  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Finnimeister
    @Thomas-Braun sagte in SyntaxError: Unexpected Tokken:
    sudo -u iobroker groups
    iobroker redis
    code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -u iobroker groups
    iobroker tty dialout audio video bluetooth redis gpio i2c
    pi@All-In-One_RasPi:/opt/iobroker $ iobroker redis
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start - starts the js-controller
    iobroker stop - stops the js-controller
    iobroker start <adapter>[.instance] - starts a specified adapter instance
    iobroker stop <adapter>.[instance] - stops a specified adapter instance
    iobroker start all - starts js-controller and all adapters
    iobroker restart - restarts the js-controller
    iobroker restart <adapter>[.instance] - restarts a specified adapter
    iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
        --wait stops the execution until the debugger is attached.
        --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
    iobroker info - shows the host info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter> - installs a specified adapter
    iobroker rebuild <adapter>|self [--install]
    iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
    iobroker del <adapter> - remove adapter from system
    iobroker del <adapter>.<instance> - remove adapter instance
    iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
    iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all - upload all adapter files to make them available for instances
    iobroker upload <adapter> - upload specified adapter files to make them available for instances
    iobroker object get <id> - get object specified by id
    iobroker object set <id> <json-value> - set object with the given id by providing a new json object
    iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
    iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id> - get state, specified by id
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instance] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path> - restore a specified backup
    iobroker validate <backup name or path> - validate a specified backup
    iobroker <command> --timeout 5000
    iobroker status [all|<adapter>.<instance>]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix - execute the installation fixer script, this updates your ioBroker installation
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status - show if compact mode is enabled in general
    iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
    iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
    iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
    iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
    iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
    iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
    iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
    iobroker version [adapter] - show version of js-controller or specified adapter
    iobroker [adapter] -v - show version of js-controller or specified adapter
    Options:
      --help     Hilfe anzeigen  [boolean]
      --version  Version anzeigen  [boolean]
    @Finnimeister
    Und nu? Lüppt das Ding?
    iobroker status
    iobroker version
    F 1 Antwort Letzte Antwort
      @Finnimeister
      iobroker status
      iobroker version
      Finnimeister
      iobroker version
      code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker status
      iobroker is not running on this host.
      No iobroker host is running.
      Objects type: file
      States  type: redis
      pi@All-In-One_RasPi:/opt/iobroker $ iobroker version
      3.1.6
      • F Finnimeister
        iobroker version
        Objects type: file
        States  type: redis
        3.1.6
        @Finnimeister
        Hast du das mal auf redis umgestellt?
        Ist das ein Multi-Host-Setup?
        • F Offline
          Finnimeister
          ich hab da nichts umgestellt.....nicht bewusst....
          hab nur das gemacht was du gesagt hast.
            @Finnimeister
            HomoranH Offline
            HomoranH Offline
            #66
            wenn das ein uraltes All-In-One Image war, ist da redis aktiviert gewesen
              Finnimeister
              #67
              @Homoran
              hab es durchlaufen lassen ,aber das sytem kan ich nicht starten...
              • F Finnimeister
                @Homoran
                HomoranH Offline
                HomoranH Offline
                #68
                @Finnimeister sagte in SyntaxError: Unexpected Tokken:
                was steht im log (/opt/iobroker/log/Datum_von_heute)
                F werner2000xW 2 Antworten Letzte Antwort
                  Finnimeister
                  #69
                  @Homoran sagte in SyntaxError: Unexpected Tokken:
                  wie muss ich das eingeben
                  • F Offline
                    Finnimeister
                    #70
                    Danke!!!Alles läuft wieder....
                      werner2000xW Offline
                      werner2000x
                      #71
                      @Homoran Ich habe auch Probleme mit dem KM200. Das steht im Log:
                      Unter "Instanzen" ist der Adapter grün. Unter "Objekte" steht "Unexpected Token"
                      "error": {},
                      "error_description": "SyntaxError: Unexpected token � in JSON at position 0 on string ��c�F�یa\u0014���\t��",
                      "valIs": "values"
                      Ich bin ratlos. Hat jemand eine Idee?
                      Raspi4 8 GB mit Aqara Zigbee USB, iob
                      Innogy Smarthome
                      Bosch Bridge 2
                      HUE Bridge
                      OpenWB Wallbox mit EVU Kit
                      Google Nest Pro Hub
                      HA auf uGreen dxp4800
