  4. js-controller 3.2 jetzt im Latest!
575 Beiträge 70 Kommentatoren 189.5k Aufrufe 57 Beobachtet
  • J jm1292
    @e-s ich habe genau das selbe Problem, hier der Log:
    2021-02-07 22:52:19.247  - info: host.ioBroker received SIGTERM
    2021-02-07 22:52:19.288  - info: host.ioBroker terminated
    2021-02-07 22:55:29.331  - info: host.ioBroker iobroker.js-controller version 3.2.13 js-controller starting
    2021-02-07 22:55:29.337  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-02-07 22:55:29.338  - info: host.ioBroker hostname: ioBroker, node: v10.21.0
    2021-02-07 22:55:29.339  - info: host.ioBroker ip addresses: 192.168.128.146 2001:16b8:6fc3:9200:4e1c:3039:9c1f:ec18 fe80::8232:6ee5:1972:6495
    2021-02-07 22:55:29.488  - error: host.ioBroker Cannot read system.config: null (OK when migrating or restoring)
    2021-02-07 22:55:29.638  - info: host.ioBroker connected to Objects and States
    2021-02-07 22:55:29.696  - info: host.ioBroker added notifications configuration of host
    2021-02-07 22:55:29.702  - error: host.ioBroker Cannot find view "system" for search "instance"
    2021-02-07 22:55:29.703  - error: host.ioBroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-02-07 22:55:29.722  - info: host.ioBroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-02-07 22:55:29.776  - error: host.ioBroker Cannot find view "system" for search "host"
    2021-02-07 22:55:29.785  - error: host.ioBroker Cannot find view "system" for search "state"
    2021-02-07 22:55:29.786  - error: host.ioBroker Cannot find view "system" for search "instance"
    2021-02-07 22:55:29.787  - error: host.ioBroker Could not collect system.host.ioBroker states to check for obsolete states: Error: Cannot find view "system"
    2021-02-07 22:55:29.788  - error: host.ioBroker _design/system missing - call node iobroker.js setup
    2021-02-07 22:55:30.019  - info: host.ioBroker Created UUID: 50dde655-a2b6-e79a-c5ca-eba2548d285c
    Wie mache ich hier ein Downgrade?
    e-s
    schrieb am zuletzt editiert von e-s
    #437
    @jm1292
    npm install iobroker.js-controller@2.3.11
    Danach die states.json und objects.json austauschen aus dem Backup
    • apollon77A Offline
      #438
      Wie habt Ihr denn genau installiert?? mit kommandos oben? oder wie genau habt Ihr das Update gemacht?
      • E e-s
        @jm1292
        #439
        @e-s ich hoffe 3.2.11 ...
          #440
          Ok, Problem gefunden. Die Vorbereitungen für die 3.2.14 haben irgendwie vollkommen unerwartete (es lebe die npm magie) Auswirkungen gehabt (potentiell) ...
          Es gibt (nicht nur deswegen) jetzt die 3.2.14 aka Stable RC3. Bitte installiert die!:
          • (AlCalzone) support github branch names with slashes on adapter install
          • (foxriver76) Fix wrong logger pattern that caused issues on windows
          • (Apollon77) fix potential crash when restoring backup
          • (Apollon77) restore old logfile deletion logic because rotator library do not work as expected
          • (Apollon77) Optimize File DBs to lower write i/o by 50% ( backup file is not renamed instead of rewritten)
          • (AlCalzone/Apollon77) Restructure DB code to allow easier new DB types
          • (Apollon77) Try to fix logging when seq is used
          ? sigi234S E amg_666A DiginixD 5 Antworten Letzte Antwort
          • apollon77A apollon77
            #441
            @apollon77 Moin,
            dankeschön, die 3.2.14 läuft ohne Fehler hier.
