  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.6m Aufrufe 201 Beobachtet
  • ChaotC Chaot
    @rene_hm
    Ich habe seit gestern die Fehlermeldung:
    heatingcontrol.0	2021-01-26 08:41:28.351	warn	(22665) !!! Statechange not handled fritzdect.0.DECT_2E:B9:36-900.tsoll {"val":23,"ack":true,"ts":1611646888309,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611644400132
    heatingcontrol.0	2021-01-26 08:41:28.351	warn	(22665) !!! Statechange not handled fritzdect.0.DECT_119610273248.tsoll {"val":24,"ack":true,"ts":1611646888308,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611644400356
    heatingcontrol.0	2021-01-26 08:41:28.325	warn	(22665) !!! Statechange not handled fritzdect.0.DECT_119600101272.tsoll {"val":23,"ack":true,"ts":1611646888294,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611644400470
    heatingcontrol.0	2021-01-26 08:41:28.310	warn	(22665) !!! Statechange not handled fritzdect.0.DECT_119600122088.tsoll {"val":23,"ack":true,"ts":1611646888286,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611644400241
    heatingcontrol.0	2021-01-26 08:41:28.302	warn	(22665) !!! Statechange not handled fritzdect.0.DECT_119600200880.tsoll {"val":23,"ack":true,"ts":1611646888285,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611644400304
    Adapter V. 2.0.3
    JS 4.10.14
    JS-Controler 3.2.11
    lobomauL
    lobomauL
    lobomau
    #2012
    @chaot die Warnmeldung kommt bei mir auch mit 2.0.3. Bei 2.0.2. keine Warnung.
    heatingcontrol.0	2021-01-26 13:13:27.607	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ1072301.2.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611663207095,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315276}
    heatingcontrol.0	2021-01-26 13:12:56.335	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ0861493.4.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611663176311,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315313}
    heatingcontrol.0	2021-01-26 13:11:16.499	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ1072301.2.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611663076429,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315276}
    heatingcontrol.0	2021-01-26 13:10:25.055	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ0861493.4.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611663025033,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315313}
    heatingcontrol.0	2021-01-26 13:08:53.010	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ1072301.2.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611662932631,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315276}
    heatingcontrol.0	2021-01-26 13:07:39.952	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ0861493.4.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611662859889,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315313}
    heatingcontrol.0	2021-01-26 13:06:14.106	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ1072301.2.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611662774094,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315276}
    heatingcontrol.0	2021-01-26 13:04:39.230	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ0861493.4.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611662679205,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315313}
    heatingcontrol.0	2021-01-26 13:03:21.450	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ1072301.2.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611662601427,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315276}
    heatingcontrol.0	2021-01-26 13:02:29.460	warn	(547) !!! Statechange not handled hm-rpc.0.LEQ0861493.4.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611662549316,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611662315313}
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
    • B
      B
      Borio85
      #2013
      @chrisxy said in Test Adapter HeatingControl v2.0.x:
      Hab den Adapter komplett gelöscht und aus dem gut neu geladen.
      Du nutzt aber die falsche VIS! V3.0.1 ist nicht für den Adapter V2.x.x aus dem Git sonder für V1.1.2
      Wenn du etwas in der VIS änderst wird wahrscheinlich nur 1-4 übernommen wobei 4 dann eigentlich deine 5 Periode ist, die VIS geht von 0-4 und nicht wie der Adapter von 1-5.
      Lade dir mal 3.1.2 aus dem Git von Pittini
      https://github.com/Pittini/iobroker-heatingcontrol-vis
      @all Bitte korrigieren, falls ich was falsches geschrieben habe :)
      C 1 Antwort Letzte Antwort
      • B Borio85
        C
        C
        ChrisXY
        #2014
        @borio85 Danke die Lösung.
        Hab aber nu im Log:
        (25750) exception in SetRoomTemperature [Error: The id is empty! Please provide a valid id.]
        B Rene_HMR 2 Antworten Letzte Antwort
        • C ChrisXY
          also ich tu mich echt schwer mit dem Adapter .. Aktuell verhaut es mir immer meine Profile. 4 sind eingestellt 5 steht "Null" Wenn ich das anpasse übernimmt er nichts.
