  4. BackItUp - Fehler beim InfluxDB Backup
influxdbinfluxbackupbackitupbackitup influxdb
21 Beiträge 3 Kommentatoren 3.3k Aufrufe 3 Beobachtet
    @prezl sagte in BackItUp - Fehler beim InfluxDB Backup:
    connect: connection refused. Waiting 2s and retrying (0)..
    läuft influx local oder separat?
    bind addresse RPC sollte standard "127.0.0.1:8088" in der influx config stehen, zufälligerweise da was geändert?
    Prezl
    In der Influx config wurde nichts geändert.
    pi@raspberrypi:~ $ influxd config
    Merging with configuration at: /etc/influxdb/influxdb.conf
    reporting-disabled = false
    bind-address = "127.0.0.1:8088"
    Die InfluxDB läuft auf dem gleichen Raspberry wie der iobroker (IP-Adresse 192.168.178.42). Deshalb sehen meine Einstellungen so aus:
    Wenn ich "InfluxDB-Hostname" auf localhost oder Sicherungsquelle auf Lokal stelle, kommt folgender Fehler:
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 738 states saved
    [DEBUG] [iobroker] - host.raspberrypi 914 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_27-14_43_50_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database Energie -host localhost:8088 "/opt/iobroker/backups/influxDB_2021_02_27-14_43_56_backupiobroker"
    backup: open /opt/iobroker/backups/influxDB_2021_02_27-14_43_56_backupiobroker/meta.00.pending: stale NFS file handle
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
    • P Prezl
      crunchipC Offline
      crunchipC Offline
      @prezl deine Sicherungsquelle muss auf Local stehen, da du influx ja direkt auf dem iobroker laufen hast. Bei Host entweder die IP oder gar nichts eingeben, sollte auch automatisch richtig eingetragen werden, wenn du auf ermittle Konfig drückst.
      Desweiteren schreibst du
      Das Backup für den iobroker scheint zu funktionieren,
      ja oder nein?
      Wenn dies ebenfalls nicht funktioniert, dann stimmt deine CIFS Verbindung nicht
      P 1 Antwort Letzte Antwort
        ja oder nein?
        Prezl
        Ich gehe davon aus, dass das Backup vom iobroker funktioniert. Es wird eine Datei auf dem USB-Stick erstellt, z. B. "iobroker_2021_02_27-14_39_03_backupiobroker.tar.gz" und im Tab "Wiederherstellen" kann ich die entsprechende Sicherung auch auswählen.
        Wenn ich die Sicherungsquelle bei InfluxDB auf Local stelle, kommt es zu folgendem Fehler (Zeile 14).
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_27-15_41_35_backupiobroker.tar.gz
        [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database Energie "/opt/iobroker/backups/influxDB_2021_02_27-15_41_41_backupiobroker"
        backup: open /opt/iobroker/backups/influxDB_2021_02_27-15_41_41_backupiobroker/meta.00.pending: stale NFS file handle
        • P Prezl
          crunchipC Offline
          crunchipC Offline
          ok, wenn die Datei vorhanden ist, funktioniert ja die generelle Verbindung zum Stick, also ein spezielles Problem mit Influx.
          stell mal auf Remote und gib bei Host deine IP an, so steht es auch im offiziellen Thread
            Prezl
            @crunchip sagte in BackItUp - Fehler beim InfluxDB Backup:
            So hatte ich es ja ganz am Anfang, siehe den ersten Post. Nur kommt dann eben der Fehler...
            Muss ich für ein Backup bei InfluxDB etwas spezielles einstellen?
            • P Prezl
              crunchipC Offline
              crunchipC Offline
              nicht das ich wüsste
              aber wenn du testweise mal in der influx config die bind Adresse änderst
              statt # bind-address = "127.0.0.1:8088"
              bind-address = "192.168.178.42.1:8088"
              danach den service neu starten
              systemctl restart influxdb.service
                Prezl
                Hat leider auch nichts gebracht...
                • P Prezl
                  crunchipC Offline
                  crunchipC Offline
                  @prezl dann fällt mir leider auch nichts mehr ein, musst du mal @simatec um Rat fragen
                    simatecS Online
                    simatecS Online
                    simatec
                    @crunchip
                    Wenn du Influx auf dem gleichen System wie iobroker hast, stelle in Backitup auf lokal.
                    Bind adress dann bitte auf dem Standard lassen.
                    Also 127.0.0.1.
                    Falls der Fehler immernoch erscheint, dann ermittelte den Pfad von influxd und trage diesen ebenfalls in Backitup ein.
