  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 3.0m Aufrufe 113 Beobachtet
  • M MCU
    @thomas-braun Ja hatte ich manuell kopiert.
    Einstellungen umgestellt und erstes Backup gemacht:
    Started iobroker ...
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 684 states saved
    [DEBUG] [iobroker] - host.raspberrypi 864 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_05_13-20_21_58_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [jarvis] - found Jarvis Instance: 0
    [DEBUG] [jarvis] - start Jarvis Backup for Instance 0...
    [DEBUG] [jarvis] - Backup created: /opt/iobroker/backups/jarvis.0_2021_05_13-20_22_05_backupiobroker.tar.gz
    [DEBUG] [jarvis] - done
    [DEBUG] [javascripts] - javascript directory "/media/usb/scripts" not found
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #1210
    @mcu Das geht nicht. Backitup kann natürlich keine Dateien zurückspielen, an denen es keine ausreichenden Rechte hat.
    Und wenn nach dem umount in /opt/iobroker/backups noch Dateien liegen, dann ist das nicht richtig, der Mountpunkt soll leer sein.
      M
      M
      MCU
      #1211
      @thomas-braun Dann lösch ich die lokalen erstmal.
      Danach ein Restore versucht:
      Started restore ...
      [DEBUG] [jarvis] - Start Jarvis Restore ...
      [DEBUG] [jarvis] - filename for restore: /opt/iobroker/backups/jarvis.0_2021_05_13-02_02_52_backupiobroker.tar.gz
      [DEBUG] [jarvis] - jarvis tmp directory created: /opt/iobroker/backups/jarvis_0
      [DEBUG] [jarvis] - old jarvis database directory was successfully deleted
      [DEBUG] [jarvis] - jarvis.0 stopped
      [ERROR] [jarvis] - jarvis restore not completed
      [ERROR] [jarvis] - Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/jarvis_0/'
      [EXIT] 0
      drwxrwxrwx  2 root     root            0 Mai 13 20:28 jarvis_0
      Lass jetzt nach Umstellung der Einstellung auf dem Quellsystem nochmal eine Sicherung laufen.
      • M MCU
        Started restore ...
        [EXIT] 0
        Thomas BraunT
        Thomas BraunT
        #1212
        @mcu sagte in Test Adapter Backitup v2.1.x:
        jarvis hab ich nicht im Einsatz, keine Ahnung wie da das Backup erfolgt.
        utime
        deutet aber darauf hin, dass der user keine Rechte hat den Zeitstempel für die Datei zu setzen.
           EPERM  times is not NULL, the caller's effective UID does not
                  match the owner of the file, and the caller is not
                  privileged (Linux: does not have the CAP_FOWNER
                  capability).
          utime
                    capability).
          M
          M
          MCU
          #1213
          @thomas-braun Die Berechtigungen setzt aber Backitup selber.
          • M MCU
            Thomas BraunT
            Thomas BraunT
            #1214
            @mcu
            Aber nicht wenn:
            Oder da vorher ohne die 'noserverino'-Option gemountet wurde.
            M 2 Antworten Letzte Antwort
              @mcu
              Aber nicht wenn:
              M
              M
              MCU
              #1215
              @thomas-braun Das war ja nur ein Test, hab ich wieder gelöscht und Backitup machen lassen, aber es funktioniert nicht.
              • M MCU
                Thomas BraunT
                Thomas BraunT
                #1216
                Heißt konkret?
                  @mcu
                  Aber nicht wenn:
                  M
                  M
                  MCU
                  #1217
                  @thomas-braun sagte in Test Adapter Backitup v2.1.x:
                  Habe jetzt mit geänderten Einstellungen nochmal ein Backup laufen und dieses versucht zurückzuspielen -> auch Fehler
                   mount | grep ^//
                  //192.168.178.1/FRITZ.NAS/FDB/Backup on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=Backup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
                  • M MCU
                     mount | grep ^//
                    Thomas BraunT
                    Thomas BraunT
                    #1218
                    @mcu
                    Der Rest funktioniert? Nimm jarvis mal aus dem Backitup raus.
                      @mcu
                      M
                      M
                      MCU
                      #1219
                      @thomas-braun Es geht ja gerade um jarvis. Wie bekomme ich es aus dem gesamten Backup als Restore dann heraus?
                      umount geht nach dem Fehler auch nicht mehr:
                      sudo umount /opt/iobroker/backups
                      umount: /opt/iobroker/backups: target is busy.
