  4. Test Adapter mihome-vacuum v2.0.x
    apollon77A
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 769.9k Aufrufe 118 Beobachtet
  • maeusekingM
    maeusekingM
    maeuseking
    schrieb am zuletzt editiert von maeuseking
    #1226
    Moin!
    Nachdem einige Wochen der Adapter problemlos funktionierte, stürzt er nun an einem erfolgreich Übermittelten Befehl ab. Hat dazu jemand einen Tipp?
    Neuinstallation des Adpaters und Reboot des Saugroboters haben nichts gebracht...
    mihome-vacuum.0	2020-11-18 13:45:13.301	debug	(22494) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-11-18 13:45:13.300	info	(22494) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-11-18 13:45:13.296	debug	(22494) Receive <<< Helo <<< 213100200000000013272a775fb51759ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-11-18 13:45:13.285	info	(22494) New generation or new fw(3.5.8,2516) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-11-18 13:45:13.283	info	(22494) extend state mop for State control.fan_power
    mihome-vacuum.0	2020-11-18 13:45:13.271	info	(22494) change states from State control.fan_power
    mihome-vacuum.0	2020-11-18 13:45:13.239	debug	(22494) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-11-18 13:45:13.232	info	(22494) Cloud control disabled
    mihome-vacuum.0	2020-11-18 13:45:13.231	info	(22494) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-11-18 13:45:13.226	debug	(22494) Xiaomi Cloud: Logging in
    mihome-vacuum.0	2020-11-18 13:45:13.224	debug	(22494) load Map creator... true
    mihome-vacuum.0	2020-11-18 13:45:13.169	info	(22494) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.19.1, js-controller: 3.1.6
    mihome-vacuum.0	2020-11-18 13:44:40.465	info	(22435) Terminated (NO_ERROR): Without reason
    mihome-vacuum.0	2020-11-18 13:44:40.464	info	(22435) terminating
    mihome-vacuum.0	2020-11-18 13:44:40.457	error	(22435) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:187:68 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/states
    mihome-vacuum.0	2020-11-18 13:44:40.456	error	(22435) uncaught exception: Cannot read property 'val' of null
    mihome-vacuum.0	2020-11-18 13:44:40.454	debug	(22435) sendMsg[1] >>> {"id":29,"method":"app_segment_clean","params":[19]}
    mihome-vacuum.0	2020-11-18 13:44:40.453	info	(22435) trigger cleaning segment 19
    mihome-vacuum.0	2020-11-18 13:44:40.449	debug	(22435) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-11-18 13:44:40.447	debug	(22435) stateChange mihome-vacuum.0.rooms.717001010826.roomClean {"val":true,"ack":false,"ts":1605703480443,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1605684698520}
    mihome-vacuum.0	2020-11-18 13:44:33.763	debug	(22435) CLEAN_LOGGING[{"Datum":"18.11","Start":"13:12","Saugzeit":"4 min","Fläche":"7.46 m²","Error":0,"Ende":false},{"Datum":"18.11","Start":"13:01","Saugzeit":"11 min","Fläche":"15.31 m²","Error":0,
    Nach einem neuem Befehl wieder direkter Absturz...
    mihome-vacuum.0	2020-11-18 13:49:20.617	info	(22494) Terminated (NO_ERROR): Without reason
    mihome-vacuum.0	2020-11-18 13:49:20.616	info	(22494) terminating
    mihome-vacuum.0	2020-11-18 13:49:20.608	error	(22494) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:187:68 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/states
    mihome-vacuum.0	2020-11-18 13:49:20.607	error	(22494) uncaught exception: Cannot read property 'val' of null
    mihome-vacuum.0	2020-11-18 13:49:20.605	debug	(22494) sendMsg[1] >>> {"id":14,"method":"app_segment_clean","params":[19]}
    mihome-vacuum.0	2020-11-18 13:49:20.604	info	(22494) trigger cleaning segment 19
    EDIT:
    Auch ein komplettes Update nach dieser Anleitung
    https://forum.iobroker.net/topic/37020/nodejs-update-iobroker-installation-via-curl-nicht-möglich/51
    hat nichts geändert...
