  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Finnimeister
    @Thomas-Braun sagte in SyntaxError: Unexpected Tokken:
    sudo usermod -a -G redis iobroker
    code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo usermod -a -G redis iobroker
    passiert nix
    @Finnimeister
    Starte mal durch.
    Danach sollten die Gruppen mindestens so aussehen:
    sudo -u iobroker groups
    iobroker redis
    F 1 Antwort Letzte Antwort
      @Finnimeister
      Starte mal durch.
      iobroker redis
      Finnimeister
      iobroker redis
      code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -u iobroker groups
      iobroker tty dialout audio video bluetooth redis gpio i2c
      pi@All-In-One_RasPi:/opt/iobroker $ iobroker redis
      Commands:
      iobroker setup [--objects <host>] [--states <host>] [custom]
      iobroker start - starts the js-controller
      iobroker stop - stops the js-controller
      iobroker start <adapter>[.instance] - starts a specified adapter instance
      iobroker stop <adapter>.[instance] - stops a specified adapter instance
      iobroker start all - starts js-controller and all adapters
      iobroker restart - restarts the js-controller
      iobroker restart <adapter>[.instance] - restarts a specified adapter
      iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
          --wait stops the execution until the debugger is attached.
          --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
      iobroker info - shows the host info
      iobroker logs [adapter] [--watch] [--lines=1000]
      iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
      iobroker install <adapter> - installs a specified adapter
      iobroker rebuild <adapter>|self [--install]
      iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
      iobroker del <adapter> - remove adapter from system
      iobroker del <adapter>.<instance> - remove adapter instance
      iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
      iobroker upgrade [repository url]
      iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
      iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
      iobroker upload <pathToLocalFile> <pathIniobroker>
      iobroker upload all - upload all adapter files to make them available for instances
      iobroker upload <adapter> - upload specified adapter files to make them available for instances
      iobroker object get <id> - get object specified by id
      iobroker object set <id> <json-value> - set object with the given id by providing a new json object
      iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
      iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
      iobroker object del <id|pattern> [--yes]
      iobroker object chmod <object-mode> [state-mode] <id>
      iobroker object chown <user> <group> <id>
      iobroker object list <id>
      iobroker state get <id> - get state, specified by id
      iobroker state getplain <id> [--pretty]
      iobroker state getvalue <id>
      iobroker state set <id> <value> [ack]
      iobroker state del <id>
      iobroker message <adapter>[.instance] <command> [<message>]
      iobroker list <type> [filter]
      iobroker chmod <mode> <file>
      iobroker chown <user> <group> <file>
      iobroker touch <file>
      iobroker rm <file>
      iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
      iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
      iobroker file rm <iobroker-path-to-delete>
      iobroker file sync
      iobroker user add <user> [--ingroup group] [--password pass]
      iobroker user del <user>
      iobroker user passwd <user> [--password pass]
      iobroker user enable <user>
      iobroker user disable <user>
      iobroker user get <user>
      iobroker user check <user> [--password pass]
      iobroker group add <group>
      iobroker group del <group>
      iobroker group list <group>
      iobroker group enable <group>
      iobroker group disable <group>
      iobroker group get <group>
      iobroker group adduser <group> <user>
      iobroker group deluser <group> <user>
      iobroker host this
      iobroker host <hostname>
      iobroker host set <hostname>
      iobroker host remove <hostname>
      iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
      iobroker license <license.file or license.text>
      iobroker cert create
      iobroker cert view [<certificate name>]
      iobroker clean
      iobroker backup
      iobroker restore <backup name or path> - restore a specified backup
      iobroker validate <backup name or path> - validate a specified backup
      iobroker <command> --timeout 5000
      iobroker status [all|<adapter>.<instance>]
      iobroker repo [name]
      iobroker repo add <name> <path or url>
      iobroker repo set <name>
      iobroker repo del <name>
      iobroker uuid
      iobroker unsetup
      iobroker fix - execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost <enable|disable> [--secure true|false]
      iobroker multihost browse
      iobroker multihost connect
      iobroker compact status - show if compact mode is enabled in general
      iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
      iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
      iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
      iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
      iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
      iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
      iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
      iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
      iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
      iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
      iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
      iobroker version [adapter] - show version of js-controller or specified adapter
      iobroker [adapter] -v - show version of js-controller or specified adapter
      Options:
        --help     Hilfe anzeigen  [boolean]
        --version  Version anzeigen  [boolean]
      • F Finnimeister
        iobroker redis
        Commands:
        iobroker rm <file>
        iobroker file sync
        iobroker host this
        iobroker clean
        iobroker backup
        iobroker uuid
        iobroker unsetup
        Options:
        @Finnimeister
        Und nu? Lüppt das Ding?
        iobroker status
        iobroker version
          @Finnimeister
          iobroker status
          iobroker version
          Finnimeister
          iobroker version
          code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker status
          iobroker is not running on this host.
          No iobroker host is running.
          Objects type: file
          States  type: redis
          pi@All-In-One_RasPi:/opt/iobroker $ iobroker version
          3.1.6
          • F Finnimeister
            iobroker version
            Objects type: file
            States  type: redis
            3.1.6
            @Finnimeister
            Hast du das mal auf redis umgestellt?
            Ist das ein Multi-Host-Setup?
            • F Offline
              Finnimeister
              ich hab da nichts umgestellt.....nicht bewusst....
              hab nur das gemacht was du gesagt hast.
                @Finnimeister
                HomoranH Offline
                HomoranH Offline
                #66
                wenn das ein uraltes All-In-One Image war, ist da redis aktiviert gewesen
                  Finnimeister
                  #67
                  @Homoran
                  hab es durchlaufen lassen ,aber das sytem kan ich nicht starten...
                  • F Finnimeister
                    @Homoran
                    HomoranH Offline
                    HomoranH Offline
                    #68
                    @Finnimeister sagte in SyntaxError: Unexpected Tokken:
                    was steht im log (/opt/iobroker/log/Datum_von_heute)
                    F werner2000xW 2 Antworten Letzte Antwort
                      Finnimeister
                      #69
                      @Homoran sagte in SyntaxError: Unexpected Tokken:
                      wie muss ich das eingeben
                      • F Offline
                        Finnimeister
                        #70
                        Danke!!!Alles läuft wieder....
                          werner2000xW Offline
                          werner2000x
                          #71
                          @Homoran Ich habe auch Probleme mit dem KM200. Das steht im Log:
                          Unter "Instanzen" ist der Adapter grün. Unter "Objekte" steht "Unexpected Token"
                          "error": {},
                          "error_description": "SyntaxError: Unexpected token � in JSON at position 0 on string ��c�F�یa\u0014���\t��",
                          "valIs": "values"
                          Ich bin ratlos. Hat jemand eine Idee?
                          Raspi4 8 GB mit Aqara Zigbee USB, iob
                          Innogy Smarthome
                          Bosch Bridge 2
                          HUE Bridge
                          OpenWB Wallbox mit EVU Kit
                          Google Nest Pro Hub
                          HA auf uGreen dxp4800
