  4. ZigBee neue Version 1.5.x
    6.5k
579 Beiträge 72 Kommentatoren 188.3k Aufrufe 74 Beobachtet
  • M Mr.X
    @arteck Danke
    npm rebuild macht irgendwie nichts.
    npm install -g npm auch nicht positiv
    pi@broker-slave:~ $ npm rebuild
    pi@broker-slave:~ $ npm install -g npm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/abbrev
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-align
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asap
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/assert-plus
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asynckit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws-sign2
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws4
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/balanced-match
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bluebird
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/buffer-from
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/builtins
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byline
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/call-limit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/camelcase
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/capture-stack-trace
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/caseless
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chownr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ci-info
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-boxes
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/clone
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/code-point-at
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-name
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-convert
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-styles
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/colors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-map
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/brace-expansion
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/console-control-strings
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/core-util-is
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/create-error-class
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/yallist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/crypto-random-string
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cyclist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dashdash
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debug/node_modules/ms
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debuglog
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decamelize
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decode-uri-component
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/deep-extend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/defaults
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delayed-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/combined-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delegates
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-indent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-newline
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dotenv
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexer3
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/editor
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/emoji-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/end-of-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/env-paths
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/err-code
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promise
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promisify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agent-base
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/escape-string-regexp
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/execa/node_modules/get-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extsprintf
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-json-stable-stringify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/figgy-pudding
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-npm-prefix
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/forever-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-minipass/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs.realpath
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/function-bind
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/genfun
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-caller-file
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/getpass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/global-dirs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/got/node_modules/get-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-schema
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/fast-deep-equal
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/json-schema-traverse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/ajv
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-flag
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-symbols
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-unicode
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-cache-semantics
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-proxy-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/https-proxy-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/import-lazy
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/imurmurhash
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/infer-owner
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inherits
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ini
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cidr-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-callable
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-ci/node_modules/ci-info
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-date-object
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-npm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-obj
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dot-prop
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-redirect
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-retry-allowed
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-symbol
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-to-primitive
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-abstract
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-typedarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isexe
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isstream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsbn
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-parse-better-errors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-stringify-safe
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsonparse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lazy-property
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lock-verify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lockfile
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseindexof
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._bindcallback
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._cacheindexof
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createset
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._getnative
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createcache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._root
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseuniq
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.clonedeep
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.restparam
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.union
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.uniq
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.without
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lowercase-keys
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/meant
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-db
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-types
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/form-data
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimatch
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ignore-walk
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minizlib/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp/node_modules/minimist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cmd-shim
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ms
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/humanize-ms
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agentkeepalive
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mute-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-fetch-npm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-cache-filename
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-logical-tree
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-bundled
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/number-is-nan
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/oauth-sign
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-assign
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-keys
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/define-properties
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object.getownpropertydescriptors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-homedir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-tmpdir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/osenv
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-finally
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-exists
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-absolute
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-inside
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-vacuum
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-path-inside
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-installed-globally
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-key
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-run-path
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-parse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/performance-now
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-dir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prepend-http
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/process-nextick-args
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-inflight
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-retry/node_modules/retry
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/proto-list
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/config-chain
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/protoduck
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/errno
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pseudomap
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/lru-cache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/psl
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pump
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pumpify/node_modules/pump
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/punycode
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qw
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promzard
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-cmd-shim
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-directory
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-main-filename
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/resolve-from
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/retry