    Loxone Miniserver Gen 1 / 1 Relay Extension / 2 Extension / 1 Air Extension / 1 1-Wire-Extension / 1 RS485 Extension
    1 Pi4 als ioBroker-Server und zur Visualisierung an einem HP E230t Monitor
    maeusekingM 1 Antwort Letzte Antwort
    • S
      S
      Snapergy
      #1227
      habe versucht den Thread einigermaßen zu überfliegen und habe bezüglich der Zonenreinigung schon herausgefunden, dass man "eigene Befehle senden" aktivieren muss und dann die Zone mit dem Befehl "app_zoned_clean;[[x1,y1,x2,y2,1]]" mit den entsprechenden Koordinaten an den State "mihome-vacuum.0.control.X_send_command"senden muss.
      Gibt es einen Trick, die Koordinaten möglichst einfach rauszukriegen? Die Zonen kann man ja auch in der Weboberfläche anlegen, kriegt man das darüber irgendwie einfach heraus?
      C 1 Antwort Letzte Antwort
      • D3ltoroxpD D3ltoroxp
        Hm, folgendes Problem. Ich habe das Gefühl, das er die Karte immer wieder ändert, also die zugeordneten Räume. Ich habe mir die ganzen Räume angelegt, um über Alexa dann per Befehl bestimmte Zimmer saugen zu lassen. Aber irgendwie ändert sich das ständig, immer wieder sind Räume zusammen gelegt, die ich getrennt hatte. Schau ich hin, sind die wieder zusammen. Andere Räume bekommen dann auch wieder ne andere Farbe und so mit wohl dann auch im Adapter ne andere Room Nummer.
        Kann ich das irgendwie abstellen, das er ständig ne neue Version der Karte anfertigt, oder zumindest die Raumeinteilung in Ruhe lässt ?
        Oder wie habt ihr das gelöst, das er bestimmte Räume auf Befehl reinigt ?
        C
        C
        ChrisXY
        #1228
        @D3ltoroxp eine Lösung gefunden ? Hab ktuell noch einen Deebot T8 überlege zu wechseln weil dort dieses Problem fast täglich ist mit der kaputten/anderen Karte
        • S Snapergy
          C
          C
          Coffeelover
          #1229
          @Snapergy Der einfachste Weg in meinen Augen: App von Flole installieren (https://xiaomi.flole.de), Zone zeichnen, lange auf Reinigen klicken und dann die Koordinaten aus der Zwischenablage kopieren.
          • C Coffeelover
            S
            S
            Snapergy
            #1230
            @Coffeelover
            Danke für deine Antwort, hab es mittlerweile eigenständig gelöst. Screenshot von der Karte mit der Zone [24500,24500,25500,25500], dh. -1000 von der Station weg. Dann in Paint rein, Koordinaten von dem neuen Eckpunkt und Verbindung mit dem Abstand von der Ladestation und mir dann ein Excel gebastelt, was bei Eingabe neuer Pixelkoordinaten aus Paint das ganze in Koordinaten vom Staubsauger umrechnet. Hat prima funktioniert :D
            • S
              S
              Spampunk
              #1231
              ich habe seit ein paar Tagen einen S5 max. Hab den in der Xiaomi Home App eingebunden, deutscher Server. Ich bekomme aber keine Anmeldung im iobroker-Adapter (2.0.7) zustande. Bei Klick auf "get devices" dreht sich das Rad endlos. Ich hatte zwsichenzeitlich die 2.1.1 und sogar den Fork von @Meistertr installiert. Alles zu 100% erfolglos...
              Ich habe zwar auch meinen Token ausgelesen, damit verbindet sich der Adapter dann auch mit meinem Rocky, aber ich bekommen keine Kartendarstellung. Oder hat das eine nichts mit dem anderen zu tun?
              Wäre über Eure Hilfe sehr froh!
              Viele Grüße,
              Timo
              • S Spampunk
                Viele Grüße,
                Timo
                Thomas BraunT
                Thomas BraunT
                #1232
                @Spampunk
                Den Token brauchst du natürlich. Egal welche Version oder Fork oder was auch immer da eingesetzt wird.