            ilovegym@gymberry:/opt/iobroker $ iobroker list adapters
            system.adapter.admin                   : admin          - v4.2.1
            system.adapter.alarm                   : alarm          - v1.9.0
            system.adapter.alexa2                  : alexa2         - v3.8.0
            system.adapter.amazon-dash             : amazon-dash    - v1.1.0
            system.adapter.backitup                : backitup       - v1.8.5
            system.adapter.ble                     : ble            - v0.12.0
            system.adapter.broadlink2              : broadlink2     - v2.1.5
            system.adapter.cloud                   : cloud          - v4.0.9
            system.adapter.countdown               : countdown      - v1.1.0
            system.adapter.device-reminder         : device-reminder - v1.0.6
            system.adapter.discovery               : discovery      - v2.5.0
            system.adapter.enigma2                 : enigma2        - v1.3.2
            system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.2
            system.adapter.feiertage               : feiertage      - v1.0.19
            system.adapter.firetv                  : firetv         - v1.0.0
            system.adapter.fritzbox                : fritzbox       - v0.3.1
            system.adapter.fritzdect               : fritzdect      - v2.1.7
            system.adapter.fully-tablet-control    : fully-tablet-control - v0.3.2-beta.0
            system.adapter.fullybrowser            : fullybrowser   - v2.0.5
            system.adapter.gartenbewaesserung      : gartenbewaesserung - v0.0.7
            system.adapter.habpanel                : habpanel       - v0.4.3
            system.adapter.ham                     : ham            - v3.0.2
            system.adapter.hp-ilo                  : hp-ilo         - v1.0.6
            system.adapter.ical                    : ical           - v1.9.1
            system.adapter.influxdb                : influxdb       - v1.9.4
            system.adapter.info                    : info           - v1.7.15
            system.adapter.iot                     : iot            - v1.8.13
            system.adapter.javascript              : javascript     - v4.10.15
            system.adapter.lgtv                    : lgtv           - v1.1.10
            system.adapter.lgtv11                  : lgtv11         - v1.0.5
            system.adapter.life360                 : life360        - v0.2.12
            system.adapter.linux-control           : linux-control  - v1.1.2
            system.adapter.meteoalarm              : meteoalarm     - v1.1.1
            system.adapter.mihome                  : mihome         - v1.3.7
            system.adapter.mihome-vacuum           : mihome-vacuum  - v2.2.4
            system.adapter.minuvis                 : minuvis        - v1.3.1
            system.adapter.mqtt                    : mqtt           - v2.3.4
            system.adapter.nuki                    : nuki           - v1.4.3
            system.adapter.octoprint               : octoprint      - v1.0.8
            system.adapter.odl                     : odl            - v1.1.4
            system.adapter.openligadb              : openligadb     - v1.2.0
            system.adapter.pi-hole                 : pi-hole        - v1.3.1
            system.adapter.proxmox                 : proxmox        - v1.2.0
            system.adapter.roadtraffic             : roadtraffic    - v0.2.0
            system.adapter.ryd                     : ryd            - v0.3.3
            system.adapter.samsung                 : samsung        - v0.2.9
            system.adapter.simple-api              : simple-api     - v2.5.3
            system.adapter.smartmeter              : smartmeter     - v3.2.0
            system.adapter.socketio                : socketio       - v3.1.4
            system.adapter.sonoff                  : sonoff         - v2.4.0
            system.adapter.synology                : synology       - v0.1.18
            system.adapter.tankerkoenig            : tankerkoenig   - v2.0.10
            system.adapter.telegram                : telegram       - v1.7.0
            system.adapter.tr-064                  : tr-064         - v4.2.4
            system.adapter.tuya                    : tuya           - v3.5.4
            system.adapter.viessmannapi            : viessmannapi   - v1.3.2
            system.adapter.vis                     : vis            - v1.3.7
            system.adapter.weatherunderground      : weatherunderground - v3.3.0
            system.adapter.web                     : web            - v3.3.0
            system.adapter.web-speedy              : web-speedy     - v0.2.0
            system.adapter.whatsapp-cmb            : whatsapp-cmb   - v0.1.6
            system.adapter.wifilight               : wifilight      - v1.1.0
            system.adapter.windows-control         : windows-control - v0.1.5
            system.adapter.wled                    : wled           - v0.5.6
            system.adapter.yeelight-2              : yeelight-2     - v1.0.3
              sigi234S Online
              sigi234S Online
              #442
              @apollon77 sagte in js-controller 3.2 jetzt im Latest!:
              Alles Ok, alle Adapter Grün, keine Fehler im Log.
              Windows System.
              Edit:
              3.2.16 Alles Ok
                e-s
                #443
                @apollon77
                3.2.14 läuft bei mir auch jetzt ohne Probleme, danke.
                Keine errors im log zu sehen
                  amg_666A Offline
                  amg_666A Offline
                  amg_666
                  #444
                  @apollon77 3*Raspi 3b als Master/Slave System auf dem knappe 50 Instanzen laufen, alles "grün", keine Fehler im Log.
                  Danke für deinen Einsatz :-)
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #445
                    @apollon77 3.2.14 läuft. Aber was ist in 3.2.15 neu? Der Hinweis auf das Changelog in dem nichts zur 3.2.15 steht? ;-)
                    Das cleanup für die zu alten Logs geschieht beim nächsten Datumswechsel?
                    ..:: So long! Tom ::..
                    • DiginixD Diginix
                      #446
                      @diginix sagte in js-controller 3.2 jetzt im Latest!:
                      Ne stündlich. Also mal ne stunde nach erstem start der 3.2.14 schauen
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #447
                        @apollon77 Stimmt, ist schon längst passiert. Läuft ja schon seit 9 Uhr.
