  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Finnimeister
    @Thomas-Braun
    code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker start
    * Startet so nicht !!!!
    @Finnimeister
    iobroker status
    F 1 Antwort Letzte Antwort
      @Finnimeister
      iobroker status
      Finnimeister
      @Thomas-Braun sagte in SyntaxError: Unexpected Tokken:
      iobroker status
      code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker status
      iobroker is not running on this host.
      No iobroker host is running.
      Objects type: file
      States  type: redis
      • F Finnimeister
        iobroker status
        Objects type: file
        States  type: redis
        @Finnimeister
        Auf mal auf redis umgestellt?
        sudo usermod -a -G redis iobroker
          @Finnimeister
          Finnimeister
          code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo usermod -a -G redis iobroker
          passiert nix
          • F Finnimeister
            passiert nix
            @Finnimeister
            Starte mal durch.
            Danach sollten die Gruppen mindestens so aussehen:
            sudo -u iobroker groups
            iobroker redis
              @Finnimeister
              Starte mal durch.
              iobroker redis
              Finnimeister
              iobroker redis
              code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -u iobroker groups
              iobroker tty dialout audio video bluetooth redis gpio i2c
              pi@All-In-One_RasPi:/opt/iobroker $ iobroker redis
              Commands:
              iobroker setup [--objects <host>] [--states <host>] [custom]
              iobroker start - starts the js-controller
              iobroker stop - stops the js-controller
              iobroker start <adapter>[.instance] - starts a specified adapter instance
              iobroker stop <adapter>.[instance] - stops a specified adapter instance
              iobroker start all - starts js-controller and all adapters
              iobroker restart - restarts the js-controller
              iobroker restart <adapter>[.instance] - restarts a specified adapter
              iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
                  --wait stops the execution until the debugger is attached.
                  --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
              iobroker info - shows the host info
              iobroker logs [adapter] [--watch] [--lines=1000]
              iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
              iobroker install <adapter> - installs a specified adapter
              iobroker rebuild <adapter>|self [--install]
              iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
              iobroker del <adapter> - remove adapter from system
              iobroker del <adapter>.<instance> - remove adapter instance
              iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
              iobroker upgrade [repository url]
              iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
              iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
              iobroker upload <pathToLocalFile> <pathIniobroker>
              iobroker upload all - upload all adapter files to make them available for instances
              iobroker upload <adapter> - upload specified adapter files to make them available for instances
              iobroker object get <id> - get object specified by id
              iobroker object set <id> <json-value> - set object with the given id by providing a new json object
              iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
              iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
              iobroker object del <id|pattern> [--yes]
              iobroker object chmod <object-mode> [state-mode] <id>
              iobroker object chown <user> <group> <id>
              iobroker object list <id>
              iobroker state get <id> - get state, specified by id
              iobroker state getplain <id> [--pretty]
              iobroker state getvalue <id>
              iobroker state set <id> <value> [ack]
              iobroker state del <id>
              iobroker message <adapter>[.instance] <command> [<message>]
              iobroker list <type> [filter]
              iobroker chmod <mode> <file>
              iobroker chown <user> <group> <file>
              iobroker touch <file>
              iobroker rm <file>
              iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
              iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
              iobroker file rm <iobroker-path-to-delete>
              iobroker file sync
              iobroker user add <user> [--ingroup group] [--password pass]
              iobroker user del <user>
              iobroker user passwd <user> [--password pass]
              iobroker user enable <user>
              iobroker user disable <user>
              iobroker user get <user>
              iobroker user check <user> [--password pass]
              iobroker group add <group>
              iobroker group del <group>
              iobroker group list <group>
              iobroker group enable <group>
              iobroker group disable <group>
              iobroker group get <group>
              iobroker group adduser <group> <user>
              iobroker group deluser <group> <user>
              iobroker host this
              iobroker host <hostname>
              iobroker host set <hostname>
              iobroker host remove <hostname>
              iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
              iobroker license <license.file or license.text>