                Zur Karte: Auf welchem Betriebssystem bist du da unterwegs?
                Evtl. fehlt da 'canvas'.
                Bitte mal die Log-Einträge vom Start des Adapters zum Besten geben.
                  @Spampunk
                  S
                  S
                  Spampunk
                  schrieb am zuletzt editiert von Spampunk
                  #1233
                  @Thomas-Braun
                  iobroker läuft auf Linux Buster
                  Intel(R) Atom(TM) x5-Z8350 CPU @ 1.44GHz
                  Node.js v12.19.0
                  Hier das Log:
                  2020-12-04 17:35:41.287 - debug: mihome-vacuum.0 (18825) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2020-12-04 17:35:41.727 - debug: mihome-vacuum.0 (18825) Objects client ready ... initialize now
                  2020-12-04 17:35:41.733 - debug: mihome-vacuum.0 (18825) Objects create System PubSub Client
                  2020-12-04 17:35:41.735 - debug: mihome-vacuum.0 (18825) Objects create User PubSub Client
                  2020-12-04 17:35:41.747 - debug: mihome-vacuum.0 (18825) Objects client initialize lua scripts
                  2020-12-04 17:35:41.780 - debug: mihome-vacuum.0 (18825) Objects connected to redis: 127.0.0.1:9001
                  2020-12-04 17:35:41.792 - debug: mihome-vacuum.0 (18825) objectDB connected
                  2020-12-04 17:35:41.796 - debug: mihome-vacuum.0 (18825) Redis States: Use Redis connection: 127.0.0.1:9000
                  2020-12-04 17:35:41.811 - debug: mihome-vacuum.0 (18825) States create User PubSub Client
                  2020-12-04 17:35:41.816 - debug: mihome-vacuum.0 (18825) States create System PubSub Client
                  2020-12-04 17:35:41.841 - debug: mihome-vacuum.0 (18825) States connected to redis: 127.0.0.1:9000
                  2020-12-04 17:35:41.843 - debug: mihome-vacuum.0 (18825) statesDB connected
                  2020-12-04 17:35:43.636 - warn: mihome-vacuum.0 (18825) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                  2020-12-04 17:35:43.637 - warn: mihome-vacuum.0 (18825) This object will not be created in future versions. Please report this to the developer.
                  2020-12-04 17:35:44.478 - info: mihome-vacuum.0 (18825) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.19.1, js-controller: 3.1.6
                  2020-12-04 17:35:44.542 - info: mihome-vacuum.0 (18825) Expert mode disabled, states deleted
                  2020-12-04 17:35:44.544 - info: mihome-vacuum.0 (18825) Cloud control disabled
                  2020-12-04 17:35:44.565 - info: mihome-vacuum.0 (18825) Disconnect
                  2020-12-04 17:35:44.572 - debug: mihome-vacuum.0 (18825) server started on 0.0.0.0:53421
                  2020-12-04 17:35:44.607 - info: mihome-vacuum.0 (18825) Connected
                  2020-12-04 17:35:44.615 - debug: mihome-vacuum.0 (18825) requesting params every: 60 Sec
                  2020-12-04 17:35:44.655 - info: linux-control.0 (1568) successful received data from iota (192.168.37.1:22)
                  2020-12-04 17:35:45.127 - info: mihome-vacuum.0 (18825) set nächster Timer: Nicht verfügbar
                  2020-12-04 17:35:59.623 - debug: mihome-vacuum.0 (18825) no answer for get_status(id:1) received, giving up
                  2020-12-04 17:35:59.632 - debug: mihome-vacuum.0 (18825) no answer for miIO.info(id:2) received, giving up
                  2020-12-04 17:35:59.633 - warn: mihome-vacuum.0 (18825) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                  2020-12-04 17:35:59.832 - debug: mihome-vacuum.0 (18825) no answer for get_consumable(id:3) received, giving up
                  2020-12-04 17:36:00.027 - debug: mihome-vacuum.0 (18825) no answer for get_clean_summary(id:4) received, giving up
                  2020-12-04 17:36:00.231 - debug: mihome-vacuum.0 (18825) no answer for get_sound_volume(id:5) received, giving up
