  4. Zwave 0.4
Zwave 0.4
142 Beiträge 16 Kommentatoren 37.6k Aufrufe
  • Lenny.CBL
    Lenny.CBL
    Lenny.CB
    so alles neu… das Gleiche wie vorher.
    kann es damit zusammen hängen? Ausschnitt aus der Installation per Putty.
    > serialport@4.0.5 install /opt/iobroker/node_modules/iobroker.zwave/node_modules/serialport
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.5/serialport-v4.0.5-node-v46-linux-arm.tar.gz
    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.5 and node@4.4.7 (node-v46 ABI) (falling back to source compile with node-gyp)
    make: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/serialport/build'
      CXX(target) Release/obj.target/serialport/src/serialport.o
      CXX(target) Release/obj.target/serialport/src/serialport_unix.o
      CXX(target) Release/obj.target/serialport/src/serialport_poller.o
      SOLINK_MODULE(target) Release/obj.target/serialport.node
      COPY Release/serialport.node
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/serialport/build'
    • DutchmanD
      DutchmanD
      Dutchman
      @Lenny.CB:
      Bei mir lief dieser schritt sauber durch sehe daher keinen verband, auch weil er ja zurueck faell cuh den source compiler with node-gyp.
      Hier mal die stelle aus meine install log:
      make: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build'
        CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-config.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-driver.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-groups.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-management.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-network.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-nodes.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-polling.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-scenes.o
        CXX(target) Release/obj.target/openzwave_shared/src/openzwave-values.o
        CXX(target) Release/obj.target/openzwave_shared/src/utils.o
        SOLINK_MODULE(target) Release/obj.target/openzwave_shared.node
        COPY Release/openzwave_shared.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build'
      [serialport] Success: "/opt/iobroker/node_modules/iobroker.zwave/node_modules/serialport/build/Release/serialport.node" is installed via remote
      iobroker.zwave@0.4.0 node_modules/iobroker.zwave
      ├── openzwave-shared@1.2.0 (nan@2.4.0)
      └── serialport@4.0.5 (bindings@1.2.1, commander@2.9.0, debug@2.2.0, nan@2.4.0, object.assign@4.0.4, lie@3.1.0)
      got /opt/iobroker/node_modules/iobroker.zwave/admin
      Dennoch habe ich das gleiche problem wie du mit start adapter.
        Interessant, dass die Installation von serialport bei Dutschman keine Probleme macht. Bei mir gab es auf zwei PIs diese ERR Meldung.
        Ich war dann mal mutig und hab bisschen rumgesucht und dannn gefunden, dass man u.U. –unsafe-perm nehmen soll und habe folgendes gemacht (alles als root)
        cd /opt/iobroker/node_modules/iobroker.zwave
        npm install serialport
        –> gleiche Fehlermeldung
        node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.5/serialport-v4.0.5-node-v14-linux-arm.tar.gz
        Dann:
        npm install serialport --unsafe-perm --build-from-source
        Soweit OK durchgelaufen.
        Allerdings habe ich auch das Problem, dass die Instanz sich immer beendet und neu startet.
        • BluefoxB
          Hm..
          Was sagt so was?
          cd /opt/iobroker
          iobroker stop zwave.0
          node node_modules/iobroker.zwave/main.js --force --logs
            module.js:327
                throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.zwave/admin/js/comClasses.js'
                at Function.Module._resolveFilename (module.js:325:15)
                at Function.Module._load (module.js:276:25)
                at Module.require (module.js:353:17)
                at require (internal/module.js:12:17)
                at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.zwave/main.js:11:20)
                at Module._compile (module.js:409:26)
                at Object.Module._extensions..js (module.js:416:10)
                at Module.load (module.js:343:32)
                at Function.Module._load (module.js:300:12)
                at Function.Module.runMain (module.js:441:10)</anonymous>
            …../admin/js gibt es nicht
            • BluefoxB
              Ok. Habe eine Datei vergessen einzuchecken.