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/run-queue/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safer-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asn1
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ecc-jsbn
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iconv-lite
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/encoding
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver-diff
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/set-blocking
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sha
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-command
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/signal-exit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/slide
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/smart-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/node_modules/agent-base
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-object
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-exceptions
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-expression-parse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-correct
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/split-on-first
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-shift
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-each
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strict-uri-encode
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/query-string
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string_decoder/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stringify-package
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-eof
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-json-comments
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rc
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-auth-token
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-url
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/supports-color
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chalk
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/term-size
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/JSONStream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/timed-out
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tough-cookie
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tunnel-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tweetnacl
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bcrypt-pbkdf
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sshpk
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/typedarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uid-number
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/umask
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-lifecycle
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-slug
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-filename
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-string
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unpipe
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unzip-response
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uri-js/node_modules/punycode
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/url-parse-lax
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/package-json
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/latest-version
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-deprecate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-extend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-installed
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-promisify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-tree
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uuid
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-license
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-name
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/verror
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsprim
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-signature
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/request
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wcwidth
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which-module
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wide-align/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npmlog
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/widest-line
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/boxen
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/worker-farm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libcipm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrappy
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dezalgo
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/once
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inflight
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-packlist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rimraf
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readdir-scoped-modules
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/write-file-atomic
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bin-links
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xdg-basedir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/configstore
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/update-notifier
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xtend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mississippi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/y18n
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yallist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lru-cache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/hosted-git-info
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-json
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-install-checks
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-package-arg
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-pick-manifest
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ssri
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cacache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-fetch-happen
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs-parser/node_modules/camelcase
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-try
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-limit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-locate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/locate-path
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/find-up
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpx
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansicolors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansistyles
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/archy
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byte-size
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-columns
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-table3
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/columnify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/init-package-json
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-cidr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmaccess
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmhook
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmorg
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmpublish
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmsearch
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmteam
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-audit-report
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-profile
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-user-validate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/opener
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qrcode-terminal
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/text-table
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tiny-relative-date
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /usr/lib/node_modules/npm/node_modules/abbrev
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
    npm ERR!  [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/abbrev'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/pi/.npm/_logs/2021-06-01T13_19_29_344Z-debug.log
    XsevX Offline
    XsevX Offline
    Xsev
    schrieb am zuletzt editiert von Xsev
    #323
    @mr-x Kann es sein das du auf dem Slave ein Rechte Problem hast? Laut log hat er ja keinen Schreibzugriff auf die Dateien beim npm rebuild.
    Evtl. sudo?
    • M Mr.X
      @arteck Danke
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
      #324
      @mr-x
      Der pi darf mit sicherheit nicht in /usr/lib herumschreiben.
      npm install -g npm
      ist auch gefährlicher Quatsch, nicht machen!
      Und für npm rebuild stehst du im falschen Verzeichnis. Du musst dafür in das Verzeichnis wo der zu rebuildende Code liegt.
      'Eigentlich' rebuilded sich das Modul aber automagisch von alleine. Tut es jedenfalls bei mir immer.
        @mr-x
        npm install -g npm
        arteckA Offline
        arteckA Offline
        arteck
        #325
        @thomas-braun sagte in ZigBee neue Version 1.5.x:
        ne macht der nicht... so wie der serialport..
        • arteckA arteck
          #326
          @arteck
          Hm. Also ich habe unlängst mit meinen node-Installationen Jojo gespielt (rauf/runter/kreuz/quer), da wurde der ble wie auch der zigbee-Adapter immer brav neu gegen die entsprechende Version gebaut. Manchmal erst im dritten Anlauf, aber handanlegen musste ich nie.
          • arteckA Offline
            arteckA Offline
            arteck
            #327
            @Mr-X
            bevor du anfängst was wild auszuprobieren
            adapter stoppen DEN RICHTIGEN
            console auf AUF DEM RICHTIGEN HOST AUF
            rm -R /opt/iobroker/node_modules/zigbee-herdsman
            rm -R /opt/iobroker/node_modules/zigbee-herdsman-converters
            rm -R /opt/iobroker/node_modules/@serialport
            rm -R /opt/iobroker/node_modules/iobroker.zigbee
            dann von GIT ... AUF DEM RICHTIGEN HOST installieren https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
            nix löschen... nix deinstallieren... nur das machen was da oben steht
            Thomas BraunT Bjoern77B M 4 Antworten Letzte Antwort
            • arteckA arteck
              @Mr-X
              #328
              @arteck sagte in ZigBee neue Version 1.5.x:
              @Mr-X
              Und noch davor würde ich mal schauen ob nodeJS senkrecht ist auf beiden Systemen:
              which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              • arteckA arteck
                @Mr-X
                Bjoern77B Offline
                Bjoern77B Offline
                Bjoern77
                #329
                @arteck
                Moin
                Ich habe jetzt auch mal ein Update versucht von 1.4.1 auf 1.5.6 über die Update Funktion. Node ist v12.22.1. NPM 6.14.12
                Leider läuft der Adapter nicht los und bleibt auf gelb.
                Wenn ich in die Einstellungen des Adapters möchte, kommt die Meldung:
                "Error You need save and run adapter before pairing!"
                Hier ist mein LOG nach Versuch eines Adapterstarts:
                2021-06-01 18:19:19.813 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                2021-06-01 18:19:19.910 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 28157
                2021-06-01 18:19:22.834 - info: zigbee.0 (28157) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                2021-06-01 18:19:22.932 - info: zigbee.0 (28157) Starting Zigbee npm ...
