  4. Betatester für Backitup 2.0.0 gesucht
    apollon77A
293 Beiträge 32 Kommentatoren 74.9k Aufrufe 28 Beobachtet
  • FenriswolfF Fenriswolf
    @simatec
    Habe auch deinen neuen Adapter direkt mal installiert und probiert. Bekomme aber noch Fehler im Logbuch.
    So wie es aussieht, scheint es vom WebDav zu kommen. Wollte auf einen seperaten Raspi bei mir sichern auf dem Nextcloud läuft.
    backitup.0	2021-02-01 19:55:19.148	debug	(4282) mount successfully completed
    backitup.0	2021-02-01 19:55:19.133	warn	(4282) Terminated (UNCAUGHT_EXCEPTION): Without reason
    backitup.0	2021-02-01 19:55:19.132	debug	(4282) Plugin sentry destroyed
    backitup.0	2021-02-01 19:55:19.131	info	(4282) terminating
    backitup.0	2021-02-01 19:55:19.130	info	(4282) cleaned everything up...
    backitup.0	2021-02-01 19:55:19.102	error	(4282) Exception-Code: DEPTH_ZERO_SELF_SIGNED_CERT: self signed certificate
    backitup.0	2021-02-01 19:55:19.101	error	(4282) Error: self signed certificate at TLSSocket.onConnectSecure (_tls_wrap.js:1502:34) at TLSSocket.emit (events.js:314:20) at TLSSocket.EventEmitter.emit (domain.js:483:12) at TLSS
    backitup.0	2021-02-01 19:55:19.101	error	(4282) unhandled promise rejection: self signed certificate
    backitup.0	2021-02-01 19:55:19.100	error	(4282) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    backitup.0	2021-02-01 19:55:18.820	info	(4282) [ccu] backup was activated at 01:30 every 2 day(s)
    backitup.0	2021-02-01 19:55:18.807	info	(4282) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2021-02-01 19:55:18.730	info	(4282) starting. Version 2.0.0-beta.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.20.1, js-controller: 3.2.12
    simatecS
    simatecS
    simatec
    @fenriswolf
    Bitte poste mal den kompletten debug Log und dein Config
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    FenriswolfF R 2 Antworten Letzte Antwort
      habe es auch mal getestet, funktioniert soweit, bis auf folgendes
      [DEBUG] [jarvis] - Jarvis Backup cannot created. Please install a Jarvis version >= 2.2.0
      was mir noch auffällt
      [DEBUG] [iobroker] - host.IoBroker 53511 states saved
      [DEBUG] [iobroker] - host.IoBroker 42968 objects saved
      simatecS
      simatecS
      simatec
      @crunchip
      Jarvis muss in Version >= 2.2.0 installiert sein.
      Also die aktuelle Beta nehmen.
      Grund hierfür ist, dass jarvis und backitup sich ab Version 2.2.0 auf diese Backupstruktur geeinigt haben.
      Die States passen so. Es sind auch Systeminterne States dabei. Eventuell mal Experten Einstellungen im Objektbaum aktivieren, dann sollten die Zahl passen
      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
      • simatecS simatec
        @crunchip
        crunchipC
        crunchipC
        Developer Global Moderator Most Active Forum Testing
        @simatec
        ok, >=v2.2.0 ist ja installiert gewesen, war nur nicht die aktuelle beta, daher etwas irreführend
        Experten Modus ändert nichts an Zahlen, dann wird wohl der Rest Systeminterne States sein
        • simatecS simatec
          @crunchip
          Thomas BraunT
          Thomas BraunT
          Most Active Developer
          @simatec
          Hab jetzt auch mal installiert.
          Started iobroker ...
          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.0.42/FRITZ.NAS/iobroker_backups /opt/iobroker/backups
          mount error(16): Device or resource busy
          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
          [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.0.42/FRITZ.NAS/iobroker_backups /opt/iobroker/backups
          [DEBUG] [iobroker] - host.raspberrypi 3667 states saved
          [DEBUG] [iobroker] - host.raspberrypi 4442 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_01-22_50_26_backupiobroker.tar.gz
          [DEBUG] [iobroker] - done
          [DEBUG] [redis] - Start Redis Backup ...
