  4. JavaScript
  5. [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
474 Beiträge 50 Kommentatoren 141.3k Aufrufe 41 Beobachtet
  • P Protheus
    @pittini
    Leider tut noch immer nicht:
    Im Log sehe ich jetzt auch nichts auffälliges:
    javascript.0	2021-04-17 01:20:24.364	info	(12184) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxxxxxxx.mode / read=true write=true
    javascript.0	2021-04-17 01:20:24.364	info	(12184) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxxxxxxx.dry / read=true write=true
    javascript.0	2021-04-17 01:20:24.364	info	(12184) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxxxxxxx.child_lock / read=true write=true
    javascript.0	2021-04-17 01:20:24.364	info	(12184) script.js.common.System.Mi-Home-Integration: No Datapoint Trigger set for humidity because its readonly.
    javascript.0	2021-04-17 01:20:24.364	info	(12184) script.js.common.System.Mi-Home-Integration: No Datapoint Trigger set for temperature because its readonly.
    javascript.0	2021-04-17 01:20:24.364	info	(12184) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxxxxxxx.buzzer / read=true write=true
    javascript.0	2021-04-17 01:20:24.363	info	(12184) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxxxxxxx.led / read=true write=true
    javascript.0	2021-04-17 01:20:24.363	info	(12184) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxxxxxxx.limit_hum / read=true write=true
    javascript.0	2021-04-17 01:20:24.363	info	(12184) script.js.common.System.Mi-Home-Integration: No Datapoint Trigger set for depth because its readonly.
    javascript.0	2021-04-17 01:20:24.363	info	(12184) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxxxxx.power / read=true write=true
    javascript.0	2021-04-17 01:20:24.363	info	(12184) script.js.common.System.Mi-Home-Integration: Setting DataPointTrigger #0 for zhimi.humidifier.ca4
    javascript.0	2021-04-17 01:20:24.362	info	(12184) script.js.common.System.Mi-Home-Integration: Reaching CreateDpTrigger
    javascript.0	2021-04-17 01:20:24.362	info	(12184) script.js.common.System.Mi-Home-Integration: Setting trigger #0 for zhimi.humidifier.ca4
    javascript.0	2021-04-17 01:20:24.362	info	(12184) script.js.common.System.Mi-Home-Integration: Init Device# 0 - device="zhimi.humidifier.ca4"
    javascript.0	2021-04-17 01:20:24.136	info	(12184) script.js.common.System.Mi-Home-Integration: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"xxxxxxxxxxxxxxxx","address":"10.10.80.99","token":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    javascript.0	2021-04-17 01:20:24.135	info	(12184) script.js.common.System.Mi-Home-Integration: Now creating device for zhimi.humidifier.ca4 / xxxxxxxxxxxxx / 10.10.80.99 / xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx / 10000
    javascript.0	2021-04-17 01:20:24.135	info	(12184) script.js.common.System.Mi-Home-Integration: Reaching CreateDevices
    javascript.0	2021-04-17 01:20:24.134	info	(12184) script.js.common.System.Mi-Home-Integration: Reaching WriteGenericDpValues()
    javascript.0	2021-04-17 01:20:24.133	info	(12184) script.js.common.System.Mi-Home-Integration: Reaching main
    javascript.0	2021-04-17 01:20:24.133	info	(12184) script.js.common.System.Mi-Home-Integration: 17 States created, now setting up channels!
    javascript.0	2021-04-17 01:20:24.082	info	(12184) script.js.common.System.Mi-Home-Integration: Reaching CreateStates()
    javascript.0	2021-04-17 01:20:24.082	info	(12184) script.js.common.System.Mi-Home-Integration: Reaching PrepareDeviceDps, did=xxxxxxxxxxxxxxxxx model=zhimi.humidifier.ca4
    javascript.0	2021-04-17 01:20:24.082	info	(12184) script.js.common.System.Mi-Home-Integration: Device Luftbefeuchter-AZ is supported, creating DataPoints
    javascript.0	2021-04-17 01:20:24.082	info	(12184) script.js.common.System.Mi-Home-Integration: Now searching for supported Devices...
    javascript.0	2021-04-17 01:20:24.082	info	(12184) script.js.common.System.Mi-Home-Integration: Luftbefeuchter-AZ
    javascript.0	2021-04-17 01:20:24.081	info	(12184) script.js.common.System.Mi-Home-Integration: Found 1 MiHome Devices, those are:
    javascript.0	2021-04-17 01:20:23.921	info	(12184) script.js.common.System.Mi-Home-Integration: Retrieving your in de registered MiHome Devices
    Zumindest alles nur info Lines.
