  3. Entwicklung
  4. Adapter: Pilight
Adapter: Pilight
62 Beiträge 14 Kommentatoren 19.4k Aufrufe 4 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    jep konnte ich ….
    hat mir keine ruhe gelassen..alles löschen und nochmal neu und siehe da
    pilight.0	2017-01-06 16:34:21.725	info	terminating
    pilight.0	2017-01-06 16:34:21.707	info	cleaned everything up...
    pilight.0	2017-01-06 16:34:21.704	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    pilight.0	2017-01-06 16:34:21.704	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    pilight.0	2017-01-06 16:34:21.704	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    pilight.0	2017-01-06 16:34:21.704	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    pilight.0	2017-01-06 16:34:21.704	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    pilight.0	2017-01-06 16:34:21.704	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    pilight.0	2017-01-06 16:34:21.704	error	at Socket. (/opt/iobroker/node_modules/iobroker.pilight/lib/PilightWebsocket.js:119:38)
    pilight.0	2017-01-06 16:34:21.704	error	at Object.module.exports.createDeviceConfig.createPropertyConfig (/opt/iobroker/node_modules/iobroker.pilight/lib/pilight/index.js:68:34)
    pilight.0	2017-01-06 16:34:21.704	error	at Array.forEach (native)
    pilight.0	2017-01-06 16:34:21.704	error	at /opt/iobroker/node_modules/iobroker.pilight/lib/pilight/index.js:74:48
    pilight.0	2017-01-06 16:34:21.704	error	TypeError: Cannot read property 'role' of undefined
    pilight.0	2017-01-06 16:34:21.691	error	uncaught exception: Cannot read property 'role' of undefined
    pilight.0	2017-01-06 16:34:21.655	info	Creating state rKuche.state
    jetzt klapt der import auch nicht mehr..
    vorschläge ??
    • arteckA Offline
      arteckA Offline
      arteck
      gefindet
      wetterdaten und
      programm
      anbei meine config.json die Probleme bereitet
      	"devices": {
      		"rKuche": {
      			"protocol": [ "elro_800_switch" ],
      			"id": [{
      				"systemcode": 1,
      				"unitcode": 20
      			"state": "on"
      		"rebootprogram": {
      			"protocol": [ "program" ],
      			"id": [{
      				"name": "Reboot"
      			"program": "/sbin/reboot",
      			"arguments": "",
      			"stop-command": "",
      			"start-command": "/sbin/reboot",
      			"state": "stopped",
      			"pid": 0
      		"rEbootswitch": {
      			"protocol": [ "generic_switch" ],
      			"id": [{
      				"id": 1
      			"state": "on"
      		"wetterdaten_Oberhausen": {
      			"protocol": [ "openweathermap" ],
      			"id": [{
      				"location": "oberhausen",
      				"country": "de"
      			"humidity": 58.00,
      			"temperature": -1.76,
      			"poll-interval": 600,
      			"sunrise": 8.36,
      			"sunset": 16.41,
      			"sun": "rise",
      			"update": 0
      	"rules": {
      		"rebootrule": {
      			"rule": "IF rebootswitch.state IS on THEN switch DEVICE rebootprogram TO running",
      			"active": 1
      	"gui": {
      		"rKuche": {
      			"name": "Küche",
      			"group": [ "Rollo" ],
      			"media": [ "all" ],
      			"readonly": 0
      		"rEbootswitch": {
      			"name": "Reboot",
      			"group": [ "Wohnung" ],
      			"media": [ "all" ],
      			"confirm": 1
      			"name": "Oberhausen DE: T [Grad C], RH [%]",
      			"group": [ "Wetter" ],
      			"media": [ "all" ]
      	"settings": {
      		"log-level": 6,
      		"pid-file": "/var/run/pilight.pid",
      		"log-file": "/var/log/pilight.log",
      		"webserver-enable": 1,
      		"webserver-root": "/usr/local/share/pilight/",
      		"webserver-http-port": 5001,
      		"webserver-cache": 1
      	"hardware": {
      		"433gpio": {
      			"sender": 0,
      			"receiver": 1
      	"registry": {
      		"pilight": {
      			"firmware": {
      				"version": 65277,
      				"lpf": 204730,
      				"hpf": 70890
      			"version": {
      				"current": "7.0"
      • arteckA Offline
        arteckA Offline
        arteck
        so bin wieder stückchen weiter..
        der Fehler besteht immer noch ..hab die sequenzen rausgenommen ..dann läuft der Adapter..
        was noch zu sagen ist.. pilight darf niergends im Browser auf sein.. dann wird nicht geschaltet..
        komisch ist aber so.. hatte es noch auf Arbeitsrechner im FF offen
          sebastianj
          Also das mit dem offenen pilight webui kann ich nicht nachvollziehen. Ich hatte beides auf.
