  4. [Gelöst] deConz Adapter | Datenpunkte nicht aktuell
deconz
34 Beiträge 6 Kommentatoren 3.9k Aufrufe 6 Beobachtet
    @crazy32
    systemctl status deconz
    Bzw.
    systemctl status deconz-gui
    sagt?
    Crazy32C Offline
    Crazy32C Offline
    Crazy32
    @thomas-braun sagte in deConz Adapter / Phoscon App | Datenpunkte nicht aktuell:
    pi@raspberrypi:~ $ systemctl status deconz
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
       Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: e
       Active: active (running) since Tue 2021-02-02 18:23:33 CET; 15h ago
     Main PID: 397 (deCONZ)
        Tasks: 5 (limit: 4915)
       CGroup: /system.slice/deconz.service
               └─397 /usr/bin/deCONZ -platform minimal --http-port=80
    Feb 02 18:23:33 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST A
    Feb 02 18:23:34 raspberrypi deCONZ[397]: QStandardPaths: XDG_RUNTIME_DIR not set
    Feb 02 18:23:35 raspberrypi deCONZ[397]: libpng warning: iCCP: known incorrect s
    Feb 02 18:23:35 raspberrypi deCONZ[397]: This plugin does not support propagateS
    lines 1-13/13 (END)
       Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
    Feb 02 18:23:33 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
    Feb 02 18:23:34 raspberrypi deCONZ[397]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
    Feb 02 18:23:35 raspberrypi deCONZ[397]: libpng warning: iCCP: known incorrect sRGB profile
    Feb 02 18:23:35 raspberrypi deCONZ[397]: This plugin does not support propagateSizeHints()
    lines 1-13/13 (END)...skipping...
    lines 1-13/13 (END)
    lines 1-13/13 (END)
    pi@raspberrypi:~ $ systemctl status deconz-gui
    ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
       Loaded: loaded (/lib/systemd/system/deconz-gui.service; enabled; vendor prese
       Active: active (running) since Tue 2021-02-02 18:24:21 CET; 15h ago
     Main PID: 2208 (deCONZ)
        Tasks: 6 (limit: 4915)
       CGroup: /system.slice/deconz-gui.service
               └─2208 /usr/bin/deCONZ --http-port=80
    Feb 02 18:24:21 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- GUI/RE
    Feb 02 18:24:22 raspberrypi deCONZ[2208]: QStandardPaths: XDG_RUNTIME_DIR not se
    Feb 02 18:24:25 raspberrypi deCONZ[2208]: libpng warning: iCCP: known incorrect
    Feb 03 07:30:04 raspberrypi deCONZ[2208]: QStandardPaths: XDG_RUNTIME_DIR not se
    Feb 03 07:38:34 raspberrypi deCONZ[2208]: QStandardPaths: XDG_RUNTIME_DIR not se
    lines 1-14/14 (END)
    • Crazy32C Crazy32
      lines 1-13/13 (END)
      lines 1-13/13 (END)
      lines 1-13/13 (END)
      lines 1-14/14 (END)
      @crazy32 Ich meine mich erinnern zu können das nicht beide Services gleichzeitig geladen sein sollten.
      Ich betreibe den Pi aber natürlich ohnehin ohne GUI, was ich auch hier dringend empfehlen würde.
      Crazy32C 1 Antwort Letzte Antwort
        Crazy32C Offline
        Crazy32C Offline
        Crazy32
        @thomas-braun Sorry, aber ohne GUI bin ich aufgeschmissen. Das heißt, ich müsste den Service ohne GUI stoppen? Wie mache ich das?
        • Crazy32C Crazy32
          @crazy32
          Wozu eine GUI auf einem Slave?
          sudo systemctl stop deconz
          sudo systemctl disable deconz
          bzw. sinnvoller wäre:
          sudo systemctl stop deconz-gui
          sudo systemctl disable deconz-gui
            @crazy32
            Crazy32C Offline
            Crazy32C Offline
            Crazy32
            @thomas-braun So kann ich wenigstens in dem deconz Programm sehen, ob ein Sensor mit dem Stick verbunden ist oder nicht. Macht für mich die Fehlersuche einfacher. Ich würde da auch lieber deconz und nicht deconz-gui stoppen.
