  4. js-controller 3.3 jetzt im Beta
791 Beiträge 75 Kommentatoren 331.0k Aufrufe 56 Beobachtet
  • M
    M
    msauer
    Hi...Habe JSONL im Einsatz.
    Bekomme beim Update aber Fehler:
    root@MSNUC-IOB:/opt/iobroker# iobroker stop
    root@MSNUC-IOB:/opt/iobroker# sudo npm i iobroker.js-controller
    > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.12
    > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Installation broken or unknown states type: jsonl configured.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm ERR! code ELIFECYCLE
    npm ERR! errno 101
    npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
    npm ERR! Exit status 101
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
    npm ERR!     /root/.npm/_logs/2021-04-30T09_28_04_276Z-debug.log
    Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
    Thomas BraunT apollon77A 2 Antworten Letzte Antwort
    • M msauer
      npm ERR! errno 101
      npm ERR!
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @msauer sagte in js-controller 3.3 jetzt im Latest:
      root@MSNUC-IOB
      -_-
      • M
        M
        msauer
        Wen ich den Upgrade mit "iobroker upgrade self" machen will
        root@MSNUC-IOB:/opt/iobroker# iobroker upgrade self
        Controller is running. Please stop ioBroker first.
        No connection to databases possible ...
        root@MSNUC-IOB:/opt/iobroker# sudo iobroker upgrade self
        • M msauer
          Thomas BraunT
          Thomas BraunT
          Da krieg ich wieder extremes Bauchweh, bei dem Rumgemurkse mit den Rechten...
          Meld dich als Standard-User an, nicht als root!
          Ja, das geht auch in einem Container/Proxmox.
          • M
            M
            msauer
            bevor ich in die "ROOT" Diskussion NICHT einsteige:
            der og. eigentliche Fehler lag daran, das bei npm i iobroker.js-controller die Version 3.2.16 installiert werden will. Warum auch immer...sicher bestimmt wegen root.
            Nachdem ich die konkrete Version eingeben hatte, funktioniert es jetzt. Ja, ich habe einen "iobroker fix" hinterher geschoben.
            HomoranH apollon77A 2 Antworten Letzte Antwort
            -1
            • D
              D
              dack23
              Moin ich hab mich auch mal getraut das sind meine warns wenn ich den log als text posten soll oder sonst wie helfen soll sagt bescheid
              • M msauer
                reicht als Grund: weil das die stable Version ist???
                aber auch der kann nichts fixen, das in /root liegt und der user iobroker keinen Zugriff drauf hat
                  Thomas BraunT
                  Thomas BraunT
                  Genau sowas meinte ich mit planlosem Rumgemurkse mit den Rechten.
                  Als root hampelt man nicht rum, erst recht nicht wenn man die grundlegenden Konzepte von sudo und den entsprechenden Rechten offenbar überhaupt nicht verstanden hat.
                  • M msauer
                    npm ERR! errno 101
                    npm ERR!
                    apollon77A
                    apollon77A
                    @msauer Bitte oben im text lesen und im anderen Thread melden :-)
                    • M msauer
                      apollon77A
                      apollon77A
                      Strange ... Würde heissen das der npm server von dem geladen wird noch alte Daten hat ...
                      • D dack23
                        apollon77A
                        apollon77A
                        @dack23 So wie es im Eingabspost steht bitte pro Adapter der dich mit sowas bombardiert ein Issue öffnen und das dort posten.
                        • apollon77A
                          apollon77A
                          Zur Info
                          3.3.2 (2021-04-30)
                          • (Apollon77) "upgrade self" CLI command should not start controller because we require it to be stopped before (will be effective for all upgrades from 3.3.2 to higher versions only)
                          • (Apollon77) fix "iobroker upgrade" call that crashed when no updates were available
                          • (foxriver76) adjust some state wrote checks (type array needs to provide a string, ack-only-sets are allowed again)
                          ... bald schon in Ihrem Theater :-)
                          sigi234S D FredFF 3 Antworten Letzte Antwort
                          • apollon77A apollon77
                            Zur Info
                            3.3.2 (2021-04-30)
                            sigi234S
                            sigi234S
                            @apollon77 sagte in js-controller 3.3 jetzt im Latest:
                            und bei mir. 😀
                            Läuft....
                              Zur Info
                              3.3.2 (2021-04-30)
                              D
                              D
                              deta
                              @apollon77 👍 3.3.2
                              • K
                                K
                                Kueppert
                                wo habt ihr denn die 3.3.2 her? Hab gerade über die Konsole das Update gemacht - und kein Update von 3.3.1 auf 3.3.2 angeboten bekommen
                                FredFF sigi234S Thomas BraunT 3 Antworten Letzte Antwort
                                • K Kueppert
                                  FredFF
                                  FredFF
                                  FredF
                                  Most Active Forum Testing
                                  @kueppert Geduld, wird mir auch noch nicht angeboten
                                  • K Kueppert
                                    sigi234S
                                    sigi234S
                                    @kueppert sagte in js-controller 3.3 jetzt im Latest:
                                    Ging bei mir so: (Kommandozeile im jeweiligen Host)
                                    iobroker stop
                                    npm install iobroker.js-controller@3.3.2
                                    iobroker start
                                    Habe ein Windows System!
                                    Edit:
                                    @ für bestimmte Version!
                                    • HomoranH
                                      ich war ganz mutig und habe es über npm installiert.
                                      leider bekomme ich den iobroker nicht gestoppt, daher nimmt er diese Version nicht an
                                      habe iobroker stop und sudo systemctl stop iobroker ausprobiert.
                                      in der Konsole kommt bei iobroker -v bereits die 3.3.2, aber in der GUI leider nicht
                                      • sigi234S sigi234
                                        und bei mir. 😀
                                        Läuft....
                                        K
                                        K
                                        klassisch
                                        @sigi234 sagte in js-controller 3.3 jetzt im Latest:
                                        und bei mir. 😀
                                        Läuft....
                                        Du hast doch eine Win Installer Installation. Wie hast Du upgedatet?
                                        • K klassisch
                                          und bei mir. 😀
                                          Läuft....
                                          sigi234S
                                          sigi234S
                                          @klassisch sagte in js-controller 3.3 jetzt im Latest:
                                          und bei mir. 😀
                                          Läuft....
                                          Steht 2 Beiträge unten.....
                                          HomoranH K 2 Antworten Letzte Antwort
                                          84.1k
