  4. js-controller 3.2 jetzt im Latest!
575 Beiträge 70 Kommentatoren 210.1k Aufrufe 57 Beobachtet
  • FeuersturmF
    FeuersturmF
    Feuersturm
    @apollon77 Heute um 17.00 Uhr hat der DWD Adapter folgendes gemeldet:
    2021-01-17 17:00:31.794 - info: dwd.0 (15026) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.18.3, js-controller: 3.2.7
    2021-01-17 17:00:32.375 - info: dwd.0 (15026) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-01-17 17:00:32.974 - warn: dwd.0 (15026) get state Error: Connection is closed.
    2021-01-17 17:00:32.979 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.980 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.981 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.982 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.986 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.991 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.993 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.994 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.997 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:32.998 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.001 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.002 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.004 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.005 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.007 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.008 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.009 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.015 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.016 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.017 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.018 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.019 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.020 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.027 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.028 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.029 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.030 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.031 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.032 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.033 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.039 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.040 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.041 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.042 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.047 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.048 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.049 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.050 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.056 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.057 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.058 - warn: dwd.0 (15026) get state Error: DB closed
    2021-01-17 17:00:33.162 - info: host.beebox(iobrokerMaster) instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Davor und danach war alles ruhig im Log.
    • N Noell
      zwave2.0 Adapter läuft nicht mit dieser Version. Folgende Fehlermeldung wird ausgegeen wenn der Adapter gestartet wird. "Failed to load the configuration: config_1.loadDeviceClasses is not a function"
      apollon77A
      apollon77A
      @noell Also bei anderen tut es. Bitte am besten mal schauen und die aktuelle version von zwave2 neu installieren bzw updaten
      N 1 Antwort Letzte Antwort
      • FeuersturmF Feuersturm
        apollon77A
        apollon77A
        @feuersturm ich schaue nochmal was da ist in dwd
        • apollon77A apollon77
          N
          N
          Noell
          schrieb am zuletzt editiert von Noell
          @apollon77 Ja da scheint bei mir was anderes defekt zu sein, es liegt nicht an der 3.2.7. Der Adapter läuft jetzt nach der neu Installation.
          Tom SonT 1 Antwort Letzte Antwort
          • N Noell
            Tom SonT
            Tom SonT
            Tom Son
            Hi all
            Bei mir läuft soweit auch alles "fast" nur der Vaillant Adapter hat was aus zu setzten seit dem, kann das mit dem Update zusammen hängen?
            host.Surface-3	2021-01-17 19:36:37.283	info	instance system.adapter.vaillant.0 started with pid 59903
            host.Surface-3	2021-01-17 19:36:07.226	info	Restart adapter system.adapter.vaillant.0 because enabled
            host.Surface-3	2021-01-17 19:36:07.225	error	instance system.adapter.vaillant.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            vaillant.0	2021-01-17 19:36:06.540	error	(59709) The state contains no properties! At least one property is expected!
            vaillant.0	2021-01-17 19:36:06.540	error	(59709) Error: The state contains no properties! At least one property is expected! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5783:23)
            vaillant.0	2021-01-17 19:36:06.536	error	(59709) unhandled promise rejection: The state contains no properties! At least one property is expected!
