  3. Off Topic
  4. Proxmox
  5. Proxmox container backup fehler
Geplant Angeheftet Gesperrt Verschoben Proxmox
backuppiholeproxmox
30 Beiträge 11 Kommentatoren 8.6k Aufrufe 11 Beobachtet
  • WebrangerW Offline
    WebrangerW Offline
    Webranger
    Steht auf "Max Backups 15"
    Wenn ich das Backup von Hand starte kommt folgendes:
    INFO: starting new backup job: vzdump 102 --remove 0 --mode snapshot --node pve --storage NFSBackup --compress lzo
    INFO: Starting Backup of VM 102 (lxc)
    INFO: Backup started at 2019-07-23 17:12:06
    INFO: status = running
    INFO: CT Name: pi-hole
    INFO: backup mode: snapshot
    INFO: ionice priority: 7
    INFO: create storage snapshot 'vzdump'
      Using default stripesize 64.00 KiB.
      For thin pool auto extension activation/thin_pool_autoextend_threshold should be below 100.
      Logical volume "snap_vm-102-disk-0_vzdump" created.
      WARNING: Sum of all thin volume sizes (216.38 GiB) exceeds the size of thin pool pve/data and the size of whole volume group (118.99 GiB)!
    INFO: creating archive '/mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-17_12_06.tar.lzo'
    INFO: tar: /mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-17_12_06.tmp: Cannot open: Permission denied
    INFO: tar: Error is not recoverable: exiting now
    INFO: remove vzdump snapshot
      Logical volume "snap_vm-102-disk-0_vzdump" successfully removed
    ERROR: Backup of VM 102 failed - command 'set -o pipefail && lxc-usernsexec -m u:0:100000:65536 -m g:0:100000:65536 -- tar cpf - --totals --one-file-system -p --sparse --numeric-owner --acls --xattrs '--xattrs-include=user.*' '--xattrs-include=security.capability' '--warning=no-file-ignored' '--warning=no-xattr-write' --one-file-system '--warning=no-file-ignored' '--directory=/mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-17_12_06.tmp' ./etc/vzdump/pct.conf '--directory=/mnt/vzsnap0' --no-anchored '--exclude=lost+found' --anchored '--exclude=./tmp/?*' '--exclude=./var/tmp/?*' '--exclude=./var/run/?*.pid' ./ | lzop >/mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-17_12_06.tar.dat' failed: exit code 2
    INFO: Failed at 2019-07-23 17:12:07
    INFO: Backup job finished with errors
    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
      WebrangerW Offline
      Webranger
      Hmm Backup local geht und legt mir ohne probleme 500 mb datei an.
      NFSBackup geht halt nicht???
      • BBTownB BBTown
        @Webranger
        @FredF sagte in Proxmox container backup fehler:
        in der kostenlosen Version von Proxmox kein weiteres mehr machen...
        Doch, das geht schon, aber wenn man ein Ziel für Backup definiert, dann ist - soviel ich mich erinnere - "1 " voreingestellt, ... aber du kannst den Wert erhöhen.
        FredFF Offline
        FredFF Offline
        FredF
        Most Active Forum Testing
        @BBTown sagte in Proxmox container backup fehler:
        Wieder was gelernt, danke
        • WebrangerW Webranger
          Ich habe seit Samstag ein pihole im Container auf proxmox. Datensicherung eingerichtet für nachts und bekomme dann folgenden Fehler.
