  4. Test Coronavirus Statistics for ioBroker
    apollon77A
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 581.7k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    Aktuelle Test Version 0.6.9
    Veröffentlichungsdatum 22-03-2021
    Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
    NPM npm i ioBroker.coronavirus-statistics@latest
    Adapter to show Global Corona Virus information and current reports
    Coronavirus Live Statistics adapter for ioBroker
    There is no configuration required, after installation it will :
    • Receive global information world-wide and write it to "global_totals"
    • Create a folder for each country with all relevant information regarding COVID-19
    • Update the information every 15 minutes
    The following information is available :
    Datapoint Details
    active Amount of current infected people
    cases Amount of totally known cases
    casesPerOneMillion Amount of totally known cases per million citizen
    critical Amount of critical situation (Hospitalized)
    deaths Amount of current registered deaths
    deathsPerOneMillion Amount of current registered deaths per million citizen
    recovered Amount of totally known recovered cases
    todayCases New Cases by Today
    todayDeaths Amount of totally known people died today
    test Total number of covid-19 tests taken globally
    tests per one million counties Total number of covid-19 tests taken globally per one million
    Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
    German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
    Generic Source : https://coronavirus-19-api.herokuapp.com
    Advanced settings
    Option Description
    All Countries Get data for all countries World-Wide (Default: false)
    Continents Group total amounts by continent in seperate state (Default: false)
    Delete unused States Delete data when countries are deselected (Default: false)
    German counties Get counties data for Germany (Selected only, Default false)
    German federal states Get federal state data for Germany (Selected only, Default false)
    Get all German federal states Get federal state data for Germany (Default false)
    Get all German counties Get all counties data for Germany (Default false)
    For Germany only
    It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
    You can choose to recieve all data or just select specific regions in advanced settings.
    Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
    Add missing countries
    It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
    coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
    Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
    List with country names
    With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
    The JSON string then looks like this, for example:
    	"Cabo_Verde": "Cape Verde",
    	"Timor-Leste": "East Timor"
    As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
    Changelog
    D
    D
    deta
    #737
    @Dutchman Habe gerade diese Seite gefunden, vom RKI Region Hannover,
    da ist links unten alle einzelenen Orte eingetragen, mit den Zahlen. Sieht doch so aus, als wenn die Daten doch da wo als API zur Verfügung stehen. Ich will jetzt keinen extra Account anlegen wollen um weiter zu Forschen, kannst du das mal bitte Prüfen und wäre toll, diese Unterteilungen auch noch abrufen zu können.
    https://experience.arcgis.com/experience/7d52c64b899d4d72bde23950dad56ffb
    • S
      S
      Supermicha
      #738
      Moin zusammen
      mein Corona-Adapter aktualisiert seit ca. einer Woche nicht mehr.
      Wenn ich ihn neu starte, dann kommen 1-2 mal neue Werte rein, danach nichts mehr.
      Hier mal das Log von heute Nacht
      2020-12-06 04:00:00.014  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 04:15:04.045  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 04:30:00.014  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 04:45:04.048  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 05:00:00.016  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 05:15:04.055  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 05:30:00.015  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 05:45:04.044  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-06 06:00:00.014  - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      und hier mal von eben, da scheint er aktualisiert zu haben...
      2020-12-06 14:45:01.173  - debug: coronavirus-statistics.0 (15812) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-12-06 14:45:01.273  - debug: coronavirus-statistics.0 (15812) Objects client ready ... initialize now
      2020-12-06 14:45:01.280  - debug: coronavirus-statistics.0 (15812) Objects create System PubSub Client
      2020-12-06 14:45:01.283  - debug: coronavirus-statistics.0 (15812) Objects create User PubSub Client
      2020-12-06 14:45:01.286  - debug: coronavirus-statistics.0 (15812) Objects client initialize lua scripts
      2020-12-06 14:45:01.326  - debug: coronavirus-statistics.0 (15812) Objects connected to redis: 127.0.0.1:9001
      2020-12-06 14:45:01.341  - debug: coronavirus-statistics.0 (15812) objectDB connected
      2020-12-06 14:45:01.345  - debug: coronavirus-statistics.0 (15812) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-12-06 14:45:01.363  - debug: coronavirus-statistics.0 (15812) States create User PubSub Client
