  4. Test Adapter tvprogram
adaptertvprogramviswidget
929 Beiträge 51 Kommentatoren 345.5k Aufrufe 51 Beobachtet
  • M MCU
    @oliverio Bei der Deinstallation aufgefallen bzw log:
    $ ./iobroker del tvprogram
    Delete adapter "tvprogram"
    host.raspberrypi Counted 1 meta of tvprogram
    host.raspberrypi Counted 1 adapter for tvprogram
    host.raspberrypi Counted 2 states (system.adapter.tvprogram.*) from states
    host.raspberrypi file vis/widgets/tvprogram deleted
    host.raspberrypi file vis/widgets/tvprogram.html deleted
    host.raspberrypi file tvprogram.admin deleted
    host.raspberrypi object tvprogram.admin deleted
    host.raspberrypi Deleting 2 object(s).
    host.raspberrypi Deleting 2 state(s).
    npm uninstall iobroker.tvprogram --error --prefix "/opt/iobroker" (System call)
    npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself.
    npm WARN typedoc-plugin-markdown@3.1.1 requires a peer of typedoc@>=0.19.0 < 0.20.0 but none is installed. You must install peer dependencies yourself.
    npm WARN typedoc-plugin-no-inherit@1.2.0 requires a peer of typedoc@>=0.16.0 but none is installed. You must install peer dependencies yourself.
    npm WARN typedoc-plugin-sourcefile-url@1.0.6 requires a peer of typedoc@>=0.16.0 but none is installed. You must install peer dependencies yourself.
    npm WARN typedoc-plugin-markdown@3.1.0 requires a peer of typedoc@>=0.19.0 < 0.20.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.2.1 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.2.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    Adapter "system.adapter.vis.0" restarted.
    process exited with code 0
    Neuinstallation:
    Die 1 schlecht zu erkennen
    '+' gedrückt und Speichern und schliessen
    und Läuft:
    Kann man das auch so machen das man dem tv1 einen Namen geben kann?
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    #505
    @mcu said in Test Adapter tvprogram:
    Neuinstallation:
    und Läuft:
    Bei der Deinstallation ist mir nix spezielles aufgefallen. Das ist alles gut.
    ich wußte, das die Frage nach einem eigenen Namen kommt.
    Also dem Datenpunk selbst nicht, da ich einen technischen Namen zum durchzählen benötige
    Ich könnte einen weiteren beschreibbaren Datenpunkt hinzufügen, wo jeder dann den Namen eingeben kann.
    Meine Adapter und Widgets
    Links im Profil
    • OliverIOO OliverIO
      Neuinstallation:
      und Läuft:
      MCU
      #506
      @oliverio Vielleicht dazwischen
      Beschreibung
      Wo sehe jetzt die Favoriten mit der Zeit?
      • M MCU
        Beschreibung
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #507
        Beschreibung
        Was meinst du mit dazwischen?
        Für die Favoriten hast du schon den richtigen Datenpunkt "favorites" markiert.
        Beachte aber, das der Favoritenmechanismus einen relativ einfachen Mechanismus zum Abgleich verwendet. Der Sendungstitel muss exakt dem gemerkten Titek für die Favoriten entsprechen,.
        Links im Profil
          Beschreibung
          MCU
          #508
          @oliverio Ich dachte die Beschreibung vom tv1 direkt dahinter eingeben zu können oder den DP "tv1" beschreibbar.
          Besser wäre, wenn man "+" klickt, das man dann auch sofort den Namen eingeben könnte, oder nicht?
          Mit den Favoriten dachte ich, gibt es eine Liste in der man erkennen kann, welche der Favoriten Sendungen, wann laufen?
          Oder muss ich die sendto-Befehle verwenden?
          Habe auf record geklickt aber ich sehe keinen Unterschied, müsste es nicht rot werden?
          {"startTime":"2021-02-06T03:20:00+01:00","endTime":"2021-02-06T04:45:00+01:00","title":"Pulp Fiction","channel":39,"channelid":"rtl2"}
          • M MCU
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #509
            Mit den Favoriten dachte gibt es eine Liste in der man erkennen kann welche der Favoriten Sendungen, wann laufen?
            Oder muss die sendto-Befehle verwenden?
            Für den Namen habe ich bereits einen neuen beschreibbaren Datenpunkt Name hinzugefügt.
            Ich wollte die Admin-Oberfläche nicht besonders aufwändig machen. Wenn ich da Eingabefelder zulasse, benötige ich auch wieder einen Editier-Dialog.
            Für einen Namen, der eigentlich nur für den admin (also dir) sichtbar ist, reicht ein datenpunkt mit editierbaren namen aus. da kann mann dann noch Wohnzimmer oder Kinderzimmer mit eintragen
            Hast du den schon das widget Favorites ausprobiert? Es gibt doch schon 3 verschiedene widgets widgets
            Bei record verändert sich nichts, Außer das es die Daten in den Datenpunkt schreibt
            Links im Profil
            M sigi234S 3 Antworten Letzte Antwort
              MCU
              #510
              @oliverio Nein, das Widget Favorites habe ich noch nicht probiert. Mache ich noch.