          [DEBUG] [redis] - done
          [DEBUG] [cifs] - done
          [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_02_01-22_50_26_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: Error: Unknown system error -116: Unknown system error -116, open '/opt/iobroker/backups/iobroker_2021_02_01-22_50_26_backupiobroker.tar.gz'
          Mit den gleichen Einstellungen hat das in 1.8.5 immer wunderbar funktioniert.
          In dmesg finde ich auf auf einmal viele Einträge dazu. Die ersten paar Zeilen waren das nächtliche automatisierte Backup in den letzten Nächten:
          [   69.266841] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [ 1082.685761] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [23613.674561] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [110015.201171] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [196416.931959] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [282818.708390] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [355129.727389] CIFS: Attempting to mount //192.168.178.1/FRITZ.NAS/iobroker_backups
          [355139.776479] CIFS VFS: Error connecting to socket. Aborting operation.
          [355139.776499] CIFS VFS: cifs_mount failed w/return code = -2
          [355139.851154] CIFS: Attempting to mount //192.168.178.1/FRITZ.NAS/iobroker_backups
          [355139.851264] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
          [355149.936718] CIFS VFS: Error connecting to socket. Aborting operation.
          [355149.936740] CIFS VFS: cifs_mount failed w/return code = -2
          [355262.162504] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [355320.577457] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [355332.600034] CIFS VFS: bogus file nlink value 0
          [355332.605856] CIFS VFS: bogus file nlink value 0
          [355333.114350] CIFS VFS: bogus file nlink value 0
          [355333.127420] CIFS VFS: bogus file nlink value 0
          [355663.236274] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [355663.395131] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [355663.395215] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
          [355909.277648] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [355923.282396] CIFS VFS: bogus file nlink value 0
          [355923.290974] CIFS VFS: bogus file nlink value 0
          [355923.820181] CIFS VFS: bogus file nlink value 0
          [355923.833061] CIFS VFS: bogus file nlink value 0
          [356150.682616] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [356150.778504] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [356150.778566] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
          [356253.906657] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [356254.004691] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [356254.004751] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
          [356505.859671] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [356505.956918] CIFS: Attempting to mount //192.168.0.42/FRITZ.NAS/iobroker_backups
          [356505.956997] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
          [356518.314935] CIFS VFS: bogus file nlink value 0
          [356518.320970] CIFS VFS: bogus file nlink value 0
          [356518.894873] CIFS VFS: bogus file nlink value 0
          [356518.912211] CIFS VFS: bogus file nlink value 0
          [Edit:] Backup auf das NAS/FritzBox funktioniert nun, allerdings wird das Backup nicht nach Google Drive geschoben.
          Schaut so aus:
          [DEBUG] [mount] - mount successfully completed
          [DEBUG] [mount] - done
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_01-23_01_54_backupiobroker.tar.gz
          [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_02_01-23_01_54_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: Error: Unknown system error -116: Unknown system error -116, open '/opt/iobroker/backups/iobroker_2021_02_01-23_01_54_backupiobroker.tar.gz'
          [ERROR] [googledrive] - Google Drive: Error: <!DOCTYPE html>
          <html lang=en>
            <meta charset=utf-8>
            <meta name=viewport content="initial-scale=1, minimum-scale=1, width=device-width">
            <title>Error 408 (Request Timeout)!!1</title>
            <style>