                2021-06-01 18:19:23.245 - info: zigbee.0 (28157) Installed Version: iobroker.zigbee@1.5.6
                2021-06-01 18:19:24.890 - error: zigbee.0 (28157) Configuration is not consistent with adapter state/backup!
                2021-06-01 18:19:24.891 - error: zigbee.0 (28157) - PAN ID: configured=6754, adapter=6754
                2021-06-01 18:19:24.892 - error: zigbee.0 (28157) - Extended PAN ID: configured=aadddddddddddddd, adapter=00124b0009d6d8b0
                2021-06-01 18:19:24.893 - error: zigbee.0 (28157) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                2021-06-01 18:19:24.893 - error: zigbee.0 (28157) - Channel List: configured=24, adapter=24
                2021-06-01 18:19:24.894 - error: zigbee.0 (28157) Please update configuration to prevent further issues.
                2021-06-01 18:19:24.894 - error: zigbee.0 (28157) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                2021-06-01 18:19:24.895 - error: zigbee.0 (28157) Re-commissioning your network will require re-pairing of all devices!
                2021-06-01 18:19:24.896 - error: zigbee.0 (28157) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                2021-06-01 18:19:24.896 - error: zigbee.0 (28157) Failed to start Zigbee
                2021-06-01 18:19:24.897 - error: zigbee.0 (28157) Error herdsman start
                2021-06-01 18:19:34.898 - info: zigbee.0 (28157) Try to reconnect. 1 attempts left
                2021-06-01 18:19:34.900 - info: zigbee.0 (28157) Starting Zigbee npm ...
                2021-06-01 18:19:34.934 - info: zigbee.0 (28157) Installed Version: iobroker.zigbee@1.5.6
                2021-06-01 18:19:35.137 - error: zigbee.0 (28157) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                2021-06-01 18:19:35.138 - error: zigbee.0 (28157) Failed to start Zigbee
                2021-06-01 18:19:35.139 - error: zigbee.0 (28157) Error herdsman start
                Bisher kann ich noch immer auf 1.4.1 zurück und meine Geräte sind dann wieder da.
                Wenn ich das hier mache, gibt es wohl kein zurück, oder?:
                Neu anlernen wäre nicht schön. Es sind schon 36 Geräte im Netz.
                Oder bleiben die Geräte erhalten nach der rm Löschen-Aktion?
                Danke für jeden Tip und Gruß
                Björn
                • Bjoern77B Bjoern77
                  @arteck
                  Moin
                  Björn
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #330
                  @bjoern77 sagte in ZigBee neue Version 1.5.x:
                  auch danach kannst du auf 1.4.1 zurück. Die Geräte sind an anderer Stelle abgelegt.
                  A.
                  Bjoern77B 1 Antwort Letzte Antwort
                  • arteckA arteck
                    @Mr-X
                    Mr.X
                    #331
                    @arteck
                    @Thomas-Braun
                    Vielen Dank für eure Hilf. ich werde es ausprobieren. Kann aber erst morgen früh wieder basteln.
                    • arteckA arteck
                      @Mr-X
                      Mr.X
                      #332
                      @Mr-X
                      Hey, sorry, soll ich das ganze auf dem Master machen, oder auf dem Slave, wo Zigbee nicht mehr tut?
                      • M Mr.X
                        @Mr-X
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #333
                        @mr-x ist jetzt nicht dein ernst...
                        also auf dem wo es nicht tut..also SLAVE bei dir
                          Mr.X
                          #334
                          Ja, ich schäme mich wirklich....
                          War verwirrt, weil ich ja auf beiden prüfen sollte.
                            Mr.X
                            schrieb am zuletzt editiert von Mr.X
                            #335
                            @arteck
                            Habe die Befehle mit sudo eingegeben und nie eine Antwort erhalten in der Konsole.
                            Danach lief der Adapter, wurde grün und auch die alten Geräte funktionieren.
                            Habe images von allem gemacht, um einen guten Zustand zu haben.
                            Also, vielen lieben dank an ALLE für ihr Hilfe und Geduld.
                            Hoffe wir sprechen uns nicht beim nächsten Update..... 😁
                            • M Mr.X
                              @arteck
                              #336
                              @mr-x sagte in ZigBee neue Version 1.5.x:
                              Das ist der Normalfall, wenn der Befehl umgesetzt wurde. Du bekommst nur im negativen Fall eine Rückmeldung von der Konsole.
                                Mr.X
                                #337
                                @thomas-braun OK. danke. habe mich nur gewundert.
                                Haupsache es läuft jetzt.