    Nodejs habe ich auch bereits wie in einem Beitrag hier in dem Thread neu installiert.
    Das System (und auch den JS-Adapter) habe ich mehrfach neu gestartet.
    Den Ordner node-mihome habe ich auch mal umbenannt und geschaut wie er sich nach einem Neustart verhält
    -> Das node-mihome Modul wird neu installiert und die Device-Datei zhimi.humidifier.ca4 ist auch in dem original node-mihome Adapter dabei
    Hat hierzu noch jemand eine Idee?
    Viele Grüße
    Protheus
    haselchenH Offline
    haselchenH Offline
    haselchen
    #114
    @protheus
    Wie sieht denn jetzt dein Eintrag im Javascript Adapter aus bezüglich NPM Module?
    Und hast du Nodejs12 am Laufen ?
    P 1 Antwort Letzte Antwort
    • haselchenH haselchen
      @protheus
      Protheus
      #115
      @haselchen sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
      @protheus
      wie von Pittini angemerkt nur noch das node-mihome Modul drin
      Ja, meines Erachtens nach alles aktuell
      Ist ein Debian 10 und apt update zeigt nix neues an.
      Viele Grüße
      Protheus
      • haselchenH Offline
        haselchenH Offline
        haselchen
        #116
        @protheus
        Okay. Wenn du node-mihome installiert hast, die Definitionsdatei von Pittinis Link im Ordner hast und Nodejs12 ist, dann kann vermutlich nur der Entwickler helfen.
        Er selbst schreibt auf seiner Github Seite, dass das Gerät bereit zum Testen ist. Was mir halt sagt, dass es noch nicht voll integriert ist.
        Smartmi Evaporative Humidifier - zhimi.humidifier.cb1 - (voll/voll)
        Smartmi Evaporative Humidifier - deerma.humidifier.jsq - (ready to test)
        **Smartmi Evaporative Humidifier - zhimi.humidifier.ca4 - (ready to test)**
        https://github.com/Pittini/iobroker-nodemihome
        • P Protheus
          @pittini
          Viele Grüße
          Protheus
          Pittini
          schrieb am zuletzt editiert von Pittini
          #117
          @protheus sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
          Das heißt aber nicht dasses eine funktionierende Version ist, bitte zur Sicherheit unbedingt die von mir verwenden. Gehts dann immer noch nicht, das logging im Skript aktivieren und startlog hier posten. Ach und welche Version vom JS Adapter nutzt Du?
          • P Pittini
            Protheus
            #118
            @pittini sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
            Der Javascript Adapter hat Version 5.0.14 (aktuell)
            Mit der neuen ca4 Datei (aus Pittini-Repo) gehts auch nicht.
            Hier das Log:
            javascript.0	2021-04-17 12:31:38.811	info	(31213) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxx.mode / read=true write=true
            javascript.0	2021-04-17 12:31:38.811	info	(31213) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxx.dry / read=true write=true
            javascript.0	2021-04-17 12:31:38.811	info	(31213) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxx.child_lock / read=true write=true
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: No Datapoint Trigger set for humidity because its readonly.
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: No Datapoint Trigger set for temperature because its readonly.
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxx.buzzer / read=true write=true
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxx.led / read=true write=true
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxx.limit_hum / read=true write=true
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: No Datapoint Trigger set for depth because its readonly.
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: Setting Datapoint Trigger for javascript.0.MiHomeAll.xxxxxxxxxxx.power / read=true write=true
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: Setting DataPointTrigger #0 for zhimi.humidifier.ca4
            javascript.0	2021-04-17 12:31:38.810	info	(31213) script.js.common.System.Mi-Home-Integration: Reaching CreateDpTrigger
            javascript.0	2021-04-17 12:31:38.809	info	(31213) script.js.common.System.Mi-Home-Integration: Setting trigger #0 for zhimi.humidifier.ca4
            javascript.0	2021-04-17 12:31:38.809	info	(31213) script.js.common.System.Mi-Home-Integration: Init Device# 0 - device="zhimi.humidifier.ca4"
            javascript.0	2021-04-17 12:31:38.424	info	(31213) script.js.common.System.Mi-Home-Integration: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"xxxxxxxxxxx","address":"10.10.80.99","token":"xxxxxxxxxxxxxxxxxxxxxxxxxxx
            javascript.0	2021-04-17 12:31:38.423	info	(31213) script.js.common.System.Mi-Home-Integration: Now creating device for zhimi.humidifier.ca4 / xxxxxxxxxxx / 10.10.80.99 / xxxxxxxxxxxxxxxxxxxxxxxxxxx26 / 10000
            javascript.0	2021-04-17 12:31:38.423	info	(31213) script.js.common.System.Mi-Home-Integration: Reaching CreateDevices
            javascript.0	2021-04-17 12:31:38.423	info	(31213) script.js.common.System.Mi-Home-Integration: Reaching WriteGenericDpValues()
            javascript.0	2021-04-17 12:31:38.423	info	(31213) script.js.common.System.Mi-Home-Integration: Reaching main
            javascript.0	2021-04-17 12:31:38.422	info	(31213) script.js.common.System.Mi-Home-Integration: 17 States created, now setting up channels!
