  4. Material Design Widgets: Value Widget
vis
76 Beiträge 16 Kommentatoren 15.6k Aufrufe 18 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    @sigi234
    mittlerweile habe ich das value widget
    da geht es auch
    selbe formel - selber datenpunkt
    • liv-in-skyL liv-in-sky
      @sigi234
      da geht es auch
      sigi234S Online
      sigi234S Online
      @liv-in-sky
      Geht nicht, mein Original RAW:
        "from": "system.adapter.homeconnect.0",
        "user": "system.user.admin",
        "ts": 1616770922094,
        "common": {
          "name": "Betriebsstatus",
          "type": "mixed",
          "role": "indicator",
          "unit": "",
          "write": true,
          "read": true,
          "states": {
            "BSH.Common.EnumType.OperationState.Inactive": "Inactive",
            "BSH.Common.EnumType.OperationState.Ready": "Ready",
            "BSH.Common.EnumType.OperationState.Run": "Run",
            "BSH.Common.EnumType.OperationState.Finished": "Finished"
        "native": {},
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
        "_id": "homeconnect.0.401010522278007458.status.BSH_Common_Status_OperationState",
        "ty
      • sigi234S sigi234
        @liv-in-sky
          "common": {
            "type": "mixed",
            "unit": "",
            "write": true,
            "read": true,
            "states": {
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "ty
        liv-in-skyL Offline
        liv-in-skyL Offline
        @sigi234 zeig mal die formel
          sigi234S Online
          sigi234S Online
          @liv-in-sky sagte in Material Design Widgets: Value Widget:
          {a:homeconnect.0.401010522278007458.status.BSH_Common_Status_OperationState; a === "BSH.Common.EnumType.OperationState.Inactive" ? "aus" : a === "BSH.Common.EnumType.OperationState.Ready" ? "Ready" : a === "BSH.Common.EnumType.OperationState.Run" ? "Run" : a === "BSH.Common.EnumType.OperationState.Finished" ? "Finished"}
          Im Wert sind Klammern?
          • ub.privatU ub.privat
            @scrounger
            Du hast recht, es fehlte das Ausführungszeichen "...
            {a:homeconnect.0.SIEMENS-HS858GXB6-68A40E060A0C.status.BSH_Common_Status_OperationState; a === "BSH.Common.EnumType.OperationState.Inactive" ? "Inactive" : a === "BSH.Common.EnumType.OperationState.Ready" ? "Ready" : a === "BSH.Common.EnumType.OperationState.Run" ? "Run" : a === "BSH.Common.EnumType.OperationState.Finished" ? "Finished" : a === "BSH.Common.EnumType.OperationState.Pause" ? "Pause"}
            es ändert aber nichts am Ergebnis!
            So langsam gebe ich auf...
            Du hattest geschrieben: "😉 Mit dem value Widget geht das noch nicht, muss ich noch implementieren.", , dass du diese Art der Abfrage mit in das Widget einbauen möchtest. Dann werde ich wohl warten. Egal welches Widget ich verwende, dass Bindig ist ja entscheidend.
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            schrieb am zuletzt editiert von Scrounger
            @ub-privat, @sigi234
            Das Binding ist auch nicht korrekt, so auf die schnelle am Ende fehlt noch Else Bedienung also : xxx
            Schau dir das bei @liv-in-sky an da ist es korrekt.
            Grundsätzlich kann ich dir empfehlen Bau das Mal Schritt für Schritt auf, also erste Bedienung, testen, dann zweite Bedienung rein, testen usw
            • sigi234S sigi234
              liv-in-skyL Offline
              liv-in-skyL Offline
              @sigi234
              teste mal:
              {val:homeconnect.0.401010522278007458.status.BSH_Common_Status_OperationState; val== "BSH.Common.EnumType.OperationState.Inactive" ? "aus" : val=="BSH.Common.EnumType.OperationState.Ready" ? "Ready" : val=="BSH.Common.EnumType.OperationState.Run" ? "Run" : val=="BSH.Common.EnumType.OperationState.Finished" ? "Finished" : "no-no" }
              • sigi234S sigi234
                liv-in-skyL Offline
                liv-in-skyL Offline
                @sigi234
                sorry - diesmal hatte ich einen fehler drin
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  @sigi234
                  Jupp, es kommt Run 👍
                  Ich sehe auf den 1.Blick keinen Unterschied
                  • sigi234S sigi234
                    @sigi234
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @sigi234 dann nutz den zweiten - === ist jetzt ==
                    und am ende fehlte : no-no - sonst ist die formel nicht richtig
                      sigi234S Online
                      sigi234S Online
                      Um es zu verstehen, wie kommst du auf : no-no
                      • sigi234S sigi234
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @sigi234 das no-no kann auch irgendwas andres sein -es geht darum , dass
                        mmm ? "nnn" : "yyy"
                        wenn mmm dann nnn sonst yyy
                        wenn du nun immer wieder statt yyy eine weitere abfrage reingibst, fehlt am ende ein
                        : yyy
                        die formel ist dann nicht fertig - man nennt das auch einen defaultwert - wenn alles davor nicht paßt, wird yyy eingesetzt - ich habe einfach no-no genommen - da kann auch "" stehen,
                        normalerweise bringt der adapter genaudie 4 werte - daher wirst du no-no nie sehen werden !
