  4. js-controller 3.2 jetzt im Latest!
575 Beiträge 70 Kommentatoren 183.8k Aufrufe 57 Beobachtet
  • apollon77A apollon77
    @didi-0 und node -v gibt wirklich nodejs 12? :-)
    auch nodejs -v ?
    e-s
    #433
    @apollon77
    Habe auch mein System geschrottet beim Update von glaube ich 3.2.9 auf 3.2.13
    2021-02-07 21:41:03.158  - info: host.ubuntuserver received SIGTERM
    2021-02-07 21:41:03.181  - info: host.ubuntuserver terminated
    2021-02-07 21:41:05.048  - info: host.ubuntuserver iobroker.js-controller version 3.2.13 js-controller starting
    2021-02-07 21:41:05.053  - info: host.ubuntuserver Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-02-07 21:41:05.053  - info: host.ubuntuserver hostname: ubuntuserver, node: v14.15.4
    2021-02-07 21:41:05.054  - info: host.ubuntuserver ip addresses: 192.168.2.222 2a02:f08:1006:c600:461e:a1ff:fe3b:7841 fe80::461e:a1ff:fe3b:7841
    2021-02-07 21:41:05.205  - error: host.ubuntuserver Cannot read system.config: null (OK when migrating or restoring)
    2021-02-07 21:41:05.365  - info: host.ubuntuserver connected to Objects and States
    2021-02-07 21:41:05.417  - info: host.ubuntuserver added notifications configuration of host
    2021-02-07 21:41:05.423  - error: host.ubuntuserver Cannot find view "system" for search "instance"
    2021-02-07 21:41:05.424  - error: host.ubuntuserver Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-02-07 21:41:05.441  - info: host.ubuntuserver Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-02-07 21:41:05.492  - error: host.ubuntuserver Cannot find view "system" for search "host"
    2021-02-07 21:41:05.502  - error: host.ubuntuserver Cannot find view "system" for search "state"
    2021-02-07 21:41:05.503  - error: host.ubuntuserver Cannot find view "system" for search "instance"
    2021-02-07 21:41:05.504  - error: host.ubuntuserver Could not collect system.host.ubuntuserver states to check for obsolete states: Error: Cannot find view "system"
    2021-02-07 21:41:05.506  - error: host.ubuntuserver _design/system missing - call node iobroker.js setup
    2021-02-07 21:41:05.773  - info: host.ubuntuserver Created UUID: a4cd0ac8-eee5-7aba-21d0-313dcd691925
    mehr kommt nicht mehr im log
    Update über iobroker upgrade self durchgeführt, da gab es keinen Fehler
    iobroker fix brachte nichts
    iobroker setup bringt auch nur mir unklare Antworten:
    santa@ubuntuserver:/opt/iobroker$ iobroker setup
    object 0_userdata.0.example_state created
    object 0_userdata.0 created
    object alias.0 created
    object system.certificates created
    object system.repositories created
    object system.config created
    object enum.functions created
    object enum.rooms created
    object system.group.user created
    object system.group.administrator created
    object _design/system created
    Renamed repository "default to "stable"
    Renamed repository "latest to "beta"
    • E e-s
      @apollon77
      #434
      @e-s In dem Fall hat es - warum und wie auch immer - irgendwie dein bjects.json kaputt gemacht. Sollte mit dem Update nichts zu tun haben. AM besten in /opt/iobroker/iobroker-data schauen bo das objects.bak noch hilt, sonst ggf aus dem verzeichnis backup-objects schauen was zuletzt gesichert wurde und das entpacken Und hinkopieren. Vorher iobroker stoppen!
      E 1 Antwort Letzte Antwort
        e-s
        schrieb am zuletzt editiert von e-s
        #435
        @apollon77
        die json und die backup sind extrem klein, im backup verzeichnis habe ich die entpackt und die ist einiges größer.