            javascript.0	2021-04-17 12:31:38.419	info	(31213) script.js.common.System.Mi-Home-Integration: Reaching CreateStates()
            javascript.0	2021-04-17 12:31:38.418	info	(31213) script.js.common.System.Mi-Home-Integration: Reaching PrepareDeviceDps, did=xxxxxxxxxxx model=zhimi.humidifier.ca4
            javascript.0	2021-04-17 12:31:38.418	info	(31213) script.js.common.System.Mi-Home-Integration: Device Luftbefeuchter-AZ is supported, creating DataPoints
            javascript.0	2021-04-17 12:31:38.418	info	(31213) script.js.common.System.Mi-Home-Integration: Now searching for supported Devices...
            javascript.0	2021-04-17 12:31:38.418	info	(31213) script.js.common.System.Mi-Home-Integration: Luftbefeuchter-AZ
            javascript.0	2021-04-17 12:31:38.418	info	(31213) script.js.common.System.Mi-Home-Integration: Found 1 MiHome Devices, those are:
            javascript.0	2021-04-17 12:31:38.249	info	(31213) script.js.common.System.Mi-Home-Integration: Retrieving your in de registered MiHome Devices
            Viele Grüße
            Protheus
            • P Protheus
              Hier das Log:
              Viele Grüße
              Protheus
              Pittini
              #119
              @protheus Das is das selbe Log wie oben, das reicht nicht, ich brauch das ausführliche bei eingeschaltetem logging im Skript.
              • P Pittini
                Protheus
                #120
                Isses das nich?
                Viele Grüße
                Protheus
                • P Protheus
                  Isses das nich?
                  Viele Grüße
                  Protheus
                  Pittini
                  #121
                  @protheus Ja, doch, schon. Aber iwie müßte da mehr kommen.
                  • P Pittini
                    Protheus
                    #122
                    Wenn du mir sagst wir ich ein neues (umfangreicheres) Log generiere, mache ich das gern.
                    Viele Grüße
                    Protheus
                    • P Protheus
                      Viele Grüße
                      Protheus
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #123
                      @protheus
                      Im Javascript Adapter zum Skript gehen und es stoppen.
                      Dann wieder starten. Dann müsste darunter eine Ausgabe kommen vom Start.
                      • Z Offline
                        Z Offline
                        zaim
                        #124
                        Hallo, ich habe einen xiaomi smart fan pro (mit akku). Da dafür keine konfig verfügbar war, habe ich die zhimi.fan.za4.js unter dem neuen dateinamen "dmaker.fan.p15.js" eingefügt und editiert: "static model = 'dmaker.fan.p15';
                        static name = 'Smartmi Standing Fan PRO'; ".
                        Starte ich nun das Skript, werden auch Datenpunkte angelegt, diese aber nicht aktualisiert bzw. befüllt. das log wirft auch keine fehler und erkennt meine staubsauger und den Smartmi Standing Fan PRO. was kann ich machen damit die Datenpunkte gefüllt werden?
                        • Z Offline
                          Z Offline
                          zaim
                          #125
                          hier noch das log
                          20.4.2021, 14:53:21.109 [info ]: javascript.0 (6015) Stop script script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO
                          20.4.2021, 14:53:22.271 [info ]: javascript.0 (6015) Start javascript script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO
                          20.4.2021, 14:53:22.303 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Starting AllMyMi V.0.2.11
                          20.4.2021, 14:53:22.304 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Reaching init
                          20.4.2021, 14:53:22.308 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: registered 0 subscriptions and 0 schedules
                          20.4.2021, 14:53:22.309 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: You are already logged in, login canceled
                          20.4.2021, 14:53:22.309 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Retrieving your in de registered MiHome Devices
                          20.4.2021, 14:53:22.436 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Found 3 MiHome Devices, those are:
                          20.4.2021, 14:53:22.436 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Mi Smart Standing Fan Pro
                          20.4.2021, 14:53:22.437 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Floorian
                          20.4.2021, 14:53:22.437 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Oberon
                          20.4.2021, 14:53:22.438 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Now searching for supported Devices...