                        ub.privatU 2 Antworten Letzte Antwort
                          mmm ? "nnn" : "yyy"
                          : yyy
                          ub.privatU Offline
                          ub.privatU Offline
                          ub.privat
                          @liv-in-sky
                          @Scrounger
                          @sigi234
                          war ne schwere Geburt, aber nun funktioniert es! @liv-in-sky - tolle Erklärung, nun habe ich es vollends verstanden und in mein kleines Wiki verewigt!
                          DANKE.
                            mmm ? "nnn" : "yyy"
                            : yyy
                            ub.privatU Offline
                            ub.privatU Offline
                            ub.privat
                            schrieb am zuletzt editiert von ub.privat
                            @liv-in-sky
                            ich muss leider die Flagge wieder runter ziehen, zu früh gefreut.
                            Mit dem Datenpunkt, so wie du ihn aufbereitet hast, funktioniert es bei 3 Geräten einwandfrei. Hier wird der Gerätezustand angezeigt, klappt perfekt.
                            Nun wollte ich auf die identische Art und weise die aktiven Programme visualisieren.
                            Der DP heist (RAW):
                              "type": "state",
                              "common": {
                                "name": "BSH_Common_Root_ActiveProgram",
                                "type": "string",
                                "write": true,
                                "read": true,
                                "states": {
                                  "Cooking.Oven.Program.HeatingMode.HotAirEco": "Heißluft eco",
                                  "Cooking.Oven.Program.HeatingMode.TopBottomHeatingEco": "Ober-/ Unterhitze eco",
                                  "Cooking.Oven.Program.HeatingMode.PizzaSetting": "Pizzastufe",
                                  "Cooking.Oven.Program.HeatingMode.IntensiveHeat": "Intensivhitze",
                                  "Cooking.Oven.Program.HeatingMode.SlowCook": "Sanftgaren",
                                  "Cooking.Oven.Program.HeatingMode.HotAir": "4D Heißluft",
                                  "Cooking.Oven.Program.HeatingMode.TopBottomHeating": "Ober-/ Unterhitze",
                                  "Cooking.Oven.Program.HeatingMode.HotAirGrilling": "Umluftgrillen",
                                  "Cooking.Oven.Program.HeatingMode.BottomHeating": "Unterhitze",
                                  "Cooking.Oven.Program.HeatingMode.Desiccation": "Dörren",
                                  "Cooking.Oven.Program.HeatingMode.PreheatOvenware": "Geschirr vorwärmen",
                                  "Cooking.Oven.Program.HeatingMode.FrozenHeatupSpecial": "coolStart-Funktion",
                                  "Cooking.Oven.Program.HeatingMode.KeepWarm": "Warmhalten"
                              "native": {},
                              "ts": 1616709638385,
                              "_id": "homeconnect.0.SIEMENS-CN878G4B6-68A40E0542E8.programs.active.BSH_Common_Root_ActiveProgram",
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                            Nun habe ich, das Widget wie folgt beschrieben:
                            {val:homeconnect.0.SIEMENS-CN878G4B6-68A40E0542E8.programs.active.BSH_Common_Root_ActiveProgram; val== "Cooking.Oven.Program.HeatingMode.PizzaSetting": ? "Pizzastufe" : "no-no" }
                            Nach Scrougers Ratschlag, erstmal einen Zustand zu testen und dan zu erweitern, war richtig und gut. Deshalb habe ich nur die Pizzstufe drin, kann es auch gerade testen, weil der Backofen an ist.
                            Nur in der VISU kommt wieder eine NULL!
                            Würdest bitte noch mal einen Blick auf das Binding werfen?
                              @liv-in-sky
                              Der DP heist (RAW):
                                "type": "state",
                                "common": {
                                  "type": "string",
                                  "write": true,
                                  "read": true,
                                  "states": {
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @ub-privat der ":" vor dem "?" nach pizzasetting gehört da nicht hin gehört
                              du kannst in chrome die entwicklertools öffnen und auf console-tab siehst du sofort beim laden, ob du ein symantisches problem hast
                              • ub.privatU Offline
                                ub.privatU Offline
                                ub.privat
                                @liv-in-sky
                                Der Hinweis mit GoogleChrome ist gar nicht so schlecht. Ein paar Fehler - SCHREIBFEHLER! - konnte ich bereits beseitigen. DANKE.