                  2020-12-04 17:36:02.583 - debug: mihome-vacuum.0 (18825) no answer for get_carpet_mode(id:6) received, giving up
                  2020-12-04 17:36:02.588 - debug: mihome-vacuum.0 (18825) no answer for get_room_mapping(id:7) received, giving up
                  2020-12-04 17:36:06.073 - info: web.0 (10285) <==Disconnect system.user.admin from ::ffff:192.168.37.9 vis.0
                  2020-12-04 17:36:19.587 - debug: mihome-vacuum.0 (18825) no answer for get_status(id:8) received, giving up
                  2020-12-04 17:36:24.575 - info: mihome-vacuum.0 (18825) Disconnect
                  2020-12-04 17:36:24.580 - info: mihome-vacuum.0 (18825) Connected
                  2020-12-04 17:36:24.583 - debug: mihome-vacuum.0 (18825) requesting params every: 60 Sec
                  2020-12-04 17:36:32.426 - debug: musiccast.0 (17642) system.adapter.admin.0: logging false
                  2020-12-04 17:36:32.428 - debug: mihome-vacuum.0 (18825) system.adapter.admin.0: logging false
                  2020-12-04 17:36:39.594 - debug: mihome-vacuum.0 (18825) no answer for get_status(id:9) received, giving up
                  2020-12-04 17:36:39.597 - debug: mihome-vacuum.0 (18825) no answer for get_consumable(id:10) received, giving up
                  2020-12-04 17:36:39.796 - debug: mihome-vacuum.0 (18825) no answer for get_clean_summary(id:11) received, giving up
                  2020-12-04 17:36:39.996 - debug: mihome-vacuum.0 (18825) no answer for get_sound_volume(id:12) received, giving up
                  2020-12-04 17:36:44.569 - debug: mihome-vacuum.0 (18825) requesting params every: 60 Sec
                  2020-12-04 17:36:50.026 - debug: mihome-vacuum.0 (18825) Xiaomi Cloud: Logging in
                  2020-12-04 17:36:59.589 - debug: mihome-vacuum.0 (18825) no answer for get_consumable(id:13) received, giving up
                  2020-12-04 17:36:59.595 - debug: mihome-vacuum.0 (18825) no answer for get_status(id:14) received, giving up
                  2020-12-04 17:36:59.790 - debug: mihome-vacuum.0 (18825) no answer for get_clean_summary(id:15) received, giving up
                  2020-12-04 17:36:59.988 - debug: mihome-vacuum.0 (18825) no answer for get_sound_volume(id:16) received, giving up
                  2020-12-04 17:37:04.582 - info: mihome-vacuum.0 (18825) Disconnect
                  2020-12-04 17:37:04.588 - info: mihome-vacuum.0 (18825) Connected
                  2020-12-04 17:37:04.594 - debug: mihome-vacuum.0 (18825) requesting params every: 60 Sec
                  2020-12-04 17:37:12.247 - info: web.0 (10285) <==Disconnect system.user.admin from ::ffff:192.168.37.7 vis.0
                  2020-12-04 17:37:13.816 - info: web.0 (10285) ==>Connected system.user.admin from ::ffff:192.168.37.7
                  2020-12-04 17:37:19.607 - debug: mihome-vacuum.0 (18825) no answer for get_status(id:17) received, giving up
                  2020-12-04 17:37:19.613 - debug: mihome-vacuum.0 (18825) no answer for get_consumable(id:18) received, giving up
                  2020-12-04 17:37:19.808 - debug: mihome-vacuum.0 (18825) no answer for get_clean_summary(id:19) received, giving up
                  2020-12-04 17:37:19.867 - info: host.iota stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                  2020-12-04 17:37:19.869 - info: host.iota stopInstance system.adapter.mihome-vacuum.0 send kill signal
                  2020-12-04 17:37:19.880 - info: mihome-vacuum.0 (18825) Got terminate signal TERMINATE_YOURSELF
                  2020-12-04 17:37:19.882 - info: mihome-vacuum.0 (18825) terminating
                  2020-12-04 17:37:19.884 - info: mihome-vacuum.0 (18825) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2020-12-04 17:37:19.924 - debug: musiccast.0 (17642) system.adapter.admin.0: logging true
                  2020-12-04 17:37:19.928 - debug: mihome-vacuum.0 (18825) system.adapter.admin.0: logging true
                  2020-12-04 17:37:20.006 - debug: mihome-vacuum.0 (18825) no answer for get_sound_volume(id:20) received, giving up