            vaillant.0	2021-01-17 19:36:06.534	error	(59709) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            TI Board CC2652R1 / latest / js-Controler 3.3.18 / NodeJS 12.22.7
            amg_666A apollon77A 2 Antworten Letzte Antwort
            • Tom SonT Tom Son
              Hi all
              amg_666A
              amg_666A
              amg_666
              @apollon77 ICh hatte das erst als "normales" Problem unter allgemein gepostet, hoffe ich bin hier richtig :-)
              System mit 3 Raspi Pi 3b+, alle auf js-controller 3.1.6 und node.js v12.19.0). Habe einen Slave upgegradet und da Probleme mit plenticore adapter:
              plenticore.0	2021-01-17 20:52:11.674	error	(18379) Cannot check object existence of "plenticore.0.info.connection": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.672	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.YieldYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.671	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyToGridYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.670	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.YieldTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.669	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyToGridTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.668	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.YieldMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.666	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyToGridMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.665	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.YieldDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.664	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyToGridDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.663	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.OwnConsumptionRateYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.662	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.OwnConsumptionRateTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.659	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.OwnConsumptionRateMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.658	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.OwnConsumptionRateDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.657	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomePvYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.656	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomePvTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.655	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomePvMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.654	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomePvDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.653	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeGridYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.652	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeGridTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.651	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeGridMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.650	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeGridDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.649	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeBatYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.648	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeBatTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.646	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeBatMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.645	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeBatDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.643	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.642	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.640	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.639	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.EnergyHomeDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.638	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.CO2SavingYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.637	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.CO2SavingTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.636	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.CO2SavingMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.634	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.CO2SavingDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.633	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.AutarkyYear": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.632	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.AutarkyTotal": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.631	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.AutarkyMonth": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.630	error	(18379) Cannot check object existence of "plenticore.0.scb.statistic.EnergyFlow.AutarkyDay": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.629	error	(18379) Cannot check object existence of "plenticore.0.scb.export.PortalConActive": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.628	error	(18379) Cannot check object existence of "plenticore.0.devices.local.pv2.U": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.627	error	(18379) Cannot check object existence of "plenticore.0.devices.local.pv2.P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.601	error	(18379) Cannot check object existence of "plenticore.0.devices.local.pv2.I": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.601	error	(18379) Cannot check object existence of "plenticore.0.devices.local.pv1.U": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.600	error	(18379) Cannot check object existence of "plenticore.0.devices.local.pv1.P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.599	error	(18379) Cannot check object existence of "plenticore.0.devices.local.pv1.I": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.598	error	(18379) Cannot check object existence of "plenticore.0.devices.local.battery.U": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.597	error	(18379) Cannot check object existence of "plenticore.0.devices.local.battery.SoC": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.596	error	(18379) Cannot check object existence of "plenticore.0.devices.local.battery.P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.595	error	(18379) Cannot check object existence of "plenticore.0.devices.local.battery.I": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.595	error	(18379) Cannot check object existence of "plenticore.0.devices.local.battery.Cycles": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.594	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.S": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.593	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.Q": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.592	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.591	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ToGrid_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.590	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L3_U": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.589	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L3_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.589	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L3_I": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.588	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L2_U": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.587	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L2_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.586	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L2_I": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.585	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L1_U": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.584	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L1_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.584	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.L1_I": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.583	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.Frequency": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.582	error	(18379) Cannot check object existence of "plenticore.0.devices.local.ac.CosPhi": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.581	error	(18379) Cannot check object existence of "plenticore.0.devices.local.LimitEvuAbs": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.580	error	(18379) Cannot check object existence of "plenticore.0.devices.local.inverter.State": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.579	error	(18379) Cannot check object existence of "plenticore.0.devices.local.Home_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.579	error	(18379) Cannot check object existence of "plenticore.0.devices.local.HomePv_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.578	error	(18379) Cannot check object existence of "plenticore.0.devices.local.HomeOwn_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.577	error	(18379) Cannot check object existence of "plenticore.0.devices.local.HomeGrid_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.576	error	(18379) Cannot check object existence of "plenticore.0.devices.local.HomeBat_P": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.575	error	(18379) Cannot check object existence of "plenticore.0.devices.local.EM_State": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.574	error	(18379) Cannot check object existence of "plenticore.0.devices.local.DigitalIn": ReplyError: Error exists NOT SUPPORTED
              plenticore.0	2021-01-17 20:52:11.572	error	(18379) Cannot check object existence of "plenticore.0.devices.local.Dc_P": ReplyError: Error exists NOT SUPPORTED
              Thomas BraunT apollon77A M 3 Antworten Letzte Antwort
              • amg_666A amg_666
                Thomas BraunT
                Thomas BraunT
                Most Active Developer
                @amg_666 Du hast doch in dem anderen Threads schon gesagt bekommen, was zu tun ist bzw. was du ggf. falsch machst.
                • Tom SonT Tom Son
                  Hi all
                  apollon77A
                  apollon77A
                  @tom-son Bitte beim Adapter ein Issue anlegen
                  • amg_666A amg_666
                    apollon77A
                    apollon77A
                    @amg_666 Bitte beim Adapter ein Issue anlegen
                      lobomauL
                      lobomauL
                      lobomau
                      @apollon77 3.2.7. läuft bei mir den ganzen Tag ohne Probleme. Ohne krumme Version klappt auch wieder das Adapter-Update 👍
                      ioBroker als Container unter Proxmox kann ich nur empfehlen 😁
                      Host: NUC8i3 mit Proxmox:
                      • Slave: Pi4
                      • FeuersturmF
                        FeuersturmF
                        Feuersturm
                        @apollon77
                        Gerade hat sich der COVID-19 live information Adapter ( @Dutchman ) zu Wort gemeldet. Ist das ein Adapter oder ein js-controller Thema?
