  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
    @Finnimeister
    Auf mal auf redis umgestellt?
    sudo usermod -a -G redis iobroker
    Finnimeister
    @Thomas-Braun sagte in SyntaxError: Unexpected Tokken:
    code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo usermod -a -G redis iobroker
    passiert nix
    • F Finnimeister
      passiert nix
      @Finnimeister
      Starte mal durch.
      Danach sollten die Gruppen mindestens so aussehen:
      sudo -u iobroker groups
      iobroker redis
      F 1 Antwort Letzte Antwort
        @Finnimeister
        Starte mal durch.
        iobroker redis
        Finnimeister
        iobroker redis
        code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -u iobroker groups
        iobroker tty dialout audio video bluetooth redis gpio i2c
        pi@All-In-One_RasPi:/opt/iobroker $ iobroker redis
        Commands:
        iobroker setup [--objects <host>] [--states <host>] [custom]
        iobroker start - starts the js-controller
        iobroker stop - stops the js-controller
        iobroker start <adapter>[.instance] - starts a specified adapter instance
        iobroker stop <adapter>.[instance] - stops a specified adapter instance
        iobroker start all - starts js-controller and all adapters
        iobroker restart - restarts the js-controller
        iobroker restart <adapter>[.instance] - restarts a specified adapter
        iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
            --wait stops the execution until the debugger is attached.
            --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
        iobroker info - shows the host info
        iobroker logs [adapter] [--watch] [--lines=1000]
        iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
        iobroker install <adapter> - installs a specified adapter
        iobroker rebuild <adapter>|self [--install]
        iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
        iobroker del <adapter> - remove adapter from system
        iobroker del <adapter>.<instance> - remove adapter instance
        iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
        iobroker upgrade [repository url]
        iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
        iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
        iobroker upload <pathToLocalFile> <pathIniobroker>
        iobroker upload all - upload all adapter files to make them available for instances
        iobroker upload <adapter> - upload specified adapter files to make them available for instances
        iobroker object get <id> - get object specified by id
        iobroker object set <id> <json-value> - set object with the given id by providing a new json object
        iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
        iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
        iobroker object del <id|pattern> [--yes]
        iobroker object chmod <object-mode> [state-mode] <id>
        iobroker object chown <user> <group> <id>
        iobroker object list <id>
        iobroker state get <id> - get state, specified by id
        iobroker state getplain <id> [--pretty]
        iobroker state getvalue <id>
        iobroker state set <id> <value> [ack]
        iobroker state del <id>
        iobroker message <adapter>[.instance] <command> [<message>]
        iobroker list <type> [filter]
        iobroker chmod <mode> <file>
        iobroker chown <user> <group> <file>
        iobroker touch <file>
        iobroker rm <file>
        iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
        iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
        iobroker file rm <iobroker-path-to-delete>
        iobroker file sync
        iobroker user add <user> [--ingroup group] [--password pass]
        iobroker user del <user>
        iobroker user passwd <user> [--password pass]
        iobroker user enable <user>
        iobroker user disable <user>
        iobroker user get <user>
        iobroker user check <user> [--password pass]
        iobroker group add <group>
        iobroker group del <group>
        iobroker group list <group>
        iobroker group enable <group>
        iobroker group disable <group>
        iobroker group get <group>
        iobroker group adduser <group> <user>
        iobroker group deluser <group> <user>
        iobroker host this
        iobroker host <hostname>
        iobroker host set <hostname>
        iobroker host remove <hostname>
        iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
        iobroker license <license.file or license.text>
        iobroker cert create
        iobroker cert view [<certificate name>]
        iobroker clean
        iobroker backup
        iobroker restore <backup name or path> - restore a specified backup
        iobroker validate <backup name or path> - validate a specified backup
        iobroker <command> --timeout 5000
        iobroker status [all|<adapter>.<instance>]
        iobroker repo [name]
        iobroker repo add <name> <path or url>
        iobroker repo set <name>
        iobroker repo del <name>
        iobroker uuid
        iobroker unsetup
        iobroker fix - execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost <enable|disable> [--secure true|false]
        iobroker multihost browse
        iobroker multihost connect
        iobroker compact status - show if compact mode is enabled in general
        iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
        iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
        iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
        iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
        iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
        iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
        iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
        iobroker version [adapter] - show version of js-controller or specified adapter
        iobroker [adapter] -v - show version of js-controller or specified adapter
        Options:
          --help     Hilfe anzeigen  [boolean]
          --version  Version anzeigen  [boolean]
        • F Finnimeister
          iobroker redis
          Commands:
          iobroker rm <file>
          iobroker file sync
          iobroker host this
          iobroker clean
          iobroker backup
          iobroker uuid
          iobroker unsetup
          Options:
          @Finnimeister
          Und nu? Lüppt das Ding?
          iobroker status
          iobroker version
            @Finnimeister
            iobroker status
            iobroker version
            Finnimeister
            iobroker version
            code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker status
            iobroker is not running on this host.
            No iobroker host is running.
            Objects type: file
            States  type: redis
            pi@All-In-One_RasPi:/opt/iobroker $ iobroker version
            3.1.6
            • F Finnimeister
              iobroker version
              Objects type: file
              States  type: redis
              3.1.6
              @Finnimeister
              Hast du das mal auf redis umgestellt?
              Ist das ein Multi-Host-Setup?
              • F Offline
                Finnimeister
                ich hab da nichts umgestellt.....nicht bewusst....
                hab nur das gemacht was du gesagt hast.
                  @Finnimeister
                  HomoranH Offline
                  HomoranH Offline
                  #66
                  wenn das ein uraltes All-In-One Image war, ist da redis aktiviert gewesen
                    Finnimeister
                    #67
                    @Homoran
                    hab es durchlaufen lassen ,aber das sytem kan ich nicht starten...
                    • F Finnimeister
                      @Homoran
                      HomoranH Offline
                      HomoranH Offline
                      #68
                      @Finnimeister sagte in SyntaxError: Unexpected Tokken:
                      was steht im log (/opt/iobroker/log/Datum_von_heute)
                      F werner2000xW 2 Antworten Letzte Antwort
                        Finnimeister
                        #69
                        @Homoran sagte in SyntaxError: Unexpected Tokken:
                        wie muss ich das eingeben
                        • F Offline
                          Finnimeister
                          #70
                          Danke!!!Alles läuft wieder....
                            werner2000xW Offline
                            werner2000x
                            #71
                            @Homoran Ich habe auch Probleme mit dem KM200. Das steht im Log:
                            Unter "Instanzen" ist der Adapter grün. Unter "Objekte" steht "Unexpected Token"
                            "error": {},
                            "error_description": "SyntaxError: Unexpected token � in JSON at position 0 on string ��c�F�یa\u0014���\t��",
                            "valIs": "values"
                            Ich bin ratlos. Hat jemand eine Idee?
                            Raspi4 8 GB mit Aqara Zigbee USB, iob
                            Innogy Smarthome
                            Bosch Bridge 2
                            HUE Bridge
                            OpenWB Wallbox mit EVU Kit
                            Google Nest Pro Hub
                            HA auf uGreen dxp4800