          Hab den Adapter komplett gelöscht und aus dem gut neu geladen. Bildschirmfoto vom 2021-01-26 09-03-39.png Bildschirmfoto vom 2021-01-26 09-03-52.png
          Dominik F.D
          Dominik F.D
          Dominik F.
          #2015
          @chrisxy
          Und dazu hast du im Adapter unter Profile keine Temperaturabsenkung eingestellt, aus dem Grund ist unter Profilparameter nichts sichtbar, weil sich die Einstellungen nur auf die Absenkung beziehen. Stellst du relativ oder absolut ein, sollte dort auch was stehen.
          coyoteC C 2 Antworten Letzte Antwort
          • Dominik F.D Dominik F.
            @chrisxy
            coyoteC
            coyoteC
            coyote
            #2016
            @Chaot @lobomau @Rene_HM ja habe ich jetzt auch mit der letzten Version.
            heatingcontrol.0	2021-01-26 15:16:04.003	warn	(15852) !!! Statechange not handled hm-rpc.0.MEQ1573948.2.SET_TEMPERATURE {"val":21,"ack":true,"ts":1611670563998,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1611669663403}
            Rene_HMR 1 Antwort Letzte Antwort
              @chrisxy
              C
              C
              ChrisXY
              #2017
              @dominik-f Das habe ich natürlich. Kommt immer wenn ich in einem Raum die Temperaturen anpasse für die Uhrzeiten
              • C ChrisXY
                Hab aber nu im Log:
                B
                B
                Borio85
                #2018
                Hast du den Räumen im Adapter die richtigen Datenpunkte zugewiesen? Vorallem OID aktueller Wert und OID Zielwert?
                Die Meldung liest sich so als hättest du das nicht gemacht
                • coyoteC coyote
                  Rene_HMR
                  Rene_HMR
                  Rene_HM
                  #2019
                  @coyote @Chaot, @lobomau zur Warnung
                  Könnt ihr bitte mal ein debug log zeigen, was da davor passiert?
                  In der 2.0.3 sind sehr wenig Änderungen drin und die sollten nicht zu dieser Warnung führen...
                  coyoteC ChaotC 2 Antworten Letzte Antwort
                  • C ChrisXY
                    Hab aber nu im Log:
                    Rene_HMR
                    Rene_HMR
                    Rene_HM
                    #2020
                    @chrisxy sagte in Test Adapter HeatingControl v2.0.x:
                    Du hast ein Thermostat konfiguriert, aber keine OID_Target vergeben...
                    • Rene_HMR Rene_HM
                      coyoteC
                      coyoteC
                      coyote
                      #2021
                      @rene_hm
                      Hm, jetzt hab ich auf "debug" umgestellt, jetzt kam bisher die Meldung nicht mehr. Mal schauen, ob sie nochmal auftaucht.