                          20.4.2021, 14:53:22.438 [warn ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: No supported Devices found!
                          20.4.2021, 14:53:22.439 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Reaching CreateStates()
                          20.4.2021, 14:53:22.491 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: 21 States created, now setting up channels!
                          20.4.2021, 14:53:22.493 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Reaching main
                          20.4.2021, 14:53:22.493 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Reaching WriteGenericDpValues()
                          20.4.2021, 14:53:22.498 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Reaching CreateDevices
                          20.4.2021, 14:53:22.499 [info ]: javascript.0 (6015) script.js.Tests.Xiaomi_Geräte_Smart_FAN_PRO: Reaching CreateDpTrigger
                          • Z zaim
                            hier noch das log
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #126
                            @zaim
                            Es reicht ja nicht die Namen nur zu ändern.
                            Du musst herausfinden mit welchen get und set Befehlen die Daten vom Lüfter geholt werden können.
                            Der Log Auszug sagt es ja schon
                            Z 1 Antwort Letzte Antwort
                              Marc12345
                              #127
                              ich habe aktuelles Node, aktuellen Javascript und hier alles in den Anleitungen befolgt. Mein Luftreiniger (Xiaomi 3H) wird auch einschl. Netzwerkadresse etc. erkannt und alle Datenpunkte leer angelegt, allerdings keinerlei Daten eingelesen. Angeblich wären die Schreibpunkte schreibgeschützt (den Schreibschutz habe ich aber testweise überall manuell entfernt).
                              Der Luftreiniger hängt im Gästenetz, Biobroker im Hauptnetz. Da die Daten aber aus der Cloud geladen werden, dürfte das aber doch nichts ausmachen. Was mache ich falsch?
                              javascript.0	2021-04-20 17:43:50.745	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.physical-controls-locked.physical-controls-locked / read=true write=true
                              javascript.0	2021-04-20 17:43:50.745	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for filter.filter-used-time because its readonly.
                              javascript.0	2021-04-20 17:43:50.744	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for filter.filter-life-level because its readonly.
                              javascript.0	2021-04-20 17:43:50.743	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for environment.pm2_5-density because its readonly.
                              javascript.0	2021-04-20 17:43:50.743	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for environment.relative-humidity because its readonly.
                              javascript.0	2021-04-20 17:43:50.742	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for use-time.use-time because its readonly.
                              javascript.0	2021-04-20 17:43:50.741	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.motor-speed.favorite-fan-level / read=true write=true
                              javascript.0	2021-04-20 17:43:50.740	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for motor-speed.motor-set-speed because its readonly.
                              javascript.0	2021-04-20 17:43:50.740	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for motor-speed.motor-speed because its readonly.
                              javascript.0	2021-04-20 17:43:50.739	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for environment.temperature because its readonly.
                              javascript.0	2021-04-20 17:43:50.738	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.indicator-light.on / read=true write=true
                              javascript.0	2021-04-20 17:43:50.737	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.indicator-light.brightness / read=true write=true
                              javascript.0	2021-04-20 17:43:50.736	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.alarm.alarm / read=true write=true
                              javascript.0	2021-04-20 17:43:50.735	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.air-purifier.fan-level / read=true write=true
                              javascript.0	2021-04-20 17:43:50.735	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.air-purifier.mode / read=true write=true
                              javascript.0	2021-04-20 17:43:50.734	info	(31556) script.js.Xiaomi: No Datapoint Trigger set for air-purifier.fault because its readonly.