              iobroker cert create
              iobroker cert view [<certificate name>]
              iobroker clean
              iobroker backup
              iobroker restore <backup name or path> - restore a specified backup
              iobroker validate <backup name or path> - validate a specified backup
              iobroker <command> --timeout 5000
              iobroker status [all|<adapter>.<instance>]
              iobroker repo [name]
              iobroker repo add <name> <path or url>
              iobroker repo set <name>
              iobroker repo del <name>
              iobroker uuid
              iobroker unsetup
              iobroker fix - execute the installation fixer script, this updates your ioBroker installation
              iobroker multihost <enable|disable> [--secure true|false]
              iobroker multihost browse
              iobroker multihost connect
              iobroker compact status - show if compact mode is enabled in general
              iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
              iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
              iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
              iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
              iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
              iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
              iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
              iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
              iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
              iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
              iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
              iobroker version [adapter] - show version of js-controller or specified adapter
              iobroker [adapter] -v - show version of js-controller or specified adapter
              Options:
                --help     Hilfe anzeigen  [boolean]
                --version  Version anzeigen  [boolean]
              • F Finnimeister
                iobroker redis
                Commands:
                iobroker rm <file>
                iobroker file sync
                iobroker host this
                iobroker clean
                iobroker backup
                iobroker uuid
                iobroker unsetup
                Options:
                @Finnimeister
                Und nu? Lüppt das Ding?
                iobroker status
                iobroker version
                  @Finnimeister
                  iobroker status
                  iobroker version
                  Finnimeister
                  iobroker version
                  Objects type: file
                  States  type: redis
                  pi@All-In-One_RasPi:/opt/iobroker $ iobroker version
                  3.1.6
                  • F Finnimeister
                    iobroker version
                    Objects type: file
                    States  type: redis
                    3.1.6
                    @Finnimeister
                    Hast du das mal auf redis umgestellt?
                    Ist das ein Multi-Host-Setup?
                    • F Offline
                      Finnimeister
                      ich hab da nichts umgestellt.....nicht bewusst....
                      hab nur das gemacht was du gesagt hast.
                        @Finnimeister
                        HomoranH Offline
                        HomoranH Offline
                        #66
                        wenn das ein uraltes All-In-One Image war, ist da redis aktiviert gewesen
                          Finnimeister
                          #67
                          @Homoran
                          hab es durchlaufen lassen ,aber das sytem kan ich nicht starten...
                          • F Finnimeister
                            @Homoran
                            HomoranH Offline
                            HomoranH Offline
                            #68
                            @Finnimeister sagte in SyntaxError: Unexpected Tokken:
                            was steht im log (/opt/iobroker/log/Datum_von_heute)
                            F werner2000xW 2 Antworten Letzte Antwort
                              Finnimeister
                              #69
                              @Homoran sagte in SyntaxError: Unexpected Tokken:
                              wie muss ich das eingeben
                              • F Offline
                                Finnimeister
                                #70
                                Danke!!!Alles läuft wieder....
                                  werner2000xW Offline
                                  werner2000x
                                  #71
                                  @Homoran Ich habe auch Probleme mit dem KM200. Das steht im Log:
                                  Unter "Instanzen" ist der Adapter grün. Unter "Objekte" steht "Unexpected Token"
                                  "error": {},
                                  "error_description": "SyntaxError: Unexpected token � in JSON at position 0 on string ��c�F�یa\u0014���\t��",
                                  "valIs": "values"
                                  Ich bin ratlos. Hat jemand eine Idee?
                                  Raspi4 8 GB mit Aqara Zigbee USB, iob
                                  Innogy Smarthome
                                  Bosch Bridge 2
                                  HUE Bridge
                                  OpenWB Wallbox mit EVU Kit
                                  Google Nest Pro Hub
                                  HA auf uGreen dxp4800
