  4. Test Adapter enigma2 v1.2.x
adapterenigma2
640 Beiträge 71 Kommentatoren 286.0k Aufrufe 60 Beobachtet
  • Matten MattenM Matten Matten
    @Jan1 sagte in Test Adapter enigma2 v1.2.x:
    Der Adapter läuft leider nicht mehr mit dem neuen JS-Controller 3.2.3 und bringt Fehler:
    2021-01-09 13:18:47.837 - info: host.Beelink "system.adapter.enigma2.0" disabled
    2021-01-09 13:19:03.296 - info: host.Beelink "system.adapter.enigma2.0" enabled
    2021-01-09 13:19:03.363 - info: host.Beelink instance system.adapter.enigma2.0 started with pid 1556694
    2021-01-09 13:19:05.000 - info: enigma2.0 (1556694) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.15.4, js-controller: 3.2.3
    2021-01-09 13:19:05.031 - info: enigma2.0 (1556694) starting Polling every 5000 ms
    2021-01-09 13:19:05.075 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-01-09 13:19:05.076 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
    2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Error: Not exists
    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2270:17)
    at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3010:38)
    at processImmediate (internal/timers.js:463:21)
    2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Not exists
    2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
    2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Error: Not exists
    2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Not exists
    2021-01-09 13:19:05.104 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
    2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Error: Not exists
    2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Not exists
    2021-01-09 13:19:05.106 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
    2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) Error: Not exists
    2021-01-09 13:19:05.108 - error: enigma2.0 (1556694) Not exists
    2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
    2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Error: Not exists
    2021-01-09 13:19:05.110 - error: enigma2.0 (1556694) Not exists
    2021-01-09 13:19:05.619 - info: enigma2.0 (1556694) terminating
    2021-01-09 13:19:05.621 - warn: enigma2.0 (1556694) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-01-09 13:19:06.260 - error: host.Beelink instance system.adapter.enigma2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-01-09 13:19:06.262 - info: host.Beelink Restart adapter system.adapter.enigma2.0 because enabled
    "fixed with js-controller 3.2.4" hat Apollon geantwortet.
    Matten Matten
    J
    J
    Jan1
    #421
    @Matten-Matten
    bleibt für Dich noch dieses kleine Problemchen ;)
    enigma2.0	2021-01-10 11:38:36.473	warn	(2002513) State "enigma2.0.Message.MESSAGE_ANSWER" has no existing object, this might lead to an error in future versions
    enigma2.0	2021-01-10 11:38:36.471	warn	(2002513) State "enigma2.0.enigma2.CHANNEL_PICON" has no existing object, this might lead to an error in future versions
    • T
      T
      Termina
      #422
      Thema Videowiedergabe
      Gibt es eine Möglichkeit Informationen zu erhalten, wenn die Box ein Video abspielt? Das normale TV-Programm kann man ja mittlerweile super auch in der VIS abbilden - wäre bei Filmen doch auch super, oder?
      A SBorgS 2 Antworten Letzte Antwort
      • T Termina
        A
        A
        aleks-83
        schrieb am zuletzt editiert von aleks-83
        #423
        @termina
        Geht das Ganze nicht über die "EVENT..." Datenpunkte? (EVENT_PROGRESS_PERCENT, EVENTREMAINING_MIN...)
        Kann man mit dem Adapter eigentlich irgendwie das Display einer Enigma2 Box dimmen?
        Speziell einer VU+ Duo2?
        = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
        = Node.js v22.22.2 = NPM 10.9.7 = JS Controller 7.2.5 =
        Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
        Glasfaser 400
        • T Termina
          SBorgS
          SBorgS
          SBorg
          #424
          @termina sagte in Test Adapter enigma2 v1.2.x:
          Ja, ich finde nur gerade nicht wie ich es genau gelöst habe. Ich lasse mir aber in der VIS das Sender-Picon anzeigen. Wenn ich ein Video abspiele wird dies dann durch ein "Festplatten"-Picon ersetzt.
          Soweit ich mich erinnere wird beim abspielen eines Videos die SID in etwa auf "0:0:0:0:0:0:0:0::" gesetzt, was ich mir dafür zu nutze mache, denn die wird nur da in der Art gesetzt.
          @aleks-83 IMHO nein, denn mir wäre aktuell kein Web-IF Befehl (und die nutzt der Adapter per API) bekannt der die Helligkeit dimmen könnte. Außer es gäbe einen Konsolen-Befehl dafür, dann könnte man den per SSH absetzen.
          LG SBorg ( SBorg auf GitHub)
          • E
            E
            EVOlutionIX
            #425
            Hallo alle zusammen, ich bin jetzt wirklich 424 Beiträge durch gegangen aber ich kann kaum verstehen wie es funktioniert einfach auf einen bestimmten Kanal zu wechseln.