                  2020-12-04 17:37:20.445 - info: host.iota instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2020-12-04 17:37:22.911 - info: host.iota instance system.adapter.mihome-vacuum.0 started with pid 19080
                  2020-12-04 17:37:23.930 - debug: mihome-vacuum.0 (19080) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2020-12-04 17:37:24.373 - debug: mihome-vacuum.0 (19080) Objects client ready ... initialize now
                  2020-12-04 17:37:24.378 - debug: mihome-vacuum.0 (19080) Objects create System PubSub Client
                  2020-12-04 17:37:24.380 - debug: mihome-vacuum.0 (19080) Objects create User PubSub Client
                  2020-12-04 17:37:24.381 - debug: mihome-vacuum.0 (19080) Objects client initialize lua scripts
                  2020-12-04 17:37:24.411 - debug: mihome-vacuum.0 (19080) Objects connected to redis: 127.0.0.1:9001
                  2020-12-04 17:37:24.424 - debug: mihome-vacuum.0 (19080) objectDB connected
                  2020-12-04 17:37:24.428 - debug: mihome-vacuum.0 (19080) Redis States: Use Redis connection: 127.0.0.1:9000
                  2020-12-04 17:37:24.448 - debug: mihome-vacuum.0 (19080) States create User PubSub Client
                  2020-12-04 17:37:24.453 - debug: mihome-vacuum.0 (19080) States create System PubSub Client
                  2020-12-04 17:37:24.481 - debug: mihome-vacuum.0 (19080) States connected to redis: 127.0.0.1:9000
                  2020-12-04 17:37:24.483 - debug: mihome-vacuum.0 (19080) statesDB connected
                  2020-12-04 17:37:26.305 - warn: mihome-vacuum.0 (19080) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                  2020-12-04 17:37:26.307 - warn: mihome-vacuum.0 (19080) This object will not be created in future versions. Please report this to the developer.
                  2020-12-04 17:37:26.964 - info: mihome-vacuum.0 (19080) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.19.1, js-controller: 3.1.6
                  2020-12-04 17:37:27.024 - info: mihome-vacuum.0 (19080) Expert mode enabled, states created
                  2020-12-04 17:37:27.026 - info: mihome-vacuum.0 (19080) Cloud control disabled
                  2020-12-04 17:37:27.047 - info: mihome-vacuum.0 (19080) Disconnect
                  2020-12-04 17:37:27.054 - debug: mihome-vacuum.0 (19080) server started on 0.0.0.0:53421
                  2020-12-04 17:37:27.088 - info: mihome-vacuum.0 (19080) Connected
                  2020-12-04 17:37:27.096 - debug: mihome-vacuum.0 (19080) requesting params every: 60 Sec
                  2020-12-04 17:37:27.615 - info: mihome-vacuum.0 (19080) set nächster Timer: Nicht verfügbar
                  2020-12-04 17:37:42.105 - debug: mihome-vacuum.0 (19080) no answer for get_status(id:1) received, giving up
                  2020-12-04 17:37:42.112 - debug: mihome-vacuum.0 (19080) no answer for miIO.info(id:2) received, giving up
                  2020-12-04 17:37:42.114 - warn: mihome-vacuum.0 (19080) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                  2020-12-04 17:37:42.310 - debug: mihome-vacuum.0 (19080) no answer for get_consumable(id:3) received, giving up
                  2020-12-04 17:37:42.512 - debug: mihome-vacuum.0 (19080) no answer for get_clean_summary(id:4) received, giving up
                  2020-12-04 17:37:42.714 - debug: mihome-vacuum.0 (19080) no answer for get_sound_volume(id:5) received, giving up
                  2020-12-04 17:37:45.064 - debug: mihome-vacuum.0 (19080) no answer for get_carpet_mode(id:6) received, giving up
                  2020-12-04 17:37:45.068 - debug: mihome-vacuum.0 (19080) no answer for get_room_mapping(id:7) received, giving up
                  • S Spampunk
                    @Thomas-Braun
                    Node.js v12.19.0
                    Hier das Log:
                    Thomas BraunT
                    Thomas BraunT
                    #1234
                    @Spampunk Bitte Text in CodeTags einbetten.
