RFlink (LOS GEHT ES ) Bestellung d.Hardware (20€) + 5€ Spende an Forum f.d. Adapter (crowdfunding like :-)
New RFLink firmware (R44) now available!
Brand new RFLink Gateway firmware adds support for Ikea Ansluta, Philips Living Colors Gen1, MySensors devices and has "Mini" GPIO.
For Ansluta or Living Colors you will need a CC2500 module. Details on how to connect these modules are on the Wiring details page.
Changelog:
R44:
New Device: Ikea Ansluta (2.4 Ghz device, CC2500 transceiver required)
New Device: Philips Living Colors Generation 1 (2.4 Ghz device, CC2500 transceiver required)
New Device: Friedland DC44
New Device: Warema EWFS shutters and awnings
New Device: Bosch DID09T951, Bosch DID09T950 and compatible ventilation units
New Device: Siemens SF-01 and compatible ventilation units
New Device: Wave Design SF-01 and compatible ventilation units
New Device: Visonic MCT-302 open and close signal
New Device: Ningbo KD-205-1 switch set
New Device: Steffen Power Switch (1204380 3M)
New Device: Bresser weather sensor
New Device: RFTech 210TX weather sensor
New Feature: Bluetooth LE Advertisement packet sniffing experimental (NRF24L01 required, needs to be wired for MiLight)
New Feature: MySensors packet sniffing experimental (NRF24L01 required, needs to be wired for MiLight)
New Device: MySensors temperature and humidity devices (more types to follow) (NRF24L01 required, needs to be wired for MiLight)
Fixed: Improved OWL CM130 recognition
Fixed: Revolt power reporting corrected
Fixed: RFmeter values presented in hexadecimal
Fixed: Improved Baldr signal recognition
Added: Friedland PIR checksum calculation
Added: GPIO 4 input and 4 output pins can be used as on/off or push button devices
Hallo, für den Garagentor habe ich noch ein TüR/Fenster-Kontakt gekauft. 2.99€ ohen Versandkosten :lol: Das Teil soll kompartibel sein! :mrgreen:
Link: http://www.dx.com/de/p/oudi-ad-87-433mh … Bw1WTXy070
ich freue mich schon auf den RfLink, kannst Du es abschätzen wie lange Du noch für die Auslieferung benötigst?
Gruß an die Bastler
gibt es auch Fotos von der HW?
Ist 433Mhz Empfänger und Sender dabei?
Ist da Atmge2560 dabei?
Lieferzeiten?
das würde mich auch sehr interessieren….
In China sind weit verbreitet die Sender Chinese transmitter (XD-FST FS1000A) und der nebenan abgebildete Empfänger (XY-MK-5V) .
Laut ganz vielen Recensionen soll der Sender sehr gut sein, was man nicht von dem Empänger sagen kann. Hierbei soll der Empfänger gerade mal bis 5m Reichweite funktionieren. Danach streikt das Teil. Interessant ist, was wir da bekommen werden....
Ich habe mir einen RXB6 433 Mhz Superheterodyne Funkempfänger zusätzlich gekauft.
Hierbei erreicht man deutlich größere Reichweiten. Laut vielen Tests sollen es 15-25m sein. In China kostet die Teile ca. 2,50€ und in DE um die 5€.
http://www.ebay.de/itm/172297596527?_tr ... EBIDX%3AIT
Eine Antenne für 433 Mhz kann man sich selbst aus Kupferdrahr bauen. Anleitungen gibt es satt im Netz.
Gibt es ein Gehäuse dazu? Fragen über Fragen .... :), ich weiss dass man für 20€ nicht viel erwarten kann, deshlab da die Fragen was alles dabei ist. So kann man sich schon mal vorab etwas die Hardware anpassen.
Ich hole mir noch einen Arduino Mega 2560 dazu um noch parallel die Domoticz Software auzuprobieren.
1526_s-l1600.jpg -
danke knopers1!
Jeder kriegt ein mega2560, GEHÄUSE aus Plexiglas, ein Kombi aus Empfänger und receiver mit Antennen !
es dauert ein bischen länger, d ich verschiedene Empfänger mit unterschiedlichen antennen teste.
Bis jetzt muss ich sagen ein gerade Draht (ca 17cm) nicht gewickelt funktioniert am besten.
die kupferantennen zum anlöten sind bisschen schlechter aber KLEINER :-)
Hi folks,
Hat jemand schon erfahrung mit dem RF-Link gesammelt und wie verknuepfen mit z.b. KAKU hin zu bekommen sind ?