          Das andere ist mein Ding. Ich schaue da mal rein, dass ich den Fehler abfange. Magst du dazu ein issue bei GitHub aufmachen?
          Sebastian
          • arteckA Offline
            arteckA Offline
            arteck
            hab 2 issues erstellt
            • C Offline
              ccc.ggg73
              @sebastianj:
              Hi!
              Ich habe mich mal an einen Pilight adapter gemacht. Erste Dinge wie Schalten von Zwischensteckern und das auslesen von Wetter sollten gehen.
              Nun hätte ich gerne jemanden, der das testet. Denn mehr als Wetter und Zwischenstecker hab ich nicht. :-) Und es ist mein erster Adapter.
              https://github.com/sja/ioBroker.pilight
              Installation also mit````
              npm install https://github.com/sja/iobroker.pilight/tarball/master/
              Sebastian `
              Hallo Sebastianj, ich habe mit npm install aus ssh terminal installiert aber auf meine iobroker adapterliste taucht nix auf.
              Habe ich was falsches gemacht?
              Gesendet von meinem SM-G930F mit Tapatalk
                sebastianj
                Hast du das auch im ioBroker Verzeichnis gemacht? Meistens ist das /opt/iobroker
                • C Offline
                  ccc.ggg73
                  Ups… Ne. Vielen Dank
                    sebastianj
                    @arteck Ich habe gestern den von dir gefundenen Bug gefixt. Sollte jetzt stabiler mit unbekannten Konfigurationen umgehen.
                    Ich habe etwas (3h) gebraucht, um durch die Tests zu steigen. Der Test-Code aus dem ioBroker-Adapter-Template ist sehr unmodular in einer großen Datei, in der viele Dinge passieren, bei denen man Kenntnis über den ioBroker-Code haben muss. Daher hat es viel zeit gekostet, einen sinnvollen Test zu schreiben, anstatt einfach nur den Adapter zu starten und wieder zu beenden.
                    Jetzt bin ich aber soweit, dass ich einen WebSocket-Server hochfahren kann, um pilight zu emulieren und beliebige Configs beim testen unterzujubeln. Wenn also noch jemand eine Config hat, die Fehler im Log schmeißt, dann immer her damit.
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      klasse… hast aber noch nicht eingecheckt ??
                      • C Offline
                        crepp
                        Ich habe die Funksteckdosen aktuell auf einem zweiten Raspi laufen (mit wiring pi) Ich bin natürlich sehr interessiert dass ich alles über iobroker steuern kann. Deswegen war ich froh als ich gesehen habe dass es jetzt einen Adapter gibt der das (evtl. ?) untersützt. Was muss ich bei der Config (Port) eingeben ? Hab leider noch keine Anleitung gefunden.
                        Hab mal die IP des anderen Raspi angegeben u. die Portnummer die voreingestellt ist beibehalten, aber Fehlanzeige:
                        MfG
                        crepp
                        crepp
                        CCU2 / 2x RaspberryPi / 2x Amazon Echo Dot / Milight LED / Philips Hue (z.Z. 16 Homematic-Geräte)
                        Kodi auf W10pro und OSMC
                        DVBViewer MediaServer auf W10
                        • BluefoxB Offline
                          BluefoxB Offline
                          @ccc.ggg73:
                          @sebastianj:
                          Hi!
                          Sebastian `
                          Gesendet von meinem SM-G930F mit Tapatalk `
                          In welchem Verzeichnis hast du das gemacht?
                          Es muss in /opt/iobroker passieren. Danach auf refresh Button auf Adapter Tab chicken.
                            MadM4x
                            Tachen,
                            da ich gerade dabei bin mich mit iobroker zu beschäftigen und darüber meine komplette Steuerung zu nutzen,
                            wollte ich mal Fragen ob der pilight Adapter nun fehlerfrei läuft auf nem RPi 3?
                            Und/Oder ob an dem Adapter überhaupt noch weiter gearbeitet bzw. gefixed wird?
                            Oder ist das Projekt "gestorben" ?
                            Der letzte Posting ist ja nun doch schon etwas länger her….
                            Hab den Thread gerade durch Zufall bei Google gefunden.