                        coronavirus-statistics.0	2021-01-17 22:45:45.398	info	(17994) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        coronavirus-statistics.0	2021-01-17 22:45:38.861	error	at Covid19.onReady (/opt/iobroker/node_modules/iobroker.coronavirus-statistics/main.js:599:5)
                        coronavirus-statistics.0	2021-01-17 22:45:38.861	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                        coronavirus-statistics.0	2021-01-17 22:45:38.861	error	at runMicrotasks (<anonymous>)
                        coronavirus-statistics.0	2021-01-17 22:45:38.861	error	at germanyBundersland (/opt/iobroker/node_modules/iobroker.coronavirus-statistics/main.js:314:35)
                        coronavirus-statistics.0	2021-01-17 22:45:38.861	error	(17994) [germanyFederalStates] error: values.features is not iterable, stack: TypeError: values.features is not iterable
                        Issue: https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/issues/158
                        apollon77A DutchmanD 2 Antworten Letzte Antwort
                          @apollon77
                          apollon77A
                          apollon77A
                          @feuersturm Eindeutig Adapter
                            @apollon77
                            DutchmanD
                            DutchmanD
                            Dutchman
                            @feuersturm said in js-controller 3.2 jetzt im Latest!:
                            Gerade hat sich der COVID-19 live information Adapter ( Dutchman ) zu Wort gemeldet. Ist das ein Adapter oder ein js-controller Thema?
                            Thanks fürs git issue kümmern mich drum
                            P 1 Antwort Letzte Antwort
                            • DutchmanD Dutchman
                              P
                              P
                              PrinzEisenherz1
                              Hab jetzt unter js-controller 3.2.7 schon das zweite mal folgenden fehler vom dwd-Adapter
                              2021-01-18 00:00:14.153 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.begin": Error: Connection is closed.
                              2021-01-18 00:00:14.163 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.end": Error: Connection is closed.
                              2021-01-18 00:00:14.167 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.severity": Error: Connection is closed.
                              2021-01-18 00:00:14.168 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.level": Error: Connection is closed.
                              2021-01-18 00:00:14.169 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.type": Error: Connection is closed.
                              2021-01-18 00:00:14.170 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.text": Error: Connection is closed.
                              2021-01-18 00:00:14.171 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.headline": Error: Connection is closed.
                              2021-01-18 00:00:14.171 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.description": Error: Connection is closed.
                              2021-01-18 00:00:14.175 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.object": Error: Connection is closed.
                              2021-01-18 00:00:14.177 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning.map": Error: Connection is closed.
                              2021-01-18 00:00:14.200 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.begin": Error: Connection is closed.
                              2021-01-18 00:00:14.200 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.end": Error: Connection is closed.
                              2021-01-18 00:00:14.201 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.severity": Error: Connection is closed.
                              2021-01-18 00:00:14.201 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.level": Error: Connection is closed.
                              2021-01-18 00:00:14.211 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.type": Error: Connection is closed.
                              2021-01-18 00:00:14.212 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.text": Error: Connection is closed.
                              2021-01-18 00:00:14.212 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.headline": Error: Connection is closed.
                              2021-01-18 00:00:14.212 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.description": Error: Connection is closed.
                              2021-01-18 00:00:14.213 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.object": Error: Connection is closed.
                              2021-01-18 00:00:14.213 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning1.map": Error: Connection is closed.
                              2021-01-18 00:00:14.214 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.begin": Error: Connection is closed.
                              2021-01-18 00:00:14.214 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.end": Error: Connection is closed.
                              2021-01-18 00:00:14.215 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.severity": Error: Connection is closed.
                              2021-01-18 00:00:14.215 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.level": Error: Connection is closed.
                              2021-01-18 00:00:14.215 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.type": Error: Connection is closed.
                              2021-01-18 00:00:14.216 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.text": Error: Connection is closed.
                              2021-01-18 00:00:14.216 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.headline": Error: Connection is closed.
                              2021-01-18 00:00:14.216 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.description": Error: Connection is closed.
                              2021-01-18 00:00:14.217 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.object": Error: Connection is closed.
                              2021-01-18 00:00:14.217 - error: dwd.0 (5122) Cannot check object existence of "dwd.0.warning2.map": Error: Connection is closed.