                        Und was ist nun mit der bei GIT gelisteten 3.2.15?
                          #448
                          In wenigen Minuten bis Stunden (bei Repo bei allen angekommen ist) kommt noch die 3.2.16 aka Stable RC4 (ja und eine 3.2.15 gabs auch mal kurz zwischendurch bevor noch ein Issue mit seq Logging gemeldet wurde).
                          3.2.15/16
                          • letzter Fix für seq Logging im js-controller
                          • Änderung des Umgangs mit DB Paket-Abhängikeiten das so ein Fall wie gestern Nachmittag nicht nochmals passieren kann
                          Also jetzt sollten wir wirklich soweit durch sein ... sind wir mal gespannt was noch aufkommt :-)
                          amg_666A FeuersturmF 2 Antworten Letzte Antwort
                            3.2.15/16
                            amg_666A Offline
                            amg_666A Offline
                            amg_666
                            #449
                            @apollon77 auf einem slave habe ich die 3.2.16 installiert bekommen (alles ohne Fehler/Logeinträge o.ä.) aber auf den anderen kriege ich es nicht geladen
                            pi@iostrom:/opt/iobroker $ iobroker update
                            No connection to databases possible ..
                            Lastprobleme auf dem Server ???
                            • amg_666A amg_666
                              #450
                              @amg_666 Der Master läuft? Und ist auch 3.2?
                                amg_666A Offline
                                amg_666A Offline
                                amg_666
                                #451
                                @apollon77 ich hatte jetzt zuerst die slaves versucht upzudaten, der Master ist auf 3.2.14
                                • amg_666A amg_666
                                  #452
                                  @amg_666 an sich sollte das wennn 3.2.x ist kein problem sein ... versuch mal mastr zu updaten ob es dann geht ... strange
                                  amg_666A M 2 Antworten Letzte Antwort
                                    amg_666A Offline
                                    amg_666A Offline
                                    amg_666
                                    #453
                                    @apollon77 der MAster und 1 Slave haben jetzt die 16er, der andere zickt rum.
                                    Ist da was auf dem Raspberry zerschossen?
                                    internal/modules/cjs/loader.js:818
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                                        at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                                        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                                        at internal/main/run_main_module.js:17:47 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                    • amg_666A amg_666
                                        throw err;
                                        requireStack: []
                                      amg_666A Offline
                                      amg_666A Offline
                                      amg_666
                                      #454
                                      Kann mir hier jemand weiterhelfen? ich hab jetzt versucht js-controller neu zu installieren, das führt aber zu Fehlern:
                                      pi@iostrom:/opt/iobroker $ sudo npm install iobroker.js-controller --production
                                      > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                      > node lib/preinstallCheck.js
                                      NPM version: 6.14.10
                                      > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
                                      > node iobroker.js setup first
                                      Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.b
                                      Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                      Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                                      internal/fs/utils.js:269
                                          throw err;
                                      Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                          at Object.mkdirSync (fs.js:921:3)
                                          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:835:16)
                                          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:500:23)
                                          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2896:5)
                                          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                                          at Module._compile (internal/modules/cjs/loader.js:999:30)
                                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                          at Module.load (internal/modules/cjs/loader.js:863:32)
                                          at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
                                        errno: -13,
                                        syscall: 'mkdir',
                                        code: 'EACCES',
                                        path: '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 1
                                      npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
                                      npm ERR!     /root/.npm/_logs/2021-02-08T16_43_21_660Z-debug.log
                                      K Thomas BraunT 2 Antworten Letzte Antwort
                                      • amg_666A amg_666
                                            throw err;
                                          errno: -13,
                                          syscall: 'mkdir',
                                          code: 'EACCES',
                                        npm ERR! errno 1
                                        npm ERR!
                                        Kueppert
                                        #455
                                        @amg_666 sagte in js-controller 3.2 jetzt im Latest!:
                                        permission denied
                                        na, da lass doch mal den Fixer laufen ;)
                                        • amg_666A amg_666
                                              throw err;
                                            errno: -13,
                                            syscall: 'mkdir',
                                            code: 'EACCES',
                                          npm ERR! errno 1
                                          npm ERR!
                                          #456
                                          sudo npm install
                                          Niemals sudo (ohne weitere Optionen) in Verbindung mit npm verwenden.
                                          Dann knallt dir (unter anderem) alles in ~ von root rein:
                                          /root/.npm/
                                          Und da kann iobroker nix mit anfangen.
                                          Versuch mit dem
                                          iobroker fix
                                          das wieder glatt zu ziehen.