        Fehlermeldung bleibt aber gleich und die json hat dann wieder nur 11000 bytes, statt 8MB
        Backup von gestern und heute getestet
        edit:
        mit downgrade auf 3.2.11 läuft iobroker wieder
        Die states.json war auch kaputt
        • E e-s
          @apollon77
          edit:
          jm1292
          #436
          @e-s ich habe genau das selbe Problem, hier der Log:
          2021-02-07 22:52:19.247  - info: host.ioBroker received SIGTERM
          2021-02-07 22:52:19.288  - info: host.ioBroker terminated
          2021-02-07 22:55:29.331  - info: host.ioBroker iobroker.js-controller version 3.2.13 js-controller starting
          2021-02-07 22:55:29.337  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
          2021-02-07 22:55:29.338  - info: host.ioBroker hostname: ioBroker, node: v10.21.0
          2021-02-07 22:55:29.339  - info: host.ioBroker ip addresses: 192.168.128.146 2001:16b8:6fc3:9200:4e1c:3039:9c1f:ec18 fe80::8232:6ee5:1972:6495
          2021-02-07 22:55:29.488  - error: host.ioBroker Cannot read system.config: null (OK when migrating or restoring)
          2021-02-07 22:55:29.638  - info: host.ioBroker connected to Objects and States
          2021-02-07 22:55:29.696  - info: host.ioBroker added notifications configuration of host
          2021-02-07 22:55:29.702  - error: host.ioBroker Cannot find view "system" for search "instance"
          2021-02-07 22:55:29.703  - error: host.ioBroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
          2021-02-07 22:55:29.722  - info: host.ioBroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2021-02-07 22:55:29.776  - error: host.ioBroker Cannot find view "system" for search "host"
          2021-02-07 22:55:29.785  - error: host.ioBroker Cannot find view "system" for search "state"
          2021-02-07 22:55:29.786  - error: host.ioBroker Cannot find view "system" for search "instance"
          2021-02-07 22:55:29.787  - error: host.ioBroker Could not collect system.host.ioBroker states to check for obsolete states: Error: Cannot find view "system"
          2021-02-07 22:55:29.788  - error: host.ioBroker _design/system missing - call node iobroker.js setup
          2021-02-07 22:55:30.019  - info: host.ioBroker Created UUID: 50dde655-a2b6-e79a-c5ca-eba2548d285c
          Wie mache ich hier ein Downgrade?
          • J jm1292
            e-s
            #437
            @jm1292
            npm install iobroker.js-controller@2.3.11
            Danach die states.json und objects.json austauschen aus dem Backup
            • apollon77A Offline
              #438
              Wie habt Ihr denn genau installiert?? mit kommandos oben? oder wie genau habt Ihr das Update gemacht?
              • E e-s
                @jm1292
                #439
                @e-s ich hoffe 3.2.11 ...
                  #440
                  Ok, Problem gefunden. Die Vorbereitungen für die 3.2.14 haben irgendwie vollkommen unerwartete (es lebe die npm magie) Auswirkungen gehabt (potentiell) ...
                  Es gibt (nicht nur deswegen) jetzt die 3.2.14 aka Stable RC3. Bitte installiert die!:
                  • (AlCalzone) support github branch names with slashes on adapter install
                  • (foxriver76) Fix wrong logger pattern that caused issues on windows
                  • (Apollon77) fix potential crash when restoring backup
                  • (Apollon77) restore old logfile deletion logic because rotator library do not work as expected
                  • (Apollon77) Optimize File DBs to lower write i/o by 50% ( backup file is not renamed instead of rewritten)
                  • (AlCalzone/Apollon77) Restructure DB code to allow easier new DB types
                  • (Apollon77) Try to fix logging when seq is used
                  ? sigi234S E amg_666A DiginixD 5 Antworten Letzte Antwort
                    #441
                    @apollon77 Moin,
                    dankeschön, die 3.2.14 läuft ohne Fehler hier.
