Test Adapter ioBroker.backitup v3.1.x
@simatec sagte in Test Adapter Backitup v1.8.x:
Sind bei dem jarvis Backup irgendwie abweichende Rechte?
Glaube nicht, wo sehe ich die?
Wie kann ich manuell ein influxdb backup anstoßen? Ich möchte meine Konfiguration testen.
EDIT: wird beim normalen iobroker backup angestoßen. -
seit ein paar Tagen läuft das Backup nicht mehr.
Folgendes steht im Log:
backitup.0 close Zeit debug Meldung backitup.0 2021-02-07 11:00:31.338 error --- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix" backitup.0 2021-02-07 11:00:31.338 error | index 0 -> object with constructor 'DailyRotateFile' backitup.0 2021-02-07 11:00:31.338 error | property 'pipes' -> object with constructor 'Array' backitup.0 2021-02-07 11:00:31.338 error | property '_readableState' -> object with constructor 'ReadableState' backitup.0 2021-02-07 11:00:31.338 error --> starting at object with constructor 'DerivedLogger' backitup.0 2021-02-07 11:00:31.338 error (780) [iobroker] error on backup process: Script "umount" TypeError: Converting circular structure to JSON backitup.0 2021-02-07 11:00:31.185 error (780) [iobroker] error on backup process: Script "history" SyntaxError: Unexpected token u in JSON at position 0 Please check the config of backitup and execute "iobroker fix" backitup.0 2021-02-07 11:00:31.183 error (780) [iobroker] cannot parse config for history!! backitup.0 2021-02-07 11:00:30.880 error (780) [iobroker] error on backup process: Script "telegram" SyntaxError: Unexpected token u in JSON at position 0 Please check the config of backitup and execute "iobroker fix" backitup.0 2021-02-07 11:00:30.878 error (780) [iobroker] cannot parse config for telegram!! backitup.0 2021-02-07 11:00:20.725 error --- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix" backitup.0 2021-02-07 11:00:20.725 error | index 0 -> object with constructor 'DailyRotateFile' backitup.0 2021-02-07 11:00:20.725 error | property 'pipes' -> object with constructor 'Array' backitup.0 2021-02-07 11:00:20.725 error | property '_readableState' -> object with constructor 'ReadableState' backitup.0 2021-02-07 11:00:20.725 error --> starting at object with constructor 'DerivedLogger' backitup.0 2021-02-07 11:00:20.725 error (780) [iobroker] error on backup process: Script "cifs" TypeError: Converting circular structure to JSON backitup.0 2021-02-07 11:00:10.172 error --- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix" backitup.0 2021-02-07 11:00:10.172 error | index 0 -> object with constructor 'DailyRotateFile' backitup.0 2021-02-07 11:00:10.172 error | property 'pipes' -> object with constructor 'Array' backitup.0 2021-02-07 11:00:10.172 error | property '_readableState' -> object with constructor 'ReadableState' backitup.0 2021-02-07 11:00:10.172 error --> starting at object with constructor 'DerivedLogger' backitup.0 2021-02-07 11:00:10.172 error (780) [iobroker] error on backup process: Script "iobroker" TypeError: Converting circular structure to JSON backitup.0 2021-02-07 11:00:10.017 error --- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix" backitup.0 2021-02-07 11:00:10.017 error | index 0 -> object with constructor 'DailyRotateFile' backitup.0 2021-02-07 11:00:10.017 error | property 'pipes' -> object with constructor 'Array' backitup.0 2021-02-07 11:00:10.017 error | property '_readableState' -> object with constructor 'ReadableState' backitup.0 2021-02-07 11:00:10.017 error --> starting at object with constructor 'DerivedLogger' backitup.0 2021-02-07 11:00:10.017 error (780) [iobroker] error on backup process: Script "mount" TypeError: Converting circular structure to JSONHat jemand eine Idee, woran das liegen kann?
An den Settings habe ich nichts geändert.EDIT:
Hab grad iobroker fix drüber laufen lassen.
Das manuelle Backup hat jetzt geklappt, morgen mal das automatische Backup abwarten.Was das wohl war, wenn es dann klappt....
Ab sofort steht die Version 2.0.0 auf Github und in Kürze auch im latest (Beta) bereit.
Changelog
2.0.0 (31.01.2021)
- (simatec) BugFix detect last backup
- (simatec) WebDAV added
- (simatec) BugFix Zigbee
- (simatec) stop/start Instances on restore
- (simatec) Download Icon for Cloud Restore added
- (simatec) javscript Backup added
- (simatec) Grafana Backup added
- (simatec) Restore added for some types without restart
- (simatec) timestamp for history-json added
- (simatec) Source code rewritten
- (simatec) Restore revised
- (simatec) fixed many small bugs
- (simatec) Added warning messages
- (simatec) Fixed cloud restore
Vielen Dank für diese neue Version - funktioniert sehr gut. Geil finde ich auch das Grafana mit dabei ist
@jb_sullivan
Dankeschön... viel Spaß damit -
@simatec
Seit v2 erhalte ich keine Telegram Benachrichtigung nach erfolgreichem Backup.
