  4. [Projekt] MDCSS v2: Material Design CSS Version 2
material uivismaterial css
717 Beiträge 74 Kommentatoren 255.5k Aufrufe 77 Beobachtet
  • Dominik F.D Dominik F.
    ich habe folgendes Widget:
    [{"tpl":"tplValueBool","data":{"oid":"scene.0.Gute_Nacht.Gute_Nacht","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":" mdui-state mdui-center-v ","html_true":"<div class=\"mdui-green-bg\"><img src='/icons-mfd-png/scene_night.png' width=\"30px\" height=\"30px\">eingeschaltet</div>","html_false":"<div class=\"mdui-red-bg\"><img src='/icons-mfd-png/scene_night.png' width=\"30px\" height=\"25px\">ausgeschaltet</div>","html_append":""},"style":{"left":"calc(78% - 75px)","top":"117px","width":"150px","height":"30px"},"widgetSet":"basic"}]
    Hier nochmal als Bildes geht um das mittlere rechte Widget:
    Mein Problem mit dem Widget ist, dass es eigentlich rot sein müsste und ausgeschaltet dort stehen sollte, wie das obere rechte Widget.
    Das Problem liegt wohl an dem Datenpunkt, der uncertain ist. Ich bekomme es auch mit bindings nicht hin, dass es bei true grün und eingeschaltet ist, und bei false und uncertain rot und ausgeschaltet. kann mir jemand helfen?
    Dominik F.D Offline
    Dominik F.D Offline
    Dominik F.
    #634
    Okay, scheint wohl ein unlösbares Problem zu sein.
    @Uhula
    Kann man mit deinem CSS den mdui-Switch invertieren? Habe momentan das Problem das ich 3 States bei einem Datenpunkt habe. True, False,Uncertain. Uncertain wird anscheinend wie True angesehen und der mdui-switch soll bei uncertain oder false in diesem Fall false anzeigen.
    Hast du eine Idee?
    • F Offline
      fritzke316
      #635
      @Uhula
      Mit welcher Variable wird denn das Umschalten der Schriften von schwarz auf weiß gesteuert?
      Ich würde damit auch gerne das Invertieren meiner .png Icons steuern, wenn das möglich ist?
      jpgorganizerJ 1 Antwort Letzte Antwort
      • F fritzke316
        @Uhula
        jpgorganizerJ Offline
        jpgorganizer
        schrieb am zuletzt editiert von jpgorganizer
        #636
        ich würde gerne einen Time Picker (https://material.io/archive/guidelines/components/pickers.html#pickers-usage etwas runterscrollen) nutzen, aber gerade keine Idee ob und wie. Hat jemand einen Tipp für mich?
        jpgorganizer
        Edit 28.12.20: niemand eine Idee?
        Ich habe es für mich gelöst, zwar anders wie ursprünglich gedacht, aber für mich ok.
        smartgarden Adapter für GARDENA smart system
        • foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #637
          gibt es eine Möglichkeit, auch negative Zahlen in mdui-range-min-max zu nutzen?
          Falls nein, gibt es eine Chance dass du es rein packst @Uhula? ;-)
          beste Grüße
          fox
          Videotutorials & mehr
          • nukleuzN Offline
            nukleuzN Offline
            nukleuz
            #638
            erst einmal: Super Arbeit!!!
            Bei mir wird mdui-state im Frontend nicht angezeigt.
            Ich nutze das MDSimple - dort die States mit Vorgabe der Werteliste.
            Im VIS-Editor sieht alles super aus - nur halt im VIS-Frontend nicht.
            Sonst scheint alles wunderbar zu funktionieren...
            Hat jemand einen Rat?
            Danke und ach ja, frohes Neuses! :)
            Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
            • jpgorganizerJ jpgorganizer
              jpgorganizer
              jpgorganizer
              #639
              Hi @Uhula,
              ich versuche gerade mit mdui-click?action:setValue(mystate,abc 123) in den state zu schreiben, aber es steht immer nur ab drin. Sogar das c fehlt schon.
              Kann es sein, dass hier nur Werte ohne Blank zulässig sind?
              VG jpgorganizer
              Edit:
              habe das Problem gefunden. Es liegt an der Funktion
              // liefert den suffix einer gegebenen class zurück
              // Bsp: mdui-target-w00002 -> w00002
              //      mdui-range-100-200 -> 100-200
              function _getSuffix( s, classname ) {
                  let suf = "";
                  if (s.includes(classname)) {
                      suf = s.substr(s.indexOf(classname)+classname.length,1000)+" ";
                      suf = suf.substr(0,suf.indexOf(" "));
                  return suf;
              und da an der o.a. Codezeile 8. Dort wird bei dem Blank abgeschnitten .... hmmm, muss das so sein. Wenn ja warum?
              Ich mach mir mal eine Fkt _getSuffixWithBlank und ruf die an der relevanten Stelle auf, aber an allen anderen Stellen lass ich es mal so wie es ist
              VG jpgorganizer
                Hi @Uhula,
                VG jpgorganizer
                Edit:
                    let suf = "";
                    return suf;
                VG jpgorganizer
                jpgorganizer
                #640
                fyi, was ich zu mdui-click rausgefunden habe - ob dies das gewünschte Verhalten ist/war oder nicht, das muss jemand anderes bewerten
                • es geht nur eine Action: schon vor längerem erkannt (und damals auch für mich behoben - ich glaube ich habe es damals auch gepostet)
                • bei Action setValue(state,value) darf kein Blank im Wert sein, der in den State geschrieben werden soll
                • wenn man ein Widget jqui - navigation - Icon nimmt, dort wie vorgesehen eine View zum Navigieren angibt und zusätzlich dann eine Action setValue(state,value) dazu schreibt, dann funktioniert dies bei mir nur im Browser auf dem PC (Firefox); auf dem Handy mit Chrome funktioniert das setValue(state,value) dann nicht. Nimmt man den Wert bei View zum Navigieren raus und macht eine weitere Action changeView(destview) dazu, dann geht es in beiden Fällen (man beachte aber den ersten Aufzählungspunkt.