                    • Besuche meine Github Seite
                    • HowTo Restore ioBroker
                    crunchipC P 2 Antworten Letzte Antwort
                    • simatecS simatec
                      @crunchip
                      Also 127.0.0.1.
                      crunchipC Offline
                      crunchipC Offline
                      @simatec das hat er ja schon versucht, siehe https://forum.iobroker.net/post/589028
                      dann bleibt nur noch den Pfad direkt einzutragen, da dieser leer ist
                      • simatecS simatec
                        @crunchip
                        Also 127.0.0.1.
                        Prezl
                        @simatec
                        Bind Adresse auf Standard und Sicherungsquelle auf Lokal funktioniert leider auch nicht.
                        Wie ermittle ich den richtigen Pfad der InfluxDB?
                        • P Prezl
                          @simatec
                          simatecS Online
                          simatecS Online
                          simatec
                          @prezl
                          which influxd
                          • simatecS simatec
                            @prezl
                            which influxd
                            Prezl
                            @simatec
                            Leider immer noch nicht.
                            Das ist eingestellt
                            pi@raspberrypi:~ $ which influxd
                            /usr/bin/influxd
                            Und dann kommt dieser Fehler
                            [ERROR] [influxDB] - [IGNORED] Error: Command failed: "/usr/bin/influxd" backup -portable -database Energie "/opt/iobroker/backups/influxDB_2021_02_27-21_45_49_backupiobroker"
                            backup: open /opt/iobroker/backups/influxDB_2021_02_27-21_45_49_backupiobroker/meta.00.pending: stale NFS file handle
                            • P Prezl
                              @simatec
                              Das ist eingestellt
                              /usr/bin/influxd
                              simatecS Online
                              simatecS Online
                              simatec
                              @prezl
                              Versuche das ganze bitte mal lokal zu sichern.
                              Ich habe die Vermutung, dass etwas an deinen Schreibrechten auf dem NAS nicht passt.
                              Um das Problem einzugrenzen, schaue mal, ob es als lokale Sicherung läuft
                              • simatecS simatec
                                @prezl
                                Prezl
                                @simatec
                                Ok, werde ich mal versuchen. Komisch ist dann aber, dass die iobroker Sicherungsdatei auf das NAS geschrieben wird.
                                • simatecS simatec
                                  @prezl
                                  Prezl
                                  @simatec
                                  Eine lokale Sicherung funktioniert auch nicht richtig.
                                  Ich habe das Verzeichnis /home/pi/Test erstellt und wollte darin sichern, aber auch das schaff ich nicht...
                                  Die Sicherungsdateien für iobroker und InfluxDB werden aber alle im Ordner /opt/iobroker/backups/ erstellt.
                                  Gestartet...
                                  [DEBUG] [iobroker] - host.raspberrypi 767 states saved
                                  [DEBUG] [iobroker] - host.raspberrypi 945 objects saved
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_28-15_39_30_backupiobroker.tar.gz
                                  [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_02_28-15_39_36_backupiobroker.tar.gz
                                  [DEBUG] [influxDB] - done
                                  [DEBUG] [cifs] - Copy iobroker_2021_02_28-15_39_30_backupiobroker.tar.gz...
                                  [ERROR] [cifs] - Error: EACCES: permission denied, open '/home/pi/Test/iobroker_2021_02_28-15_39_30_backupiobroker.tar.gz'
                                  [DEBUG] [cifs] - Copy influxDB_2021_02_28-15_39_36_backupiobroker.tar.gz...
                                  [ERROR] [cifs] - Error: EACCES: permission denied, open '/home/pi/Test/influxDB_2021_02_28-15_39_36_backupiobroker.tar.gz'
                                  [DEBUG] [umount] - done
                                  [EXIT] 0
                                  • P Prezl
                                    @simatec
                                    Gestartet...
                                    [EXIT] 0
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    @prezl
                                    Nein lokal meine ich ohne copy oder NAS.
                                    Einfach in das iobroker Backup Verzeichnis sichern
                                    • simatecS simatec
                                      @prezl
                                      Prezl
                                      @simatec
                                      Ohne copy oder NAS funktioniert es. Da läuft die Sicherung ohne Fehler durch.
                                      Gestartet...
                                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_28-20_47_32_backupiobroker.tar.gz
                                      [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_02_28-20_47_38_backupiobroker.tar.gz
                                      [EXIT] 0
                                      • P Prezl
                                        @simatec
                                        Gestartet...
                                        [EXIT] 0
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        @prezl
                                        Gut dann ist es eindeutig ein Rechteproblem auf deinem NAS.
                                        Es kann zwar ein Ordner angelegt werden, aber der Ordner kann nicht beschrieben werden.
                                        So deute ich den Log.