Meine Einstellungen sehen so aus und habe bis einschl. v1.8 immer funktioniert:
Wenn ich das Empfänger Dropdown aufklappe sehe ich merkwürdige "firstname" Einträge. Eigentlich gibt es nur 2 Telegram Kontakte. Der 2 fehlt komplett.
Im Log sehe ich dann:
telegram.0 2021-02-24 00:30:32.996 warn (3670) 1 of 1 recipients are unknown!Ich habe extra in Telegram den Empfänger gelöscht und wieder neu angelegt.
Hilft aber nicht.
Nur wenn ich "alle Empfänger" wähle, bekomme ich eine Benachrichtigung. -
@simatec
Hilft aber nicht.
@diginix
Das liegt nicht an Backitup.
Backitup holt sich deine angelegten User aus dem Objekt "telegram.0.communicate.users"
Hier sollte der Wert wie folgt aussehen:{"12345678":"username"}@simatec Soweit klar, aber da passt mMn alles. Ich kann in Skripten alle oder einen der 2 Empfänger auswählen und die Nachrichten werden korrekt zugestellt.
{"123456789":{"firstName":"Tom","userName":"Diginix"},"987654321":{"firstName":"Martina","userName":""}}Hat sich seit Telegram 1.8 da vllt was geändert und backitup muss das anders Parsen?
@diginix sagte in Test Adapter Backitup v2.0.x:
editiere mal deinen Datenpunkt wie folgt:
{"123456789":"Tom","987654321":"Martina"}Ich denke so sollte es wieder passen
@simatec Ich kann doch die "neue" Telegram Struktur nicht manuell überschreiben.
Ich habe mal alle Empfänger gelöscht, danach ist der DP leer. Wenn ich mich per /start im Bot wieder hinzufüge, steht sofort:{"123456789":{"firstName":"Tom","userName":"Diginix"}}im DP.
Ich editiere doch da jetzt nicht immer dran rum, nur damit backitup klar kommt. Das ist doch die falsche Herangehensweise.In Telegram ist folgendes eingestellt, war aber auch schon vor Monaten so und funktionierte damals mit backitup. In Skripten nutze ich auch schon immer Vornamen. Will das also nicht nur für backitup nun alles ändern müssen.
Backitup hat in der Kontaktauswahl ja den username "Diginix" stehen, übergibt den aber vllt mittlerweile falsch an Telegram?
Anders kann ich mir "1 of 1 recipients are unknown!" im Log nicht erklären. -
Anders kann ich mir "1 of 1 recipients are unknown!" im Log nicht erklären.@diginix sagte in Test Adapter Backitup v2.0.x:
Das hat auch keiner gesagt ... Backitup braucht da keine spezielle Struktur, sondern nutzt die Daten aus Telegram.
Keine Ahnung, was du da genau machst, aber bei anderen Usern funktioniert es ja auch ohne editieren -
@diginix
Anbei mal Screenshots, wie es bei mir ausschaut und problemlos funktioniertTelegram:
Backitup:
Da ist nirgends was editiert oder sonstiges ...
@simatec Du hast ja auch den Haken "Username statt Vornamen" aktiv. Das will ich aber nicht und war bisher auch nicht nötig. Ich möchte in Skripten die Vornamen als Empfänger bei sendto Telegram nutzen.
D.h. backitup setzt zwingend diese Einstellung in Telegram voraus und ist dahin gehend nicht neutral, kommt also mit dem anderen JSON nicht klar und dieser Bug wird auch nicht gefixt? -
D.h. backitup setzt zwingend diese Einstellung in Telegram voraus und ist dahin gehend nicht neutral, kommt also mit dem anderen JSON nicht klar und dieser Bug wird auch nicht gefixt?@diginix sagte in Test Adapter Backitup v2.0.x:
@simatec Du hast ja auch den Haken "username statt Vornamen" aktiv. Das will ich aber nicht und war bisher auch nicht nötig.
D.h. backitup setzt zwingend diese Einstellung in Telegram voraus und ist dahin gehend nicht neutral?Auch das habe ich nicht geschrieben ... Das sind lediglich meine Settings ... Interpretiere doch hier bitte nicht irgendwas rein.
Backitup liest lediglich die vorhandenen Daten aus dem Objekt des Telegram Adapters aus und verwendet diese
Backitup setzt nichts voraus ... -
Backitup setzt nichts voraus ...@simatec Sorry, aber das war von mir nur eine konsequente Schlussfolgerung.
Mit Einstellung "Vornamen" geht es nicht, mit "username" schon.
Demnach funktioniert es aktuell nicht generisch. Du gehst ja bisher wenig analytisch auf meine Inhalte ein. Ein Satz wie "ich prüfe das" oder ähnliches würde mir schon helfen. Wenn du keine Zeit hast, auch ok. Aber bisher ist immer noch unklar ob es ein rein lokales Problem bei mir ist oder doch ein Bug. Irgend etwas scheint beim Auslesen des Objektes nicht zu passen wenn dort nicht nur "username:value" enthalten ist. Dein Vorschlag war, das hart zu editieren. Das ist aber bei DP von Adaptern eine eher unsaubere Art und auch nicht persistent.
Ich kann gern auch ein issue auf git öffnen aber auch da würde ich auf einen Satz mehr von dir warten.