              Bitte noch mal vom git updaten
              • DutchmanD
                DutchmanD
                Dutchman
                @Bluefox:
                Bitte noch mal vom git updaten `
                Neu von git geladen, jetzt komt das folgende im log:
                host.HomeControl	2016-11-07 22:02:55.259	info	Restart adapter system.adapter.zwave.0 because enabled
                host.HomeControl	2016-11-07 22:02:55.259	error	instance system.adapter.zwave.0 terminated with code 0 (OK)
                inMem	2016-11-07 22:02:55.224	debug	message zwave.0.* zwave.0.exclusionOn val=false, ack=true, ts=1478552575209, q=0, from=system.adapter.zwave.0, lc=1478552575209
                inMem	2016-11-07 22:02:55.215	debug	message zwave.0.* zwave.0.inclusionOn val=false, ack=true, ts=1478552575204, q=0, from=system.adapter.zwave.0, lc=1478552575204
                inMem	2016-11-07 22:02:55.204	debug	message zwave.0.* zwave.0.info.connection val=false, ack=true, ts=1478552575197, q=0, from=system.adapter.zwave.0, lc=1478552575197
                Error:	2016-11-07 22:02:55.193	error	at Module.load (module.js:343:32)
                Error:	2016-11-07 22:02:55.193	error	at Object.Module._extensions..js (module.js:416:10)
                Error:	2016-11-07 22:02:55.193	error	at Module._compile (module.js:409:26)
                Error:	2016-11-07 22:02:55.193	error	at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
                Error:	2016-11-07 22:02:55.193	error	at require (internal/module.js:12:17)
                Error:	2016-11-07 22:02:55.193	error	at Module.require (module.js:353:17)
                Error:	2016-11-07 22:02:55.193	error	at Function.Module._load (module.js:300:12)
                Error:	2016-11-07 22:02:55.193	error	at Object.Module._extensions..node (module.js:434:18)
                Error:	2016-11-07 22:02:55.193	error	at Error (native)
                Error:	2016-11-07 22:02:55.193	error	libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                uncaught	2016-11-07 22:02:55.191	error	exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                Auszug der ACL im node_modules dir:
                drwxr-xr-x 7 rafal rafal  4096 Oct 16 23:43 iobroker.vis-canvas-gauges
                drwxr-xr-x 6 rafal rafal  4096 Sep 25 19:39 iobroker.vis-fancyswitch
                drwxr-xr-x 6 rafal rafal  4096 Oct 16 11:43 iobroker.vis-history
                drwxr-xr-x 6 rafal rafal  4096 Oct 16 11:43 iobroker.vis-hqwidgets
                drwxr-xr-x 6 rafal rafal  4096 Oct 16 23:44 iobroker.vis-jqui-mfd
                drwxr-xr-x 7 rafal rafal  4096 Oct 17 06:01 iobroker.vis-justgage
                drwxr-xr-x 7 rafal rafal  4096 Oct 17 06:07 iobroker.vis-lcars
                drwxr-xr-x 6 rafal rafal  4096 Oct 16 11:43 iobroker.vis-metro
                drwxr-xr-x 6 rafal rafal  4096 Oct  1 17:29 iobroker.vis-rgraph
                drwxr-xr-x 6 rafal rafal  4096 Oct  1 17:29 iobroker.vis-timeandweather
                drwxrwxrwx 5 rafal rafal  4096 Oct 30 15:14 iobroker.weatherunderground
                drwxr-xr-x 8 rafal rafal  4096 Oct 16 11:44 iobroker.web
                drwxr-xr-x 8 rafal rafal  4096 Nov  7 22:01 iobroker.zwave
                -rw-rw-r-- 1 rafal rafal 63386 Oct  1 17:16 npm-debug.log
                • Lenny.CBL
                  Lenny.CBL
                  Lenny.CB
                  @Bluefox:
                  ich habe erst einmal keine "roten" Logeinträge…
                  sind auch alle Geräte da. Schaue mich dann mal bei den Objekten um...
                  Instanzen-Konfiguration schaut nun so bei mir aus:
                  • DutchmanD
                    DutchmanD
                    Dutchman
                    auch ich habe den adapter jetzt am laufen
                    @Bluefox
                    Fuers wiki, wen problem meldung
                    dan volgendes ausfuehren:
                    sudo ldconfig /usr/local/lib64
                    ich hab im moment 1 geraet ligen (verbrauchsmesser) den werde ich mal anlernen.
                    Mein voriges geraet (Fiabro Wall plug) liegt im moment wo anders, in objecten faellt mir auf das de switch da ist aber mir fehlen die kanaele fuer leistungs messung.