Ich benutze derzeit dafuer de RFXCom und domotiz, da die KAKU module ein pairing brauchen sendet Domoticz halt das signal wodurch ein handshake entsteht.
Der adapter gebt mir den eindruk das nur geraet welche senden hierdurch erkannt werden ? Um das 433Mhz band gut ausnutzen zu koennen muesste man sowohl "blind" senden/empfangen als auch den handshake machen koennen.
Ich probieren dies gerade mit de RFXCom und Node-red instanzen zu machen nur da ist meine jetzige loesung (Domoticz ==> MQTT ==> oObroker ==> MQTT ==> Domoticz doch leichter :P (aber sehr aufwendich)
Es waere cool wen man die irgendwie uernehmen koennte, fuer mich waere support RFLink + RFXCom der hammer.
RFXCom: http://www.rfxcom.com/store/Transceivers/14103
NodeModul: https://www.npmjs.com/package/node-red-contrib-rfxcom
Greetz,
Dutch
PS: Warum RFXCom anstatt RFLink: Ich kennen nicht alle starken von RFLink, by RFXCom is die firmware bereits da wohl nahezu alle garaete und protocolle (auch handshake) unterstuetzt werden. Vielleich sollte dies auch in einem seperaten thread besprochen werden, war vor allem neugierig nach dem adapter ob der nicht RFLink + RFXCom supporten koennte (fuer spende bereit !)
Ich hebe andere Fragen.
Da der Kollege Maxtox doch ein paar Tage länger braucht um die Hardware zu verschicken, habe ich mir ein Arduino Mega Board 2560 inkl. Sender und Empfänger + ein paar Dupont Kabel 20cm Stecker und Buchse gekauft.
Jetzt habe ich ein paar Fragen zu der Einrichtung der Hardware.
Die Verdrahtung verschiedener Sender und. Empfänger ist auf der Seite gut beschrieben. Ebenfalls stehen dort auch Informationen, welche Sender und Empfänger gut sind, und welche davon weniger geeignet sind. Evtl. sollte der Kollege Maxtox nicht "das Rad neuerfinden", sondern einfach mal die Hardware aussuchen, die bereits von anderen getestet und für gut befundet wurde.
http://www.nemcon.nl/blog2/wiring
Ebenso findet man dort auch die Firmware RFLink Firmware 44 und eine gute Anleitung wie man die Firmware auf den Arduino bekommt.
Jetzt aber zu meiner Frage!
Ist das der richtige Weg? Soll dort diese Firmware drauf? was muß ich noch beachten, damit ich den Arduino mir RFLink betreiben kann?
~~http://up.picr.de/27357421xg.jpg" />
~~http://up.picr.de/27357423df.jpg" />
~~http://up.picr.de/27357424jd.jpg" />
~~http://up.picr.de/27357425xr.jpg" />
~~http://up.picr.de/27357426ee.jpg" />
http://up.picr.de/27357430dj.jpg" />~~~~~~~~~~ -
habt ihr schon adapter "rflink" runtergeladen?…da habt ihr sogar möglichkeit direkt den sketch hochzuladen!!!! `
ich habe den Adapter "rflink" runtergeladen, kann aber die Stelle nicht seher, wo man den Sketch laden kann. Kann es sein, dass man dazu erst die Hardware haben muß, die dann verbunden ist?
kannst Du nur grob sagen, was man auf den Arduino für Software hochladen muß? Soll es die Firmware RFLink Gateway R44 sein?
Einfach hier die neueste Firmware runterladen:
http://www.nemcon.nl/blog2/download
dann den Arduino Mega 2560 mit dem RFLINKloader flashen, einen 433 MHz Empfänger an Pin 19
Mega 2560 an den Raspi (oder an den Rechner auf dem IOBroker läuft)
Hat bei mir direkt funktioniert ;-)
LaCrosse 1 gerade jetzt, TEMP: 21.2
mega an den raspi…
adapter im iobroker admin installieren
im adapter richtigen usb wählen (usb0 oder usb1 o.ä)
auf den 3ten reiter =flash arduino gehen...
den file mit endung .hex aus dem angehängten archiv draufdropen und schon ist es fertig geflasht...
933_rflink_v1.1_r44.zip -