                      S
                      S
                      Spampunk
                      #1235
                      @Thomas-Braun
                      hab den Fred geändert :) Danke für den Hinweis!
                      Anmerkung:
                      der Adapter ist zwar grün, aber alle DP sind leer. Hier noch ein Log im Betrieb:
                      mihome-vacuum.0	2020-12-04 18:53:13.369	info	(20833) Connected
                      mihome-vacuum.0	2020-12-04 18:53:13.363	info	(20833) Disconnect
                      mihome-vacuum.0	2020-12-04 18:52:33.365	info	(20833) Connected
                      mihome-vacuum.0	2020-12-04 18:52:33.360	info	(20833) Disconnect
                      mihome-vacuum.0	2020-12-04 18:51:53.360	info	(20833) Connected
                      mihome-vacuum.0	2020-12-04 18:51:53.354	info	(20833) Disconnect
                      mihome-vacuum.0	2020-12-04 18:51:13.355	info	(20833) Connected
                      mihome-vacuum.0	2020-12-04 18:51:13.349	info	(20833) Disconnect
                      mihome-vacuum.0	2020-12-04 18:50:33.352	info	(20833) Connected
                      mihome-vacuum.0	2020-12-04 18:50:33.345	info	(20833) Disconnect
                      mihome-vacuum.0	2020-12-04 18:49:53.346	info	(20833) Connected
                      mihome-vacuum.0	2020-12-04 18:49:53.339	info	(20833) Disconnect
                      mihome-vacuum.0	2020-12-04 18:49:13.337	info	(20833) Connected
                      mihome-vacuum.0	2020-12-04 18:49:13.332	info	(20833) Disconnect
                      mihome-vacuum.0	2020-12-04 18:48:33.331	info	(20833) Connected
                      • S Spampunk
                        @Thomas-Braun
                        Anmerkung:
                        Thomas BraunT
                        Thomas BraunT
                        #1236
                        @Spampunk
                        sudo apt update
                        sudo apt dist-upgrade
                        sudo reboot
                        Dann:
                        iobroker update
                        iobroker upgrade
                        • S Spampunk
                          @Thomas-Braun
                          Anmerkung:
                          Thomas BraunT
                          Thomas BraunT
                          #1237
                          @Spampunk sagte in Test Adapter mihome-vacuum v2.0.x:
                          Der Sauger antwortet ja auch nicht. Hast du das Token ausgelesen und gesetzt? IP stimmt?
                          • S
                            S
                            Spampunk
                            #1238
                            Ja, das Token habe ich aus der russischen App. Ich hatte zwischenzeitlich den Sauger jedoch zurückgesetzt, fällt mir ein, da ich von Null beginnen wollte. Wird damit das Token ungültig?
                            IP passt.
                            Server & iobroker aktualisiert. Keine Veränderung.
                            • S Spampunk
                              IP passt.
                              Thomas BraunT
                              Thomas BraunT
                              #1239
                              @Spampunk
                              Ja, der Token dürfte sich dann ändern. Auch bei Änderungen beim WLAN ändert sich der schon. Mit dem Adapter kann man den auch ohne Russki-App auslesen. Jedenfalls in der Beta-Version. Ob das in deiner V 2.0.7 schon geht weiß ich gerade nicht.
