js-controller 3.2 jetzt im Latest!
Auch beim Zugriff auf den Admin kommt es mir so vor, dass er länger lädt bis alles komplett aufgebaut ist.
Das Gefühl habe ich auch seit der 3.2!
Hallo kann das jemand nachvollziehen?
C:\Program Files\iobroker\iobroker003>iobroker status all iobroker is running on this host. SYSTEM/memoryLimitMB: 0 SYSTEM/hostname: HP-ED800(iobroker003) NETWORK/IPv4: true NETWORK/IPv6: true NETWORK/useSystemNpm: true OBJECTS/type: file OBJECTS/host: 127.0.0.1 OBJECTS/port: 9001 OBJECTS/user: OBJECTS/pass: OBJECTS/noFileCache: false OBJECTS/connectTimeout: 2000 OBJECTS/OPTIONS/retryStrategy: reconnectCount => { if (!ready && initError && ignoreErrors) { return new Error('No more tries'); } if (this.stop) { return new Error('Client has stopped ... no retries anymore'); } if (ready && reconnectCount >= retry_max_count) { return new Error('Stop trying to reconnect'); } // A function that receives an options object as parameter including the retry attempt, // the total_retry_time indicating how much time passed since the last time connected, // the error why the connection was lost and the number of times_connected in total. // If you return a number from this function, the retry will happen exactly after that // time in milliseconds. If you return a non-number, no further retry will happen and // all offline commands are flushed with errors. Return an error to return that // specific error to all offline commands. if (!ready) { return 300; } else { return retry_max_delay; } /*if (options.error.code === 'ECONNREFUSED') { // End reconnecting on a specific error and flush all commands with a individual error return new Error('The server refused the connection'); } if (options.total_retry_time > 1000 * 60 * 60) { // End reconnecting after a specific timeout and flush all commands with a individual error return new Error('Retry time exhausted'); } if (options.times_connected > 10) { // End reconnecting with built in error return undefined; } // reconnect after return Math.max(options.attempt * 100, 3000);*/ } OBJECTS/OPTIONS/enableReadyCheck: true OBJECTS/OPTIONS/host: 127.0.0.1 OBJECTS/OPTIONS/port: 9001 OBJECTS/OPTIONS/db: 0 OBJECTS/OPTIONS/family: 0 OBJECTS/OPTIONS/autoResubscribe: false OBJECTS/OPTIONS/connectionName: OBJECTS/maxQueue: 1000 STATES/type: file STATES/host: 127.0.0.1 STATES/port: 9000 STATES/maxQueue: 1000 STATES/OPTIONS/retryStrategy: reconnectCount => { if (!ready && initError) { return new Error('No more tries'); } if (this.stop) { return new Error('Client has stopped ... no retries anymore'); } if (ready && reconnectCount >= retry_max_count) { return new Error('Stop trying to reconnect'); } // A function that receives an options object as parameter including the retry attempt, // the total_retry_time indicating how much time passed since the last time connected, // the error why the connection was lost and the number of times_connected in total. // If you return a number from this function, the retry will happen exactly after that // time in milliseconds. If you return a non-number, no further retry will happen and // all offline commands are flushed with errors. Return an error to return that // specific error to all offline commands. if (!ready) { return 300; } return retry_max_delay; /*if (options.error.code === 'ECONNREFUSED') { // End reconnecting on a specific error and flush all commands with a individual error return new Error('The server refused the connection'); } if (options.total_retry_time > 1000 * 60 * 60) { // End reconnecting after a specific timeout and flush all commands with a individual error return new Error('Retry time exhausted'); } if (options.times_connected > 10) { // End reconnecting with built in error return undefined; } // reconnect after return Math.max(options.attempt * 100, 3000);*/ } STATES/OPTIONS/enableReadyCheck: true STATES/OPTIONS/host: 127.0.0.1 STATES/OPTIONS/port: 9000 STATES/OPTIONS/db: 0 STATES/OPTIONS/family: 0 STATES/OPTIONS/autoResubscribe: false STATES/OPTIONS/connectionName: LOG/level: info LOG/maxDays: 7 LOG/noStdout: true LOG/TRANSPORT/FILE1/type: file LOG/TRANSPORT/FILE1/enabled: true LOG/TRANSPORT/FILE1/filename: log/iobroker LOG/TRANSPORT/FILE1/fileext: .log LOG/TRANSPORT/SYSLOG1/type: syslog LOG/TRANSPORT/SYSLOG1/enabled: false LOG/TRANSPORT/SYSLOG1/host: localhost LOG/TRANSPORT/SYSLOG1/protocol: udp4 LOG/TRANSPORT/SYSLOG1/localhost: iobroker dataDir: ../../iobroker-data/ C:\Program Files\iobroker\iobroker003>Ausser obige Auffälligkeit läuft die 3.2.11 unter Windows problemfrei.