                    Werde den fiabro mal wieder zurueck klauen am wochende und weiter teste.
                    Basis: Adapter laeuft und erste sachen werder eingelesen to be continued
                    Update: Kan es sein das der adaper erst objecte erstell en auch daten darueb gelaufen sind ?
                    Z.b.:
                    • Fiabro plug: An/Aus ist da aber keine energy messung (stimmt auch ist nicht angeschlossen und hatte keinen verbraucher vor 2 wochen)
                    • EnergieMesser: Object ist angelernt (also aerostick knopf druecken und pairen) object ist erstellt aber keine kanaele.
                    Ich schliesse den messer morgen weiter an damit er waete generiert, jetzt hund gassie und dan orchen lauschern.
                    • Lenny.CBL
                      Lenny.CBL
                      Lenny.CB
                      es werden einige Kanäle angezeigt, einige fehlen aber noch. (z.B. Spannung, Stromstärke usw. bei Aeotec EnergyMeter)
                      Die fehlenden Kanäle lassen sich auch nicht über die Konfiguration aufrufen.
                      abgeleitet davon:
                      weiterhin ist mir aufgefallen, dass sich nichts ansteuern lässt. (WallPlug und RollerShutter)
                      hier noch etwas Debug-Log wenn ich in "Objekte" die State für den WallPlug ändere:
                      zwave.0 2016-11-08 10:05:53.647 info zwave.0 starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v4.4.7
                      zwave.0 2016-11-08 10:05:09.862 debug inMem message zwave.0.* zwave.0.info.connection
                      zwave.0 2016-11-08 10:05:09.861 debug inMem message zwave.0.* zwave.0.exclusionOn
                      zwave.0 2016-11-08 10:05:09.861 debug inMem message zwave.0.* zwave.0.inclusionOn
                      zwave.0 2016-11-08 10:05:09.860 debug inMem message zwave.0.* zwave.0.info.connection
                      zwave.0 2016-11-08 10:05:09.854 info zwave.0 connected: homeid = 1.4.0
                      zwave.0 2016-11-08 10:05:08.630 warn Object "zwave.0.NODE7.SWITCH_BINARY.Switch_1" was not detected
                      zwave.0 2016-11-08 10:05:08.627 debug stateChange zwave.0.NODE7.SWITCH_BINARY.Switch_1 set {"val":true,"ack":false,"ts":1478595908602,"q":0,"from":"system.adapter.admin.0","lc":1478595908602}
                      zwave.0 2016-11-08 10:05:08.004 debug received all objects
                      zwave.0 2016-11-08 10:05:06.996 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v4.4.7
                      zwave.0 2016-11-08 10:05:06.623 debug statesDB connected
                      zwave.0 2016-11-08 10:05:06.522 debug objectDB connected
                      zwave.0 2016-11-08 10:04:32.136 error failed to start driver
                      zwave.0 2016-11-08 10:04:22.127 info connected: homeid = 1.4.0
                      zwave.0 2016-11-08 10:04:21.253 debug received all objects
                      zwave.0 2016-11-08 10:04:20.492 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v4.4.7
                      zwave.0 2016-11-08 10:04:20.250 debug statesDB connected
                      zwave.0 2016-11-08 10:04:20.186 debug objectDB connected
                      zwave.0 2016-11-08 10:03:46.958 error failed to start driver
                      zwave.0 2016-11-08 10:03:36.954 info connected: homeid = 1.4.0
                      zwave.0 2016-11-08 10:03:35.525 debug received all objects
                      zwave.0 2016-11-08 10:03:34.927 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v4.4.7
                      zwave.0 2016-11-08 10:03:34.703 debug statesDB connected
                      zwave.0 2016-11-08 10:03:34.640 debug objectDB connected
                      zwave.0 2016-11-08 10:03:30.960 info terminating
                      zwave.0 2016-11-08 10:05:09.668 debug inMem message zwave.0.* zwave.0.NODE1.alive
                      zwave.0 2016-11-08 10:05:09.615 debug inMem message zwave.0.* zwave.0.NODE1.sleep
                      zwave.0 2016-11-08 10:05:09.567 debug inMem message zwave.0.* zwave.0.NODE1.ready
                      zwave.0 2016-11-08 10:05:09.508 debug inMem message zwave.0.* zwave.0.NODE2.alive
                      zwave.0 2016-11-08 10:05:09.459 debug inMem message zwave.0.* zwave.0.NODE2.sleep
                      mir fallen das so Sachen auf wie:
                      ****error failed to start driver****
                      oder
                      ****warn Object "zwave.0.NODE7.SWITCH_BINARY.Switch_1" was not detected****
                      Vielleicht sollte ich noch dazu sagen, dass ich nicht neu "Inkludiert" habe nachdem der Aeotec-Stick vom FHEM-System auf IoBroker "umgezogen" ist.
