  4. [SourceAnalytix 0.4.8-Final] Released !
    5.9k
2.3k Beiträge 184 Kommentatoren 1.4m Aufrufe 153 Beobachtet
  • G gramar
    @crunchip
    2021-06-01 00:00:00.034  - info: sourceanalytix.0 (2735) Reset start values for : 0_userdata.0.power.currentEnergyFridge
    2021-06-01 00:00:00.135  - info: sourceanalytix.0 (2735) Memory values before reset : {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"0_userdata__0__power__currentEnergyFridge","financialCategory":"costs","headCategory":"consumed","meter_values":false,"name":"currentEnergyFridge","stateType":"Electricity","stateUnit":"W","useUnit":"kWh"},"calcValues":{"start_day":126.83756066755701,"start_month":104.17565750031011,"start_quarter":81.51084640275386,"start_week":126.83756066755701,"start_year":13.218844167194998,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":127.5928532914266,"previousReadingWatt":31.651756449122114,"previousReadingWattTs":1622498340109},"prices":{"basicPrice":"0","unitPrice":"0.10"}}
    2021-06-01 00:00:00.662  - error: sourceanalytix.0 (2735) uncaught exception: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2021-05-31.log'
    2021-06-01 00:00:00.663  - error: sourceanalytix.0 (2735) Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2021-05-31.log'
        at Object.unlinkSync (fs.js:1136:3)
        at WriteStream.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js:138:28)
        at WriteStream.emit (events.js:326:22)
        at WriteStream.EventEmitter.emit (domain.js:483:12)
        at finishMaybe (_stream_writable.js:639:14)
        at _stream_writable.js:616:5
        at WriteStream._final (internal/fs/streams.js:352:3)
        at callFinal (_stream_writable.js:609:10)
        at processTicksAndRejections (internal/process/task_queues.js:84:21)
    2021-06-01 00:00:00.663  - error: sourceanalytix.0 (2735) Exception-Code: ENOENT: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2021-05-31.log'
    2021-06-01 00:00:00.702  - info: sourceanalytix.0 (2735) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
    Rumpeltec
    #529
    Hallo allerseits,
    ich habe heute das Update auf 0.49 von 0.48 (beta?) gemacht wegen des neuen Adminadapters.
    Nun habe ich den lustigen Fall, dass eines meiner smartmeter (Aeontech G5 3Phasen) vorwärts und rückwärts die kwh aus einer experimentellen PV Anlage zählt. Vorher war das überhaupt kein Problem das mit SA zu erfassen.
    Doch jetzt zählt der kwh Zähler in SA nur noch "plus" obwohl an der Messeinrichtung sich die kwh gerade verringern.
    Wenn ich die Momentanleistung in Watt mit SA auswerte erfasst der Adapter das richtig und zählt im Plus und im Minus.
    Hat dafür jemand eine Erklärung oder einen Lösungsansatz?
    Vielen Dank schon mal im Voraus.
      @nwh nein, warum sollte da jeden Tag 0 drin stehen?
      NWHN Offline
      NWHN Offline
      NWH
      schrieb am zuletzt editiert von NWH
      #530
      @crunchip Was soll den da drinnen stehen?
      Am Tagesanfang sollte der Wert ja 0 sein, Im Modbus Adapter ist es auch null.
      Ich logge ja den Tagesertrag des Wechselrichters. Dieser wird ja in der Nacht wieder auf Null gesetzt und beginnt am nächsten Tag wieder von vorne.
      Ich habe jetzt den SA Adapter jetzt komplett neu installiert und alle Daten gelöscht. Und beginne bei null mit nur einem Eintrag. Ich verfolge das jetzt mal genau mit.
      • R Rumpeltec
        Hallo allerseits,
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #531
        @rumpeltec sagte in [SourceAnalytix 0.4.8-Final] Released !:
        Hallo allerseits,
        Ich verstehe den use case nicht ganz dies kan aber nicht mit 0.4.8 nach 0.4.9 zu tun haben darin wurde nur der admin 5 interface geändert und ein par Übersetzungen ;)
        • G gramar
          @crunchip
          crunchipC Offline
          crunchipC Offline
          #532
          @gramar bin grad nur am handy, scheinbar hast du da etwas falsch konfiguriert
          G 1 Antwort Letzte Antwort
          • NWHN NWH
            crunchipC Offline
            crunchipC Offline
            #533
            @nwh da steht der Zählerstand drin, den er um Mitternacht hat.