                      • Rene_HMR Rene_HM
                        ChaotC
                        ChaotC
                        Chaot
                        schrieb am zuletzt editiert von Chaot
                        #2022
                        @rene_hm so oder mehr?:
                        heatingcontrol.0	2021-01-26 18:36:28.511	debug	(27671) AddStatusToLog skip Schlafzimmer auto holiday at home 22°C
                        heatingcontrol.0	2021-01-26 18:36:28.469	warn	(27671) !!! Statechange not handled fritzdect.0.DECT_2E:B9:36-900.tsoll {"val":22,"ack":true,"ts":1611682588406,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611682499986}
                        heatingcontrol.0	2021-01-26 18:36:28.461	warn	(27671) !!! Statechange not handled fritzdect.0.DECT_119610273248.tsoll {"val":24,"ack":true,"ts":1611682588398,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611682500235}
                        heatingcontrol.0	2021-01-26 18:36:28.461	debug	(27671) ChangeStatus called, while already changing, push to list Toilette Thermostats_Current {"val":25,"ack":true,"ts":1611682588398,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.adm
                        heatingcontrol.0	2021-01-26 18:36:28.460	debug	(27671) ChangeStatus called, while already changing, push to list Martin Thermostats_Current {"val":23,"ack":true,"ts":1611682588394,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin
                        heatingcontrol.0	2021-01-26 18:36:28.452	debug	(27671) UpdateDPs for Schlafzimmer auto
                        Etwas länger:
                        heatingcontrol.0	2021-01-26 18:46:28.921	debug	(27671) Reaching SetStatusLog for Rooms.Wohnzimmer.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.921	debug	(27671) HandleStateChanges vis heatingcontrol.0.Rooms.Toilette.StatusLog with 26.01.2021 18:35:00 auto holiday at home 24°C <br> 26.01.2021 18:34:58 starting holiday at home 25°C <br> 26.01.2021 18:3
                        heatingcontrol.0	2021-01-26 18:46:28.920	debug	(27671) HandleStateChangeGeneral heatingcontrol.0.Rooms.Toilette.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.920	debug	(27671) ### handle state change heatingcontrol.0.Rooms.Toilette.StatusLog {"val":" 26.01.2021 18:35:00 auto holiday at home 24°C <br> 26.01.2021 18:34:58 starting holiday at home 25°C <br> 26.01.2021
                        heatingcontrol.0	2021-01-26 18:46:28.907	debug	(27671) AddStatusToLog skip Toilette auto holiday at home 24°C
                        heatingcontrol.0	2021-01-26 18:46:28.844	debug	(27671) UpdateDPs for Toilette auto
                        heatingcontrol.0	2021-01-26 18:46:28.843	debug	(27671) HandleActors for Toilette auto
                        heatingcontrol.0	2021-01-26 18:46:28.843	debug	(27671) Change Status current temperature in Toilette to 25.5
                        heatingcontrol.0	2021-01-26 18:46:28.842	debug	(27671) Toilette ### ChangeStatus Thermostats_Current to {"val":25.5,"ack":true,"ts":1611683188435,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611682888359} in auto
                        heatingcontrol.0	2021-01-26 18:46:28.842	debug	(27671) ChangeStatus recall cmd from list Toilette Thermostats_Current {"val":25.5,"ack":true,"ts":1611683188435,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611682888359
                        heatingcontrol.0	2021-01-26 18:46:28.836	debug	(27671) Reaching SetStatusLog for Rooms.Wohnzimmer.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.835	debug	(27671) HandleStateChanges vis heatingcontrol.0.Rooms.Martin.StatusLog with 26.01.2021 18:35:00 auto holiday at home 22°C <br> 26.01.2021 18:34:58 starting holiday at home 22°C <br> 26.01.2021 18:34:
                        heatingcontrol.0	2021-01-26 18:46:28.833	debug	(27671) HandleStateChangeGeneral heatingcontrol.0.Rooms.Martin.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.833	debug	(27671) ### handle state change heatingcontrol.0.Rooms.Martin.StatusLog {"val":" 26.01.2021 18:35:00 auto holiday at home 22°C <br> 26.01.2021 18:34:58 starting holiday at home 22°C <br> 26.01.2021 18
                        heatingcontrol.0	2021-01-26 18:46:28.796	debug	(27671) AddStatusToLog skip Martin auto holiday at home 22°C