              *{margin:0;padding:0}html,code{font:15px/22px arial,sans-serif}html{background:#fff;color:#222;padding:15px}body{margin:7% auto 0;max-width:390px;min-height:180px;padding:30px 0 15px}* > body{background:url(//www.google.com/images/errors/robot.png) 100% 5px no-repeat;padding-right:205px}p{margin:11px 0 22px;overflow:hidden}ins{color:#777;text-decoration:none}a img{border:0}@media screen and (max-width:772px){body{background:none;margin-top:0;max-width:none;padding-right:0}}#logo{background:url(//www.google.com/images/branding/googlelogo/1x/googlelogo_color_150x54dp.png) no-repeat;margin-left:-5px}@media only screen and (min-resolution:192dpi){#logo{background:url(//www.google.com/images/branding/googlelogo/2x/googlelogo_color_150x54dp.png) no-repeat 0% 0%/100% 100%;-moz-border-image:url(//www.google.com/images/branding/googlelogo/2x/googlelogo_color_150x54dp.png) 0}}@media only screen and (-webkit-min-device-pixel-ratio:2){#logo{background:url(//www.google.com/images/branding/googlelogo/2x/googlelogo_color_150x54dp.png) no-repeat;-webkit-background-size:100% 100%}}#logo{display:inline-block;height:54px;width:150px}
            </style>
            <a href=//www.google.com/><span id=logo aria-label=Google></span></a>
            <p><b>408.</b> <ins>That’s an error.</ins>
            <p>Your client has taken too long to issue its request.  <ins>That’s all we know.</ins>
          [DEBUG] [googledrive] - Google Drive: Copy redis_2021_02_01-23_02_05_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: Error: Unknown system error -116: Unknown system error -116, open '/opt/iobroker/backups/redis_2021_02_01-23_02_05_backupiobroker.tar.gz'
          <html lang=en>
            <style>
            </style>
          [DEBUG] [googledrive] - done
          [DEBUG] [clean] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
          [DEBUG] [umount] - umount successfully completed
          [DEBUG] [umount] - done
          simatecS 2 Antworten Letzte Antwort
            @simatec
            Schaut so aus:
            <html lang=en>
              <style>
              </style>
            <html lang=en>
              <style>
              </style>
            simatecS
            simatecS
            simatec
            Das muss ich mir morgen mal in Ruhe anschauen und testen. Bis auf die aktuelle dependencies hat sich an Google Drive seit der Version 1.8.5 nix geändert.
              @simatec
              Schaut so aus:
              <html lang=en>
                <style>
                </style>
              <html lang=en>
                <style>
                </style>
              simatecS
              simatecS
              simatec
              Kannst du dein NAS nochmal bitte nach den Rechten checken. So wie ich den Log deute, kann für den Upload auf GoogleDrive nicht auf die BackupFiles zugegriffen werden.
              Ist aktuell nur ne Vermutung und ich werde das morgen mal nachstellen
              • simatecS simatec
                Thomas BraunT
                Thomas BraunT
                @simatec
                Ich hatte jetzt auch wie besprochen aus zwei Instanzen eine gemacht.
                Neu ist jetzt, dass zuerst Freigabe aus der Fritzbox gemountet wird, das Backup angelegt wird und dann auch ins Google Drive geschoben werden soll.
                Bislang waren das ja einzelne Vorgänge in eigenen Instanzen.
                Ich wüsste jetzt auch gar nicht wie ich dem Google Drive Rechte auf dem FritzNAS einrichten könnte. Oder andersrum.
                • simatecS simatec
                  @fenriswolf
                  FenriswolfF
                  FenriswolfF
                  Fenriswolf
                  @simatec sagte in Betatester für Backitup 2.0.0 gesucht:
                  @fenriswolf
                  Aber gerne doch ....
                  backitup.0	2021-02-02 06:45:28.244	warn	(9308) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  backitup.0	2021-02-02 06:45:28.244	debug	(9308) Plugin sentry destroyed
                  backitup.0	2021-02-02 06:45:28.243	info	(9308) terminating
                  backitup.0	2021-02-02 06:45:28.242	info	(9308) cleaned everything up...
                  backitup.0	2021-02-02 06:45:28.193	error	(9308) Exception-Code: DEPTH_ZERO_SELF_SIGNED_CERT: self signed certificate
                  backitup.0	2021-02-02 06:45:28.193	error	(9308) Error: self signed certificate at TLSSocket.onConnectSecure (_tls_wrap.js:1502:34) at TLSSocket.emit (events.js:314:20) at TLSSocket.EventEmitter.emit (domain.js:483:12) at TLSS
                  backitup.0	2021-02-02 06:45:28.190	error	(9308) unhandled promise rejection: self signed certificate
                  backitup.0	2021-02-02 06:45:28.189	error	(9308) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  backitup.0	2021-02-02 06:45:28.126	debug	(9308) first mount attempt with smb option failed. try next mount attempt without smb option ...