          102: 2019-07-23 02:00:03 INFO: Starting Backup of VM 102 (lxc)
          102: 2019-07-23 02:00:03 INFO: status = running
          102: 2019-07-23 02:00:03 INFO: CT Name: pi-hole
          102: 2019-07-23 02:00:03 INFO: backup mode: snapshot
          102: 2019-07-23 02:00:03 INFO: ionice priority: 7
          102: 2019-07-23 02:00:03 INFO: create storage snapshot 'vzdump'
          102: 2019-07-23 02:00:05 INFO: creating archive '/mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-02_00_03.tar.lzo'
          102: 2019-07-23 02:00:05 INFO: tar: /mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-02_00_03.tmp: Cannot open: Permission denied
          102: 2019-07-23 02:00:05 INFO: tar: Error is not recoverable: exiting now
          102: 2019-07-23 02:00:05 INFO: remove vzdump snapshot
          102: 2019-07-23 02:00:05 ERROR: Backup of VM 102 failed - command 'set -o pipefail && lxc-usernsexec -m u:0:100000:65536 -m g:0:100000:65536 -- tar cpf - --totals --one-file-system -p --sparse --numeric-owner --acls --xattrs '--xattrs-include=user.*' '--xattrs-include=security.capability' '--warning=no-file-ignored' '--warning=no-xattr-write' --one-file-system '--warning=no-file-ignored' '--directory=/mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-02_00_03.tmp' ./etc/vzdump/pct.conf '--directory=/mnt/vzsnap0' --no-anchored '--exclude=lost+found' --anchored '--exclude=./tmp/?*' '--exclude=./var/tmp/?*' '--exclude=./var/run/?*.pid' ./ | lzop >/mnt/pve/NFSBackup/dump/vzdump-lxc-102-2019_07_23-02_00_03.tar.dat' failed: exit code 2
          Kann mir evtl jemand sagen warum er das nicht macht? Warum kann er das gerade selbst erstellte backup nicht öffnen und meckert dann?
          Danke und Gruss Danyel
          @Webranger ich hatte gerade den gleichen Fehler beim Backup auf NFS.
          Backup von VM geht, Backup von CT geht nicht.
          Lösung:
          Auf dem Host muss in der Datei /etc/vzdump.conf ein tmp-Folder angegeben werden.
          https://www.reddit.com/r/Proxmox/comments/ca7mep/cannot_backup_one_container/
          • E Offline
            ecki945
            Ich muss das Thema hier leider wieder hochholen. Kämpfe mit dem gleichen Problem. Kein Backup möglich wegen vermutlich Zugriffsproblemen. Das seltsame ich kann nur mit bei meinem Iobroker Container kein Backup ausführen. Egal ob lokal oder auf dem NAS. Die anderen beiden Container die laufen machen da keine Probleme.
            Temp Verzeichnis in vzdump.conf habe ich gemacht.
            INFO: starting new backup job: vzdump 100 --compress lzo --mode snapshot --node NUC --storage Syno-Backup --remove 0
            INFO: Starting Backup of VM 100 (lxc)
            INFO: Backup started at 2020-01-21 05:12:15
            INFO: CT Name: IobrokerCT
              Logical volume "snap_vm-100-disk-0_vzdump" created.
            INFO: creating archive '/mnt/pve/Syno-Backup/dump/vzdump-lxc-100-2020_01_21-05_12_15.tar.lzo'
            INFO: tar: ./var/cache/private: Cannot open: Permission denied
            INFO: tar: ./var/log/btmp: Cannot open: Permission denied
            INFO: tar: ./var/log/private: Cannot open: Permission denied
            INFO: tar: ./var/log/mail.err: Cannot open: Permission denied
            INFO: tar: ./var/lib/private: Cannot open: Permission denied
            INFO: Total bytes written: 3676989440 (3.5GiB, 164MiB/s)
            INFO: tar: Exiting with failure status due to previous errors
              Logical volume "snap_vm-100-disk-0_vzdump" successfully removed
            ERROR: Backup of VM 100 failed - command 'set -o pipefail && lxc-usernsexec -m u:0:100000:65536 -m g:0:100000:65536 -- tar cpf - --totals --one-file-system -p --sparse --numeric-owner --acls --xattrs '--xattrs-include=user.*' '--xattrs-include=security.capability' '--warning=no-file-ignored' '--warning=no-xattr-write' --one-file-system '--warning=no-file-ignored' '--directory=/tmp/vzdumptmp7276' ./etc/vzdump/pct.conf ./etc/vzdump/pct.fw '--directory=/mnt/vzsnap0' --no-anchored '--exclude=lost+found' --anchored '--exclude=./tmp/?*' '--exclude=./var/tmp/?*' '--exclude=./var/run/?*.pid' ./ | lzop >/mnt/pve/Syno-Backup/dump/vzdump-lxc-100-2020_01_21-05_12_15.tar.dat' failed: exit code 2
            INFO: Failed at 2020-01-21 05:12:41
            TASK ERROR: job errors
            Hat jemand eine Idee?