                Ich habe dies heute Abend für mich so festgestellt. Evtl. gibt es weitere Randbedingungen wann dies geschieht und wann auch nicht. Diese sind mir dann aber nicht bewusst geworden. Ich habe für die ersten beiden Aufzählungspunkte das Script angepasst, so dass dies nun funktioniert und eben keine Einschränkung mehr da ist. Der dritte Aufzählungspunkt erfordert keine Scriptänderung, sondern wäre evtl. was für die Doku.
                @Uhula, falls du die Änderungen möchtest, dann kann ich dir das schicken. Evtl. kannst du davon etwas in deinen Standard oder auch in die Doku übernehmen
                @all, Ihr könnt das ja mal bei euch ausprobieren. Evtl. ist das alles nur bei mir und ich habe irgendwo etwas (unbewusst) verstellt und stoße nun auf solche Dinge
                VG jpgorganizer
                • V Offline
                  V Offline
                  Volker859
                  #641
                  ich bin neu hier im Forum und blutiger Anfänger in Sachen ioBroker.
                  Vor einigen Tagen habe ich die Doku "Material Design CSS" gelesen und mich gefragt, ob es möglich ist, Cards in der Content-View unabhängig von der Bildschirmgröße jeweils zentriert anordnen bzw. anzeigen zu lassen.
                  Über eine Antwort würde ich mich freuen.
                  P 1 Antwort Letzte Antwort
                  • V Volker859
                    Pittini
                    #642
                    @Volker859 sagte in [Projekt] MDCSS v2: Material Design CSS Version 2:
                    Das geht grundsätzlich immer, unabhängig vom Material Design. Du gibst bei left und top Eigenschaft keine direkte Angabe sondern ne berechnete. Sieht so aus: calc(50% - XYpx) - XY ist die halbe widthangabe des widgets, der Card oder was auch immer.
                    • P Pittini
                      Dominik F.D Offline
                      Dominik F.D Offline
                      Dominik F.
                      #643
                      @Pittini
                      Du kennst dich ja auch sehr gut mit MD V2 aus,
                      Ich würde die Card EG Temperaturen gerne unterhalb der anderen beiden Cards anordnen. Hast du eine Idee wie ich das hinbekomme?
                      P S 2 Antworten Letzte Antwort
                        @Pittini
                        Pittini
                        #644
                        @Dominik-F Gesamtbereich kleiner machen, dann müßte das responsive greifen. Oder responsive abschalten und manuell platzieren.
                        • P Pittini
                          Dominik F.D Offline
                          Dominik F.D Offline
                          Dominik F.
                          #645
                          @Pittini
                          Mein Problem ist, das ich das ganze zusätzlich auf dem Handy noch nutze. Da ist der Bereich ja kleiner und es passt alles.
                          Wenn ich den Gesamtbereich kleiner mache, dann passen viele andere Views nicht mehr, da ist alles so aufgebaut, dass immer 3 Cards nebeneinander passen.
                          Ich kann daher auch die Cards nicht breiter machen, dass die sich automatisch nach unten schiebt.
                          Hast du noch eine andere Idee?
                            @Pittini
                            Pittini
                            #646
                            @Dominik-F Naja, dann ist das ein "Wasch mich aber mach mich nicht nass" Problem. Da fällt mir nur ein nen zusätzlichen anderen View zumachen.
                            • P Pittini
                              Dominik F.D Offline
                              Dominik F.D Offline
                              Dominik F.
                              #647
                              @Pittini
                              Ja, das hatte ich befürchtet. Ich danke dir
                                @Pittini
                                Saschag
                                #648
                                @Dominik-F
                                Vielleicht eine leere Card als Platzhalter, zumindest wenn es nur um ein Endgerät geht.
                                • Q Offline
                                  Q Offline
                                  quorle
                                  schrieb am zuletzt editiert von quorle
                                  #649
                                  @Uhula
                                  Kann man den "Flow-Effect" eigentlich in einem bestimmten Radius biegen? So dass man auf 180° kommt und die Animation das abfährt?
                                    Borio85
                                    schrieb am zuletzt editiert von Borio85
                                    #650
                                    Hallo Zusammen,
                                    ich habe ein kleines grafisches Problem mit der HeatingControl VIS von Pittini, auf dem PC wird alles richtig dargestellt aber auf dem iPad werden einige Felder abgeschnitten, woran kann das liegen?
                                    Auf meinem iPhone sind die Felder auch abgeschnitten
                                    Dominik F.D bilberryB 2 Antworten Letzte Antwort
                                    • B Borio85
                                      Hallo Zusammen,
                                      Dominik F.D Offline
                                      Dominik F.D Offline
                                      Dominik F.
                                      #651
                                      @borio85
                                      Hast du mal versucht mit einem anderen Browser auf dem Ipad die Vis anzeigen zu lassen? Tritt dann das gleiche Problem auf?
                                        @borio85
                                        Borio85
                                        #652
                                        @dominik-f said in [Projekt] MDCSS v2: Material Design CSS Version 2:
                                        Daran habe ich noch nicht gedacht, hab mir gerade Opera Touch geladen aber auch da ist es abgeschnitten.
                                        J Dominik F.D 2 Antworten Letzte Antwort
                                        • B Borio85
                                          Ja.rod
                                          #653
                                          @borio85 Ich nutze die iOS App iobroker-Anzeige, bei der ist es auch abgeschnitten.