            Wie muss ich das verstehen. Laufen jetzt deconz und deconz-gui parallel und könnten sich gegenseitig stören? Ich hätte gedacht, dass die gui zusätzlich zur deconz software ist.
            • Crazy32C Crazy32
              @crazy32 sagte in deConz Adapter / Phoscon App | Datenpunkte nicht aktuell:
              Ich meine das sei so. Entweder der eine oder der andere Service läuft, nicht beide. Aber kannst du ja mit den systemctl Kommandos ausprobieren.
              Normalerweise ist das bei solchen Diensten auch so. Die GUI ist ein 'Aufsatz' auf den Service. Dresden Elektronik macht das aber anders.
                Crazy32C Offline
                Crazy32C Offline
                Crazy32
                schrieb am zuletzt editiert von Crazy32
                @thomas-braun Ok. Wie teste ich das am Besten? IoBroker neustarten und abwarten?
                Und wie ist das nach einem Neustart des Raspbi? Da starten bestimmt beide services und ich muss einen wieder stoppen, oder?
                EDIT: Jetzt bekomme ich Fehlermeldungen:
                Thomas BraunT Jey CeeJ 2 Antworten Letzte Antwort
                • Crazy32C Crazy32
                  @crazy32
                  Die Meldungen kommen nach welcher Aktion?
                  Mit
                  systemctl disable SERVICENAME
                  wird der entsprechende Service aus dem Bootvorgang herausgenommen.
                    @crazy32
                    Mit
                    Crazy32C Offline
                    Crazy32C Offline
                    Crazy32
                    @thomas-braun Die haben angefangen nachdem ich das hier eingegeben habe:
                    • Crazy32C Crazy32
                      Moin. Ich habe mir einen Conbee Stick zugelegt und einen Tradfri Dimmer und zwei Aqara Temperatursensoren. Es scheint auch alles soweit funktioniert zu haben. In der Phoscon App werden die Sensoren angezeigt und im iobroker werden die Datenpunkte angezeigt. Allerdings aktualiseren die sich nicht. Der eine Sensor liegt draußen, ich glaube nicht, dass wir in Deutschland gerade 23°C haben 😬 Ich habe allerdings bemerkt, dass in der Phoscon App angezeigt wird, dass die Sensoren zuletzt gestern aktualisiert wurden. Der Zeitpunkt passt mit dem, als ich die Sensoren verbunden habe. Es scheint so, dass die Werte einmal abgerufen wurden und danach nicht mehr. Hat das schon mal jemand gehabt und hat einen Rat für mich?
                      LG
                      Markus
                      hsteinmeH Offline
                      hsteinmeH Offline
                      hsteinme
                      In einer derartigen Situation bin ich immer unsicher, ob der Adapter keine aktualisierten Werte erhält/abholt oder ob der Browser aktualisierte Werte nicht anzeigt. Hier bieten sich dann verschiedene Wege zum Quercheck an:
                      • Verschiedene Browser ausprobieren
                      • Für den fraglichen Datenpunkt die History aktivieren und diese dann ansehen
                      • Auf den fraglichen Datenpunkt die Events filtern und Änderungen beobachten
                      • Kleines Skript schreiben, das den fraglichen Datenpunkt abonniert und bei Änderungen einen Logeintrag vornimmt
                      • Crazy32C Crazy32
                        @crazy32
                        Hast du mal neugestartet danach?
                        • Crazy32C Crazy32
                          Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          @crazy32 adapter neustarten, hilft wahrscheinlich. Kann aber sein das du deConz neustarten musst weil das Port Binding für deconz-gui fehlt.
                          Persönlicher Support
                          Spenden -> paypal.me/J3YC33
                            @crazy32
                            Crazy32C Offline
                            Crazy32C Offline
                            Crazy32
                            @thomas-braun Noch nicht. Muss ich vorher systemctl disable deconz eingeben? Ist das einmalig, oder muss ich das irgendwie wieder aktivieren, wenn es nicht klappt?
                            @hsteinme Chrome und Firefox zeigen das Gleiche, sind also beide nicht aktuell. Bei den restlichen drei Vorschägen müsste ich erst schauen wie ich das mache.