                        heatingcontrol.0	2021-01-26 18:46:28.749	debug	(27671) UpdateDPs for Martin auto
                        heatingcontrol.0	2021-01-26 18:46:28.749	debug	(27671) HandleActors for Martin auto
                        heatingcontrol.0	2021-01-26 18:46:28.748	debug	(27671) Change Status current temperature in Martin to 22.5
                        heatingcontrol.0	2021-01-26 18:46:28.746	debug	(27671) Martin ### ChangeStatus Thermostats_Current to {"val":22.5,"ack":true,"ts":1611683188414,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611683188414} in auto
                        heatingcontrol.0	2021-01-26 18:46:28.746	debug	(27671) ChangeStatus recall cmd from list Martin Thermostats_Current {"val":22.5,"ack":true,"ts":1611683188414,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611683188414}
                        heatingcontrol.0	2021-01-26 18:46:28.736	debug	(27671) Reaching SetStatusLog for Rooms.Wohnzimmer.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.735	debug	(27671) HandleStateChanges vis heatingcontrol.0.Rooms.Wohnzimmer.StatusLog with 26.01.2021 18:35:00 auto holiday at home 22°C <br> 26.01.2021 18:34:58 starting holiday at home 23°C <br> 26.01.2021 18
                        heatingcontrol.0	2021-01-26 18:46:28.735	debug	(27671) HandleStateChangeGeneral heatingcontrol.0.Rooms.Wohnzimmer.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.734	debug	(27671) ### handle state change heatingcontrol.0.Rooms.Wohnzimmer.StatusLog {"val":" 26.01.2021 18:35:00 auto holiday at home 22°C <br> 26.01.2021 18:34:58 starting holiday at home 23°C <br> 26.01.202
                        heatingcontrol.0	2021-01-26 18:46:28.704	debug	(27671) AddStatusToLog skip Wohnzimmer auto holiday at home 22°C
                        heatingcontrol.0	2021-01-26 18:46:28.689	debug	(27671) HandleStateChanges CurrentTimePeriod 9
                        heatingcontrol.0	2021-01-26 18:46:28.689	debug	(27671) HandleStateChanges vis heatingcontrol.0.Rooms.Wohnzimmer.CurrentTimePeriod with 9 refreshVis false
                        heatingcontrol.0	2021-01-26 18:46:28.688	debug	(27671) HandleStateChangeGeneral heatingcontrol.0.Rooms.Wohnzimmer.CurrentTimePeriod
                        heatingcontrol.0	2021-01-26 18:46:28.688	debug	(27671) ### handle state change heatingcontrol.0.Rooms.Wohnzimmer.CurrentTimePeriod {"val":9,"ack":false,"ts":1611683188686,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","l
                        heatingcontrol.0	2021-01-26 18:46:28.625	debug	(27671) UpdateDPs for Wohnzimmer auto
                        heatingcontrol.0	2021-01-26 18:46:28.625	debug	(27671) HandleActors for Wohnzimmer auto
                        heatingcontrol.0	2021-01-26 18:46:28.624	debug	(27671) Change Status current temperature in Wohnzimmer to 23.5
                        heatingcontrol.0	2021-01-26 18:46:28.624	debug	(27671) Wohnzimmer ### ChangeStatus Thermostats_Current to {"val":23.5,"ack":true,"ts":1611683188395,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611682888350} in auto
                        heatingcontrol.0	2021-01-26 18:46:28.623	debug	(27671) ChangeStatus recall cmd from list Wohnzimmer Thermostats_Current {"val":23.5,"ack":true,"ts":1611683188395,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":16116828883
                        heatingcontrol.0	2021-01-26 18:46:28.613	debug	(27671) Reaching SetStatusLog for Rooms.Wohnzimmer.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.612	debug	(27671) HandleStateChanges vis heatingcontrol.0.Rooms.Schlafzimmer.StatusLog with 26.01.2021 18:35:00 auto holiday at home 22°C <br> 26.01.2021 18:34:58 starting holiday at home 22°C <br> 26.01.2021
                        heatingcontrol.0	2021-01-26 18:46:28.612	debug	(27671) HandleStateChangeGeneral heatingcontrol.0.Rooms.Schlafzimmer.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.611	debug	(27671) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.StatusLog {"val":" 26.01.2021 18:35:00 auto holiday at home 22°C <br> 26.01.2021 18:34:58 starting holiday at home 22°C <br> 26.01.2
                        heatingcontrol.0	2021-01-26 18:46:28.593	debug	(27671) AddStatusToLog skip Schlafzimmer auto holiday at home 22°C