                              javascript.0	2021-04-20 17:43:50.733	info	(31556) script.js.Xiaomi: Setting Datapoint Trigger for javascript.0.MiHomeAll.392268520.air-purifier.on / read=true write=true
                              javascript.0	2021-04-20 17:43:50.732	info	(31556) script.js.Xiaomi: Setting DataPointTrigger #0 for zhimi.airpurifier.mb3
                              javascript.0	2021-04-20 17:43:50.731	info	(31556) script.js.Xiaomi: Reaching CreateDpTrigger
                              javascript.0	2021-04-20 17:43:50.729	info	(31556) script.js.Xiaomi: Setting trigger #0 for zhimi.airpurifier.mb3
                              javascript.0	2021-04-20 17:43:50.728	info	(31556) script.js.Xiaomi: Init Device# 0 - device="zhimi.airpurifier.mb3"
                              javascript.0	2021-04-20 17:43:46.583	info	(31556) script.js.Xiaomi: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"392218520","address":"192.168.179.100","token":"b62a7sdf96a5d379f3a73518cd7sdfa8a5","protocol":"local",
                              javascript.0	2021-04-20 17:43:46.582	info	(31556) script.js.Xiaomi: Now creating device for zhimi.airpurifier.mb3 / 392218520 / 192.168.179.100 / b62a7sdf96a5d379f3a73518cd7sdfa8a5 / 10000
                              javascript.0	2021-04-20 17:43:46.581	info	(31556) script.js.Xiaomi: Reaching CreateDevices
                              javascript.0	2021-04-20 17:43:46.579	info	(31556) script.js.Xiaomi: Reaching WriteGenericDpValues()
                              javascript.0	2021-04-20 17:43:46.579	info	(31556) script.js.Xiaomi: Reaching main
                              javascript.0	2021-04-20 17:43:46.578	info	(31556) script.js.Xiaomi: 24 States created, now setting up channels!
                              javascript.0	2021-04-20 17:43:46.328	info	(31556) script.js.Xiaomi: Reaching CreateStates()
                              javascript.0	2021-04-20 17:43:46.327	info	(31556) script.js.Xiaomi: Reaching PrepareDeviceDps, did=392218520 model=zhimi.airpurifier.mb3
                              javascript.0	2021-04-20 17:43:46.326	info	(31556) script.js.Xiaomi: Device Luftreiniger is supported, creating DataPoints
                              javascript.0	2021-04-20 17:43:46.326	info	(31556) script.js.Xiaomi: Now searching for supported Devices...
                              javascript.0	2021-04-20 17:43:46.325	info	(31556) script.js.Xiaomi: Luftreiniger
                              javascript.0	2021-04-20 17:43:46.325	info	(31556) script.js.Xiaomi: Found 1 MiHome Devices, those are:
                              javascript.0	2021-04-20 17:43:46.213	info	(31556) script.js.Xiaomi: Retrieving your in de registered MiHome Devices
                              javascript.0	2021-04-20 17:43:46.212	info	(31556) script.js.Xiaomi: You are already logged in, login canceled
                              javascript.0	2021-04-20 17:43:46.211	info	(31556) script.js.Xiaomi: registered 0 subscriptions and 0 schedules
                              javascript.0	2021-04-20 17:43:46.208	info	(31556) script.js.Xiaomi: Reaching init
                              javascript.0	2021-04-20 17:43:46.208	info	(31556) script.js.Xiaomi: Starting AllMyMi V.0.2.11
                              javascript.0	2021-04-20 17:43:46.185	info	(31556) Start javascript script.js.Xiaomi
                              • M Marc12345
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                #128
                                @marc12345
                                Hast du die .js Datei vom 3H von Pittinis Seite geladen und in den mihome Ordner kopiert?
                                Und readonly ist okay oder was willst du an den Datenpunkten ändern können?
                                Das sind Info Datenpunkte, nix zum Rumspielen.
                                  @zaim
                                  Z Offline
                                  Z Offline
                                  zaim
                                  #129
                                  @haselchen ich muss da selber auf die Befehle kommen? ich dachte da die befehle des ursprünglichen zhimi.fan.za4.js in der datei stehen, dass wenigstens ein paar sachen funktionieren ;)
                                  wie finde ich das denn raus? kann ja schlecht munter drauflos raten oder ;)
                                    @marc12345
                                    Marc12345
                                    #130
                                    Ja, unter "/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices" liegt bei mir u.a. die Datei "zhimi.airpurifier.mb3.js"
                                    • Z zaim
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #131
                                      @zaim
                                      Musst mal im Netz schauen , auf Anhieb weiss ich die Seite nicht mehr.
                                      Jeder Purifier hat eine Art Definitionsdatei womit die Werte abgefragt werden.
                                      Github würde ich mal probieren.
                                      Oder @Pittini als Entwickler hat ne Idee.
                                      • M Marc12345
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #132
                                        @marc12345
                                        Hast du sie dir geholt und reinkopiert oder die da schon war dringelassen?
                                          @marc12345
                                          Marc12345
                                          #133
                                          Ich habe in der bereits vorhandenen den Inhalt gelöscht und den Inhalt von der speziellen Datei von Pittini reimkopiert (auch wenn mir diese identisch vorkommen)