            • XxJooOX Offline
              XxJooOX Offline
              XxJooO
              Das ist jetzt nicht hilfreich, aber bei mir funktioniert es im Moment grundsätzlich:
              Virtual Environment 6.1-5
              Suche
              Container 202 (ioBrokerDebian10) auf Knoten 'pve'
              SystemProxmoxBackup-NAS
              lxc-202-
              Server-Ansicht
              Logs
              INFO: starting new backup job: vzdump 202 --remove 0 --storage SystemProxmoxBackup-NAS --compress gzip --mode snapshot --node pve
              INFO: Starting Backup of VM 202 (lxc)
              INFO: Backup started at 2020-01-21 05:46:51
              INFO: CT Name: ioBrokerDebian10
                Logical volume "snap_vm-202-disk-0_vzdump" created.
              INFO: creating archive '/mnt/pve/SystemProxmoxBackup-NAS/dump/vzdump-lxc-202-2020_01_21-05_46_51.tar.gz'
              INFO: Total bytes written: 1512294400 (1.5GiB, 14MiB/s)
              INFO: archive file size: 606MB
                Logical volume "snap_vm-202-disk-0_vzdump" successfully removed
              INFO: Finished Backup of VM 202 (00:01:46)
              INFO: Backup finished at 2020-01-21 05:48:37
              INFO: Backup job finished successfully
              TASK OK
              Mein Proxmox steht auf 6.1-5 und ist im Moment auch absolut aktuell, da ich erst seit dem Wochenende daran arbeite. Vielleicht bringt es etwas, ein apt update und ein apt upgrade zu machen. Ansonsten würde ich zumindest proxmox mal neu starten und schauen, ob es dann geht.
              Und dann boeobachte ich noch ein eigenartiges Phänomen bei mir, das aber eher mitd er Synology NAS zu tun hat: Bevor ich das System am Wochenende neu aufgesetzt habe hatte ich festegestellt, dass das eingerichtete Backup seit einigen Tagen nicht gelaufen war. Hier kam aber ein mount Fehler von der Syno. Gleiches Problem mit dem mount hatte ich schon mal unter ioBroker mit backitup-adapter. Da musste ich das Verzeichnis auf der Syno neu anlegen, sonst funktionierte es nicht mehr. Ich kann mich des Eindruckes nicht erwehren, dass updates der Syno manchmal Probleme machen, die dann später den NFS mount behindern...
              ioBroker auf Intel NUC - Homematic CCU3/pivCCU auf Raspi 3B+
              • E Offline
                ecki945
                Das seltsame bei mir ist, dass das "gleiche" Backup ja bei den anderen beiden LXC Container funktioniert. Nur beim IoBroker Container nicht, egal ob ich als Ziel das Synology NAS angebe oder Lokal. Fehlermeldung ist in beiden Fällen "Permission denied".
                Alle 3 Container laufen auch Fehlerfrei und basieren auf nem Debian 9 Template.
                C 1 Antwort Letzte Antwort
                • E ecki945
                  Chrisidonner
                  @ecki945 was hat dir den nun geholfen ? Stehe vor dem selben Problem ?!?!?
                  E Meister MopperM 2 Antworten Letzte Antwort
                  • C Chrisidonner
                    ecki945
                    @Chrisidonner noch gar nix. Der Fehler ist, dass ich beim Anlegen des Containers nicht die richtigen Einstellungen gemacht habe. Wird darauf hinauslaufen nen neuen Container mit iobroker zu erstellen. Aktuell sind andere Sachen wichtiger. Deshalb muss das Warten.