                        heatingcontrol.0	2021-01-26 18:46:28.547	debug	(27671) UpdateDPs for Schlafzimmer auto
                        heatingcontrol.0	2021-01-26 18:46:28.546	debug	(27671) HandleActors for Schlafzimmer auto
                        heatingcontrol.0	2021-01-26 18:46:28.546	debug	(27671) Change Status current temperature in Schlafzimmer to 22.5
                        heatingcontrol.0	2021-01-26 18:46:28.546	debug	(27671) Schlafzimmer ### ChangeStatus Thermostats_Current to {"val":22.5,"ack":true,"ts":1611683188376,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611677488330} in auto
                        heatingcontrol.0	2021-01-26 18:46:28.545	debug	(27671) ChangeStatus recall cmd from list Schlafzimmer Thermostats_Current {"val":22.5,"ack":true,"ts":1611683188376,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":161167748
                        heatingcontrol.0	2021-01-26 18:46:28.528	debug	(27671) Reaching SetStatusLog for Rooms.Wohnzimmer.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.525	debug	(27671) HandleStateChanges vis heatingcontrol.0.Rooms.Julia.StatusLog with 26.01.2021 18:35:00 auto holiday at home 21°C <br> 26.01.2021 18:34:58 starting holiday at home 21°C <br> 26.01.2021 18:34:5
                        heatingcontrol.0	2021-01-26 18:46:28.524	debug	(27671) HandleStateChangeGeneral heatingcontrol.0.Rooms.Julia.StatusLog
                        heatingcontrol.0	2021-01-26 18:46:28.524	debug	(27671) ### handle state change heatingcontrol.0.Rooms.Julia.StatusLog {"val":" 26.01.2021 18:35:00 auto holiday at home 21°C <br> 26.01.2021 18:34:58 starting holiday at home 21°C <br> 26.01.2021 18:
                        heatingcontrol.0	2021-01-26 18:46:28.503	warn	(27671) !!! Statechange not handled fritzdect.0.DECT_2E:B9:36-900.tsoll {"val":22,"ack":true,"ts":1611683188453,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611682499986}
                        heatingcontrol.0	2021-01-26 18:46:28.502	warn	(27671) !!! Statechange not handled fritzdect.0.DECT_119610273248.tsoll {"val":24,"ack":true,"ts":1611683188436,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611682500235}
                        heatingcontrol.0	2021-01-26 18:46:28.501	debug	(27671) ChangeStatus called, while already changing, push to list Toilette Thermostats_Current {"val":25.5,"ack":true,"ts":1611683188435,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.a
                        heatingcontrol.0	2021-01-26 18:46:28.458	debug	(27671) AddStatusToLog skip Julia auto holiday at home 21°C
                        heatingcontrol.0	2021-01-26 18:46:28.424	debug	(27671) ChangeStatus called, while already changing, push to list Martin Thermostats_Current {"val":22.5,"ack":true,"ts":1611683188414,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.adm
                        heatingcontrol.0	2021-01-26 18:46:28.405	debug	(27671) ChangeStatus called, while already changing, push to list Wohnzimmer Thermostats_Current {"val":23.5,"ack":true,"ts":1611683188395,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user
                        heatingcontrol.0	2021-01-26 18:46:28.381	debug	(27671) ChangeStatus called, while already changing, push to list Schlafzimmer Thermostats_Current {"val":22.5,"ack":true,"ts":1611683188376,"q":0,"from":"system.adapter.fritzdect.0","user":"system.us
                        heatingcontrol.0	2021-01-26 18:46:28.360	debug	(27671) UpdateDPs for Julia auto
                        heatingcontrol.0	2021-01-26 18:46:28.359	debug	(27671) HandleActors for Julia auto
                        heatingcontrol.0	2021-01-26 18:46:28.359	debug	(27671) Change Status current temperature in Julia to 22
                        heatingcontrol.0	2021-01-26 18:46:28.359	debug	(27671) Julia ### ChangeStatus Thermostats_Current to {"val":22,"ack":true,"ts":1611683188354,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1611679888339} in auto
                        • ChaotC Chaot
                          Etwas länger:
                          Rene_HMR
                          Rene_HMR
                          Rene_HM
                          #2023
                          @chaot sagte in Test Adapter HeatingControl v2.0.x:
                          welche Einstellung hast du hier?