                  backitup.0	2021-02-02 06:45:27.841	debug	(9308) [ccu] 10 30 01 */2 * *
                  backitup.0	2021-02-02 06:45:27.837	info	(9308) [ccu] backup was activated at 01:30 every 2 day(s)
                  backitup.0	2021-02-02 06:45:27.836	debug	(9308) [iobroker] 10 00 02 */1 * *
                  backitup.0	2021-02-02 06:45:27.821	info	(9308) [iobroker] backup was activated at 02:00 every 1 day(s)
                  backitup.0	2021-02-02 06:45:27.739	info	(9308) starting. Version 2.0.0-beta.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.20.1, js-controller: 3.2.12
                  backitup.0	2021-02-02 06:45:27.490	debug	(9308) Plugin sentry Initialize Plugin (enabled=true)
                  backitup.0	2021-02-02 06:44:52.856	warn	(8256) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  backitup.0	2021-02-02 06:44:52.856	debug	(8256) Plugin sentry destroyed
                  backitup.0	2021-02-02 06:44:52.855	info	(8256) terminating
                  backitup.0	2021-02-02 06:44:52.854	info	(8256) cleaned everything up...
                  backitup.0	2021-02-02 06:44:52.827	error	(8256) Exception-Code: DEPTH_ZERO_SELF_SIGNED_CERT: self signed certificate
                  backitup.0	2021-02-02 06:44:52.826	error	(8256) Error: self signed certificate at TLSSocket.onConnectSecure (_tls_wrap.js:1502:34) at TLSSocket.emit (events.js:314:20) at TLSSocket.EventEmitter.emit (domain.js:483:12) at TLSS
                  backitup.0	2021-02-02 06:44:52.826	error	(8256) unhandled promise rejection: self signed certificate
                  backitup.0	2021-02-02 06:44:52.825	error	(8256) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  backitup.0	2021-02-02 06:44:52.752	debug	(8256) mount successfully completed
                  backitup.0	2021-02-02 06:44:52.426	debug	(8256) [ccu] 10 30 01 */2 * *
                  backitup.0	2021-02-02 06:44:52.421	info	(8256) [ccu] backup was activated at 01:30 every 2 day(s)
                  backitup.0	2021-02-02 06:44:52.420	debug	(8256) [iobroker] 10 00 02 */1 * *
                  backitup.0	2021-02-02 06:44:52.407	info	(8256) [iobroker] backup was activated at 02:00 every 1 day(s)
                  backitup.0	2021-02-02 06:44:52.329	info	(8256) starting. Version 2.0.0-beta.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.20.1, js-controller: 3.2.12
                  ![Bildschirmfoto 2021-02-02 um 06.42.10.png](/assets/uploads/files/1612244831143-bildschirmfoto-2021-02-02-um-06.42.10.png)
                  • simatecS simatec
                    Thomas BraunT
                    Thomas BraunT
                    Hat sich wohl erledigt. Das automatische Nacht-Backup ist durchgelaufen. War wohl irgendwie Schluckauf bei Google Drive.
                      @fenriswolf
                      simatecS
                      simatecS
                      simatec
                      @fenriswolf
                      Dein Screenshot reicht leider nicht. Dort sehe ich nur die Haupteinstellungen. Lade mir mal über die Pfeiltasten deine Config runter und poste sie hier. Passwörter und Keys natürlich dann mit ein paar Sternchen versehen ... ;-)
                      FenriswolfF 1 Antwort Letzte Antwort
                      • simatecS simatec
                        @fenriswolf
                        FenriswolfF
                        FenriswolfF
                        Fenriswolf
                        @fenriswolf
                        gerne
                        system.adapter.backitup.0.json
                        simatecS FenriswolfF 2 Antworten Letzte Antwort
                          simatecS
                          simatecS
                          simatec
                          Konnte auf meinen Testsystemen auch keine Auffälligkeiten feststellen.
                          2021-02-02 07:53:10.266 - debug: backitup.0 (11148) Backup has started ...