                              2021-01-18 00:00:14.218 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.numberofwarnings: Error: Cannot check object existence of "dwd.0.numberofwarnings": Error: Connection is closed.
                              2021-01-18 00:00:14.223 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.begin: Error: Cannot check object existence of "dwd.0.warning.begin": Error: Connection is closed.
                              2021-01-18 00:00:14.224 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.end: Error: Cannot check object existence of "dwd.0.warning.end": Error: Connection is closed.
                              2021-01-18 00:00:14.225 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.severity: Error: Cannot check object existence of "dwd.0.warning.severity": Error: Connection is closed.
                              2021-01-18 00:00:14.225 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.level: Error: Cannot check object existence of "dwd.0.warning.level": Error: Connection is closed.
                              2021-01-18 00:00:14.226 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.type: Error: Cannot check object existence of "dwd.0.warning.type": Error: Connection is closed.
                              2021-01-18 00:00:14.227 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.text: Error: Cannot check object existence of "dwd.0.warning.text": Error: Connection is closed.
                              2021-01-18 00:00:14.228 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.headline: Error: Cannot check object existence of "dwd.0.warning.headline": Error: Connection is closed.
                              2021-01-18 00:00:14.259 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.description: Error: Cannot check object existence of "dwd.0.warning.description": Error: Connection is closed.
                              2021-01-18 00:00:14.260 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.object: Error: Cannot check object existence of "dwd.0.warning.object": Error: Connection is closed.
                              2021-01-18 00:00:14.260 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning.map: Error: Cannot check object existence of "dwd.0.warning.map": Error: Connection is closed.
                              2021-01-18 00:00:14.261 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.begin: Error: Cannot check object existence of "dwd.0.warning1.begin": Error: Connection is closed.
                              2021-01-18 00:00:14.262 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.end: Error: Cannot check object existence of "dwd.0.warning1.end": Error: Connection is closed.
                              2021-01-18 00:00:14.263 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.severity: Error: Cannot check object existence of "dwd.0.warning1.severity": Error: Connection is closed.
                              2021-01-18 00:00:14.264 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.level: Error: Cannot check object existence of "dwd.0.warning1.level": Error: Connection is closed.
                              2021-01-18 00:00:14.264 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.type: Error: Cannot check object existence of "dwd.0.warning1.type": Error: Connection is closed.
                              2021-01-18 00:00:14.265 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.text: Error: Cannot check object existence of "dwd.0.warning1.text": Error: Connection is closed.
                              2021-01-18 00:00:14.266 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.headline: Error: Cannot check object existence of "dwd.0.warning1.headline": Error: Connection is closed.
                              2021-01-18 00:00:14.311 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.description: Error: Cannot check object existence of "dwd.0.warning1.description": Error: Connection is closed.
                              2021-01-18 00:00:14.312 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.object: Error: Cannot check object existence of "dwd.0.warning1.object": Error: Connection is closed.
                              2021-01-18 00:00:14.313 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning1.map: Error: Cannot check object existence of "dwd.0.warning1.map": Error: Connection is closed.
                              2021-01-18 00:00:14.314 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.begin: Error: Cannot check object existence of "dwd.0.warning2.begin": Error: Connection is closed.
                              2021-01-18 00:00:14.315 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.end: Error: Cannot check object existence of "dwd.0.warning2.end": Error: Connection is closed.
                              2021-01-18 00:00:14.316 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.severity: Error: Cannot check object existence of "dwd.0.warning2.severity": Error: Connection is closed.
                              2021-01-18 00:00:14.316 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.level: Error: Cannot check object existence of "dwd.0.warning2.level": Error: Connection is closed.
                              2021-01-18 00:00:14.317 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.type: Error: Cannot check object existence of "dwd.0.warning2.type": Error: Connection is closed.
                              2021-01-18 00:00:14.318 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.text: Error: Cannot check object existence of "dwd.0.warning2.text": Error: Connection is closed.
                              2021-01-18 00:00:14.335 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.headline: Error: Cannot check object existence of "dwd.0.warning2.headline": Error: Connection is closed.
                              2021-01-18 00:00:14.336 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.description: Error: Cannot check object existence of "dwd.0.warning2.description": Error: Connection is closed.
                              2021-01-18 00:00:14.337 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.object: Error: Cannot check object existence of "dwd.0.warning2.object": Error: Connection is closed.