                                Nun habe ich noch folgenden Fehler, dazu der ERROR-Text aus der Console:
                                promisebuffer.ts:24 Error in eval[value]     : {val:homeconnect.0.SIEMENS-SX858D06PE-68A40E064ECA.programs.active.BSH_Common_Root_ActiveProgram; val== "Dishcare.Dishwasher.Program.Intensiv70" ? "Intensiv 70°C" : val== "Dishcare.Dishwasher.Program.Auto2" ? "Auto 45-65°C" : val== "Dishcare.Dishwasher.Program.Eco50" ? "Eco 50°C : val== "Dishcare.Dishwasher.Program.NightWash" ? "Leise" : val== "Dishcare.Dishwasher.Program.Quick65" ? "Schnell 65°C" : val== "Dishcare.Dishwasher.Program.Quick45" ? "Schnell 45°C" : val== "Dishcare.Dishwasher.Program.MachineCare" ? "Maschinenpflege" : "no-no" }
                                (anonymous) @ promisebuffer.ts:24
                                (anonymous) @ captureconsole.ts:16
                                formatBinding @ vis.js:2498
                                createIds @ vis.js:3312
                                (anonymous) @ vis.js:3330
                                sentryWrapped @ helpers.ts:124
                                setTimeout (async)
                                (anonymous) @ trycatch.ts:197
                                createIds @ vis.js:3329
                                (anonymous) @ vis.js:3461
                                (anonymous) @ conn.js:801
                                r.onack @ socket.io.js:8
                                r.onpacket @ socket.io.js:8
                                (anonymous) @ socket.io.js:8
                                r.emit @ socket.io.js:6
                                r.ondecoded @ socket.io.js:6
                                a.add @ socket.io.js:6
                                r.ondata @ socket.io.js:6
                                r.onPacket @ socket.io.js:6
                                (anonymous) @ socket.io.js:6
                                r.onPacket @ socket.io.js:7
                                r.onData @ socket.io.js:7
                                ws.onmessage @ socket.io.js:8
                                promisebuffer.ts:24 Error in eval[script]: var val = "undefined";return  val== "Dishcare.Dishwasher.Program.Intensiv70" ? "Intensiv 70°C" : val== "Dishcare.Dishwasher.Program.Auto2" ? "Auto 45-65°C" : val== "Dishcare.Dishwasher.Program.Eco50" ? "Eco 50°C : val== "Dishcare.Dishwasher.Program.NightWash" ? "Leise" : val== "Dishcare.Dishwasher.Program.Quick65" ? "Schnell 65°C" : val== "Dishcare.Dishwasher.Program.Quick45" ? "Schnell 45°C" : val== "Dishcare.Dishwasher.Program.MachineCare" ? "Maschinenpflege" : "no-no" ;
                                formatBinding @ vis.js:2499
                                setTimeout (async)
                                promisebuffer.ts:24 Error in eval[error] : SyntaxError: Unexpected identifier
                                Das ist mein Binding:
                                Wie muss ich den Fehlertext lesen? Ist dies die Fehlerquelle: Error in eval[script]: var val = "undefined";return ?
                                  @liv-in-sky
                                  setTimeout (async)
                                  setTimeout (async)
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @ub-privat
                                  anführungszeichen fehlt
                                  nach 50°C
                                  ub.privatU 1 Antwort Letzte Antwort
                                    @ub-privat
                                    nach 50°C
                                    ub.privatU Offline
                                    ub.privatU Offline
                                    ub.privat
                                    @liv-in-sky
                                    JUPP, das wars. Ich glaube, das Programmieren wird nicht mein Spezialgebiet. Diese Syntax nervt einen die Sicht...
                                    Aber deine Empfehlung ist Gold-Wert.
                                    Wie hast du so schnell die fehlenden " gefunden?
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @ub-privat
                                      intuition - keine ahnung - habe in letzter zeit viel mit code gemacht - irgendwann sieht man das - nachdem man natütlich die selben fehler 100 mal selber gemacht hat
                                        @ub-privat
                                        ub.privatU Offline
                                        ub.privatU Offline
                                        ub.privat
                                        @liv-in-sky
                                        na dann bin ich beruhigt, vllt. wird's ja noch! DANKE nochmals!
                                          Marcel85
                                          Hallo.
                                          Ist stehe gerade vor dem selben Problem.
                                          Ich habe schon die letzten Bindings mit meinem verglichen und nach meinem Verständnis sollte es bei mir so funktionieren.
                                          Allerdings zeigt er mir im Widget nur 0 an.
                                          Der Datenpunkt gibt die Werte 1, 2 und 3 aus. Daraus soll er offen, verriegelt und entriegelt machen.
                                          Vielleicht könnte mir dabei jemand auf die Sprünge helfen.
                                          Mein Binding:
                                          {val:vw-connect.0.TMB**************.status.data_0x030104FFFF.field_0x0301040001.value; val== "2" ? "offen"}
                                          Vielen Dank schon mal!
                                          Gruß Marcel