                    ilovegym@gymberry:/opt/iobroker $ iobroker list adapters
                    system.adapter.admin                   : admin          - v4.2.1
                    system.adapter.alarm                   : alarm          - v1.9.0
                    system.adapter.alexa2                  : alexa2         - v3.8.0
                    system.adapter.amazon-dash             : amazon-dash    - v1.1.0
                    system.adapter.backitup                : backitup       - v1.8.5
                    system.adapter.ble                     : ble            - v0.12.0
                    system.adapter.broadlink2              : broadlink2     - v2.1.5
                    system.adapter.cloud                   : cloud          - v4.0.9
                    system.adapter.countdown               : countdown      - v1.1.0
                    system.adapter.device-reminder         : device-reminder - v1.0.6
                    system.adapter.discovery               : discovery      - v2.5.0
                    system.adapter.enigma2                 : enigma2        - v1.3.2
                    system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.2
                    system.adapter.feiertage               : feiertage      - v1.0.19
                    system.adapter.firetv                  : firetv         - v1.0.0
                    system.adapter.fritzbox                : fritzbox       - v0.3.1
                    system.adapter.fritzdect               : fritzdect      - v2.1.7
                    system.adapter.fully-tablet-control    : fully-tablet-control - v0.3.2-beta.0
                    system.adapter.fullybrowser            : fullybrowser   - v2.0.5
                    system.adapter.gartenbewaesserung      : gartenbewaesserung - v0.0.7
                    system.adapter.habpanel                : habpanel       - v0.4.3
                    system.adapter.ham                     : ham            - v3.0.2
                    system.adapter.hp-ilo                  : hp-ilo         - v1.0.6
                    system.adapter.ical                    : ical           - v1.9.1
                    system.adapter.influxdb                : influxdb       - v1.9.4
                    system.adapter.info                    : info           - v1.7.15
                    system.adapter.iot                     : iot            - v1.8.13
                    system.adapter.javascript              : javascript     - v4.10.15
                    system.adapter.lgtv                    : lgtv           - v1.1.10
                    system.adapter.lgtv11                  : lgtv11         - v1.0.5
                    system.adapter.life360                 : life360        - v0.2.12
                    system.adapter.linux-control           : linux-control  - v1.1.2
                    system.adapter.meteoalarm              : meteoalarm     - v1.1.1
                    system.adapter.mihome                  : mihome         - v1.3.7
                    system.adapter.mihome-vacuum           : mihome-vacuum  - v2.2.4
                    system.adapter.minuvis                 : minuvis        - v1.3.1
                    system.adapter.mqtt                    : mqtt           - v2.3.4
                    system.adapter.nuki                    : nuki           - v1.4.3
                    system.adapter.octoprint               : octoprint      - v1.0.8
                    system.adapter.odl                     : odl            - v1.1.4
                    system.adapter.openligadb              : openligadb     - v1.2.0
                    system.adapter.pi-hole                 : pi-hole        - v1.3.1
                    system.adapter.proxmox                 : proxmox        - v1.2.0
                    system.adapter.roadtraffic             : roadtraffic    - v0.2.0
                    system.adapter.ryd                     : ryd            - v0.3.3
                    system.adapter.samsung                 : samsung        - v0.2.9
                    system.adapter.simple-api              : simple-api     - v2.5.3
                    system.adapter.smartmeter              : smartmeter     - v3.2.0
                    system.adapter.socketio                : socketio       - v3.1.4
                    system.adapter.sonoff                  : sonoff         - v2.4.0
                    system.adapter.synology                : synology       - v0.1.18
                    system.adapter.tankerkoenig            : tankerkoenig   - v2.0.10
                    system.adapter.telegram                : telegram       - v1.7.0
                    system.adapter.tr-064                  : tr-064         - v4.2.4
                    system.adapter.tuya                    : tuya           - v3.5.4
                    system.adapter.viessmannapi            : viessmannapi   - v1.3.2
                    system.adapter.vis                     : vis            - v1.3.7
                    system.adapter.weatherunderground      : weatherunderground - v3.3.0
                    system.adapter.web                     : web            - v3.3.0
                    system.adapter.web-speedy              : web-speedy     - v0.2.0
                    system.adapter.whatsapp-cmb            : whatsapp-cmb   - v0.1.6
                    system.adapter.wifilight               : wifilight      - v1.1.0
                    system.adapter.windows-control         : windows-control - v0.1.5
                    system.adapter.wled                    : wled           - v0.5.6
                    system.adapter.yeelight-2              : yeelight-2     - v1.0.3
                      sigi234S Online
                      sigi234S Online
                      #442
                      @apollon77 sagte in js-controller 3.2 jetzt im Latest!:
                      Alles Ok, alle Adapter Grün, keine Fehler im Log.