                          2021-02-02 07:53:10.271 - silly: backitup.0 (11148) States user redis pmessage io.backitup.0.oneClick.*/io.backitup.0.oneClick.iobroker:{"val":true,"ack":true,"ts":1612248790268,"q":0,"from":"system.adapter.backitup.0","user":"system.user.admin","lc":1612248790268}
                          2021-02-02 07:53:20.360 - debug: backitup.0 (11148) [iobroker/mount] mount successfully completed
                          2021-02-02 07:53:20.364 - debug: backitup.0 (11148) [iobroker/mount] done
                          2021-02-02 07:53:22.159 - debug: backitup.0 (11148) [iobroker/iobroker] host.iobroker-dev 1628 states saved
                          2021-02-02 07:53:22.187 - debug: backitup.0 (11148) [iobroker/iobroker] host.iobroker-dev 2019 objects saved
                          2021-02-02 07:53:24.567 - debug: backitup.0 (11148) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_02_02-07_53_20_dev_backupiobroker.tar.gz
                          2021-02-02 07:53:28.491 - debug: backitup.0 (11148) [iobroker/iobroker] done
                          2021-02-02 07:53:29.095 - debug: backitup.0 (11148) [iobroker/redis] Start Redis Backup ...
                          2021-02-02 07:53:42.294 - debug: backitup.0 (11148) [iobroker/redis] Packed 35MB so far...
                          2021-02-02 07:53:51.363 - debug: backitup.0 (11148) [iobroker/redis] Packed 60MB so far...
                          2021-02-02 07:53:58.532 - debug: backitup.0 (11148) [iobroker/redis] done
                          2021-02-02 07:53:58.843 - debug: backitup.0 (11148) [iobroker/zigbee] found zigbee database: zigbee.0,zigbee.1
                          2021-02-02 07:53:58.844 - debug: backitup.0 (11148) [iobroker/zigbee] done
                          2021-02-02 07:53:58.997 - debug: backitup.0 (11148) [iobroker/grafana] Start Grafana Backup ...
                          2021-02-02 07:54:01.549 - debug: backitup.0 (11148) [iobroker/grafana] Created grafana_tmp directory
                          2021-02-02 07:54:01.571 - debug: backitup.0 (11148) [iobroker/grafana] Created dashboard directory
                          2021-02-02 07:54:01.594 - debug: backitup.0 (11148) [iobroker/grafana] Created dashboards_manually_restore directory
                          2021-02-02 07:54:01.616 - debug: backitup.0 (11148) [iobroker/grafana] Created datasource directory
                          2021-02-02 07:54:01.618 - debug: backitup.0 (11148) [iobroker/grafana] start Grafana request ...
                          2021-02-02 07:54:01.675 - debug: backitup.0 (11148) [iobroker/grafana] Grafana is available ... Status: 200
                          2021-02-02 07:54:02.461 - debug: backitup.0 (11148) [iobroker/grafana] found Dashboard: conronastatistik
                          2021-02-02 07:54:02.468 - debug: backitup.0 (11148) [iobroker/grafana] found Dashboard: wetterbedingungen
                          2021-02-02 07:54:02.475 - debug: backitup.0 (11148) [iobroker/grafana] found Dashboard: gestorben
                          2021-02-02 07:54:02.477 - debug: backitup.0 (11148) [iobroker/grafana] start Grafana backup compress ...
                          2021-02-02 07:54:02.665 - debug: backitup.0 (11148) [iobroker/grafana] Backup created: /opt/iobroker/backups/grafana_2021_02_02-07_54_02_backupiobroker.tar.gz
                          2021-02-02 07:54:02.666 - debug: backitup.0 (11148) [iobroker/grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                          2021-02-02 07:54:02.825 - debug: backitup.0 (11148) [iobroker/grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                          2021-02-02 07:54:02.827 - debug: backitup.0 (11148) [iobroker/grafana] done
                          2021-02-02 07:54:02.980 - debug: backitup.0 (11148) [iobroker/jarvis] found Jarvis Instance: 0
                          2021-02-02 07:54:02.981 - debug: backitup.0 (11148) [iobroker/jarvis] start Jarvis Backup for Instance 0...