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              ja der läuft auf dem pi3 und was soll da weiterentwickelt werden ??
                                MadM4x
                                @arteck:
                                ja der läuft auf dem pi3 und was soll da weiterentwickelt werden ?? `
                                Das weiterentwickeln bezog sich darauf, falls der Adapter nicht zu 100% funzt ;)
                                Aber wenn er läuft werd ich ihn mal installieren.
                                Danke fürs Feedback
                                • H Offline
                                  holodoc
                                  Ich will den Adapter auch mal ausprobieren, habe ihn auch installiert bekommen, hänge nun aber bei
                                  pilight.0	2017-12-09 16:16:37.718	info	Requesting initial states...
                                  pilight.0	2017-12-09 16:16:37.715	info	WebSocket connection established!
                                  pilight.0	2017-12-09 16:16:37.651	info	Connecting to "ws://localhost:5001/"
                                  pilight.0	2017-12-09 16:16:37.649	info	Option sharedWS = false
                                  pilight.0	2017-12-09 16:16:37.628	info	starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.pilight, node: v6.12.0
                                  Eine Idee?
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    wie hast du pilight konfiguriert ?? welche adressen dürfen es aufrufen ??
                                    • H Offline
                                      holodoc
                                      Siehe unten meine Pilight-Config, ich habe keine Whitelist für Zugriffe angelegt falls Du das meinst - ich hätte gedacht wenn es eh direkt vom localhost kommt, sollte da nicht geblockt werden oder sehe ich das falsch?
                                              "devices": {
                                                      "Steckdose1": {
                                                              "protocol": [ "intertechno_switch" ],
                                                              "id": [{
        "id": 24438618,
        "unit": 0
                                                              "state": "off"
                                                      "Steckdose2": {
                                                              "id": [{
        "id": 24438618,
        "unit": 1
                                                              "state": "off"
                                                      "Steckdose3": {
                                                              "id": [{
        "id": 24438618,
        "unit": 2
                                                              "state": "off"
                                                      "Steckdose4": {
                                                              "protocol": [ "kaku_screen" ],
                                                              "id": [{
        "id": 24438618,
        "unit": 3
                                                              "state": "down"
                                                      "Steckdose5": {
                                                              "protocol": [ "quigg_gt7000" ],
                                                              "id": [{
        "id": 1967,
        "unit": 0
                                                              "state": "off"
                                              "rules": {},
                                              "gui": {
                                                      "Steckdose1": {
                                                              "name": "Steckdose 1 (Intertechno)",
                                                              "group": [ "MeineSwitches" ],
                                                              "media": [ "all" ]
                                                      "Steckdose2": {
                                                              "name": "Steckdose 2 (Intertechno)",
                                                              "media": [ "all" ]
                                                      "Steckdose3": {
                                                              "name": "Steckdose 3 (Intertechno)",
                                                              "media": [ "all" ]
                                                      "Steckdose4": {
                                                              "name": "Steckdose 4 (aussen)",
                                                              "media": [ "all" ]
                                                      "Steckdose5": {
                                                              "name": "Steckdose 5 (Quigg)",
                                                              "media": [ "all" ]
                                              "settings": {
                                                      "log-level": 6,
                                                      "webserver-root": "/usr/local/share/pilight/webgui",
                                                      "webserver-https-port": 5002,
                                                      "webserver-cache": 1,
                                                      "gpio-platform": "raspberrypi3"
                                              "hardware": {
                                                      "433gpio": {
                                                              "sender": 0,
                                                              "receiver": 1
                                              "registry": {}
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        genau so… die pilight oberfläche bekommst du zu sehen in Browser ??
                                        also ip:5001
                                        so sieht meine konfig aus ...
                                        "settings": {
                                        		"log-level": 6,
                                        		"whitelist": "127.0.0.1"
                                        	"hardware": {
                                        		"433gpio": {
                                        			"sender": 0,
                                        			"receiver": 1
                                        	"registry": {
                                        		"pilight": {
                                        			"firmware": {
                                        				"version": 65535,
                                        				"lpf": 655350,
                                        				"hpf": 655350
                                        			"version": {
                                        				"current": "7.0"
                                        • H Offline
                                          holodoc
                                          Mmh da ist ja nicht viel anders, ich habe die Whitelist und die registry noch so übernommen, aber es werden weiterhin keine Objekte angelegt :/
                                          Achso und die normale Pilight-Browseroberfläche funktioniert, ja.