      2020-12-06 14:45:01.369  - debug: coronavirus-statistics.0 (15812) States create System PubSub Client
      2020-12-06 14:45:01.405  - debug: coronavirus-statistics.0 (15812) States connected to redis: 127.0.0.1:9000
      2020-12-06 14:45:01.407  - debug: coronavirus-statistics.0 (15812) statesDB connected
      2020-12-06 14:45:02.369  - debug: coronavirus-statistics.0 (15812) Plugin sentry Initialize Plugin (enabled=true)
      2020-12-06 14:45:02.594  - info: coronavirus-statistics.0 (15812) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 14:45:02.636  - debug: coronavirus-statistics.0 (15812) Configuration object before config load : {"deleteUnused":true,"getContinents":true,"getGermanyFederalStates":true,"getGermanyCities":true,"getGermanyCounties":false,"getAllGermanyFederalStates":true,"getAllGermanyCities":false,"getAllGermanyCounties":false,"loadAllCountrys":false,"selectedGermanyFederalStates":[],"selectedGermanyCities":["Rostock"],"selectedGermanyCounties":[],"countries":["Australia","Austria","China","Denmark","Germany","Italy","Poland","Russia","Spain","Switzerland","United Kingdom","United States"]}
      2020-12-06 14:45:07.054  - debug: coronavirus-statistics.0 (15812) Data from COVID-19 API received : [object Object]
      2020-12-06 14:45:07.055  - debug: coronavirus-statistics.0 (15812) Create_state called for : global_totals.updated with value : 1607261771117
      2020-12-06 14:45:07.056  - debug: coronavirus-statistics.0 (15812) Write value : false
      2020-12-06 14:45:07.108  - debug: coronavirus-statistics.0 (15812) Create_state called for : global_totals.cases with value : 66991090
      2020-12-06 14:45:07.109  - debug: coronavirus-statistics.0 (15812) Write value : false
      2020-12-06 14:45:07.129  - debug: coronavirus-statistics.0 (15812) Create_state called for : global_totals.todayCases with value : 150887
      2020-12-06 14:45:07.131  - debug: coronavirus-statistics.0 (15812) Write value : false
      2020-12-06 14:45:07.151  - debug: coronavirus-statistics.0 (15812) Create_state called for : global_totals.deaths with value : 1536864
      2020-12-06 14:45:07.153  - debug: coronavirus-statistics.0 (15812) Write value : false
      2020-12-06 14:45:07.177  - debug: coronavirus-statistics.0 (15812) Create_state called for : global_totals.todayDeaths with value : 3033
      2020-12-06 14:45:07.177  - debug: coronavirus-statistics.0 (15812) Write value : false
      2020-12-06 14:45:07.232  - debug: coronavirus-statistics.0 (15812) Create_state called for : global_totals.recovered with value : 46364717
      2020-12-06 14:45:07.234  - debug: coronavirus-statistics.0 (15812) Write value : false
      2020-12-06 14:46:17.832  - debug: coronavirus-statistics.0 (15812) Plugin sentry destroyed
      2020-12-06 14:46:17.833  - info: coronavirus-statistics.0 (15812) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      Kann mir da keinen Reim drauf machen, woran es liegen könnte... Sieht für mich unauffällig aus...
      auch wenn ich ihn jetzt nach dem Adapter-Neustart beobachte, läuft alles glatt, aber irgendwann scheint er sich auszuklinken... habe ihn gestern abend mal komplett deinstalliert und wieder neu installiert, danach lief alles gut. und als ich heute früh geguckt habe, war die letzte Aktualisierung 23:15....
      das log von gestern abend mal vollständig...
      (da stand die Log-Stufe allerdings nur auf Info)
      2020-12-05 22:30:02.380 - info: coronavirus-statistics.0 (22350) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.20.0, js-controller: 3.1.6
      2020-12-05 22:31:12.416 - info: coronavirus-statistics.0 (22350) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-12-05 22:45:07.100 - info: coronavirus-statistics.0 (2844) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.20.0, js-controller: 3.1.6
      2020-12-05 22:46:11.495 - info: coronavirus-statistics.0 (2844) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-12-05 23:00:02.370 - info: coronavirus-statistics.0 (15530) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.20.0, js-controller: 3.1.6
      2020-12-05 23:01:06.733 - info: coronavirus-statistics.0 (15530) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-12-05 23:15:07.221 - info: coronavirus-statistics.0 (28230) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.20.0, js-controller: 3.1.6
      2020-12-05 23:30:00.029 - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      2020-12-05 23:45:04.050 - warn: host.ioBroker instance system.adapter.coronavirus-statistics.0 already running with pid 28230
      um 23:30 kommt die erste Warnung...
      • S Supermicha
        Moin zusammen
        K
        K
        kwittig
        #739
        @Supermicha
        Das Problem hatte ich auch, es half nur die Instance zu deinstallieren und neu zu installieren.
        Anscheinend wird der Adapter manchmal nach der Abfrage der Daten nicht richtig beendet.
        Beim nächsten Startversuch tritt dann der Fehler auf.
        Seit dem ich die Abfragezeit auf 30 Minuten eingestellt habe, ist das nicht mehr vorgekommen.
        Gruss Klaus
        • B
          B
          bauerpower
          #740
          kurze Frage ... von der Logik her sollte das Bundesland eigentlich höhere Zahlen haben als
          der Kreis... oder !!??
