  4. Test Adapter tvprogram
    apollon77A
adaptertvprogramviswidget
938 Beiträge 51 Kommentatoren 418.2k Aufrufe 54 Beobachtet
  • OliverIOO OliverIO
    @Oli sehr gut, danke, das hilft weiter.
    Fix kommt voraussichtlich heute Abend.
    KnallochseK
    KnallochseK
    Knallochse
    @OliverIO Ich habe auch mal die Konsolenausgabe für dich (bei Start der Runtime)
    Bei mir in der Runtime ebenfalls keine Anzeige (Chrome & Edge)
    createWidget init
    tvprogram.js:56 createWidget start
    tvprogram.js:1146 bindStates
    index.html#Test_TVProgramm:1 Uncaught SyntaxError: Unexpected token u in JSON at position 0
        at JSON.parse (<anonymous>)
        at Object.createWidget (tvprogram.js:81)
        at tvprogram.js:53
    createWidget @ tvprogram.js:81
    (anonymous) @ tvprogram.js:53
    setTimeout (async)
    createWidget @ tvprogram.js:52
    eval @ tpltvprogramtime1.js:24
    n.render @ can.custom.min.js:76
    t.template.fn @ can.custom.min.js:76
    r @ can.custom.min.js:58
    renderTo @ can.custom.min.js:58
    renderAs @ can.custom.min.js:58
    e.view.e.template @ can.custom.min.js:58
    renderWidget @ vis.js:1644
    (anonymous) @ vis.js:916
    (anonymous) @ vis.js:2860
    (anonymous) @ conn.js:792
    r.onack @ socket.io.js:8
    r.onpacket @ socket.io.js:8
    (anonymous) @ socket.io.js:8
    r.emit @ socket.io.js:6
    r.ondecoded @ socket.io.js:6
    a.add @ socket.io.js:6
    r.ondata @ socket.io.js:6
    r.onPacket @ socket.io.js:7
    (anonymous) @ socket.io.js:7
    r.onData @ socket.io.js:7
    ws.onmessage @ socket.io.js:8
    tvprogram.js:540 changed tvprogram.0.categories.val
    tvprogram.js:48 createWidget init
    conn.js:1247 Error: Error: can't create states object for tvprogram.0.categories(SyntaxError: Unexpected token u in JSON at position 0)
    DevTools failed to load SourceMap: Could not load content for http://192.168.178.86:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILU
    • KnallochseK Knallochse
      createWidget init
          at tvprogram.js:53
      setTimeout (async)
      OliverIOO
      OliverIOO
      OliverIO
      Neue Version 0.0.4
      Letzter Fehler ist behoben. bzw scheint das verhalten zum Abruf von Datenpunkten
      in manchen Systemen abzuweichen.
      Nach dem Fehler ist vor dem Fehler :)
      Meine Adapter und Widgets
      Links im Profil
      O 2 Antworten Letzte Antwort
        Neue Version 0.0.4
        O
        O
        Oli
        schrieb am zuletzt editiert von Oli
        @OliverIO
        Super, jetzt funktioniert es.
        kann ich irgendwo die Schriftgröße und die Größe des Popup Fensters einstellen ?
        Oliver
          Neue Version 0.0.4
          O
          O
          Oli
          @OliverIO
          im Vis Editor ist mir noch was aufgefallen:
          Oliver
          • O Oli
            @OliverIO
            OliverIOO
            OliverIOO
            OliverIO
            @Oli sagte in Test Adapter tvprogram:
            @OliverIO
            Normalerweise im Editor, bei den css-anweisungen rechts.
            ich dachte das das mit den von mir verwendeten css-größen funktioniert.
            hab aber eine Möglichkeit gefunden, wie ich die Schriftgröße relativ zur Haupt-Schriftgröße
            angeben kann. Kommt im nächsten Release.
            Ich hab noch vor, auch die Größe einer Zeile, sowie die Anzeige für 30 Minuten konfigurierbar zu machen.