                          2021-02-02 07:54:02.983 - debug: backitup.0 (11148) [iobroker/jarvis] found Jarvis Instance: 1
                          2021-02-02 07:54:02.984 - debug: backitup.0 (11148) [iobroker/jarvis] start Jarvis Backup for Instance 1...
                          2021-02-02 07:54:03.012 - debug: backitup.0 (11148) [iobroker/jarvis] Backup created: /opt/iobroker/backups/jarvis.1_2021_02_02-07_54_02_backupiobroker.tar.gz
                          2021-02-02 07:54:03.013 - debug: backitup.0 (11148) [iobroker/jarvis] done
                          2021-02-02 07:54:03.022 - debug: backitup.0 (11148) [iobroker/jarvis] Backup created: /opt/iobroker/backups/jarvis.0_2021_02_02-07_54_02_backupiobroker.tar.gz
                          2021-02-02 07:54:03.370 - debug: backitup.0 (11148) [iobroker/javascripts] done
                          2021-02-02 07:54:03.674 - debug: backitup.0 (11148) [iobroker/cifs] done
                          2021-02-02 07:54:04.134 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy iobroker_2021_02_02-07_53_20_dev_backupiobroker.tar.gz...
                          2021-02-02 07:54:23.922 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy redis_2021_02_02-07_53_29_backupiobroker.tar.gz...
                          2021-02-02 08:00:55.893 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy zigbee.0_2021_02_02-07_53_58_backupiobroker.tar.gz...
                          2021-02-02 08:00:58.562 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy zigbee.1_2021_02_02-07_53_58_backupiobroker.tar.gz...
                          2021-02-02 08:01:02.062 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy grafana_2021_02_02-07_54_02_backupiobroker.tar.gz...
                          2021-02-02 08:01:04.738 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy jarvis.0_2021_02_02-07_54_02_backupiobroker.tar.gz...
                          2021-02-02 08:01:07.211 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy jarvis.1_2021_02_02-07_54_02_backupiobroker.tar.gz...
                          2021-02-02 08:01:09.619 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: Copy javascripts_2021_02_02-07_54_03_backupiobroker.tar.gz...
                          2021-02-02 08:01:14.733 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: delete iobroker_2020_12_07-16_09_20_dev_backupiobroker.tar.gz
                          2021-02-02 08:01:15.598 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: delete redis_2020_12_07-16_09_25_backupiobroker.tar.gz
                          2021-02-02 08:01:16.267 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: delete zigbee.0_2020_09_28-12_46_25_backupiobroker.tar.gz
                          2021-02-02 08:01:16.955 - debug: backitup.0 (11148) [iobroker/googledrive] Google Drive: delete zigbee.1_2020_09_28-12_46_25_backupiobroker.tar.gz
                          2021-02-02 08:01:17.669 - debug: backitup.0 (11148) [iobroker/googledrive] done
                          2021-02-02 08:01:17.838 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2021_01_31-17_03_20_dev_backupiobroker.tar.gz
                          2021-02-02 08:01:21.267 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/redis_2021_01_31-17_03_29_backupiobroker.tar.gz
                          2021-02-02 08:01:21.324 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2021_01_31-17_03_59_backupiobroker.tar.gz
                          2021-02-02 08:01:21.356 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/zigbee.1_2021_01_31-17_03_59_backupiobroker.tar.gz
                          2021-02-02 08:01:21.390 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/grafana_2021_01_31-17_04_02_backupiobroker.tar.gz
                          2021-02-02 08:01:21.423 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/jarvis.1_2021_01_31-17_04_03_backupiobroker.tar.gz
                          2021-02-02 08:01:21.456 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/jarvis.0_2021_01_31-17_04_03_backupiobroker.tar.gz
                          2021-02-02 08:01:21.491 - debug: backitup.0 (11148) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2021_01_31-17_04_04_backupiobroker.tar.gz
                          2021-02-02 08:01:21.517 - debug: backitup.0 (11148) [iobroker/clean] done
                          2021-02-02 08:01:21.679 - debug: backitup.0 (11148) [iobroker/email] done
                          2021-02-02 08:01:22.289 - debug: backitup.0 (11148) [iobroker/historyHTML] new history html values created
                          2021-02-02 08:01:22.291 - debug: backitup.0 (11148) [iobroker/historyHTML] done
                          2021-02-02 08:01:22.452 - debug: backitup.0 (11148) [iobroker/historyJSON] new history json values created
                          2021-02-02 08:01:22.453 - debug: backitup.0 (11148) [iobroker/historyJSON] done
                          2021-02-02 08:01:22.632 - debug: backitup.0 (11148) [iobroker/umount] mount activ... umount in 60 Seconds!!