                                @Spampunk
                                S
                                S
                                Spampunk
                                #1240
                                @Thomas-Braun
                                So, neuer Token, neues Glück. Die DP füllen sich fleißig, nur in der Map wird weiterhin nichts angezeigt. Der Sauger taucht weiterhin nicht im Adapter auf.
                                Log-Update:
                                mihome-vacuum.0	2020-12-04 19:20:12.512	info	(5381) create state for carpet_mode
                                mihome-vacuum.0	2020-12-04 19:20:10.084	info	(5381) set nächster Timer: Nicht verfügbar
                                mihome-vacuum.0	2020-12-04 19:20:09.758	info	(5381) New generation or new fw detected, create new states goto and zoneclean
                                mihome-vacuum.0	2020-12-04 19:20:09.674	warn	(5381) This object will not be created in future versions. Please report this to the developer.
                                mihome-vacuum.0	2020-12-04 19:20:09.672	warn	(5381) Object mihome-vacuum.0.info.water_box is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                                mihome-vacuum.0	2020-12-04 19:20:09.608	info	(5381) create states for water box filter
                                mihome-vacuum.0	2020-12-04 19:20:09.607	info	(5381) create states for water box
                                mihome-vacuum.0	2020-12-04 19:20:09.575	info	(5381) Connected
                                mihome-vacuum.0	2020-12-04 19:20:09.494	info	(5381) Disconnect
                                mihome-vacuum.0	2020-12-04 19:20:09.474	info	(5381) Cloud control disabled
                                mihome-vacuum.0	2020-12-04 19:20:09.472	info	(5381) Expert mode enabled, states created
                                mihome-vacuum.0	2020-12-04 19:20:09.361	info	(5381) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.0, js-controller: 3.1.6
                                mihome-vacuum.0	2020-12-04 19:20:08.614	warn	(5381) This object will not be created in future versions. Please report this to the developer.
                                mihome-vacuum.0	2020-12-04 19:20:08.609	warn	(5381) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                mihome-vacuum.0	2020-12-04 19:20:02.490	info	(2336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                mihome-vacuum.0	2020-12-04 19:20:02.488	info	(2336) terminating
                                mihome-vacuum.0	2020-12-04 19:20:02.486	info	(2336) Got terminate signal TERMINATE_YOURSELF
                                Das heißt, dass man dem Sauger mal lieber eine feste IP zuordnen sollte, damit der Token nicht eines Tages vom DHCP zerschossen wird?
                                • S Spampunk
                                  @Thomas-Braun
                                  Log-Update:
                                  Thomas BraunT
                                  Thomas BraunT
                                  #1241
                                  ? Du bekommst doch Daten von dem Ding.
                                  cd /opt/iobroker
                                  npm list canvas
                                  • S Spampunk
                                    @Thomas-Braun
                                    Log-Update:
                                    Thomas BraunT
                                    Thomas BraunT
                                    #1242
                                    Das hat mit dem DHCP nix zu tun. Wenn du auf dem Sauger das WLAN resettest, dann ändert sich das Token. Nicht wenn der DHCP-Server da lustige Dinge tut.
                                    • S
                                      S
                                      Spampunk
                                      #1243
                                      iobroker.inst@2.0.3 /opt/iobroker
                                      ├─┬ iobroker.iot@1.5.3
                                      │ └── canvas@2.6.1
                                      └─┬ iobroker.mihome-vacuum@2.0.7
                                        └── canvas@2.6.1  deduped
                                      timo@iota:/opt/iobroker$
                                      Ich übe fleissig :)
                                      • S Spampunk
                                        │ └── canvas@2.6.1
                                        Ich übe fleissig :)
                                        Thomas BraunT
                                        Thomas BraunT
                                        #1244
                                        @Spampunk
                                        Passt soweit. In CodeTags wäre es noch schöner. :-)
                                        Hast du in den Einstellungen des Adapters jetzt auch mal mit den Einstellungen zur Map rumgespielt? Insbesondere mit dem 'Enable map from Xiaomi'-Punkt?
                                          @Spampunk
                                          S
                                          S
                                          Spampunk
                                          #1245
                                          @Thomas-Braun
                                          Ja, das habe ich.
                                          84.0k