                      • M MCU
                        Thomas BraunT
                        Thomas BraunT
                        #1220
                        @mcu In dem du in den Einstellungen von Backitup den Punkt 'jarvis' abwählst?
                          M
                          M
                          MCU
                          #1221
                          @thomas-braun Auf dem Zielsystem? Hab ich jetzt gemacht.
                          • M MCU
                            Thomas BraunT
                            Thomas BraunT
                            #1222
                            Da steht noch ein user in /opt/iobroker/backups/* drin. Dann kann das auch nicht ausgehängt werden.
                              M
                              M
                              MCU
                              #1223
                              @thomas-braun Auch wenn ich die Backitup Instanz stoppe?
                              Einmal gestoppt und umount hat funktioniert.
                              Auch nachdem ich auf dem Zielsystem jarvis-Häkchen entfernt habe und ein Restore gestartet habe -> weiterhin der Fehler.
                              • M MCU
                                Thomas BraunT
                                Thomas BraunT
                                #1224
                                Reicht, wenn du in der Konsole da noch draufhockst. Z. B. so:
                                echad@chet:/opt/iobroker/backups $
                                  M
                                  M
                                  MCU
                                  #1225
                                  @thomas-braun Also da scheint beim Backitup was nicht zu stimmen. Ich habe jetzt ein Restore machen können:
                                  Ich musste aber die Datei, die ich haben wollte ins lokale Verzeichnis /opt/iobroker/backups kopieren.
                                  Und dort die Rechte für iobroker anpassen:
                                  sudo chown -R iobroker:iobroker /opt/iobroker/backups
                                  Dann über LOKAL diese Datei auswählen, dort wurde aber der komplette Inhalt an Sicherungen von dem NAS angezeigt (erst nach einiger Zeit wurde, bzw nach nochmaliger Zurücksicherung bekomme ich plötzlich nur die eine LOKALE Datei angezeigt).
                                  Dort habe ich entsprechende Datei ausgewählt und der Restore wurde durchgeführt:
                                  Started restore ...
                                  [DEBUG] [jarvis] - filename for restore: /opt/iobroker/backups/jarvis.0_2021_05_13-20_34_02_backupiobroker.tar.gz
                                  [DEBUG] [jarvis] - jarvis database is successfully restored
                                  [DEBUG] [jarvis] - Try deleting the jarvis tmp directory
                                  [DEBUG] [jarvis] - jarvis tmp directory was successfully deleted
                                  [DEBUG] [jarvis] - jarvis Restore completed successfully
                                  [EXIT] jarvis database restore done
                                  [DEBUG] [jarvis] - jarvis.0 started
                                  Danach muss man über die Instanz von jarvis den Sicherungsstand innerhalb von jarvis auswählen:
                                  jeweils für devices und layout.
                                  Danke vielmals für Deine Hilfe.
                                  • M MCU
                                    Started restore ...
                                    Thomas BraunT
                                    Thomas BraunT
                                    #1226
                                    Da war das FritzNAS dann zu dem Zeitpunkt noch gemountet. Wird glaube ich erst nach 1 Minute umountet.
                                    Da war das FritzNAS nicht mehr gemountet und du hast dann das lokale File gesehen.
                                    Das ist aber ungünstig, den Ordner /opt/iobroker/backups sowohl als Mountpunkt wie auch als Speicherplatz lokaler Dateien zu verwenden.
                                    Das wird dir irgendwann um die Ohren fliegen.
                                      M
                                      M
                                      MCU
                                      #1227
                                      @thomas-braun Aber leider funktioniert es momentan nicht anders?
                                      • M MCU
                                        Thomas BraunT
                                        Thomas BraunT
                                        #1228
                                        @mcu
                                        Wie gesagt, bei meinen Backups funktioniert das sauber ohne Schatten im Mountpunkt.
                                        Wobei ich kein Jarvis in Verwendung habe.
                                          @mcu
                                          M
                                          M
                                          MCU
                                          #1229
                                          @thomas-braun Kann man mit debug Einstellungen für die Instanz dem ganzen noch besser auf den Grund gehen? Log-Stufe debug?
                                          84.2k