            Aber erst muss die Grundfunktionalität soweit funktionieren und getestet sein.
            Links im Profil
            • O Oli
              @OliverIO
              OliverIOO
              OliverIOO
              OliverIO
              @Oli
              ok, z-index zu hoch.
              Danke, muss ich ausprobieren, was da funktioniert.
              Links im Profil
              O 1 Antwort Letzte Antwort
                Aktuelle Test Version 0.0.1 und größer
                Veröffentlichungsdatum Januar 2021
                Github Link https://github.com/oweitman/iobroker.tvprogram
                Was kann der Adapter bereits:
                Server
                • die notwendigen TV-Daten aus dem Internet abrufen und als Datenpunkt abspeichern
                Widget
                -Darstellung des TV-Programms in der Zeitstrahl-Ansicht
                -Aufruf von Detailinformationen zu jeder einzelnen Sendung, soweit die Daten vorhanden sind.
                • Scrollen über einen ganzen Tag
                • Senderauswahl konfigurieren
                Was kann das Widget noch nicht:
                • Konfiguration der Darstellung, größerer/kleinerer Bereich je Stunde, ggfs auch hinein/hinauszoomen
                • Farbanpassung an das gewünschte Farbschema, aktuell nur Dunkel-Darstellung
                • Hervorhebung Favoritensendungen
                Weitere Punkte auf der Roadmap
                • Ideen für weitere Widgets auf Basis des bereits existierenden TVprogram-Skripts
                • sendungserinnerungen
                • ansteuern datenpunkt zum umschalten nach Klick auf senderlogo
                • Datenadapter für weitere Quellen (Internet, Hardware wie Enigma,VU-Box)
                Darüber hinaus wird in diesem Thread weiter unten immer aktuell über den Fortschritt berichtet
                Hier ein kleines Video des bisherigen Entwicklungsstandes.
                sigi234S
                sigi234S
                @OliverIO
                Ladet ewig.
                Im Editor aber da:
                  @Oli
                  O
                  O
                  Oli
                  @OliverIO
                  stimmt, kann das von @sigi234 bestätigen, dauert ziemlich lange
                  vielleicht hilft dir das kleine Video bei der Schriftgröße
                  Oliver
                  • sigi234S sigi234
                    @OliverIO
                    Ladet ewig.
                    Im Editor aber da:
                    OliverIOO
                    OliverIOO
                    OliverIO
                    @sigi234
                    Ladezeiten: ja, das ist noch ein Problem, da der Datenbestand doch recht umfangreich ist.
                    pro Tag sind es ca 500kb. Aktuell ladet das widget nur genau einen Tag.
                    für eine spätere Navigation wären es dann entsprechend viele Tage.
                    Wobei ich bei Tests festgestellt habe, das mehrere Tage laden die Zeit nicht sehr viel größer wird.
                    Allerdings habe ich hier ein recht gutes Netzwerk und der PC ist direkt am LAN und nicht per WLan angeschlossen.
                    Um das zu optimieren, müsste ich eine Client/Server Kommunikation einrichten, wobei das widget den adapter bei der Anzeige eines (neuen) Tages nur anhand der anzuzeigenden Sender die Daten abfragt,
                    Wer allerdings alle/viele Sender gleichzeitig im Blick haben möchte werden es nicht weniger Daten.
                    Als weitere Optimierung könnte man dann noch die Detailtexte weglassen.
                    Ich schreibt das mal auf meine Liste
                    Der Unterschied der Ladezeiten im Editor und in der runtime liegt an der anderen Vorgehensweise von vis.
                    Im Editor werden sämtliche Datenpunkte bereits beim Start abonniert. Daher dauert der Start dann von vis etwas länger.
                    In der Runtime, muss ich mich im widget selber drum kümmern
                    Links im Profil
                    • O Oli
                      @OliverIO
                      OliverIOO
                      OliverIOO
                      OliverIO
                      @OliverIO
                      Danke für das Video.
                      Ich habe die Stellen bereits angepasst, so das die Schrift nun relativ zu eingestellen Schriftgröße im vis-Editor angezeigt wird.