                          • Rene_HMR Rene_HM
                            ChaotC
                            ChaotC
                            Chaot
                            #2024
                            @rene_hm steht auf "nicht" und alle Haken weg.
                            AAAAber - ich habe gerade den gesamten Container neu gestartet nach einem Linux Update. Jetzt scheint der Fehler nicht mehr aufzutauchen.
                            • ChaotC Chaot
                              Rene_HMR
                              Rene_HMR
                              Rene_HM
                              #2025
                              @chaot und das war vor dem update auch so?
                              • Rene_HMR Rene_HM
                                ChaotC
                                ChaotC
                                Chaot
                                #2026
                                @rene_hm Die Einstellung habe ich nicht geändert und war vorher auch so. Vielleicht hat sich irgendwas aufgehängt das durch den Neustart jetzt weg ist.
                                Mal abwarten. Bisher hat er den Fehler alle 5 Minuten gesetzt. Jetzt läuft er aktuell etwas über eine Stunde ohne Fehler bzw. Warnmeldung. Nächster geplanter Schaltpunkt ist 21 Uhr. Wenn er danach auch noch ohne Fehler bleibt lag es vermutlich am Neustart.
                                • ChaotC Chaot
                                  Rene_HMR
                                  Rene_HMR
                                  Rene_HM
                                  #2027
                                  @chaot hattest du den Adapter nach Installation nochmal neu gestartet? Die Warnung kommt, weil die aktuelle Soll-Temperatur, die vom Thermostat regelmässig geschickt wird, nicht behandelt wird. Die sollte aber gar nicht bis zum Adapter gemeldet werden, wenn wie oben geschrieben, "nichts" konfiguriert ist
                                  ChaotC 4 Antworten Letzte Antwort
                                  • Rene_HMR Rene_HM
                                    ChaotC
                                    ChaotC
                                    Chaot
                                    #2028
                                    @rene_hm Nein.
                                    Und jetzt ist der Schaltpunkt gekommen und die Meldung ist wieder da.
                                    • Rene_HMR Rene_HM
                                      ChaotC
                                      ChaotC
                                      Chaot
                                      #2029
                                      @rene_hm Das ist ja nur eine Warnmeldung. Der Adapter dürfte ja theoretisch die States gar nicht verarbeiten und meldet das.
                                      Kann das mit dem Update vom JS Contoller zu tun haben? Da wurde ja viel geschraubt.
                                      Oh, nochwas:
                                      Es werden nur die Thermostate gemeldet.
                                      Da wird auch noch eine Gruppe gesteuert. Die taucht in der meldung nicht auf.
                                      Die Meldung kommt übrigens exakt alle 5 Minuten
                                      • Rene_HMR Rene_HM
                                        ChaotC
                                        ChaotC
                                        Chaot
                                        #2030
                                        @rene_hm
                                        Ich glaube ich habe was gefunden.
                                        Als ich die Thermostate eingerichtet habe habe ich den Namen der Thermostate nicht verändert, weil das beim Wählen des Datenpunkts sich automatisch geändert hat.
                                        Jetzt habe ich den Namen manuell eingegeben und plötzlich war die Meldung weg.
                                        Einen Raum habe ich falsch benannt. Der wurde mir weiterhin gemeldet bis ich den exakt so wie in der Geräteliste benannt habe.
                                        Die Datenpunkte werden trotzdem geschaltet. Auch wenn da nichts oder Quatsch drinsteht. Nur kommt dann eben diese Meldung.
                                        • T
                                          T
                                          Tschak
                                          #2031
                                          ich hoffe das ist keine Dumme Frage aber ich beschäftige mich mit iBroker erst seit Anfang dieses Jahres und komme nun zu der Herausforderung Thermostate und Stellantriebe. Ich würde dieses System gerne in Verbindung mit KNX Sensoren und Aktoren verwenden. Wie kann ich einen Stellwert welcher am KNX Thermostat Sensor vorübergehend eingestellt wird auch in den Adapter übernehmen?