                      Windows System.
                      Edit:
                      3.2.16 Alles Ok
                        e-s
                        #443
                        @apollon77
                        3.2.14 läuft bei mir auch jetzt ohne Probleme, danke.
                        Keine errors im log zu sehen
                          amg_666A Offline
                          amg_666A Offline
                          amg_666
                          #444
                          @apollon77 3*Raspi 3b als Master/Slave System auf dem knappe 50 Instanzen laufen, alles "grün", keine Fehler im Log.
                          Danke für deinen Einsatz :-)
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            #445
                            @apollon77 3.2.14 läuft. Aber was ist in 3.2.15 neu? Der Hinweis auf das Changelog in dem nichts zur 3.2.15 steht? ;-)
                            Das cleanup für die zu alten Logs geschieht beim nächsten Datumswechsel?
                            ..:: So long! Tom ::..
                            • DiginixD Diginix
                              #446
                              @diginix sagte in js-controller 3.2 jetzt im Latest!:
                              Ne stündlich. Also mal ne stunde nach erstem start der 3.2.14 schauen
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #447
                                @apollon77 Stimmt, ist schon längst passiert. Läuft ja schon seit 9 Uhr.
                                Und was ist nun mit der bei GIT gelisteten 3.2.15?
                                  #448
                                  In wenigen Minuten bis Stunden (bei Repo bei allen angekommen ist) kommt noch die 3.2.16 aka Stable RC4 (ja und eine 3.2.15 gabs auch mal kurz zwischendurch bevor noch ein Issue mit seq Logging gemeldet wurde).
                                  3.2.15/16
                                  • letzter Fix für seq Logging im js-controller
                                  • Änderung des Umgangs mit DB Paket-Abhängikeiten das so ein Fall wie gestern Nachmittag nicht nochmals passieren kann
                                  Also jetzt sollten wir wirklich soweit durch sein ... sind wir mal gespannt was noch aufkommt :-)
                                  amg_666A FeuersturmF 2 Antworten Letzte Antwort
                                    3.2.15/16
                                    amg_666A Offline
                                    amg_666A Offline
                                    amg_666
                                    #449
                                    @apollon77 auf einem slave habe ich die 3.2.16 installiert bekommen (alles ohne Fehler/Logeinträge o.ä.) aber auf den anderen kriege ich es nicht geladen
                                    pi@iostrom:/opt/iobroker $ iobroker update
                                    No connection to databases possible ..
                                    Lastprobleme auf dem Server ???
                                    • amg_666A amg_666
                                      #450
                                      @amg_666 Der Master läuft? Und ist auch 3.2?
                                        amg_666A Offline
                                        amg_666A Offline
                                        amg_666
                                        #451
                                        @apollon77 ich hatte jetzt zuerst die slaves versucht upzudaten, der Master ist auf 3.2.14
                                        • amg_666A amg_666
                                          #452
                                          @amg_666 an sich sollte das wennn 3.2.x ist kein problem sein ... versuch mal mastr zu updaten ob es dann geht ... strange
                                          amg_666A M 2 Antworten Letzte Antwort