            Wenn dein Zähler selbst sich jede Nacht zurück setzt(z.b. shelly) dann beginnt dein Startwert natürlich wieder bei 0.
            Logge ich einen Zähler der fortlaufend zählt, wird bei Startwert da weiter gezählt, den der Zählerstand um Mitternacht übermittelt.
            NWHN 1 Antwort Letzte Antwort
            • R Offline
              Rumpeltec
              #534
              @dutchman
              der "use case" betrifft einen Stromkreis wo ein PV-Anlage mit dran hängt. Das Smartmeter läuft im Prinzip im Net-Metering Verfahren.
              Erzeugt die PV-Anlage mehr Strom als benötigt wird, zählt der kwh Zähler des Smartmeters rückwärts. Wird mehr Strom verbraucht als Solar erzeugt wird, dann wieder vorwärts.
              Die kwh erfasse ich mit SA für die statische Auswertung. Der Datenpunkt ist eingestellt auf "Comsumption". Die Daten werden als kwh übergeben und sind auch so fest im Datenpunkt eingestellt.
              Bisher hat SA das ganz sauber erfasst und selbst eben auch vor- und rückwärts gezählt. Jetzt aber zählt SA in Plus Richtung korrekt mit, sobald aber der Verbrauch "negativ" wird addiert SA den negativen Wert als positiven auf. Interessanterweise wird jetzt bei jeder Änderung (negativ) der gesamte Zählerstand immer wieder hinzugefügt. Ergo, zählt der jetzt gerade innerhalb von Minuten von 5 kwh auf 113.000 kwh hoch.
              Zusätzlich habe ich auf die aktuelle Ausgabe der Leistung in Watt des Smartmeters ebenfalls SA aktiviert. Da zählt er ganz korrekt dann die kwh vorwärts und rückwärts.
                NWHN Offline
                NWHN Offline
                NWH
                #535
                @crunchip Ich verstehe das dann nicht. Ich lese mit dem Modbus Adapter den SMA WR aus. Der Wert den ich logge wird jeden Tag in der Nacht auf 0 gesetzt.
                Hier die Logs, mit gestern beginnend.
                Soll hier was 01_previousDay drinnen stehen oder nicht?
                Die neuen Werte werden beim nächsten Tag addiert wie es aussieht. Dachte hier wird nur der geloggte Tageswert angezeigt. Da ja der Wert in der Nacht wieder auf Null geht.
                Oder muss ich einen anderen Wert loggen? Oder ich bin zu blöd.
                • R Rumpeltec
                  @dutchman
                  DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #536
                  works as designed...
                  Wen der gesamt wert sich resettet wird der wert drauf gezählt (war auch schon immer so) um einen reset von Steckdosen etc ab zu fangen.
                  SA rechnet mit gesamte werten, z.b. gesamt verbrauch oder gesamt production
                  R 1 Antwort Letzte Antwort
                  • crunchipC Offline
                    crunchipC Offline
                    #537
                    @nwh sagte in [SourceAnalytix 0.4.8-Final] Released !:
                    Nein, du bist in meter.readings(Zählerstände), da gibts es kein previous, macht ja auch keinen Sinn😉. Muss vom Adapter noch angepasst werden.
                    Du musst in den Ordner consumed(Verbrauch)
                      NWHN Offline
                      NWHN Offline
                      NWH
                      #538
                      @crunchip ah ok Danke, hatte ich nicht angehakt🙄
                      Aber die Werte bei meter.readings(Zählerstände) werden addiert das passt so.
                      • DutchmanD Dutchman
                        Rumpeltec
                        #539
                        @dutchman
                        Ich glaube wir meinen reden etwas aneinander vorbei.
                        Messgerät hat einen internen kwh Zähler. Dieser zählt vorwärts (Strom wird verbraucht) und rückwärts (mehr Strom wird erzeugt als verbraucht). Es ist kein Zweirichtungszähler!
                        SA zählte vorher ebenfalls vorwärts und rückwärts entsprechend Verbrauch / Erzeugung . Jetzt nur noch den Verbrauch. Wird Strom erzeugt, Zähler dreht rückwärts, subtrahiert SA nicht. Vermutlich wird der verminderte Zählerstand immer wieder als Device Reset erkannt?