@unclesam sagte in js-controller 3.2 jetzt im Latest!:
@diginix Zu LE: das ist bekannt und lässt sich (ohne Fix in Greenlock) nicht beheben. Einzige Möglichkeit ist, auch lokal auf Port 443 zu wechseln.
Wo soll ich denn den Port 443 noch einstellen bzw auf ihn wechseln?
In der web.0 Instanz ist er ja schon eingetragen wegen LE.
Admin nutzt https aber eben mit 8081 und den default Zertifikaten.Bis JS-Controller 3.1 waren die lokalen URLs für flot, materialui usw. auch mit https Protokoll:
https://192.168.2.47/flot/preset.html
Da kommt aber nun als FehlerERR_SSL_VERSION_OR_CIPHER_MISMATCHUnd mit Port 80
ERR_EMPTY_RESPONSEAuch ohne Fix wäre ich über ein Workaround sehr dankbar. Ich fürchte der Fix lässt länger auf sich warten.
@uwerlp sagte in js-controller 3.2 jetzt im Latest!:
Was ist die Auffälligkeit?
status "all" liefert genau diese Ausgabe .. es fehlen glaube ich nur die Instanzen noch dazu
Diese Ausgabe
OBJECTS/OPTIONS/retryStrategy: reconnectCount => { if (!ready && initError && ignoreErrors) { return new Error('No more tries'); } if (this.stop) { return new Error('Client has stopped ... no retries anymore'); } if (ready && reconnectCount >= retry_max_count) { return new Error('Stop trying to reconnect'); } // A function that receives an options object as parameter including the retry attempt, // the total_retry_time indicating how much time passed since the last time connected, // the error why the connection was lost and the number of times_connected in total. // If you return a number from this function, the retry will happen exactly after that // time in milliseconds. If you return a non-number, no further retry will happen and // all offline commands are flushed with errors. Return an error to return that // specific error to all offline commands. if (!ready) { return 300; } else { return retry_max_delay; } /*if (options.error.code === 'ECONNREFUSED') { // End reconnecting on a specific error and flush all commands with a individual error return new Error('The server refused the connection'); } if (options.total_retry_time > 1000 * 60 * 60) { // End reconnecting after a specific timeout and flush all commands with a individual error return new Error('Retry time exhausted'); } if (options.times_connected > 10) { // End reconnecting with built in error return undefined; } // reconnect after return Math.max(options.attempt * 100, 3000);*/ }und das
STATES/OPTIONS/retryStrategy: reconnectCount => { if (!ready && initError) { return new Error('No more tries'); } if (this.stop) { return new Error('Client has stopped ... no retries anymore'); } if (ready && reconnectCount >= retry_max_count) { return new Error('Stop trying to reconnect'); } // A function that receives an options object as parameter including the retry attempt, // the total_retry_time indicating how much time passed since the last time connected, // the error why the connection was lost and the number of times_connected in total. // If you return a number from this function, the retry will happen exactly after that // time in milliseconds. If you return a non-number, no further retry will happen and // all offline commands are flushed with errors. Return an error to return that // specific error to all offline commands. if (!ready) { return 300; } return retry_max_delay; /*if (options.error.code === 'ECONNREFUSED') { // End reconnecting on a specific error and flush all commands with a individual error return new Error('The server refused the connection'); } if (options.total_retry_time > 1000 * 60 * 60) { // End reconnecting after a specific timeout and flush all commands with a individual error return new Error('Retry time exhausted'); } if (options.times_connected > 10) { // End reconnecting with built in error return undefined; } // reconnect after return Math.max(options.attempt * 100, 3000);*/ }habe ich als Fehlermeldung interpretiert.