                      Allerdings werden die Größen der Kästchen noch nicht angepasst, das werde ich zusammen mit der ZoomIn/Out-Funktionalität anpassen, so das das konfigurierbar ist.
                      Links im Profil
                        @OliverIO
                        sigi234S
                        sigi234S
                        @OliverIO
                        Hallo, der Log wird durch den TV Adapter extrem Groß!
                        • sigi234S sigi234
                          @OliverIO
                          OliverIOO
                          OliverIOO
                          OliverIO
                          Neue Version 0.0.5
                          • Das ändern von Datenpunkten wird nun nicht mehr im Log ausgegeben
                          @sigi234
                          Ich habe das mal schnell ausgebaut. Allerdings schreibt redis die geänderten Inhalte ebenfalls ins log.
                          Ich hatte es mir schon gedacht, das diese Menge von Daten in Datenpunkte wohl nicht so optimal ist.
                          Ich werde mir dazu was anderes überlegen und evtl. die Daten als Dateien auf dem Server ablegen und von dort aus den widgets zur Verfügung stellen.
                          Links im Profil
                          KnallochseK 1 Antwort Letzte Antwort
                            Neue Version 0.0.5
                            @sigi234
                            KnallochseK
                            KnallochseK
                            Knallochse
                            schrieb am zuletzt editiert von Knallochse
                            @OliverIO Runtime läuft (auch mit0.0.5)
                            Ist ja nach früh in der Entwicklung, deshalb von mir kein "das noch und das noch ..."😁
                            Gib bitte Bescheid, wenn dein Grundgerüst steht, dann schreibe ich Konfigurationswünsche.
                            Bis jetzt gefällt mir das ganze echt gut 👍 a8d5a090-9db1-4123-9369-4ac401db3777-image.png
                            Anmerkung: Die Menge der Daten unter Objekte- tvprogram.0.program scheinen sich auf die Performance auszuwirken.
                            Mittlerweile habe ich da 8 Einträge (2021-01-09 bis 2021-01-16). Werden da auch wieder welche selbstständig gelöscht, oder müsste ich das aktuell selber erledigen?
                              OliverIOO
                              OliverIOO
                              OliverIO
                              @Knallochse
                              Aktuell noch nicht, steht aber auf meiner Liste.
                              Als nächstes stell ich das Widget von Datenpunkten auf Dateien mit Client/Server-Abfrage um, dann schauen wir, wie es da mit der Performance aussieht.
                              Links im Profil
                                @Knallochse
                                OliverIOO
                                OliverIOO
                                OliverIO
                                Neue Version 0.0.6
                                • Umstellung auf Client/Server-Abfrage
                                • Reduzierung der übertragenen Datenmenge.
                                Das Widget läuft nun erheblich schneller, da nun nicht mehr alle Daten zu beginn in den Browser geladen werden, sondern nur noch eine reduzierte Menge, die zur ersten Anzeige notwendig ist. Die Details zu einzelnen Sendungen werden dann bei Klick auf eine Sendung adhoc vom Server abgerufen.
                                Nachteil ist, das sich der RAM-Bedarf des adapters auf Server-Seite erhöht hat.
                                Bei mir benötigt der Adapter bei 5 geladenen Tagen ca 90-110MB.
                                Bitte testen. Wenn der Teil erfolgreich getestet wurde, kommen die beiden folgenden Punkte.
                                Eine kleine Abstimmung wäre schön. Ebenso Vorschläge für das Navigationsproblem (bei beiden Punkten)
                                • Navigation
                                  Tag vor/zurück
                                  Hier bin ich mir noch nicht sicher, wo ich die Navigation am besten platziere, so das sie sich harmonisch in Gesamtbild einfügen. Eigentlich passen sie nirgends so richtig hin ohne einen neuen Bereich oben unten links rechts zu eröffnen. evtl habt ihr ja Vorschläge
                                • ZoomIn/Out, sowie konfigurierbare Zeilenhöhe
                                  Dynamisch mehr oder weniger Platz auf der Zeitleiste.
