982) cleaned everything up...
            backitup.0	2021-06-02 07:45:36.727	info	(18982) Got terminate signal TERMINATE_YOURSELF
            simatecS GlasfaserG 2 Antworten Letzte Antwort
              @simatec
              simatecS Offline
              simatecS Offline
              simatec
              @christian-sandkaulen Der Log sagt leider nichts aus, außer dass du den Adapter neu gestartet hast
              • simatecS simatec
                ChrisNettC Offline
                ChrisNettC Offline
                ChrisNett
                @simatec
                sorry dachte da seht das bei..
                [DEBUG] [iobroker] - host.PI4 6271 states saved
                [DEBUG] [iobroker] - host.PI4 7753 objects saved
                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz
                [DEBUG] [javascripts] - javascript directory "" not found
                [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz...
                [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_06_02-08_01_45_backupiobroker.tar.gz" not found
                [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-08_01_45_backupiobroker.tar.gz...
                [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-08_01_45_backupiobroker.tar.gz...
                [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/javascripts_2021_06_02-08_01_46_backupiobroker.tar.gz" not found
                [EXIT] 0
                  @simatec
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Biste du im BETA Kanal unterwegs !?
                  • GlasfaserG Glasfaser
                    ChrisNettC Offline
                    ChrisNettC Offline
                    ChrisNett
                    @glasfaser
                    nicht das ich wüsste sol ich das ändern?
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Zeige mal :
                      iobroker version
                      iobroker repo list
                      which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                        @simatec
                        [EXIT] 0
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @christian-sandkaulen Du hast weder bei dem History Backup einen Pfad angegeben noch beim Javascript.
                        Wenn du die beiden Optionen mitsichern willst, dann musst dort die Pfadangabe rein. Wenn nicht die beiden Optionen in den Haupteinstellungen deaktivieren
                          Zeige mal :
                          iobroker version
                          iobroker repo list
                          ChrisNettC Offline
                          ChrisNettC Offline
                          ChrisNett
                          @glasfaser
                          pi@PI4:~ $ iobroker version
                          3.3.9
                          pi@PI4:~ $ iobroker repo list
                          Stable (default): http://download.iobroker.net/sources-dist.json
                          Beta (latest): http://download.iobroker.net/sources-dist-latest.json
                          Active repo: Stable (default)
                          pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v12.22.1
                          v12.22.1
                          6.14.12
                          Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,7 kB]
                          Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                          Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
                          OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                          Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                          Holen:6 http://packages.microsoft.com/repos/code stable/main armhf Packages [30,9 kB]
                          Holen:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [30,9 kB]
                          Holen:8 http://packages.microsoft.com/repos/code stable/main amd64 Packages [29,9 kB]
                          Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [376 kB]
                          Es wurden 13,5 MB in 13 s geholt (1.077 kB/s).
                          Aktualisierung für 73 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                          OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:2 http://archive.raspberrypi.org/debian buster InRelease
                          OK:3 http://packages.microsoft.com/repos/code stable InRelease
                          nodejs:
                            Installiert:           12.22.1-1nodesource1
                            Installationskandidat: 12.22.1-1nodesource1
                            Versionstabelle:
                           *** 12.22.1-1nodesource1 500
                                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                               10.24.0~dfsg-1~deb10u1 500
                          • simatecS simatec
                            ChrisNettC Offline
                            ChrisNettC Offline
                            ChrisNett
                            @simatec
                            wie bekomme ich die Pfade raus ?
                              @simatec
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @christian-sandkaulen Jeweils auf den Button ermitteln klicken.
                              Wenn Javascript und der History Adapter richtig konfiguriert sind, holt sich Backitup die Daten
                              https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#Javascript-Backup
                                @glasfaser
                                3.3.9
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v12.22.1
                                v12.22.1
                                6.14.12
                                nodejs:
                                  Versionstabelle:
                                Eigentlich alles richtig eingestellt.
                                Du musst aber irgendwann mal die Beta-Version des js-controllers eingespielt haben, 3.3.9 war nie im Stable verfügbar.
                                Die 73 hängenden Upgrades würde ich reinholen:
                                sudo apt dist-upgrade
                                sudo reboot
                                ChrisNettC 2 Antworten Letzte Antwort
                                  sudo reboot
                                  ChrisNettC Offline
                                  ChrisNettC Offline
                                  ChrisNett
                                  ja das kann sein als ich problem mit Zigbee hatte ist das gemacht worden, update mache ich gleich.
                                  • simatecS simatec
                                    ChrisNettC Offline
                                    ChrisNettC Offline
                                    ChrisNett
                                    @simatec
                                    danke JS habe ich ümgestellt aber was muss hier rein?
                                      @simatec
                                      Bei mir habe ich da (analog zu den JS-skripten) ein Spiegelverzeichnis in /home/iobroker/history angelegt. Also außerhalb von /opt/iobroker
                                        sudo reboot
                                        ChrisNettC Offline
                                        ChrisNettC Offline
                                        ChrisNett
                                        73 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        Es müssen 149 MB an Archiven heruntergeladen werden.
                                        Nach dieser Operation werden 4.907 kB Plattenplatz zusätzlich benutzt.
                                        Möchten Sie fortfahren? [J/n] J
                                        Abbruch.
                                        pi@PI4:~ $
                                        warum bricht der das mit "J" ab?
                                          Abbruch.
                                          pi@PI4:~ $
                                          Keine Ahnung. Mit kleinem j mal probiert?
                                          Oder y?