                      Sollte das das Problem sein?
                      • BluefoxB
                        ` > Vielleicht sollte ich noch dazu sagen, dass ich nicht neu "Inkludiert" habe nachdem der Aeotec-Stick vom FHEM-System auf IoBroker "umgezogen" ist.
                        Sollte das das Problem sein? `
                        Es ist sogar besser so momentan.
                        • Lenny.CBL
                          Lenny.CBL
                          Lenny.CB
                          @Bluefox:
                          Es ist sogar besser so momentan. `
                          so alle Notes gelöscht und neu angelernt…
                          angelernt habe ich einmal über den Stick und einmal über das Config-Menü. Beides problemlos.
                          Im LOG steht dann "Scan completed".
                          Aber die Teile lassen sich nicht korrekt ansteuern.
                          was habe ich probiert:
                          1:) Rollo oben (99) --> setze Wert 50 in Objekte --> Relais "klickt", Rollo fährt nicht, Wert geht wieder auf 99 zurück
                          2:) Rollo oben (99) --> setze Wert 0 in Objekte --> Relais "klickt", Rollo fährt ganz runter, Wert geht auf 0
                          3:) Rollo unten (0) --> setze Wert 50 in Objekte --> Relais "klickt", Rollo fährt ganz hoch, Wert geht auf 99
                          Also kann man sagen, dass bei offenem Rollo nur "0" zum schließen angenommen wird und zum öffen alles ">0".
                          WallPlug habe ich auch neu angelernt. Ansteuerung ohne Erfolg.
                          Debug-Log:
                          zwave.0 2016-11-08 11:48:21.049 debug node14: timeout
                          zwave.0 2016-11-08 11:48:09.192 debug setState for: nodeID=14: comClass=37: index=0: instance=1: value=true
                          zwave.0 2016-11-08 11:48:09.190 debug stateChange zwave.0.NODE14.SWITCH_BINARY.Switch_1 set {"val":true,"ack":false,"ts":1478602089177,"q":0,"from":"system.adapter.admin.0","lc":1478602089177}
                          inMem 2016-11-08 11:48:09.188 debug message zwave.0.* zwave.0.NODE14.SWITCH_BINARY.Switch_1 val=true, ack=false, ts=1478602089177, q=0, from=system.adapter.admin.0, lc=1478602089177
                          Das Aeotec_EnergyMeter hat nach dem Anlernen alle Kanäle.
                          Die Reports lassen sich aber nicht setzen, bleiben "rot"
                           ![983_zwave_9.jpg](/assets/uploads/files/983_zwave_9.jpg)
                            Ich habe noch ein paar Fragen:
                            1. Es scheint eine zwave Config seite zu geben http://192.168.xxx.yyy:8081/#zwave
                            Da werden auch meine beiden Geräte fein aufgelistet, aber wenn ich auf das + am Zeilenanfang klicke geht ausser einer Tabellenüberschrift nichts weiter auf. Soll das so?
                            1. Es scheint einige Parameter zu geben, die ich über die Objekte nicht setzen kann. Die meisten sind OK, aber alle, die per 'dropdown-liste' gesetzt werden, kommen nicht an, bzw bleiben rot.