Wenn die Ausgabe so in Ordnung ist dann mein Fehler
Diese Ausgabe
Diese Ausgabe
@uwerlp
Nicht alles wo das Wort 'Error' drin vorkommt ist auch eine Error-Meldung.
Das was du da gefunden hast ist doch nur die retryStrategy für den Fall, das die aufgeführten Errors im System auftauchen. -
ich habe seit dem Update (hab aber zusätzlich auch apt update und upgrade gemacht) das "Problem", dass bei TOP nur noch "node" steht und nicht mehr, was dahinter steckt?
@exectix sagte in js-controller 3.2 jetzt im Latest!:
@apollon77 @eXectiX Vermutlich hängt es mit dem Fully Browser zusammen. Heute Nachmittag lief meine eigentliche Produktivinstanz auch deutlich träger als sonst. Nachdem ich den Fully Browser dann zu und wieder auf gemacht habe war es wieder flotter. Hat also erstmal nichts mit dem js-controller zu tun, werde vermutlich ein neue Diskussion dazu aufmachen.
@diginix Was ich nicht verstehe: wieso benutzt du LE für interne Server? LE ist ja eigentlich für externe Server gedacht und da gibt es nur einen Port 443. Oder wie löst du das? Split-Horizon-DNS?
Ich habe eine myfritz Domain mit der ich von außen auf MaterialUI zugreife und für die ist auch das LE Cert.
Aber wenn ich im Heimnetz bin habe ich bisher dann logischerweise lokale IPs genutzt.
Wozu gibt es LE denn, wenn nicht genau für das was ich damit mache?
Es klang so, als ob man weiterhin parallel auch lokale IPs nutzen könne, auch ohne, dass greenlock ein Fix erhält. -
Es klang so, als ob man weiterhin parallel auch lokale IPs nutzen könne, auch ohne, dass greenlock ein Fix erhält.@diginix mal ne blöde Frage: wenn du lokal zugreifst per ip kam Dann bisher immer eine ssl Warnung oder?! Weil der Domain Name hat ja nicht gepasst oder?!
Aber ja die Änderung ist scheinbar das jetzt nur noch der fqdn Zugriff von Greenlock verarbeitet wird und nicht einfach die certs so genutzt werden. :-(
@apollon77 Ja, genau der Browser hat das nat. bemerkt und als unsicher markiert, aber der Webserver hat ja geliefert. Was er eben nun nicht mehr macht.
@diginix Ja das ist blöd, mal schauen ob wir was hinbekommen. Effektiv ists aber so ne Sache. Sauberer wäre eine web Instanz zu haben die du von extern nutzt und eine andere für Lokal :-)
@apollon77 Supi.
Würde denn eine zweite web Instanz Stand heute etwas nützen?
Wär ja kein Problem die zu installierend, LE darin nicht zu aktivieren und z.B. Port 80 zu verwenden.
Aber kommen die anderen Frontend Adapter damit klar? -
@apollon77 Supi.
@diginix Am Ende kannst Du denke die gleichen alle über die andere Web Instanz auch erreichen ... musst nur angeben das es alle web's sind und nicht nur eine Instanz
@apollon77
Bei den betroffenen Instanzen kann man doch aber gar nicht auswählen mit welcher web Instanz sie arbeiten:
Oder was meinst du mit "angeben dass es alle web's sind..."?
@apollon77
@apollon77 Oh man das war jetzt echt zu einfach!
Bist mein Held!
ist jetzt ja noch besser als vorher, weil ohne Login möglich und sauber mit http auf Port 80 oder ein anderer freier. -
@apollon77
Wird es die 3.2.12 kurzfristig geben? Dann spare ich mir nämlich das Update auf die .11.