                            @Jey-Cee Der Adapter ist gelb und bleibt nach Neustart gelb. Wahrscheinlich weil ich den Service deaktiviert habe?
                            • Crazy32C Crazy32
                              systemctl disable
                              Nimmt den Service dauerhaft aus dem Boot-Vorgang raus.
                              Aktiviert bekommst du den wieder mit
                              sudo systemctl enable SERVICENAME
                                systemctl disable
                                Crazy32C Offline
                                Crazy32C Offline
                                Crazy32
                                @thomas-braun So, Neustart ist durchgeführt. Der Adapter ist grün, Phoscon App und Adapter zeigen für beide Sensoren identische Aktualisierungzeiten. Nur in der deconz App ist der Sensor 1 nicht mit der Linie verbunden. Aber ich glaube das hat gestern auch etwas länger gedauert. Ich warte jetzt mal ab.
                                • Crazy32C Crazy32
                                  Guten Morgen allerseits. Ich komme hier einfach nicht weiter. Was ich gemacht habe:
                                  • In der Phoscon App die Sensoren gelöscht und neu verbunden
                                  • Den Deconz Adapter gelöscht und neu installiert.
                                  Ergebnis:
                                  In der Deconz Software werden die Sensoren angezeigt und sind auch mit dieser Linie verbunden.
                                  In der Phoscon App werden die Sensoren angezeigt und sind auch vor kurzem aktualisiert worden.
                                  In IoBroker ist der Adapter auf grün, die Sensoren werden in der Geräteliste angezeigt.
                                  Die Datenpunkte sind alle da, aber nicht aktuell. Anscheinend werden die Aktualisierungen der Sensoren nicht auf den Adapter übertragen, oder der Adapter holt sie sich nicht, wie auch immer.
                                  Hier noch ein paar Screenshots, wenn ihr noch was braucht, was behilflich sein kann, einfach sagen.
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @crazy32
                                  Zu Deinen Screenshots von vor 5 Stunden:
                                  Du hast die falschen Werte verglichen.
                                  Auf dem Phoscon Foto ist Multisensor 1 mit irgendwann um 7uhr aktualisiert und beim Screenshot der Datenpunkte guckst du dir die Aktualisierungszeit von Multisensor 2 an.
                                  Das kann ja nicht stimmen 😊
                                  Vermutlich läuft alles richtig nur du hast flüchtig falsch geguckt.
                                  Trotzdem würde ich deine Version mal updaten.
                                  2.7.1 ist doch arg alt.
                                  • haselchenH haselchen
                                    @crazy32
                                    Jan.S100
                                    @haselchen 2.7.1 ist stable. Also erstmal schon richtig. 😀
                                    • haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @jan-s100
                                      Da gibt es noch zig unter 2.7.1 aber auch über 2.7.1 die stable sind 😉
                                      Es kann nicht schaden sein System Stable aktuell zu halten. Da werden schon viele Fehlerquellen mit ausgeschlossen.
                                      • J Jan.S100
                                        Crazy32C Offline
                                        Crazy32C Offline
                                        Crazy32
                                        @jan-s100 Also 2.7.1 lassen, ok. Hatte mich schon gewundert weil mir gestern ein Firmware Update angeboten wurde, das ich auch durchgeführt habe.
                                        @haselchen Stimmt, Ich habe da Sensor 1 mit Sensor 2 verglichen. Ist aber im Prinzip egal, da sich der Sensor seit gestern nicht aktualisiert hat.
                                        Eine Frage zu der Arbeitsweise der Sensoren, funken die regelmäßig die Werte, oder nur wenn sich was ändert? Der eine Sensor liegt nämlich im Keller am PC, könnte es sein, dass die Temperatur seit gestern einfach gleich geblieben ist und deshalb der Aktualisierungsstand noch von gestern ist? Kann ich aber andererseits auch nicht glauben, da der Sensor mit zwei Kommastellen arbeitet. So gleichbleibend wird die Temperatur auch im Keller nicht sein... Warum ist das alles nur so kompliziert? 😁
                                        EDIT:
                                        Aktueller Screenshot, diesmal auch den gleichen Sensor verglichen 😁
                                          @jan-s100
                                          Jan.S100
                                          @haselchen Hm.
                                          Also ich kenne keine Stable über 2.7.1.