                          2021-02-02 08:02:22.761 - debug: backitup.0 (11148) [iobroker/umount] umount successfully completed
                          2021-02-02 08:02:22.764 - debug: backitup.0 (11148) [iobroker/umount] done
                          2021-02-02 08:02:22.916 - debug: backitup.0 (11148) [iobroker] exec: done
                            @fenriswolf
                            gerne
                            simatecS
                            simatecS
                            simatec
                            @fenriswolf
                            Die Antwort liegt hier
                            Die interne IP Adresse ist nicht zertifiziert.
                            Konnte das auch auf meinem Testsystem nachstellen.
                            backitup.0	2021-02-02 08:23:47.157	error	at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:687:12)
                            backitup.0	2021-02-02 08:23:47.157	error	at TLSSocket._finishInit (_tls_wrap.js:917:8)
                            backitup.0	2021-02-02 08:23:47.157	error	at TLSSocket.emit (events.js:310:20)
                            backitup.0	2021-02-02 08:23:47.157	error	at TLSSocket.onConnectSecure (_tls_wrap.js:1484:27)
                            backitup.0	2021-02-02 08:23:47.157	error	at Object.checkServerIdentity (tls.js:288:12)
                            backitup.0	2021-02-02 08:23:47.157	error	(11312) Error [ERR_TLS_CERT_ALTNAME_INVALID]: Hostname/IP does not match certificate's altnames: IP: 192.168.123.43 is not in the cert's list:
                            backitup.0	2021-02-02 08:23:47.156	error	(11312) unhandled promise rejection: Hostname/IP does not match certificate's altnames: IP: 192.168.123.43 is not in the cert's list:
                            Unhandled	2021-02-02 08:23:47.155	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            Hier muss ein eindeutiger Hostname verwendet werden, dem du auch über Lets Entcrypt in deiner Nextcloud dementsprechend zulässt.
                            Den fehlerlog werde ich in der nächsten beta noch etwas besser abfangen, aber dein Problem selbst kann ich nicht beheben.
                            Nimm keine interne IP für den Zugriff auf deine Nextcloud. Selbst Chrome, Firefox und Co meckern da
                              @agria4800 sagte in Betatester für Backitup 2.0.0 gesucht:
                              Ich weiß, ist nicht zwingend notwendig, aber statt des ganzen System nur speziell die Vis Projekte zu sichern fände ich super
                              Wie meinst du das?
                              in dem "normalen" iobroker backup sind auch bereits die Vis-Projekte in den jeweiligen vis-views.json enthalten.
                              Und ich würde mich nicht wundern, wenn das dort die größten Dateien sind.
                              Du kannst das Backup mit einem entzipper öffnen und die Projekte rauskopieren.
                              Was wäre deine Wunsch-Option?
                              Agria4800A
                              Agria4800A
                              Agria4800
                              @homoran sagte in Betatester für Backitup 2.0.0 gesucht:
                              Wie meinst du das?
                              Ja, wäre nur eine Wunschoption!
                              Gerade für Leute mit wenig Erfahrung in Vis wäre es hilfreich, schnell und unkompliziert ihr Projekt wieder herstellen zu können.
                              Ich selbst habe keine Probleme und handhabe das so wie von dir beschrieben...
                              Toll fände ich auch die Möglichkeit zu haben, bei einem Backup nur ausgewählte Projekte mit zu sichern und nicht immer alle.. ich habe ca 20 In meiner Sammlung, die ich zwar ab und an brauche, aber nicht immer aktuell halten muss und somit auch nicht mit sichern müsste...