                    • C Chrisidonner
                      Meister MopperM Online
                      Meister Mopper
                      schrieb am zuletzt editiert von Meister Mopper
                      @Chrisidonner Das Problem hatte ich auch, weiter oben wird ja angegeben, dass bei einem unprivilegierten Container die Datei
                      sudo nano /etc/vzdump.conf
                      modifiziert werden muss, damit der Rechtekonflikt aufgelöst werden kann:
                      # vzdump default settings
                      tmpdir: /tmp
                      Diese Lösung folgt der Empfehlung aus diesem link.
                      Proxmox und HA ...
                        tmpdir: /tmp
                        Chrisidonner
                        @Meister-Mopper ah ok danke dafür .... bekomme ich net hin :-( habe bisher auch nur den IO instaliert ohne irgendwelche einstellung ... kann ich diesen Contaioner einfach löschen und einen neuen erstellen ohne den Hacken bei unprivileged oder?
                        • C Chrisidonner
                          crunchipC Offline
                          crunchipC Offline
                          @Chrisidonner du kannst ein Backup erstellen deines CT, dann den CT löschen, anschliessend kannst du das Backup zurückspielen, dabei hast du die Option unprivilegierten ja/nein auszuwählen
                            Chrisidonner
                            @crunchip ich kann kein Backup auf dem nas machen.... bindet man eine usb ssd auch so ein wie die syno? Geht es dann evt lokal über USB?
                            • C Chrisidonner
                              crunchipC Offline
                              crunchipC Offline
                              @Chrisidonner sagte in Proxmox container backup fehler:
                              wo läuft denn dein Proxmox bzw dein CT?
                              syno hab ich nicht,
                              ne externe USB Platte kannst du mounten und anschliessend einfach als Verzeichnis hinzufügen
                                syno hab ich nicht,
                                Chrisidonner
                                @crunchip proxmox auf einem Nuc und IO in einen LXC Container weiteres habe ich noch nicht vorgenommen da ich es sauber aufsetzten möchte und erst die Backups Funken sollen
                                crunchipC T 2 Antworten Letzte Antwort
                                • C Chrisidonner
                                  crunchipC Offline
                                  crunchipC Offline
                                  @Chrisidonner und wo ist das Problem, wie groß ist dein local, wenn genügend Platz, kannst du dort ein backup drauf spielen
                                  • C Chrisidonner
                                    tritor
                                    schrieb am zuletzt editiert von tritor
                                    @Chrisidonner
                                    ich hatte das Problem auch. Bei einer vollen VM wird das Backup anscheinend direkt auf das NAS geschreiben. Bei einem LXC wird zuerst ein lokeles file erstellt und dann eventuell auch das Ziel geschrieben. Wenn du lokal nicht genug Platz hast, dann geschieht genau das.
                                    Ich habe ein uSD Karte in den NUC geschoben und die als Temp dem System zur Verfügung gestellt.
                                    Dann klappte es auch mit dem Backup des LXC.
                                    Es gibt dazu im Forum auch einen Thread: https://forum.iobroker.net/topic/22995/sd-karte-am-nuc-unter-proxmox-als-backup-nutzen
                                    Gernot
                                    Host: i9 server Proxmox , Debian 13.4 for ioBroker
                                    ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
                                    Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
                                    Grafana 13.0.1 / InfluxDB 2.8.0
                                    • T tritor
                                      @Chrisidonner
                                      Chrisidonner
                                      @tritor hat gefunkt. Lässt sich auch wieder einspielen und nun auch Backup aufs Nas
                                      Vielen Dank euch
                                        Kueppert
                                        @meister-mopper sagte in Proxmox container backup fehler:
                                        Oh man, hatte auch das Problem jetzt. Hab vorher immer nur VMs genutzt. Mit dem editieren der Datei (Shell vom Proxmox-Node öffnen) hats geklappt :)
