  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.8k Aufrufe 78 Beobachtet
  • afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #496
    @wild-kaban
    Hallo, ich habe noch ein Update auf Github hochgeladen. Bitte testen.
    NegaleinN W 2 Antworten Letzte Antwort
    • afuerhoffA afuerhoff
      @wild-kaban
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #497
      @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
      Adapter geht mit der neuen Version gleich auf Pause
      fb-checkpresence.0	2021-04-18 02:57:00.978	info	(6038) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fb-checkpresence.0	2021-04-18 02:57:00.976	info	(6038) terminating
      fb-checkpresence.0	2021-04-18 02:57:00.474	info	(6038) cleaned everything up ...
      fb-checkpresence.0	2021-04-18 02:57:00.471	info	(6038) Got terminate signal TERMINATE_YOURSELF
      fb-checkpresence.0	2021-04-18 02:57:00.383	warn	(6038) onReady: Fb init: getSSLPort: DeviceInfo:1 GetSecurityPort timeout of 6000ms exceeded
      fb-checkpresence.0	2021-04-18 02:56:54.318	info	(6038) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.18.3, js-controller: 3.1.6
      fb-checkpresence.0	2021-04-18 02:56:52.336	debug	(6038) statesDB connected
      fb-checkpresence.0	2021-04-18 02:56:52.330	debug	(6038) States connected to redis: 0.0.0.0:9000
      fb-checkpresence.0	2021-04-18 02:56:52.231	debug	(6038) States create System PubSub Client
      fb-checkpresence.0	2021-04-18 02:56:52.228	debug	(6038) States create User PubSub Client
      fb-checkpresence.0	2021-04-18 02:56:52.183	debug	(6038) Redis States: Use Redis connection: 0.0.0.0:9000
      fb-checkpresence.0	2021-04-18 02:56:52.177	debug	(6038) objectDB connected
      fb-checkpresence.0	2021-04-18 02:56:52.164	debug	(6038) Objects connected to redis: 0.0.0.0:9001
      fb-checkpresence.0	2021-04-18 02:56:52.076	debug	(6038) Objects client initialize lua scripts
      fb-checkpresence.0	2021-04-18 02:56:52.075	debug	(6038) Objects create User PubSub Client
      fb-checkpresence.0	2021-04-18 02:56:52.074	debug	(6038) Objects create System PubSub Client
      fb-checkpresence.0	2021-04-18 02:56:52.043	debug	(6038) Objects client ready ... initialize now
      fb-checkpresence.0	2021-04-18 02:56:51.979	debug	(6038) Redis Objects: Use Redis connection: 0.0.0.0:9001
      ° Fixer ---> iob fix
      • NegaleinN Negalein
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #498
        @negalein
        In der Initialisierung hat er keine Verbindung zur Fritzbox aufbauen können. Daher der Adapter-Stop. Hat aber nichts mit der Änderung zu tun. Da scheint ein Zugriffsproblem zur Fritzbox zu bestehen.
          @negalein
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #499
          an der FB wurde nichts verändert.
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #500
            @negalein
            Versuch mal einen Reboot der Fritzbox.
            Die sperrt schon mal den Zugriff über das tr-064 Protokoll.
              @negalein
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #501
              Merci
              Das wars! :)
              Btw., muss ich da was machen?
              fb-checkpresence.0	2021-04-18 14:43:23.390	warn	(11400) The state "fb-checkpresence.0.Handy-Nega" will not longer exist in a future version. Please use "fb-checkpresence.0.Handy-Nega.presence" instead!
                Merci
                Das wars! :)
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #502
                @negalein
                Den Datenpunkt fb-checkpresence.0.Handy-Nega wird es in einer zukünftigen Version nicht mehr geben.
                Wenn du auf Kompatibilität = false stellst, werden die Datenpunkte so wie in einer zukünftigen Version angelegt. Die alten Datenpunkte musst du dann allerdings manuell noch löschen.
                Du solltest dann bei Gelegenheit auf diesen Datenpunkt umstellen -> Kompatibiltität = true: fb-checkpresence.0.Handy-Nega.presence oder Kompatibiltität = false: fb-checkpresence.0.familyMembers.Handy-Nega.presence.
                Ich hoffe, ich hab mich einigermaßen verständlich ausgedrückt.
                  @negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #503
                  Ja :)
                  Hab aber das nächste Problem.
                  Ich hab die Ordnerstruktur gelöscht, damit sie vom Adapter neu erstellt wird.
                  Neu einlesen hab ich aktiviert.
                  Mir wird aber jetzt kein Device, Blacklist und Whitelist angelegt, bzw ist ziemlich leer.