                              Vielleicht ist es ja kein großer Aufwand das in den Backitup Adapter zu integrieren
                              • simatecS simatec
                                Aktuelle Test Version 2.0.0-beta.13
                                Veröffentlichungsdatum 18.02.2021
                                Github Link https://github.com/simatec/ioBroker.backitup.git
                                Ab sofort gibt es die erste Beta-Version des Backitup Adapters in der Version 2.0.0 auf Github.
                                Wer möchte kann gerne die Version von Github installieren und hier ggfs. Bugs und sein Feedback posten.
                                Was ist Neu?
                                Als erstes hat sich einiges unter der Haube geändert und am Code wurde vieles verbessert.
                                Des Weiteren wird iobroker nun bei einem Restore von Zusatzbackups nicht mehr gestoppt.
                                Hier wird lediglich der betroffene Adapter gestoppt und im Anschluss wieder gestartet.
                                iobroker selbst wird nur noch bei einem redis-restore oder bei einem direkten iobroker restore gestoppt.
                                Neue Features:
                                Die Version 2.0.0 beinhaltet einige neue Features, die sich inzwischen viele User per Issue oder auch hier im Forum gewünscht haben.
                                Hier eine kleine Übersicht der neuen Features:
                                • WebDav für die Cloudverbindungen zur ownCloud / Nextcloud und Yandex
                                • Sicherung der Scripte aus dem Javascript-Adapter
                                • Sicherung von Grafana-Dashboards und Datasources
                                • Restore ohne Neustart für die meisten Backuptypen möglich
                                • Sicherung von Jarvis Backupdateien
                                • Sicherung von Influx-Datenbanken
                                • Sicherung von pgSql-Datenbanken
                                Dokumentation
                                https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md
                                Changelog
                                2.0.0 (31.01.2021)
                                • (simatec) BugFix detect last backup
                                • (simatec) WebDAV added
                                • (simatec) BugFix Zigbee
                                • (simatec) stop/start Instances on restore
                                • (simatec) Download Icon for Cloud Restore added
                                • (simatec) javscript Backup added
                                • (simatec) Grafana Backup added
                                • (simatec) Restore added for some types without restart
                                • (simatec) timestamp for history-json added
                                • (simatec) Source code rewritten
                                • (simatec) Restore revised
                                • (simatec) fixed many small bugs
                                Ich würde mich sehr über eure Tests und ein Feedback freuen und wünsche euch viel Spaß mit Version 2 des Backitup-Adapters.
                                da_WoodyD
                                da_WoodyD
                                @simatec bin auch mal dabei. mal schauen was um 03:30 passiert...
                                einzig bei grafana scheiter ich im moment. wenn ich im dashboard auf api keys klicke, gibts zwar einen, aber der token wird mir nirgends angezeigt zum übernehmen. wo, oder wie find ich dat?
                                • da_WoodyD da_Woody
                                  simatecS
                                  simatecS
                                  simatec
                                  @da_woody
                                  Ich werde das in der Doku zum Adapter noch aufnehmen.
                                  Benötigt wird ein Grafana API Key. Der wird in Grafana unter: Configuration → API Keys erstellt.
                                  • simatecS simatec
                                    @da_woody
                                    da_WoodyD
                                    da_WoodyD
                                    @simatec das mir schon klar,
                                    aber in jedem anderen prog kann ich den key jederzeit sehen! deswegen frug ich...
                                      simatecS
                                      simatecS
                                      simatec
                                      @da_woody
                                      Ja das geht bei Grafana leider nicht.
                                      Lege einfach einen weiteren an und kopiere ihn dir direkt irgendwo hin
                                      • simatecS simatec
                                        @da_woody
                                        da_WoodyD
                                        da_WoodyD
                                        @simatec saftsägge... ok, mal linsen.
                                        und gleich in den backup ordner am nas gespeichert... ;)
                                        • simatecS
                                          simatecS
                                          simatec
                                          Die 2.0.0-beta.2 ist auf Github Online und verbessert das Error-Handling für WebDAV ...
                                          84.0k