                          gramar
                          #540
                          @crunchip
                          Das hat vorher aber über Monate funktioniert
                          • G gramar
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            #541
                            @gramar vor Monaten war das auch noch eine andere Adapterversion und wurde vieles umgebaut.
                              gramar
                              #542
                              @crunchip
                              Das ist mir schon klar. War aber bereits seit Jänner beim RC 0.4.8 dabei. Das heisst also 4 mal hats funktioniert… ;)
                              Was meintest du damit dass ich etwas falsch konfiguriert habe?
                              • R Rumpeltec
                                @dutchman
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #543
                                @dutchman
                                ich glaube kaum das wir aneinander vorbei reden, ich habe dir das Prinzip von SA erklärt und SA zählt nicht zurück kan man so hinnehmen oder mir nicht glauben ....
                                (mja ich hab den code geschrieben also bin mir da schon ziemlich sicher, SA ist nicht fuer Zahler concipieert die zurueck laufen..... sondern gesamt werten!)
                                  @dutchman
                                  Rumpeltec
                                  #544
                                  @dutchman ich wollte dir nicht zu nahe treten. Bitte entschuldige. Du hast da eine phantastische Arbeit mit dem Adapter geleistet.
                                  Ich verstehe nur nicht, dass ich diese Funktion bis dato genutzt habe, obwohl es gar nicht geht.
                                  Im Moment nutze ich eben die Auswertung der aktuellen Watt Zahl und da zählt er schön rückwärts.
                                  Habe mal ein screenshot von der Influxdatenbank mit rangehangen.
                                  • A Aiouh
                                    Ich muss nochmal wegen meines Zweirichtungszählers nerven...
                                    Von diesem Zähler bekomme ich bei Bezug einen positiven Wert (in Watt), wenn meine PV zurückspeisst einen negativen Wert. Nun will ich für jede Richtung einen Zähler. Eine spezielle Einstellung in SA hab ich nicht gefunden, nun dachte ich daran die positiven Werte in ein Objekt zu schreiben und die negativen in ein anderes und beide mit SA zählen zu lassen.
                                    Klappt das so oder hab ich einen Denkfehler?
                                    Jeder Tip ist willkommen :)
                                    Aiouh
                                    #545
                                    @aiouh said in [SourceAnalytix 0.4.8-Final] Released !:
                                    Nur ne kurze Rückmeldung, mein Workaround für den Zweirichtungszähler funktioniert bestens ;)
                                    • R Rumpeltec
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #546
                                      Hmm lol Code technisch unmöglich 😂 welche Version war das sicher die 0.4.8?
                                      Kan ich mir nämlich echt kaum vorstellen den im Code ist ganz deutlich wen < als voriger mache rest also runter zählen sollte er nie können.
                                      Oder warte… loggst dir da nur Watt ? Den wen Watt negatief rein kommt währe es theoretisch möglich (immernoch gegen principe vom Adapter aber möglich 😉)
                                        Rumpeltec
                                        #547
                                        @dutchman said in [SourceAnalytix 0.4.8-Final] Released !:
                                        Es war vorher eine Version mit 0.48 beta, ganz sicher nicht die final. Da hats wirklich mit kwh funktioniert. Eine Geisterfunktion sozusagen. Die Tabelle im screenshot, da wird nur Watt geloggt.
                                        Kannst ja so eine Funktion für + / - auf einem Zähler mal offiziell einbauen, statt nur Consumption und Delivery, Zusätzlich NETMETERING. Freuen sich alle, die das betreiben. (z.B. in NL, oder gern auch in USA )
                                        An dieser Stelle auch nochmal Danke für deinen schnellen Support.
                                        • R Rumpeltec
                                          DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #548
                                          Ich verstehe den Sinn dahinter nicht ganz, soweit mir bekannt (und hier in Holland üblich) darf man Zähler nicht zurück drehen ergo muss man ein doppeltes Zählwerk haben (Verbrauch und einspeisen).
                                          Dazu kommt das man weniger Geld bekommt beim Verkauf von Strom als bei der Abnahme, das ist auch de Grund warum SA dafür unterschiedliche Einheiten benutzt.
                                          Das zusammen zu pakken halten ich mit diesem Hintergrund Dan auch für sinnlos, lass mich aber gerne eines besseren belehren und die Erklärung dahinter.
                                          Auch in DE ist ein doppeltes zähl Werk Pflicht bei Einspeisung verstehe den use case also immer noch nicht 😉