                  Das kommt im Log beim Start.
                  fb-checkpresence.0	2021-04-18 15:24:39.517	warn	(4781) getExtIp:
                  fb-checkpresence.0	2021-04-18 15:24:25.499	warn	(4781) getActive Handy-Nega: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                  fb-checkpresence.0	2021-04-18 15:24:19.494	warn	(4781) getActive Handy-Lisi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                  fb-checkpresence.0	2021-04-18 15:24:13.489	warn	(4781) getActive Handy-Mausi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                  fb-checkpresence.0	2021-04-18 15:23:56.977	warn	(4781) Layer3Forwarding1-GetDefaultConnectionService is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.976	warn	(4781) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.975	warn	(4781) WANPPPConnection1-ForceTermination is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.975	warn	(4781) DeviceConfig1-Reboot is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.974	warn	(4781) X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.973	warn	(4781) X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.973	warn	(4781) DeviceInfo1-GetInfo is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.972	warn	(4781) WLANConfiguration3-GetSecurityKeys is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.972	warn	(4781) WLANConfiguration3-GetInfo is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.971	warn	(4781) WLANConfiguration3-SetEnable is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.970	warn	(4781) WANIPConnection1-GetInfo is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.970	warn	(4781) WANPPPConnection1-GetInfo is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.969	warn	(4781) WANCommonInterfaceConfig1-GetCommonLinkProperties is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.968	warn	(4781) Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.967	warn	(4781) Hosts1-X_AVM-DE_GetMeshListPath is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:56.966	warn	(4781) Hosts1-X_AVM-DE_GetHostListPath is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:28.356	warn	(3425) getActive Handy-Nega: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                  fb-checkpresence.0	2021-04-18 15:23:22.349	warn	(3425) getActive Handy-Lisi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                  fb-checkpresence.0	2021-04-18 15:23:16.344	warn	(3425) getActive Handy-Mausi: Hosts:1 GetSpecificHostEntry: timeout of 6000ms exceeded
                  fb-checkpresence.0	2021-04-18 15:23:01.587	warn	(3425) Layer3Forwarding1-GetDefaultConnectionService is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:01.587	warn	(3425) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:01.586	warn	(3425) WANPPPConnection1-ForceTermination is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:01.586	warn	(3425) DeviceConfig1-Reboot is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:01.585	warn	(3425) X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:01.585	warn	(3425) X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:01.584	warn	(3425) DeviceInfo1-GetInfo is not supported! Feature is deactivated!
                  fb-checkpresence.0	2021-04-18 15:23:01.584	warn	(3425) WLANConfiguration3-GetSecurityKeys is not supported! Feature is deactivated!
                    Ja :)
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #504
                    @Negalein
                    Scheint schon wieder keine Verbindung zur Fritzbox zu bestehen.
                      @Negalein
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #505
                      jetzt läufts.
                      Warum auch immer, hat er immer nach dem speichern als Benutzername admin stehen gehabt.
                      Ich hab definitiv den richtigen reingeschrieben.
                      Jetzt nach 3maliger Prozedur läufts! :)
                        jetzt läufts.
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #506
                        @Negalein
                        Das Problem gab es schon mal. Liegt am Browser und der Autofill Funktion. Problem
                        ist bloß, dass die Fritzbox ziemlich schnell den Zugang dicht macht, wenn die Login Daten nicht stimmen. Dann hilft immer nur ein Reboot.
                        sigi234S NegaleinN 2 Antworten Letzte Antwort
                          @Negalein
                          sigi234S Online
                          sigi234S Online
                          #507
                          Jupp, Autofill habe ich deaktiviert.
                            @Negalein
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #508
                            die ist schon ewig deaktiviert.
                              @wild-kaban
                              W Offline
                              W Offline
                              Wild Kaban
                              #509
                              @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                              @wild-kaban
                              Danke ...sieht gut aus.
                              Hab viele Meldungen "The state "fb-checkpresence.0.XXXX" will not longer exist in a future version. "
                              Kann ich einfach den gesamten Datenbaum löschen um das weg zu bekommen ?
                              • W Wild Kaban
                                @wild-kaban
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #510
                                @wild-kaban
                                Hallo, bitte hier nachlesen:
                                https://forum.iobroker.net/topic/37959/test-adapter-fb-checkpresence-v1-1-x/509?_=1618851749435
                                  afuerhoffA Offline
                                  afuerhoff
                                  #511
                                  ich habe noch ein Update hochgeladen. Die Filterung habe ich noch optimiert.
                                    SBorgS Offline
                                    SBorgS Offline
                                    SBorg
                                    #512
                                    @afuerhoff Ich habe gesehen, dass du auch den Admin 5.x testest. Wahrscheinlich weißt du es bereits, aber Ergebnis bei "react UI" und dunklem Thema (weißer Adler auf weißem Grund...) :
                                    LG SBorg ( SBorg auf GitHub)
                                    TG70T afuerhoffA 2 Antworten Letzte Antwort
                                    • SBorgS SBorg
                                      TG70T Offline
                                      TG70T Offline
                                      TG70
                                      Forum Testing
                                      #513
                                      Hallo hat jemand einen Tipp für mich was das im Log bedeutet?
                                      fb-checkpresence.0	2021-04-21 13:11:02.377	error   (7269) getAllFbObjectsNew {}
                                      fb-checkpresence.0	2021-04-21 13:11:02.341	error	(7269) getDeviceList: "Can not read hostlist path"
                                      fb-checkpresence.0	2021-04-21 13:11:02.341	error	(7269) soapAction X_AVM-DE_GetHostListPath status=null errNo=0
                                      ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
                                      • SBorgS SBorg
                                        afuerhoffA Offline
                                        afuerhoffA Offline
                                        afuerhoff
                                        #514
                                        @sborg sagte in Test Adapter fb-checkpresence v1.1.x:
                                        Ist bekannt und ein Issue habe ich im Admin erstellt.
                                        • TG70T TG70
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #515
                                          @tg70 sagte in Test Adapter fb-checkpresence v1.1.x:
                                          Er konnte dann die Daten von der Fritzbox nicht abrufen. Kommt das ständig?
                                          TG70T 1 Antwort Letzte Antwort