                MCU
                #511
                @oliverio sagte in Test Adapter tvprogram:
                Man hat sich eigentlich daran gewöhnt, wenn man aufnimmt, das dann ein roter Punkt erscheint?
                • M MCU
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #512
                  ja, aber wann soll er wieder verschwinden? ich wollte eigentlich vermeiden, dass auch dieser Adapter minütlich Action auf dem Server verursacht um zu prüfen, ob der Eintrag aus einer Liste wieder verschwinden soll.
                  Das passiert hier alles auf dem Client (also im Browser)
                  Links im Profil
                    MCU
                    #513
                    @oliverio Das kann man ja dem User/admin überlassen, er schmeisst den Eintrag aus der "record"-Liste.
                    sendTo("tvprogram.0","getServerBroadcastsNow",(data)=>console.log(data));
                    Damit kommen keine Daten?
                    • M MCU
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #514
                      JSON korrekt bearbeiten? Das schaffen nicht so viele.
                      ein Zeichen falsch, dann gibt es keine roten Record-Knöpfe mehr, da die Liste kaputt ist
                      Links im Profil
                        MCU
                        #515
                        @oliverio Da kann man das javascript ja hier veröffentlichen.
                        Aber sonst hat man das Problem als User, das man nachschaut in der Programm Übersicht und überlegt habe ich das programmiert?
                        Oder man baut sich eine Anzeige in der VIS und lässt sich parallel die programmierten Programme anzeigen? Geht auch.
                        Wäre es vielleicht auch so möglich, dass man die programmierten Sendungen in der Übersicht rot markiert? Anstatt gelb halt rot?
                        OliverIOO 2 Antworten Letzte Antwort
                        • M MCU
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #516
                          @mcu sagte in Test Adapter tvprogram:
                          Ein javascript, das so eine Liste zusammen baut hatte ich ja weiter oben schon mal gepostet.
                          unter zu hilfe eines anderen adapters von mir, kann man da relativ einfach ein widget selber bauen
                          Links im Profil
                          • M MCU
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #517
                            aber wann soll er wieder verschwinden, da haben wir wieder die Minütliche Überwachung.
                            Links im Profil
                              MCU
                              #518
                              @oliverio Man kann ja alle vielleicht prüfen ist der Marker in einer roten Zone? Und wenn er da raus ist checkt man die Aufnahmen und schmeißt sie raus?
                              Wie schmeißt du denn jetzt die Favoriten raus? Mit der gelben Anzeige? Die bleiben doch den ganzen Tag drin?
                              Und die Aufnahmen können ja auch den ganzen Tag drin bleiben, dann sieht man auch später noch ,das man es aufgenommen hat oder sollte?
                              Und das aufnehmende Programm (extern) muss ja auch ne Rückmeldung geben: Ich habe die Sendung aufgenommen? Je nachdem wie es in ioBroker integriert ist.
                              Oder der User kann die Aufnahmen bestätigen und damit den Eintrag entfernen.
                              Bei der Auswahl der Sender ist mir aufgefallen, dass wenn man ca. den 25 oder mehr .Sender auswählt, wird plötzlich die Reihenfolge wieder durcheinander gebracht und man muss es neu sortieren?
                              Damit kommen auch keine Daten:
                              sendTo("tvprogram.0","getFavoritesData",["heute"],(data)=>console.log(data));
                              Genau die Favoritenliste TV Program Favorites hätte ich gerne als JSON:
                              z.B.: mit dem Aufbau:
                              [{"weekday":"Sa","date":"06.02.2021","starttime":"04:00","endtime";"04:50","channel":"RTL","favorite":"Der Blaulicht Report"},{...}]
                              z.B. unter tvprogram.0.tv1.favoritesSchedule oder tvprogram.0.tv1.favoritesTimes
                              Was wird denn jetzt im DP tvprogram.0.tv1.config eingetragen, weil da jetzt nur {} steht?
                              Welche Funktion hat der DP tvprogram.0.tv1.show?
                              Ich mach dann mal für heute PAUSE.
                              Vielen Dank. Klasse Arbeit. Mach weiter so. Echt Prima.
                                sigi234S Online
                                sigi234S Online
                                #519
                                Ist dafür ein Widget geplant?
                                • sigi234S sigi234
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #520
                                  @sigi234 sagte in Test Adapter tvprogram:
                                  Was für ein Widget?
                                  Die Daten werden in einen datenpunkt reingeschrieben, so das ein Script diese Daten in einen anderen Adapter schreiben kann um eine Videoaufzeichnung zu programmieren.
                                  Es wurde mal noch eine Liste dieser Aufnahmen gewünscht. Allerdings sehe ich so eine Sammlung eher im Adapter für den Videorecorder.
                                  Als Ersatz habe ich weiter oben ein Script gemacht, welches den datenpunkt record überwacht und alle Daten in einen anderen datenpunkt in eine Liste schreibt
                                  https://forum.iobroker.net/post/568472
                                  Links im Profil
                                    Was für ein Widget?