                                  Da ja manche Sendungen sehr kurz sind, sind die Texte nicht alle lesbar. Daher sollte man ebenso "hineinzoomen" können. Auf einem Tablet oder Gerät mit Touchfunktion sollte das mit Pinch umgesetzt werden. Für Desktops benötigen wir einen Plus/Minus-Knopf (auch hier das Problem der Navigation)
                                  Aktuell hat eine halbe Stunde einen vorgegebenen Wert von 120px, je nach Zoom soll hier ein andere Größe in die Berechnung einfließen. Ausprobieren muss ich, ob ich das stufenlos machen kann oder ob ich nur vielfache von 120/60/30 nehmen kann, so das das Layout bündig berechnet wird.
                                Anmerkung: 2 Widgets oder mehr auf einmal gehen noch nicht.
                                Links im Profil
                                KnallochseK 2 Antworten Letzte Antwort
                                  Neue Version 0.0.6
                                  • Navigation
                                    Tag vor/zurück
                                  KnallochseK
                                  KnallochseK
                                  Knallochse
                                  @oliverio Ich habe mir gerade die 0.0.6 installiert. (alte Instanz gelöscht; Adapter geupdatet ; neue Instanz erzeugt)
                                  Leider wird im Objektbaum nur folgendes angezeigt, und ich weiß nicht was ich im Widget als "tvprogram-oid: angeben soll
                                    OliverIOO
                                    OliverIOO
                                    OliverIO
                                    @knallochse
                                    Nimm config
                                    Danke für den Hinweis, nimm den config-Datenpunkt.
                                    Ich habe das widget so programmiert, das es eigentlich nur den instance namen braucht (tvprogram.0)
                                    Den Rest sucht er sich selbst zusammen.
                                    Theoretisch würde auch der connectionDP reichen.
                                    Hier das readme des adapters
                                    Widgets
                                    Time
                                    Currently only the widget "time" exists. This shows the current TV program on a timeline by TV channel.
                                    To set it up, the adapter must have already accessed and filled the necessary data points. In the configuration, the widget only needs to be filled with any data point of the adapter. The widget searches for all remaining data points automatically.
                                    Links im Profil
                                      @knallochse
                                      Nimm config
                                      Widgets
                                      Time
                                      KnallochseK
                                      KnallochseK
                                      Knallochse
                                      @oliverio said in Test Adapter tvprogram:
                                      tvprogram.0
                                      Ich habe den config-Datenpunkt eingegeben . Jetzt sieht es so aus
                                      Wo wird denn jetzt die Datenbank abgelegt, so dass ich Prüfen kann, ob diese befüllt wird.
                                      Edit: Habe es gefunden (Sieht das gut aus - von der Dateigröße?)
                                      OliverIOO 2 Antworten Letzte Antwort
                                        tvprogram.0
                                        OliverIOO
                                        OliverIOO
                                        OliverIO
                                        @knallochse
                                        Unter Linux im folgenden Ordner
                                        /opt/iobroker/iobroker-data/tvprogram
                                        Führe bitte auf der Konsole zur Sicherheit den folgenden Befehl aus:
                                        iob upload tvprogram
                                        ich hatte in der package.json was geändert und trotz löschen der instanz wusste iobroker erst nach dem upload über die Änderung Bescheid.
                                        Aus Entwicklungstechnischen gründen kann ich bei mir den Adapter nicht löschen
                                        Links im Profil
                                          tvprogram.0
                                          OliverIOO
                                          OliverIOO
                                          OliverIO
                                          @knallochse
                                          ja größen passen.
                                          die Originalgrößen aus der quelle sind nochmal doppelt so groß und zum Browser werden für einen tag nur ca 250kb übertragen. der Rest sind die texte zu den einzelnen Sendungen.
                                          Links im Profil
                                          KnallochseK liv-in-skyL 2 Antworten Letzte Antwort
                                          84.1k