                              2021-01-18 00:00:14.337 - warn: dwd.0 (5122) Could not check object existence of state dwd.0.warning2.map: Error: Cannot check object existence of "dwd.0.warning2.map": Error: Connection is closed.
                              2021-01-18 00:00:14.373 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.374 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.444 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6307:35)
                              2021-01-18 00:00:14.445 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.474 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.475 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.476 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.477 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.484 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.486 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.487 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.488 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.494 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.504 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.506 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.506 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.511 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.513 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.515 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.515 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.520 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.520 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.521 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.522 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.531 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.532 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.544 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.545 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.555 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.556 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.557 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.558 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.588 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.590 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.591 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.592 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.606 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.607 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.608 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.609 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.618 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.619 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.622 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.622 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.628 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.629 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.632 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.633 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.637 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.640 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.642 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.644 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.664 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.665 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.667 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.670 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.678 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.679 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.681 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.692 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.699 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.700 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.702 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.703 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.812 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.812 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.814 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.831 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.836 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.837 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.838 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.839 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.844 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.845 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.846 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.847 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.852 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.853 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.855 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.856 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.862 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.863 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.864 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.865 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.870 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.871 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.872 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.873 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.877 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.878 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.879 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.880 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.893 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.894 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.907 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.908 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.915 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.916 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.917 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.918 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.929 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.929 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.934 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.935 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.940 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.940 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.942 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.943 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.952 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.953 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.955 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.955 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.965 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.971 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.972 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.973 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:14.994 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:14.995 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.996 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:14.997 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              2021-01-18 00:00:15.028 - error: dwd.0 (5122) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-01-18 00:00:15.029 - error: dwd.0 (5122) unhandled promise rejection: Cannot read property 'setState' of null
                              2021-01-18 00:00:15.030 - error: dwd.0 (5122) TypeError: Cannot read property 'setState' of null
                              2021-01-18 00:00:15.031 - error: dwd.0 (5122) Cannot read property 'setState' of null
                              Woran liegts? controller oder Adapter?
                              Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                              • P PrinzEisenherz1
                                apollon77A
                                apollon77A
                                @prinzeisenherz1 Bitte mal die dwd Github version versuchen. Besser? Habe da im Adapter etwas nachgearbeitet
                                P FeuersturmF 2 Antworten Letzte Antwort
                                  P
                                  P
                                  PrinzEisenherz1
                                  @apollon77 probier ich später. Brauche jetzt n Bett. 🥱
                                  • P PrinzEisenherz1
                                    Ich bekomme folgenden Fehler angezeigt und iobroker startet nicht mehr.
                                    2021-01-18 07:14:34.463  - error: host.Collector Cannot read property 'storeNotifications' of undefined
                                    TypeError: Cannot read property 'storeNotifications' of undefined
                                        at /opt/iobroker/node_modules/iobroker.js-controller/main.js:4264:29
                                        at stopInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:4225:43)
                                        at stop (/opt/iobroker/node_modules/iobroker.js-controller/main.js:4262:5)
                                        at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/main.js:4619:9)
                                        at process.emit (events.js:314:20)
                                    2021-01-18 07:14:34.468  - error: host.Collector uncaught exception: Cannot read property 'storeNotifications' of undefined
                                    2021-01-18 07:14:34.469  - error: host.Collector TypeError: Cannot read property 'storeNotifications' of undefined
                                    2021-01-18 07:14:34.478  - error: host.Collector Cannot read property 'storeNotifications' of undefined
                                            notificationHandler.storeNotifications();
                                        at process.exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/main.js:4612:9)
                                        at process._fatalException (internal/process/execution.js:165:25)
                                      apollon77A
                                      apollon77A
                                      @jayr Interessant, da fliegt bei die scheinbar mega früh irgendeine exception. versuch bitte nochmal drüber zu installieren
                                        @apollon77 said in js-controller 3.2 jetzt im Latest!:
                                        Also es lief die Ganze Zeit ohne Probleme (Habe gestern morgen geupdated). Der Fehler ist heute morgen gekommen nachdem ich ein Adapter installiert hab.
                                        apollon77A Master67M 2 Antworten Letzte Antwort
                                          apollon77A
                                          apollon77A
                                          @jayr Ok, dann bitte mehr log ... das fehlt halt. Es kam also aus dem cli Kommando oder wie wann genau? oder ist der ganze COntroller gecraht?
                                          Aber hab schon nen Fix der mit der 3.2.8 heute abend vorauss kommt.
                                          84.1k