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    #521
                                    Das oben angegebene Script zur Recordlist enthielt wohl noch einen Fehler, der hier korrigiert wurde:
                                    Hier habe ich mal ein Skript gebastelt, das die Liste aller aktiven Aufzeichnungen führt
                                    und die Einträge nach beginn der Startzeit automatisch entfernt.
                                    Zu füllen sind nur die Bezeichnungen der beiden Datenpunkte in den ersten beiden Zeilen.
                                    • recorderListDP ist der Datenpunkt in dem die Liste gesammelt werden soll. Dieser Datenpunkt muss selbst, mit dem Typ Zeichenkette angelegt werden
                                    • recorderDP ist der Datenunkt an den der tvprogramm adpter den Aufzeichnungsauftrag ergibt. Diese Bezeichnung kann meist so einfach übernommern werden.
                                    Der erste Teil (die on-Klammer) reagiert auf den recorder Datenpunkt und nimmt die neuen Daten in die Liste auf, wobei Duplikate vermieden werden.
                                    Der zweite Teil (setIntervall) prüft einmal pro Minute, ob eine der Sendungen bereits begonnen haben und entfernt diese wieder aus der Liste.
                                    var recorderListDP = "0_userdata.0.RecorderList";
                                    var recorderDP ="tvprogram.0.tv1.record";
                                    on(recorderDP, function (obj) {
                                        var recorderList;
                                        var index;
                                        var recObj = JSON.parse(obj.newState.val);
                                        var s = getState(recorderListDP).val;
                                        s = (s=="") ? s="[]":s;
                                        recorderList = JSON.parse(s) || [];
                                        index = recorderList.findIndex(function(el) {
                                            return JSON.stringify(el)==JSON.stringify(recObj);
                                        if (index>-1) {
                                            recorderList.splice(index,1);
                                        recorderList.push(recObj);
                                        console.log("add "+ JSON.stringify(recObj));
                                        setState(recorderListDP,JSON.stringify(recorderList));
                                    var timer = setInterval(function() {
                                        var recorderList;
                                        recorderList=recorderList.filter( (el) => new Date(el.endTime)>new Date());
                                    },1000*60);
                                    Darüber hinaus kann diese Liste mit Hilfe des widgets JSON template aus dem adapter rssfeed
                                    als eigenes Widget visualisiert werden
                                    <% data.sort((a,b)=>new Date(a.startTime) - new Date(b.startTime)) %>
                                    <table>
                                        <th>Start</th>
                                        <th>Ende</th>
                                        <th>Titel</th>
                                    <% for (var i=0;i<data.length;i++) {%>
                                    <tr>
                                    <td><%- new Date(data[i].startTime).toLocaleDateString() %> <%- new Date(data[i].startTime).toLocaleTimeString() %></td>
                                    <td><%- new Date(data[i].endTime).toLocaleTimeString() %></td>
                                    <td><%- data[i].title %></td>
                                    </tr>
                                    </table>
                                    Links im Profil
                                    M sigi234S 2 Antworten Letzte Antwort
                                          var recorderList;
                                          var index;
                                          if (index>-1) {
                                          var recorderList;
                                      },1000*60);
                                      <table>
                                          <th>Start</th>
                                          <th>Ende</th>
                                          <th>Titel</th>
                                      <tr>
                                      </tr>
                                      </table>
                                      MCU
                                      #522
                                      @oliverio Kannst du mir kurz einen Hinweis geben, was ich ändern muss damit ich die Daten für "JETZT" bekomme?
                                      //Funktioniert so nicht
                                      • M MCU
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #523
                                        Skript für die Abfrage, ob gerade eine Favoritensendung statt findet.
                                        die Prüfung rfolgt einmal die Minute (60*1000):
                                        // Favorites datapoint of your tv
                                        var favoritesDP = "tvprogram.0.tv1.favorites";
                                        // channelfilter datapoint of your tv
                                        var channelfilterDP = "tvprogram.0.tv1.channelfilter";
                                        // datapoint where the result should be saved
                                        var favoritesBool ="0_userdata.0.tvprogram.favoriteNow";
                                            var favorites = JSON.parse(getState(favoritesDP).val);
                                            var channelfilter = JSON.parse(getState(channelfilterDP).val);
                                            sendTo("tvprogram.0","getServerBroadcastNow",channelfilter,(data)=>{
                                                    setState(favoritesBool,data.some((el) => favorites.includes(el.events[0].title)))
                                        },1000*60);
                                        Links im Profil
                                        • M MCU
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #524
                                          ja, hatte einen fehler in dem was ich geschrieben habe.
                                          habe gerade ein skript gepostet, mit dem du abfragen kannst, ob gerade eine Favoritensendung läuft.
                                          Für den Befehl getServerBroadcastNow muss man noch den channelfilter mit angeben. also die Liste der Sender, von denen die aktuellen Sendungen zurück gegeben werden müssen.
                                          Den konkreten Abruf siehst du im Skript
                                          Links im Profil