          Habe mir die Datenpunkte angesehen und die sind richtig?
          Liebe Grüsse
          Jörg
          • B bauerpower
            Liebe Grüsse
            Jörg
            K
            K
            kwittig
            #741
            @bauerpower
            Das sind die Fälle je 100K in 7 Tagen. warum sollten diese unbedingt im gesamten Bundesland grösser sein?
            • K kwittig
              @bauerpower
              B
              B
              bauerpower
              #742
              @kwittig
              Alles klar Du hast Recht... ich war so mit dem implementieren beschäftigt das ich nur die Zahlen betrachtet habe!
              Lieben Dank!
              Jörg
              • D
                D
                deta
                schrieb am zuletzt editiert von deta
                #743
                Kann es sein, das die API hinterher hängt?
                Ich update immer immer um 00:00 Uhr die Daten. Denke das ist der Schnittpunkt oder?
                Heute z.b.
                Deutschlandzahlen lt. Abfrage API 28179,
                aber direkt auf der RKi Seite 29.875
                Wie kommt das zustande?
                • D deta
                  Heute z.b.
                  lobomauL
                  lobomauL
                  lobomau
                  #744
                  @deta ja, ich habe bei BRD oft gegen 3:00 Uhr den Nullabgleich. Dann wirst du eine Differenz haben, wenn es um 00:00 Uhr machst. Ich würde öfter updaten. Warum nicht einmal pro Stunde?
                  Hier siehst du einen Beispielhaften Verlauf:
                  Host: NUC8i3 mit Proxmox:
                  • Slave: Pi4
                  • lobomauL lobomau
                    D
                    D
                    deta
                    #745
                    @lobomau Hab mir mal jetzt alle Punkte angeschaut, das ist zwischen 3 und 4 Uhr wo der Punkt gesetzt wird. Und da vor 5 Uhr nix passiert immer, hab ich das mal jetzt auf 5 Uhr gesetzt, werde es jetzt mal beobachten.
                      Datapoint Details
                      Advanced settings
                      Option Description
                      For Germany only
                      Changelog
                      D
                      D
                      deta
                      #746
                      @Dutchman gibt es auch die Möglichkeit, der Genesenen in den Regionen und Städten abzurufen?
                      Oder stehen die Daten nicht zur Verfügung?
                      Damit man eine Zahl hat, was jetzt aktuell noch Erkrankt ist.
                        Datapoint Details
                        Advanced settings
                        Option Description
                        For Germany only
                        Changelog
                        A
                        A
                        andyb
                        #747
                        @Dutchman
                        Impfquoten wären jetzt natürlich auch interessant 😬
                        Impfquotenmonitoring RKI (https://www.rki.de/DE/Content/InfAZ/N/Neuartiges_Coronavirus/Daten/Impfquotenmonitoring.xlsx)
                        • D deta
                          DutchmanD
                          DutchmanD
                          Dutchman
                          #748
                          @deta
                          Für DE stehen die Daten leider nicht als API zur Verfügung, habe im GIT issue eine eventuelle option hinterlegt wie man die xls vom RKI auslesen könnte
                          Habe aber eine api gefunden für Impfungen auf Landes Niveau diese werde ich implementieren muss aber alles von api V2 nach V3 umbauen also auch bissl testen ☺️
                          D A 3 Antworten Letzte Antwort
                            @deta
                            D
                            D
                            deta
                            #749
                            @Dutchman Hört sich gut an. Wir lassen uns überraschen.
                              @deta
                              A
                              A
                              andyb
                              #750
                              Vielleicht hilft das...
                              link text
                                @deta
                                D
                                D
                                deta
                                #751
                                @Dutchman oho 0.6.4 online..
                                • DutchmanD
                                  DutchmanD
                                  Dutchman
                                  schrieb am zuletzt editiert von Dutchman
                                  #752
                                  @andyb
                                  E HomoranH 2 Antworten Letzte Antwort
                                    @andyb
                                    E
                                    E
                                    ebu
                                    #753
                                    @Dutchman danke, funktioniert :)
                                    • E ebu
                                      NashraN
                                      NashraN
                                      Nashra
                                      Most Active Forum Testing
                                      #754
                                      @ebu sagte in Test Coronavirus Statistics for ioBroker:
                                      Schließe mich an, danke @Dutchman 👍
                                      Gruß Ralf
                                        Datapoint Details
                                        Advanced settings
                                        Option Description
                                        For Germany only
                                        Changelog
                                        D
                                        D
                                        deta
                                        #755
                                        Schon jemand was gebastelt an VIS für die Impfungen?
                                          @andyb
                                          #756
                                          @Dutchman
                                          Hallo Dutch!
                                          ist da noch ein kleiner Bug drin?
                                          84.0k