                                • K GrünK Offline
                                  K GrünK Offline
                                  K Grün
                                  schrieb am zuletzt editiert von K Grün
                                  #338
                                  Hallo, ich hab mal eine Frage.
                                  Ich habe ein Zigbee Netzwerk mit einer Osram Steckdose (AB3257001NJ) und mehreren Xiaomi Devices (Türsensoren (MCCGQ01LM), Klima(WSDCGQ11LM), Taster(WXKG11LM) und Vibrationssensor (DJT11LM).
                                  Bisher war die Steckdose so plaziert das alle Xiaomi Devices diese als Router genutzt haben.
                                  Nun habe ich die Steckdose so plaziert das Sie am weitesten vom Coordinator entfernt ist.
                                  Ich hätte jetzt erwartet das die Xiaomi devices sich direkt mit dem Coordinator verbinden, wegen der besseren Empfangsnähe. Nun ist es aber so das ich in der Netzwerkkarte sehe das sie immer noch alle die Osramsteckdose als Router nutzen (mit schlechter Verbindungsqualität). Nehme ich die Steckdose komplett aus dem Netzwerk, haben die Sensoren gar keinen Kontakt mehr mit dem Netzwerk.
                                  Beim Koenkk habe ich irgendwo gelesen das die Devices sich eigentlich die beste Qualität suchen, aber Xiaomi dies nicht macht. Ist das So?
                                  Was muß ich tun , alle neu anlernen? Wie mache ich das ? Wie kriege ich die schon angelernten aus dem Netzwerk?
                                  Als coordinator habe ich einen CC2652P2.
                                  Muß ich zum koppeln/neu anlernen die Taste auf dem Stick drücken oder reicht es in IOBroker "Kopplung starten" anzuklicken?
                                  Eine weitere Frage:
                                  Was machen die Buttons im Adminpanel von Iobroker/Zigbee.
                                  • "State cleanup"
                                  • "Touchlink zurücksetzten und neu koppeln"
                                  Danke im voraus.
                                  • K GrünK K Grün
                                    Eine weitere Frage:
                                    • "State cleanup"
                                    Danke im voraus.
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #339
                                    @k-grün sagte in ZigBee neue Version 1.5.x:
                                    Das ist auch bei den Xiaomi so, allerdings kann es durchaus einige Zeit dauern bis die Anpassung auch in der Netzwerkkarte sichtbar wird. Gib dem ganzen Zeit. du kannst es bei den Xiaomi Sensoren beschleunigen in dem du sie triggerst (den am Sensor vorhandenen Taster kurz drücken so das sie Daten Senden) Machst Du das mehrfach sollten Daten mit dem Koordinator ausgetauscht werden, und die Sensoren sollten sich auf die andere Netztopologie einstellen.
                                    Zum neu anlernen muss auf dem Stick der Taster nicht gedrückt werden
                                    Eine weitere Frage:
                                    • "State cleanup"
                                    Es kann bei Updates und Konfigurationsanpassung passieren das in der Objektdatenbank States verbleiben die nicht mehr mit der Hardware verbunden sind. Diese werden über diesen Knopf automatisch entfernt.
                                    Geräte die über "Touchlink" funktionieren (zumeist Lampen) lassen sich damit zurücksetzen und neu anlernen. Dazu müssen sie sich im direkten Umfeld des Koordinators (max 1 m) befinden.
                                    K GrünK 2 Antworten Letzte Antwort
                                    • ostseereiterO Offline
                                      ostseereiter
                                      #340
                                      Hallo Freunde,
                                      Warum ist die Version immer noch im Stable drin wenn sie so viele Probleme verursacht.
                                      Gruß OSR
                                      Plattform
                                      • AsgothianA Asgothian
                                        Eine weitere Frage:
                                        • "State cleanup"
                                        K GrünK Offline
                                        K GrünK Offline
                                        K Grün
                                        #341
                                        @asgothian said in ZigBee neue Version 1.5.x:
                                        Danke für die super schnelle Antwort
                                        Es sind schon mehr als 24 h vergangen . Das mit dem Triggern muß ich nachher mal testen .
                                        • ostseereiterO ostseereiter
                                          Hallo Freunde,
                                          Muchul
                                          schrieb am zuletzt editiert von Muchul
                                          #342
                                          @ostseereiter
                                          Weil nur ein Paar Leute probleme haben und die große Masse nicht.
                                          Und das gibt es immer.
                                          Die Freunde versuchen ja auch zu helfen.
                                          ostseereiterO 1 Antwort Letzte Antwort