                            Geht:
                            und im OZW_Log
                            2016-11-08 19:52:36.796 Info, Node005, Value::Set - COMMAND_CLASS_CONFIGURATION - LED brightness - 81 - 1 -
                            2016-11-08 19:52:36.796 Info, Node005, Configuration::Set - Parameter=81, Value=30 Size=1
                            2016-11-08 19:52:36.797 Detail,
                            2016-11-08 19:52:36.797 Detail, Node005, Queuing (WakeUp) ConfigurationCmd_Set (Node=5): 0x01, 0x0c, 0x00, 0x13, 0x05, 0x05, 0x70, 0x04, 0x51, 0x01, 0x1e, 0x25, 0x38, 0xc7
                            2016-11-08 19:52:36.798 Detail, Node005, Queuing (WakeUp) ConfigurationCmd_Get (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x70, 0x05, 0x51, 0x25, 0x39, 0xd8
                            2016-11-08 19:53:00.708 Detail, Node005,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x05, 0x02, 0x84, 0x07, 0x77
                            Geht nicht
                            Das kommt im OZW Log gar nicht an
                            • BluefoxB
                              @OstfrieseUnterwegs:
                              Gruß `
                              Die Seite gibt es nicht mehr. Und wird nicht mehr unterstützt.
                              Kann ich aktuellen Stand so beschreiben:
                              • lesen geht, schreiben nicht immer
                                @Bluefox:
                                Genau so ist es.
                                • DutchmanD
                                  DutchmanD
                                  Dutchman
                                  @Bluefox:
                                  Genau so ist es. `
                                  bestaetigt, muss noch 2 andere geraete teste ob alle werten durchkommen
                                    Wie geschrieben, die, die nicht schreiben, tauchen nicht mal im OZW Protokoll auf.
                                    • Alex1808A
                                      Alex1808A
                                      Alex1808
                                      Gerade gesehen das bei frische Linux Mint Installation fehlt noch was
                                      > /cpp/hidapi/linux/hid.c:46:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefunden
                                      nachinstallieren mit
                                      sudo apt-get install libudev-dev
                                      • Alex1808A
                                        Alex1808A
                                        Alex1808
                                        Bekomme diese Fehler im ioB log
                                        ` > host.alex-AKOYA-E1318T 2016-11-10 18:36:07.433 info Restart adapter system.adapter.zwave.0 because enabled
                                        host.alex-AKOYA-E1318T 2016-11-10 18:36:07.433 error instance system.adapter.zwave.0 terminated with code 0 (OK)
                                        zwave.0 2016-11-10 18:36:07.410 info terminating
                                        zwave.0 2016-11-10 18:36:07.377 error at Module.load (module.js:343:32)
                                        zwave.0 2016-11-10 18:36:07.377 error at Object.Module._extensions..js (module.js:416:10)
                                        zwave.0 2016-11-10 18:36:07.377 error at Module._compile (module.js:409:26)
                                        zwave.0 2016-11-10 18:36:07.377 error at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
                                        zwave.0 2016-11-10 18:36:07.377 error at require (internal/module.js:12:17)
                                        zwave.0 2016-11-10 18:36:07.377 error at Module.require (module.js:353:17)
                                        zwave.0 2016-11-10 18:36:07.377 error at Function.Module._load (module.js:300:12)
                                        zwave.0 2016-11-10 18:36:07.377 error at Object.Module._extensions..node (module.js:434:18)
                                        zwave.0 2016-11-10 18:36:07.377 error at Error (native)
                                        zwave.0 2016-11-10 18:36:07.377 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                                        zwave.0 2016-11-10 18:36:07.370 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                                        zwave.0 2016-11-10 18:36:07.252 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v4.6.2 `
                                        Stick wird aber vom System erkannt
                                         ~ # ls -al /dev/ttyA*
                                        crw-rw---- 1 root dialout 166, 0 Nov 10 18:35 /dev/ttyACM0
                                        alex-AKOYA-E1318T iobroker # node node_modules/iobroker.zwave/main.js --force --logs
                                        [Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory]
                                        terminating
                                        alex-AKOYA-E1318T open-zwave-master # ls
                                        ChangeLog  cpp     distfiles.mk  docs    INSTALL         libopenzwave.pc  libopenzwave.so.1.4  makedist  MinOZW         openzwave.spec  README.md
                                        config     debian  dist.mk       dotnet  libopenzwave.a  libopenzwave.so  license              Makefile  openzwave.dsc  ozw_config
                                        • DutchmanD
                                          DutchmanD
                                          Dutchman
                                          @Alex1808:
                                          terminating
                                          Siehe Post von mir http://forum.iobroker.net/viewtopic.php … =20#p39449
                                          84.2k