            Ich konnte es mir solala zusammen reimen wie ich den Kanal Wechsel über den Befehl Servicereference (woher bekommt man sie Servicereference einfacher ohne den Umweg DreamboxEDIT) ? Allerdings schaffe ich es nicht auf den stream meiner IP Kamera umzuschalten, der in der Senderliste gespeichert ist, wenn ich auf die Servicereference umschalte bekomme ich nur einen schwarzen Bildschirm?
            Schönen Sonntag noch Gruß Marcus
            Hardware: Raspberry Pi3 (ioBroker reserve) + Intel NUC (ioBroker) mit Ubutu Server 18.04 + CCU 2
            Ausstattung: HM Messdosen, HM Heizungssteuerung, HM Türsensoren, HM Lichtschalter, Sonoff Schalter
            • E EVOlutionIX
              NegaleinN
              NegaleinN
              Negalein
              #426
              @evolutionix sagte in Test Adapter enigma2 v1.2.x:
              http://IP-deiner-Box/web/getallservices
              ° Fixer ---> iob fix
              Jens MeyerJ 1 Antwort Letzte Antwort
              • NegaleinN Negalein
                Jens MeyerJ
                Jens MeyerJ
                Jens Meyer
                schrieb am zuletzt editiert von Jens Meyer
                #427
                Hallo an alle hier...
                Der Adapter funktioniert und bin gerade am probieren,
                Mit was kann ich den die movielist anzeigen lassen? Mit einfach html gehts nicht, json geht so auch nicht
                Was nehmt ihr dafür und gibts ne Möglichkeit ne epg Vorschau für mehrere Tage anzuzeigen und dann was nehme ich dann auch dafür? Ne Tabelle?
                Danke schon mal
                Meister MopperM NegaleinN 2 Antworten Letzte Antwort
                • Jens MeyerJ Jens Meyer
                  Danke schon mal
                  Meister MopperM
                  Meister MopperM
                  Meister Mopper
                  #428
                  @jens-meyer Du kannst das webif in einem View in vis anzeigen lassen und dort auch bedienen.
                  Proxmox und HA ...
                    Jens MeyerJ
                    Jens MeyerJ
                    Jens Meyer
                    #429
                    @meister-mopper ja, das wollte ich eigentlich nicht.. das webif kann ich auch so aufrufen..
                    ich dachte es muss doch ne andere Möglichkeit geben das darzustellen
                    Aber danke
                      Aber danke
                      Meister MopperM
                      Meister MopperM
                      Meister Mopper
                      #430
                      @jens-meyer Dann musst Du ein eigenes webif bauen, das wäre mir zu viel 😧
                      Proxmox und HA ...
                        Jens MeyerJ
                        Jens MeyerJ
                        Jens Meyer
                        #431
                        @meister-mopper
                        Nein ich will das ja nur in der vis darstellen...
                        Und der datenpunkt existiert ja
                          Danke schon mal
                          NegaleinN
                          NegaleinN
                          Negalein
                          #432
                          @jens-meyer sagte in Test Adapter enigma2 v1.2.x:
                          schau mal hier
                            schau mal hier
                            Jens MeyerJ
                            Jens MeyerJ
                            Jens Meyer
                            #433
                            @negalein
                            Danke, schau ich mir mal genauer an...
                            • W
                              W
                              west
                              schrieb am zuletzt editiert von west
                              #434
                              Ist das der https://github.com/Matten-Matten/ioBroker.enigma2 oder zum Testen steht oder ein anderen?
                              Habe selber eine VU+ Solo4K mit OpenATV 6.4.20210409
                              • W west
                                GlasfaserG
                                GlasfaserG
                                #435
                                @west
                                Ist der richtige Link.
                                W 1 Antwort Letzte Antwort
                                • GlasfaserG Glasfaser
                                  @west
                                  W
                                  W
                                  west
                                  #436
                                  @glasfaser Ok
                                  Die Command werden mir nicht angezeigt.
                                  • W west
                                    @glasfaser Ok
                                    GlasfaserG
                                    GlasfaserG
                                    #437
                                    @west
                                    Was heißt " command " fehlt.
                                    Fehlt der Ordner ... fehlen Datenpunkte .
                                    ioBroker Seite mal aktualisiert !?
                                      @west
                                      W
                                      W
                                      west
                                      #438
                                      @glasfaser Hast recht😉
                                      • NegaleinN
                                        NegaleinN
                                        Negalein
                                        #439
                                        Ich bekomm seit JS-Controller 3.3.14 laufend solche Meldungen.
                                        enigma2.0 | 2021-07-08 16:04:56.849 | info | State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
                                        enigma2.0 | 2021-07-08 16:04:56.848 | info | State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
                                        enigma2.0 | 2021-07-08 16:04:56.844 | info | State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
                                        Meister MopperM Matten MattenM 2 Antworten Letzte Antwort
                                          Meister MopperM
                                          Meister MopperM
                                          Meister Mopper
                                          #440
                                          @negalein
                                          Wird denn der Adapter überhaupt noch betreut?
                                          Proxmox und HA ...
                                          Matten MattenM 1 Antwort Letzte Antwort
                                          33.2k
                                          84.3k
